Re: [U-Boot] [U-Boot-Users] U-boot for PPC405GP based custom Board
Hi Feng, Below is the screen dump after enabling Debug. .. =============================================================== Booting RFL GARD 8000 Controller using u-boot based bootloader ===============================================================
U-Boot 1.3.0-rc4 (Jun 24 2010 - 16:47:32)
CPU: AMCC PowerPC 405GP Rev. E at 200 MHz (PLB=100, OPB=50, EBC=50 MHz) , PCI sync clock at 50 MHz 16 kB I-Cache 8 kB D-Cache Board: RFL-GARD8000 with AMCC PPC405GP processor I2C: ready DRAM: 64 MB SDRAM test passes FLASH: FLASH ADDR: fc000000 FLASH MANUFACT: 10001
FLASH DEVICEID: 227e227e
C2: 22222222 LS: 22012201
info->flash_id: f2
Size of Flash0 at addr 0xfc000000 is 0x2000000 FLASH ADDR: 00000000 FLASH MANUFACT: 55555555 ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
Size of Flash1 at addr 0x0 is 0x0 32 MB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Error: start and/or end address not on sector boundary Error: start and/or end address not on sector boundary Error: start and/or end address not on sector boundary Hit any key to stop autoboot: 0
=> flinfo
Bank # 1: AMD S29GL256N (256 Mbit, uniform sector size) Size: 32768 KB in 256 Sectors Sector Start Addresses: FC000000 FC020000 FC040000 FC060000 FC080000 FC0A0000 FC0C0000 FC0E0000 FC100000 FC120000 FC140000 FC160000 FC180000 FC1A0000 FC1C0000 FC1E0000 FC200000 FC220000 FC240000 FC260000 FC280000 FC2A0000 FC2C0000 FC2E0000 FC300000 FC320000 FC340000 FC360000 FC380000 FC3A0000 FC3C0000 FC3E0000 FC400000 FC420000 FC440000 FC460000 FC480000 FC4A0000 FC4C0000 FC4E0000 FC500000 FC520000 FC540000 FC560000 FC580000 FC5A0000 FC5C0000 FC5E0000 FC600000 FC620000 FC640000 FC660000 FC680000 FC6A0000 FC6C0000 FC6E0000 FC700000 FC720000 FC740000 FC760000 FC780000 FC7A0000 FC7C0000 FC7E0000 FC800000 FC820000 FC840000 FC860000 FC880000 FC8A0000 FC8C0000 FC8E0000 FC900000 FC920000 FC940000 FC960000 FC980000 FC9A0000 FC9C0000 FC9E0000 FCA00000 FCA20000 FCA40000 FCA60000 FCA80000 FCAA0000 E FCAC0000 FCAE0000 E FCB00000 FCB20000 E FCB40000 FCB60000 E FCB80000 FCBA0000 E FCBC0000 FCBE0000 E FCC00000 FCC20000 E FCC40000 FCC60000 E FCC80000 FCCA0000 E FCCC0000 FCCE0000 E FCD00000 FCD20000 E FCD40000 FCD60000 E FCD80000 FCDA0000 FCDC0000 FCDE0000 E FCE00000 FCE20000 E FCE40000 FCE60000 E FCE80000 FCEA0000 E FCEC0000 FCEE0000 E FCF00000 FCF20000 E FCF40000 FCF60000 E FCF80000 FCFA0000 E FCFC0000 FCFE0000 E FD000000 FD020000 E FD040000 FD060000 FD080000 FD0A0000 E FD0C0000 FD0E0000 E FD100000 FD120000 E FD140000 FD160000 E FD180000 FD1A0000 E FD1C0000 FD1E0000 E FD200000 FD220000 E FD240000 FD260000 E FD280000 FD2A0000 E FD2C0000 FD2E0000 E FD300000 FD320000 E FD340000 FD360000 E FD380000 FD3A0000 FD3C0000 FD3E0000 E FD400000 FD420000 E FD440000 FD460000 E FD480000 FD4A0000 E FD4C0000 FD4E0000 E FD500000 FD520000 E FD540000 FD560000 E FD580000 FD5A0000 E FD5C0000 FD5E0000 E FD600000 FD620000 E FD640000 FD660000 FD680000 FD6A0000 E FD6C0000 FD6E0000 E FD700000 FD720000 E FD740000 FD760000 E FD780000 FD7A0000 E FD7C0000 FD7E0000 FD800000 FD820000 E FD840000 FD860000 E FD880000 FD8A0000 E FD8C0000 FD8E0000 E FD900000 FD920000 E FD940000 FD960000 E FD980000 FD9A0000 E FD9C0000 FD9E0000 E FDA00000 FDA20000 E FDA40000 FDA60000 E FDA80000 FDAA0000 FDAC0000 FDAE0000 E FDB00000 FDB20000 E FDB40000 FDB60000 E FDB80000 FDBA0000 E FDBC0000 FDBE0000 E FDC00000 FDC20000 E FDC40000 FDC60000 E FDC80000 FDCA0000 FDCC0000 FDCE0000 FDD00000 FDD20000 E FDD40000 FDD60000 E FDD80000 FDDA0000 E FDDC0000 FDDE0000 E FDE00000 FDE20000 E FDE40000 FDE60000 E FDE80000 FDEA0000 E FDEC0000 FDEE0000 FDF00000 FDF20000 E FDF40000 FDF60000 E FDF80000 FDFA0000 E FDFC0000 FDFE0000 E =>
Thanks, Ravishankar Govindarao RFL Electronics Inc. E-mail : Ravi.Rao@rflelect.com Voice: 973.334.3100 Ext. 233 Fax: 973.334.3863
CONFIDENTIALITY NOTE This e-mail, including any attachments, may contain confidential and/or legally privileged information. The Information is intended only for the use of the individual or entity named on this e-mail . If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or the taking of any action in reliance on the contents of this transmitted Information is strictly prohibited. Further, if you are not the intended recipient, please notify us by return e-mail and delete the Information promptly.
Feng Kan fkan@apm.com 06/24/2010 04:32 PM
To ravi.rao@rflelect.com cc
Subject Re: [U-Boot-Users] U-boot for PPC405GP based custom Board
please enable debug in the flash driver and send out that information.
Feng Kan
On Thu, Jun 24, 2010 at 12:56 PM, ravi.rao@rflelect.com wrote:
HI All, Our Custom board is based on EP405GP which is not supported in current u-boot. I have almost everything running except for the Flash interface. I am not able to Get the Flash size correct it comes back as 32MB.Also none of the Flash related operations work. One major difference I see in our design is we have 2, AMD S29GL256N spansion flashes in the same Bank. I do not see any reference board which is doing this. Number of Banks is 1 and word size is 32. Following are the definitions
#define CFG_FLASH_CHIPS_PER_BANK 2 #define CFG_FLASH_TOTAL_BANKS 1 /* also used by CFG_MAX_FLASH_BANKS below */ #define CFG_TOTAL_CONTIG_BANKS 1 #define CFG_FLASH_BUS_WIDTH 32
#define CFG_MAX_FLASH_BANKS CFG_FLASH_TOTAL_BANKS /* max flash banks for rfl boards */
#define FLASH_BASE0_PRELIM CFG_FLASH_BASE /* FLASH bank #0 */ #define FLASH_BASE1_PRELIM 0 /* FLASH bank #1 */
#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */
#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
#define CFG_FLASH_ADDR0 0x555 #define CFG_FLASH_ADDR1 0x2aa
// An important configuration when trying to bring the board up -RAVI.. #define CFG_FLASH_WORD_SIZE unsigned int //(32 bits = Bus width..)
Any pointers to resolve this is greatly apreciated. Thanks, Ravishankar Govindarao RFL Electronics Inc. E-mail : Ravi.Rao@rflelect.com Voice: 973.334.3100 Ext. 233 Fax: 973.334.3863
------------------------------------------------------------------------------ ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit. See the prize list and enter to win: http://p.sf.net/sfu/thinkgeek-promo _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
I dont know how the hardware is tied down. But at it seems to be getting bank 0 correctly. However, you second bank base address should be bank0_base + size instead of 0. You may have a hardware problem.
Feng Kan
info->flash_id: f2
=> flinfo
Thanks, Ravishankar Govindarao RFL Electronics Inc. E-mail : *Ravi.Rao@rflelect.com* Ravi.Rao@rflelect.com Voice: 973.334.3100 Ext. 233 Fax: 973.334.3863
*CONFIDENTIALITY NOTE*
*Feng Kan fkan@apm.com*
06/24/2010 04:32 PM To ravi.rao@rflelect.com cc Subject Re: [U-Boot-Users] U-boot for PPC405GP based custom Board
Feng Kan
On Thu, Jun 24, 2010 at 12:56 PM, <*ravi.rao@rflelect.com*ravi.rao@rflelect.com> wrote:
Any pointers to resolve this is greatly apreciated. Thanks, Ravishankar Govindarao RFL Electronics Inc. E-mail : *Ravi.Rao@rflelect.com* Ravi.Rao@rflelect.com Voice: 973.334.3100 Ext. 233 Fax: 973.334.3863
ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit. See the prize list and enter to win:* **http://p.sf.net/sfu/thinkgeek-promo*http://p.sf.net/sfu/thinkgeek-promo _______________________________________________ U-Boot-Users mailing list* **U-Boot-Users@lists.sourceforge.net* U-Boot-Users@lists.sourceforge.net
**https://lists.sourceforge.net/lists/listinfo/u-boot-users*https://lists.sourceforge.net/lists/listinfo/u-boot-users
-- Feng Kan CONFIDENTIALITY NOTICE: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and contains information that is confidential and proprietary to AppliedMicro Corporation or its subsidiaries. It is to be used solely for the purpose of furthering the parties' business relationship. All unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
Hi Feng, We do not have two banks. Our design has only one Bank but two chips in the single Bank. Any idea how to get this working in u-boot.. Thanks Ravishankar Govindarao RFL Electronics Inc. E-mail : Ravi.Rao@rflelect.com Voice: 973.334.3100 Ext. 233 Fax: 973.334.3863
Feng Kan fkan@apm.com 06/24/2010 05:45 PM
To ravi.rao@rflelect.com cc u-boot@lists.denx.de Subject Re: [U-Boot-Users] U-boot for PPC405GP based custom Board
Feng Kan
info->flash_id: f2
=> flinfo
Feng Kan
Feng Kan
