[U-Boot] [PATCH v2 0/8] Add mipi display support for rk3399
Changes in v2: -Add mipi driver and it's header file -Add Kconfig and Makefile additions for mipi driver. -Add necessary Grf declaration for mipi driver. -Add mipi display mode for vop. -Add compatible items for rk3399 vop. -Change the bitwidth for different display mode. -Extend frame buffer size for mipi display -Add pwm0 pinctrl init for lcd backlight. -Add dts config for mipi display. -Add defconfigs for mipi display, so that it can be enabled by default. -Fix rk_display_init() function report error(err:-19).
Eric Gao (8): rockchip: video: Add mipi dsi driver for rk3399 rockchip: video: vop: Add mipi display mode for rk3399 rockchip: video: vop: Set different bitwidth for different display mode rockchip: video: vop: Reserve enough space for mipi dispaly rockchip: board: evb_rk3399: initialize pwm0 for dispaly backlight rockchip: dts: Add mipi dsi support for rk3399 rockchip: configs: Enable mipi dsi for rk3399 rockchip: video: vop: Fix rk_display_init() return error
arch/arm/dts/rk3399-evb.dts | 84 ++++ arch/arm/dts/rk3399.dtsi | 72 ++++ arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 25 ++ arch/arm/include/asm/arch-rockchip/mipi_rk3399.h | 195 +++++++++ arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 1 + board/rockchip/evb_rk3399/evb-rk3399.c | 7 + configs/evb-rk3399_defconfig | 6 + drivers/video/rockchip/Kconfig | 11 +- drivers/video/rockchip/Makefile | 1 + drivers/video/rockchip/rk_mipi.c | 484 +++++++++++++++++++++++ drivers/video/rockchip/rk_vop.c | 30 +- 11 files changed, 908 insertions(+), 8 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/mipi_rk3399.h create mode 100644 drivers/video/rockchip/rk_mipi.c
Signed-off-by: Eric Gao eric.gao@rock-chips.com ---
arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 25 ++ arch/arm/include/asm/arch-rockchip/mipi_rk3399.h | 195 +++++++++ drivers/video/rockchip/Kconfig | 11 +- drivers/video/rockchip/Makefile | 1 + drivers/video/rockchip/rk_mipi.c | 484 +++++++++++++++++++++++ 5 files changed, 714 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/mipi_rk3399.h create mode 100644 drivers/video/rockchip/rk_mipi.c
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h index b340b05..b4ba436 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3399.h @@ -440,6 +440,31 @@ enum { GRF_UART_DBG_SEL_MASK = 3 << GRF_UART_DBG_SEL_SHIFT, GRF_UART_DBG_SEL_C = 2,
+ /* GRF_SOC_CON20 */ + GRF_DSI0_VOP_SEL_SHIFT = 0, + GRF_DSI0_VOP_SEL_MASK = 1 << GRF_DSI0_VOP_SEL_SHIFT, + GRF_DSI0_VOP_SEL_B = 0, + GRF_DSI0_VOP_SEL_L, + + /* GRF_SOC_CON22 */ + GRF_DPHY_TX0_RXMODE_SHIFT = 0, + GRF_DPHY_TX0_RXMODE_MASK = + 0xf << GRF_DPHY_TX0_RXMODE_SHIFT, + GRF_DPHY_TX0_RXMODE_EN = 0xb, + GRF_DPHY_TX0_RXMODE_DIS = 0, + + GRF_DPHY_TX0_TXSTOPMODE_SHIFT = 4, + GRF_DPHY_TX0_TXSTOPMODE_MASK = + 0xf0 << GRF_DPHY_TX0_TXSTOPMODE_SHIFT, + GRF_DPHY_TX0_TXSTOPMODE_EN = 0xc, + GRF_DPHY_TX0_TXSTOPMODE_DIS = 0, + + GRF_DPHY_TX0_TURNREQUEST_SHIFT = 12, + GRF_DPHY_TX0_TURNREQUEST_MASK = + 0xf000 << GRF_DPHY_TX0_TURNREQUEST_SHIFT, + GRF_DPHY_TX0_TURNREQUEST_EN = 0x1, + GRF_DPHY_TX0_TURNREQUEST_DIS = 0, + /* PMUGRF_GPIO0A_IOMUX */ PMUGRF_GPIO0A6_SEL_SHIFT = 12, PMUGRF_GPIO0A6_SEL_MASK = 3 << PMUGRF_GPIO0A6_SEL_SHIFT, diff --git a/arch/arm/include/asm/arch-rockchip/mipi_rk3399.h b/arch/arm/include/asm/arch-rockchip/mipi_rk3399.h new file mode 100644 index 0000000..f55ffb6 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/mipi_rk3399.h @@ -0,0 +1,195 @@ +/* + * Copyright (C) 2017-2025 Fuzhou Rockchip Electronics Co., Ltd + * author: Eric Gao eric.gao@rock-chips.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef RK33_MIPI_DSI_H +#define RK33_MIPI_DSI_H + +/* + * All these mipi controller register declaration provide reg address offset, + * bits width, bit offset for a specified register bits. With these message, we + * can set or clear every bits individually for a 32bit widthregister. We use + * DSI_HOST_BITS macro definition to combinat these message using the following + * format: val(32bit) = addr(16bit) | width(8bit) | offest(8bit) + * For example: + * #define SHUTDOWNZ DSI_HOST_BITS(0x004, 1, 0) + * means SHUTDOWNZ is a signal reg bit with bit offset qual 0,and it's reg addr + * offset is 0x004.The conbinat result = (0x004 << 16) | (1 << 8) | 0 + */ +#define ADDR_SHIFT 16 +#define BITS_SHIFT 8 +#define OFFSET_SHIFT 0 +#define DSI_HOST_BITS(addr, bits, bit_offset) \ +((addr << ADDR_SHIFT) | (bits << BITS_SHIFT) | (bit_offset << OFFSET_SHIFT)) + +/* DWC_DSI_VERSION_0x3133302A */ +#define VERSION DSI_HOST_BITS(0x000, 32, 0) +#define SHUTDOWNZ DSI_HOST_BITS(0x004, 1, 0) +#define TO_CLK_DIVISION DSI_HOST_BITS(0x008, 8, 8) +#define TX_ESC_CLK_DIVISION DSI_HOST_BITS(0x008, 8, 0) +#define DPI_VCID DSI_HOST_BITS(0x00c, 2, 0) +#define EN18_LOOSELY DSI_HOST_BITS(0x010, 1, 8) +#define DPI_COLOR_CODING DSI_HOST_BITS(0x010, 4, 0) +#define COLORM_ACTIVE_LOW DSI_HOST_BITS(0x014, 1, 4) +#define SHUTD_ACTIVE_LOW DSI_HOST_BITS(0x014, 1, 3) +#define HSYNC_ACTIVE_LOW DSI_HOST_BITS(0x014, 1, 2) +#define VSYNC_ACTIVE_LOW DSI_HOST_BITS(0x014, 1, 1) +#define DATAEN_ACTIVE_LOW DSI_HOST_BITS(0x014, 1, 0) +#define OUTVACT_LPCMD_TIME DSI_HOST_BITS(0x018, 8, 16) +#define INVACT_LPCMD_TIME DSI_HOST_BITS(0x018, 8, 0) +#define CRC_RX_EN DSI_HOST_BITS(0x02c, 1, 4) +#define ECC_RX_EN DSI_HOST_BITS(0x02c, 1, 3) +#define BTA_EN DSI_HOST_BITS(0x02c, 1, 2) +#define EOTP_RX_EN DSI_HOST_BITS(0x02c, 1, 1) +#define EOTP_TX_EN DSI_HOST_BITS(0x02c, 1, 0) +#define GEN_VID_RX DSI_HOST_BITS(0x030, 2, 0) +#define CMD_VIDEO_MODE DSI_HOST_BITS(0x034, 1, 0) +#define VPG_ORIENTATION DSI_HOST_BITS(0x038, 1, 24) +#define VPG_MODE DSI_HOST_BITS(0x038, 1, 20) +#define VPG_EN DSI_HOST_BITS(0x038, 1, 16) +#define LP_CMD_EN DSI_HOST_BITS(0x038, 1, 15) +#define FRAME_BTA_ACK_EN DSI_HOST_BITS(0x038, 1, 14) +#define LP_HFP_EN DSI_HOST_BITS(0x038, 1, 13) +#define LP_HBP_EN DSI_HOST_BITS(0x038, 1, 12) +#define LP_VACT_EN DSI_HOST_BITS(0x038, 1, 11) +#define LP_VFP_EN DSI_HOST_BITS(0x038, 1, 10) +#define LP_VBP_EN DSI_HOST_BITS(0x038, 1, 9) +#define LP_VSA_EN DSI_HOST_BITS(0x038, 1, 8) +#define VID_MODE_TYPE DSI_HOST_BITS(0x038, 2, 0) +#define VID_PKT_SIZE DSI_HOST_BITS(0x03c, 14, 0) +#define NUM_CHUNKS DSI_HOST_BITS(0x040, 13, 0) +#define NULL_PKT_SIZE DSI_HOST_BITS(0x044, 13, 0) +#define VID_HSA_TIME DSI_HOST_BITS(0x048, 12, 0) +#define VID_HBP_TIME DSI_HOST_BITS(0x04c, 12, 0) +#define VID_HLINE_TIME DSI_HOST_BITS(0x050, 15, 0) +#define VID_VSA_LINES DSI_HOST_BITS(0x054, 10, 0) +#define VID_VBP_LINES DSI_HOST_BITS(0x058, 10, 0) +#define VID_VFP_LINES DSI_HOST_BITS(0x05c, 10, 0) +#define VID_ACTIVE_LINES DSI_HOST_BITS(0x060, 14, 0) +#define EDPI_CMD_SIZE DSI_HOST_BITS(0x064, 16, 0) +#define MAX_RD_PKT_SIZE DSI_HOST_BITS(0x068, 1, 24) +#define DCS_LW_TX DSI_HOST_BITS(0x068, 1, 19) +#define DCS_SR_0P_TX DSI_HOST_BITS(0x068, 1, 18) +#define DCS_SW_1P_TX DSI_HOST_BITS(0x068, 1, 17) +#define DCS_SW_0P_TX DSI_HOST_BITS(0x068, 1, 16) +#define GEN_LW_TX DSI_HOST_BITS(0x068, 1, 14) +#define GEN_SR_2P_TX DSI_HOST_BITS(0x068, 1, 13) +#define GEN_SR_1P_TX DSI_HOST_BITS(0x068, 1, 12) +#define GEN_SR_0P_TX DSI_HOST_BITS(0x068, 1, 11) +#define GEN_SW_2P_TX DSI_HOST_BITS(0x068, 1, 10) +#define GEN_SW_1P_TX DSI_HOST_BITS(0x068, 1, 9) +#define GEN_SW_0P_TX DSI_HOST_BITS(0x068, 1, 8) +#define ACK_RQST_EN DSI_HOST_BITS(0x068, 1, 1) +#define TEAR_FX_EN DSI_HOST_BITS(0x068, 1, 0) +#define GEN_WC_MSBYTE DSI_HOST_BITS(0x06c, 14, 16) +#define GEN_WC_LSBYTE DSI_HOST_BITS(0x06c, 8, 8) +#define GEN_VC DSI_HOST_BITS(0x06c, 2, 6) +#define GEN_DT DSI_HOST_BITS(0x06c, 6, 0) +#define GEN_PLD_DATA DSI_HOST_BITS(0x070, 32, 0) +#define GEN_RD_CMD_BUSY DSI_HOST_BITS(0x074, 1, 6) +#define GEN_PLD_R_FULL DSI_HOST_BITS(0x074, 1, 5) +#define GEN_PLD_R_EMPTY DSI_HOST_BITS(0x074, 1, 4) +#define GEN_PLD_W_FULL DSI_HOST_BITS(0x074, 1, 3) +#define GEN_PLD_W_EMPTY DSI_HOST_BITS(0x074, 1, 2) +#define GEN_CMD_FULL DSI_HOST_BITS(0x074, 1, 1) +#define GEN_CMD_EMPTY DSI_HOST_BITS(0x074, 1, 0) +#define HSTX_TO_CNT DSI_HOST_BITS(0x078, 16, 16) +#define LPRX_TO_CNT DSI_HOST_BITS(0x078, 16, 0) +#define HS_RD_TO_CNT DSI_HOST_BITS(0x07c, 16, 0) +#define LP_RD_TO_CNT DSI_HOST_BITS(0x080, 16, 0) +#define PRESP_TO_MODE DSI_HOST_BITS(0x084, 1, 24) +#define HS_WR_TO_CNT DSI_HOST_BITS(0x084, 16, 0) +#define LP_WR_TO_CNT DSI_HOST_BITS(0x088, 16, 0) +#define BTA_TO_CNT DSI_HOST_BITS(0x08c, 16, 0) +#define AUTO_CLKLANE_CTRL DSI_HOST_BITS(0x094, 1, 1) +#define PHY_TXREQUESTCLKHS DSI_HOST_BITS(0x094, 1, 0) +#define PHY_HS2LP_TIME_CLK_LANE DSI_HOST_BITS(0x098, 10, 16) +#define PHY_HS2HS_TIME_CLK_LANE DSI_HOST_BITS(0x098, 10, 0) +#define PHY_HS2LP_TIME DSI_HOST_BITS(0x09c, 8, 24) +#define PHY_LP2HS_TIME DSI_HOST_BITS(0x09c, 8, 16) +#define MAX_RD_TIME DSI_HOST_BITS(0x09c, 15, 0) +#define PHY_FORCEPLL DSI_HOST_BITS(0x0a0, 1, 3) +#define PHY_ENABLECLK DSI_HOST_BITS(0x0a0, 1, 2) +#define PHY_RSTZ DSI_HOST_BITS(0x0a0, 1, 1) +#define PHY_SHUTDOWNZ DSI_HOST_BITS(0x0a0, 1, 0) +#define PHY_STOP_WAIT_TIME DSI_HOST_BITS(0x0a4, 8, 8) +#define N_LANES DSI_HOST_BITS(0x0a4, 2, 0) +#define PHY_TXEXITULPSLAN DSI_HOST_BITS(0x0a8, 1, 3) +#define PHY_TXREQULPSLAN DSI_HOST_BITS(0x0a8, 1, 2) +#define PHY_TXEXITULPSCLK DSI_HOST_BITS(0x0a8, 1, 1) +#define PHY_TXREQULPSCLK DSI_HOST_BITS(0x0a8, 1, 0) +#define PHY_TX_TRIGGERS DSI_HOST_BITS(0x0ac, 4, 0) +#define PHYSTOPSTATECLKLANE DSI_HOST_BITS(0x0b0, 1, 2) +#define PHYLOCK DSI_HOST_BITS(0x0b0, 1, 0) +#define PHY_TESTCLK DSI_HOST_BITS(0x0b4, 1, 1) +#define PHY_TESTCLR DSI_HOST_BITS(0x0b4, 1, 0) +#define PHY_TESTEN DSI_HOST_BITS(0x0b8, 1, 16) +#define PHY_TESTDOUT DSI_HOST_BITS(0x0b8, 8, 8) +#define PHY_TESTDIN DSI_HOST_BITS(0x0b8, 8, 0) +#define PHY_TEST_CTRL1 DSI_HOST_BITS(0x0b8, 17, 0) +#define PHY_TEST_CTRL0 DSI_HOST_BITS(0x0b4, 2, 0) +#define INT_ST0 DSI_HOST_BITS(0x0bc, 21, 0) +#define INT_ST1 DSI_HOST_BITS(0x0c0, 18, 0) +#define INT_MKS0 DSI_HOST_BITS(0x0c4, 21, 0) +#define INT_MKS1 DSI_HOST_BITS(0x0c8, 18, 0) +#define INT_FORCE0 DSI_HOST_BITS(0x0d8, 21, 0) +#define INT_FORCE1 DSI_HOST_BITS(0x0dc, 18, 0) + +#define CODE_HS_RX_CLOCK 0x34 +#define CODE_HS_RX_LANE0 0x44 +#define CODE_HS_RX_LANE1 0x54 +#define CODE_HS_RX_LANE2 0x84 +#define CODE_HS_RX_LANE3 0x94 + +#define CODE_PLL_VCORANGE_VCOCAP 0x10 +#define CODE_PLL_CPCTRL 0x11 +#define CODE_PLL_LPF_CP 0x12 +#define CODE_PLL_INPUT_DIV_RAT 0x17 +#define CODE_PLL_LOOP_DIV_RAT 0x18 +#define CODE_PLL_INPUT_LOOP_DIV_RAT 0x19 +#define CODE_BANDGAP_BIAS_CTRL 0x20 +#define CODE_TERMINATION_CTRL 0x21 +#define CODE_AFE_BIAS_BANDGAP_ANOLOG 0x22 + +#define CODE_HSTXDATALANEREQUSETSTATETIME 0x70 +#define CODE_HSTXDATALANEPREPARESTATETIME 0x71 +#define CODE_HSTXDATALANEHSZEROSTATETIME 0x72 + +/* Transmission mode between vop and MIPI controller */ +enum vid_mode_type_t { + NON_BURST_SYNC_PLUSE = 0, + NON_BURST_SYNC_EVENT, + BURST_MODE, +}; + +enum cmd_video_mode { + VIDEO_MODE = 0, + CMD_MODE, +}; + +/* Indicate MIPI DSI color mode */ +enum dpi_color_coding { + DPI_16BIT_CFG_1 = 0, + DPI_16BIT_CFG_2, + DPI_16BIT_CFG_3, + DPI_18BIT_CFG_1, + DPI_18BIT_CFG_2, + DPI_24BIT, + DPI_20BIT_YCBCR_422_LP, + DPI_24BIT_YCBCR_422, + DPI_16BIT_YCBCR_422, + DPI_30BIT, + DPI_36BIT, + DPI_12BIT_YCBCR_420, +}; + +/* Indicate which VOP the MIPI DSI use, bit or little one */ +enum vop_id { + VOP_B = 0, + VOP_L, +}; + +#endif /* end of RK33_MIPI_DSI_H */ diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/Kconfig index 09c4ea2..3f57d5c 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -37,7 +37,14 @@ if VIDEO_ROCKCHIP bool "HDMI port" depends on VIDEO_ROCKCHIP help - This enable High-Definition Multimedia Interface display support. + This enable High-Definition Multimedia Interface(HDMI) display + support.
+ config DISPLAY_MIPI + bool "MIPI Port" + depends on VIDEO_ROCKCHIP + help + This enables Mobile Industry Processor Interface(MIPI) display + support. The mipi controller and dphy on rk3288& rk3399 support + 16,18, 24 bits per pixel with upto 2k resolution ratio. endif - diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index 3bb0519..f9d1abf 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -10,4 +10,5 @@ obj-y += rk_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o ../dw_hdmi.o +obj-$(CONFIG_DISPLAY_MIPI) += rk_mipi.o endif diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c new file mode 100644 index 0000000..de59f65 --- /dev/null +++ b/drivers/video/rockchip/rk_mipi.c @@ -0,0 +1,484 @@ +/* + * Copyright (c) 2016, Fuzhou Rockchip Electronics Co., Ltd + * Author: Eric Gao eric.gao@rock-chips.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <display.h> +#include <dm.h> +#include <fdtdec.h> +#include <panel.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/gpio.h> +#include <asm/hardware.h> +#include <asm/io.h> +#include <dm/uclass-internal.h> +#include <linux/kernel.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3399.h> +#include <asm/arch/grf_rk3399.h> +#include <asm/arch/mipi_rk3399.h> +#include <dt-bindings/clock/rk3288-cru.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Private information for rk mipi + * + * @regs: mipi controller address + * @grf: GRF register + * @panel: panel assined by device tree + * @ref_clk: reference clock for mipi dsi pll + * @sysclk: config clock for mipi dsi register + * @pix_clk: pixel clock for vop->dsi data transmission + * @phy_clk: mipi dphy output clock + * @txbyte_clk: clock for dsi->dphy high speed data transmission + * @txesc_clk: clock for tx esc mode + */ +struct rk_mipi_priv { + void __iomem *regs; + struct rk3399_grf_regs *grf; + struct udevice *panel; + struct mipi_dsi *dsi; + u32 ref_clk; + u32 sys_clk; + u32 pix_clk; + u32 phy_clk; + u32 txbyte_clk; + u32 txesc_clk; +}; + +static int rk_mipi_read_timing(struct udevice *dev, + struct display_timing *timing) +{ + if (fdtdec_decode_display_timing(gd->fdt_blob, dev_of_offset(dev), + 0, timing)) { + debug("%s: Failed to decode display timing\n", __func__); + return -EINVAL; + } + + return 0; +} + +/* + * Register write function used only for mipi dsi controller. + * Parameter: + * reg: combination of regaddr(16bit)|bitswidth(8bit)|offset(8bit) you can use + * define in rk_mipi.h directly for this parameter + * val: value that will be write to specified bits of register + */ +static void rk_mipi_dsi_write(u32 regs, u32 reg, u32 val) +{ + u32 dat; + u32 mask; + u32 offset = (reg >> OFFSET_SHIFT) & 0xff; + u32 bits = (reg >> BITS_SHIFT) & 0xff; + u64 addr = (reg >> ADDR_SHIFT) + regs; + + /* Mask for specifiled bits,the corresponding bits will be clear */ + mask = ~((0xffffffff << offset) & (0xffffffff >> (32 - offset - bits))); + + /* Make sure val in the available range */ + val &= ~(0xffffffff << bits); + + /* Get register's original val */ + dat = readl(addr); + + /* Clear specified bits */ + dat &= mask; + + /* Fill specified bits */ + dat |= val << offset; + + writel(dat, addr); +} + +static int rk_mipi_dsi_enable(struct udevice *dev, + const struct display_timing *timing) +{ + int node, timing_node; + int val; + struct rk_mipi_priv *priv = dev_get_priv(dev); + u64 regs = (u64)priv->regs; + struct display_plat *disp_uc_plat = dev_get_uclass_platdata(dev); + u32 txbyte_clk = priv->txbyte_clk; + u32 txesc_clk = priv->txesc_clk; + + txesc_clk = txbyte_clk/(txbyte_clk/txesc_clk + 1); + + /* Select the video source */ + switch (disp_uc_plat->source_id) { + case VOP_B: + rk_clrsetreg(&priv->grf->soc_con20, GRF_DSI0_VOP_SEL_MASK, + GRF_DSI0_VOP_SEL_B << GRF_DSI0_VOP_SEL_SHIFT); + break; + case VOP_L: + rk_clrsetreg(&priv->grf->soc_con20, GRF_DSI0_VOP_SEL_MASK, + GRF_DSI0_VOP_SEL_L << GRF_DSI0_VOP_SEL_SHIFT); + break; + default: + debug("%s: Invalid VOP id\n", __func__); + return -EINVAL; + } + + /* Set Controller as TX mode */ + val = GRF_DPHY_TX0_RXMODE_DIS << GRF_DPHY_TX0_RXMODE_SHIFT; + rk_clrsetreg(&priv->grf->soc_con22, GRF_DPHY_TX0_RXMODE_MASK, val); + + /* Exit tx stop mode */ + val |= GRF_DPHY_TX0_TXSTOPMODE_DIS << GRF_DPHY_TX0_TXSTOPMODE_SHIFT; + rk_clrsetreg(&priv->grf->soc_con22, GRF_DPHY_TX0_TXSTOPMODE_MASK, val); + + /* Disable turnequest */ + val |= GRF_DPHY_TX0_TURNREQUEST_DIS << GRF_DPHY_TX0_TURNREQUEST_SHIFT; + rk_clrsetreg(&priv->grf->soc_con22, GRF_DPHY_TX0_TURNREQUEST_MASK, val); + + /* Set Display timing parameter */ + rk_mipi_dsi_write(regs, VID_HSA_TIME, timing->hsync_len.typ); + rk_mipi_dsi_write(regs, VID_HBP_TIME, timing->hback_porch.typ); + rk_mipi_dsi_write(regs, VID_HLINE_TIME, (timing->hsync_len.typ + + timing->hback_porch.typ + timing->hactive.typ + + timing->hfront_porch.typ)); + rk_mipi_dsi_write(regs, VID_VSA_LINES, timing->vsync_len.typ); + rk_mipi_dsi_write(regs, VID_VBP_LINES, timing->vback_porch.typ); + rk_mipi_dsi_write(regs, VID_VFP_LINES, timing->vfront_porch.typ); + rk_mipi_dsi_write(regs, VID_ACTIVE_LINES, timing->vactive.typ); + + /* Set Signal Polarity */ + val = (timing->flags & DISPLAY_FLAGS_HSYNC_LOW) ? 1 : 0; + rk_mipi_dsi_write(regs, HSYNC_ACTIVE_LOW, val); + + val = (timing->flags & DISPLAY_FLAGS_VSYNC_LOW) ? 1 : 0; + rk_mipi_dsi_write(regs, VSYNC_ACTIVE_LOW, val); + + val = (timing->flags & DISPLAY_FLAGS_DE_LOW) ? 1 : 0; + rk_mipi_dsi_write(regs, DISPLAY_FLAGS_DE_LOW, val); + + val = (timing->flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) ? 1 : 0; + rk_mipi_dsi_write(regs, COLORM_ACTIVE_LOW, val); + + /* Set video mode */ + rk_mipi_dsi_write(regs, CMD_VIDEO_MODE, VIDEO_MODE); + + /* Set video mode transmission type as burst mode */ + rk_mipi_dsi_write(regs, VID_MODE_TYPE, BURST_MODE); + + /* Set pix num in a video package */ + rk_mipi_dsi_write(regs, VID_PKT_SIZE, 0x4b0); + + /* Set dpi color coding depth 24 bit */ + timing_node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(dev), + "display-timings"); + node = fdt_first_subnode(gd->fdt_blob, timing_node); + val = fdtdec_get_int(gd->fdt_blob, node, "bits-per-pixel", -1); + switch (val) { + case 16: + rk_mipi_dsi_write(regs, DPI_COLOR_CODING, DPI_16BIT_CFG_1); + break; + case 24: + rk_mipi_dsi_write(regs, DPI_COLOR_CODING, DPI_24BIT); + break; + case 30: + rk_mipi_dsi_write(regs, DPI_COLOR_CODING, DPI_30BIT); + break; + default: + rk_mipi_dsi_write(regs, DPI_COLOR_CODING, DPI_24BIT); + } + /* Enable low power mode */ + rk_mipi_dsi_write(regs, LP_CMD_EN, 1); + rk_mipi_dsi_write(regs, LP_HFP_EN, 1); + rk_mipi_dsi_write(regs, LP_VACT_EN, 1); + rk_mipi_dsi_write(regs, LP_VFP_EN, 1); + rk_mipi_dsi_write(regs, LP_VBP_EN, 1); + rk_mipi_dsi_write(regs, LP_VSA_EN, 1); + + /* Division for timeout counter clk */ + rk_mipi_dsi_write(regs, TO_CLK_DIVISION, 0x0a); + + /* Tx esc clk division from txbyte clk */ + rk_mipi_dsi_write(regs, TX_ESC_CLK_DIVISION, txbyte_clk/txesc_clk); + + /* Timeout count for hs<->lp transation between Line period */ + rk_mipi_dsi_write(regs, HSTX_TO_CNT, 0x3e8); + + /* Phy State transfer timing */ + rk_mipi_dsi_write(regs, PHY_STOP_WAIT_TIME, 32); + rk_mipi_dsi_write(regs, PHY_TXREQUESTCLKHS, 1); + rk_mipi_dsi_write(regs, PHY_HS2LP_TIME, 0x14); + rk_mipi_dsi_write(regs, PHY_LP2HS_TIME, 0x10); + rk_mipi_dsi_write(regs, MAX_RD_TIME, 0x2710); + + /* Power on */ + rk_mipi_dsi_write(regs, SHUTDOWNZ, 1); + + return 0; +} + +/* rk mipi dphy write function. It is used to write test data to dphy */ +static void rk_mipi_phy_write(u32 regs, unsigned char test_code, + unsigned char *test_data, unsigned char size) +{ + int i = 0; + + /* Write Test code */ + rk_mipi_dsi_write(regs, PHY_TESTCLK, 1); + rk_mipi_dsi_write(regs, PHY_TESTDIN, test_code); + rk_mipi_dsi_write(regs, PHY_TESTEN, 1); + rk_mipi_dsi_write(regs, PHY_TESTCLK, 0); + rk_mipi_dsi_write(regs, PHY_TESTEN, 0); + + /* Write Test data */ + for (i = 0; i < size; i++) { + rk_mipi_dsi_write(regs, PHY_TESTCLK, 0); + rk_mipi_dsi_write(regs, PHY_TESTDIN, test_data[i]); + rk_mipi_dsi_write(regs, PHY_TESTCLK, 1); + } +} + +/* + * Mipi dphy config function. Calculate the suitable prediv, feedback div, + * fsfreqrang value ,cap ,lpf and so on according to the given pix clk rate, + * and then enable phy. + */ +static int rk_mipi_phy_enable(struct udevice *dev) +{ + int i; + struct rk_mipi_priv *priv = dev_get_priv(dev); + u64 regs = (u64)priv->regs; + u64 fbdiv; + u64 prediv = 1; + u32 max_fbdiv = 512; + u32 max_prediv, min_prediv; + u64 ddr_clk = priv->phy_clk; + u32 refclk = priv->ref_clk; + u32 remain = refclk; + unsigned char test_data[2] = {0}; + + int freq_rang[][2] = { + {90, 0x01}, {100, 0x10}, {110, 0x20}, {130, 0x01}, + {140, 0x11}, {150, 0x21}, {170, 0x02}, {180, 0x12}, + {200, 0x22}, {220, 0x03}, {240, 0x13}, {250, 0x23}, + {270, 0x04}, {300, 0x14}, {330, 0x05}, {360, 0x15}, + {400, 0x25}, {450, 0x06}, {500, 0x16}, {550, 0x07}, + {600, 0x17}, {650, 0x08}, {700, 0x18}, {750, 0x09}, + {800, 0x19}, {850, 0x29}, {900, 0x39}, {950, 0x0a}, + {1000, 0x1a}, {1050, 0x2a}, {1100, 0x3a}, {1150, 0x0b}, + {1200, 0x1b}, {1250, 0x2b}, {1300, 0x3b}, {1350, 0x0c}, + {1400, 0x1c}, {1450, 0x2c}, {1500, 0x3c} + }; + + /* Shutdown mode */ + rk_mipi_dsi_write(regs, PHY_SHUTDOWNZ, 0); + rk_mipi_dsi_write(regs, PHY_RSTZ, 0); + rk_mipi_dsi_write(regs, PHY_TESTCLR, 1); + + /* Pll locking */ + rk_mipi_dsi_write(regs, PHY_TESTCLR, 0); + + /* config cp and lfp */ + test_data[0] = 0x80 | (ddr_clk / (200 * MHz)) << 3 | 0x3; + rk_mipi_phy_write(regs, CODE_PLL_VCORANGE_VCOCAP, test_data, 1); + + test_data[0] = 0x8; + rk_mipi_phy_write(regs, CODE_PLL_CPCTRL, test_data, 1); + + test_data[0] = 0x80 | 0x40; + rk_mipi_phy_write(regs, CODE_PLL_LPF_CP, test_data, 1); + + /* select the suitable value for fsfreqrang reg */ + for (i = 0; i < ARRAY_SIZE(freq_rang); i++) { + if (ddr_clk / (MHz) >= freq_rang[i][0]) + break; + } + if (i == ARRAY_SIZE(freq_rang)) { + debug("%s: Dphy freq out of range!\n", __func__); + return -EINVAL; + } + test_data[0] = freq_rang[i][1] << 1; + rk_mipi_phy_write(regs, CODE_HS_RX_LANE0, test_data, 1); + + /* + * Calculate the best ddrclk and it's corresponding div value. If the + * given pixelclock is great than 250M, ddrclk will be fix 1500M. + * Otherwise, + * it's equal to ddr_clk= pixclk * 6. 40MHz >= refclk / prediv >= 5MHz + * according to spec. + */ + max_prediv = (refclk / (5 * MHz)); + min_prediv = ((refclk / (40 * MHz)) ? (refclk / (40 * MHz) + 1) : 1); + + debug("%s: DEBUG: max_prediv=%u, min_prediv=%u\n", __func__, max_prediv, + min_prediv); + + if (max_prediv < min_prediv) { + debug("%s: Invalid refclk value\n", __func__); + return -EINVAL; + } + + /* Calculate the best refclk and feedback division value for dphy pll */ + for (i = min_prediv; i < max_prediv; i++) { + if ((ddr_clk * i % refclk < remain) && + (ddr_clk * i / refclk) < max_fbdiv) { + prediv = i; + remain = ddr_clk * i % refclk; + } + } + fbdiv = ddr_clk * prediv / refclk; + ddr_clk = refclk * fbdiv / prediv; + priv->phy_clk = ddr_clk; + + debug("%s: DEBUG: refclk=%u, refclk=%llu, fbdiv=%llu, phyclk=%llu\n", + __func__, refclk, prediv, fbdiv, ddr_clk); + + /* config prediv and feedback reg */ + test_data[0] = prediv - 1; + rk_mipi_phy_write(regs, CODE_PLL_INPUT_DIV_RAT, test_data, 1); + test_data[0] = (fbdiv - 1) & 0x1f; + rk_mipi_phy_write(regs, CODE_PLL_LOOP_DIV_RAT, test_data, 1); + test_data[0] = (fbdiv - 1) >> 5 | 0x80; + rk_mipi_phy_write(regs, CODE_PLL_LOOP_DIV_RAT, test_data, 1); + test_data[0] = 0x30; + rk_mipi_phy_write(regs, CODE_PLL_INPUT_LOOP_DIV_RAT, test_data, 1); + + /* rest config */ + test_data[0] = 0x4d; + rk_mipi_phy_write(regs, CODE_BANDGAP_BIAS_CTRL, test_data, 1); + + test_data[0] = 0x3d; + rk_mipi_phy_write(regs, CODE_TERMINATION_CTRL, test_data, 1); + + test_data[0] = 0xdf; + rk_mipi_phy_write(regs, CODE_TERMINATION_CTRL, test_data, 1); + + test_data[0] = 0x7; + rk_mipi_phy_write(regs, CODE_AFE_BIAS_BANDGAP_ANOLOG, test_data, 1); + + test_data[0] = 0x80 | 0x7; + rk_mipi_phy_write(regs, CODE_AFE_BIAS_BANDGAP_ANOLOG, test_data, 1); + + test_data[0] = 0x80 | 15; + rk_mipi_phy_write(regs, CODE_HSTXDATALANEREQUSETSTATETIME, + test_data, 1); + test_data[0] = 0x80 | 85; + rk_mipi_phy_write(regs, CODE_HSTXDATALANEPREPARESTATETIME, + test_data, 1); + test_data[0] = 0x40 | 10; + rk_mipi_phy_write(regs, CODE_HSTXDATALANEHSZEROSTATETIME, + test_data, 1); + + /* enter into stop mode */ + rk_mipi_dsi_write(regs, N_LANES, 0x03); + rk_mipi_dsi_write(regs, PHY_ENABLECLK, 1); + rk_mipi_dsi_write(regs, PHY_FORCEPLL, 1); + rk_mipi_dsi_write(regs, PHY_SHUTDOWNZ, 1); + rk_mipi_dsi_write(regs, PHY_RSTZ, 1); + + return 0; +} + +/* + * This function is called by rk_display_init() using rk_mipi_dsi_enable() and + * rk_mipi_phy_enable() to initialize mipi controller and dphy. If success, + * enable backlight. + */ +static int rk_display_enable(struct udevice *dev, int panel_bpp, + const struct display_timing *timing) +{ + int ret; + struct rk_mipi_priv *priv = dev_get_priv(dev); + + /* Fill the mipi controller parameter */ + priv->ref_clk = 24 * MHz; + priv->sys_clk = priv->ref_clk; + priv->pix_clk = timing->pixelclock.typ; + priv->phy_clk = priv->pix_clk * 6; + priv->txbyte_clk = priv->phy_clk / 8; + priv->txesc_clk = 20 * MHz; + + /* Config and enable mipi dsi according to timing */ + ret = rk_mipi_dsi_enable(dev, timing); + if (ret) { + debug("%s: rk_mipi_dsi_enable() failed (err=%d)\n", + __func__, ret); + return ret; + } + + /* Config and enable mipi phy */ + ret = rk_mipi_phy_enable(dev); + if (ret) { + debug("%s: rk_mipi_phy_enable() failed (err=%d)\n", + __func__, ret); + return ret; + } + + /* Enable backlight */ + ret = panel_enable_backlight(priv->panel); + if (ret) { + debug("%s: panel_enable_backlight() failed (err=%d)\n", + __func__, ret); + return ret; + } + + return 0; +} + +static int rk_mipi_ofdata_to_platdata(struct udevice *dev) +{ + struct rk_mipi_priv *priv = dev_get_priv(dev); + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (!priv->grf) { + debug("%s: Get syscon grf failed\n", __func__); + return -ENXIO; + } + priv->regs = (void *)dev_get_addr(dev); + if (!priv->regs) { + debug("%s: Get MIPI dsi address failed\n", __func__); + return -ENXIO; + } + + return 0; +} + +/* + * Probe function: check panel existence and readingit's timing. Then config + * mipi dsi controller and enable it according to the timing parameter. + */ +static int rk_mipi_probe(struct udevice *dev) +{ + int ret; + struct rk_mipi_priv *priv = dev_get_priv(dev); + + ret = uclass_get_device_by_phandle(UCLASS_PANEL, dev, "rockchip,panel", + &priv->panel); + if (ret) { + debug("%s: Can not find panel (err=%d)\n", __func__, ret); + return ret; + } + + return 0; +} + +static const struct dm_display_ops rk_mipi_dsi_ops = { + .read_timing = rk_mipi_read_timing, + .enable = rk_display_enable, +}; + +static const struct udevice_id rk_mipi_dsi_ids[] = { + { .compatible = "rockchip,rk3399_mipi_dsi" }, + { } +}; + +U_BOOT_DRIVER(rk_mipi_dsi) = { + .name = "rk_mipi_dsi", + .id = UCLASS_DISPLAY, + .of_match = rk_mipi_dsi_ids, + .ofdata_to_platdata = rk_mipi_ofdata_to_platdata, + .probe = rk_mipi_probe, + .ops = &rk_mipi_dsi_ops, + .priv_auto_alloc_size = sizeof(struct rk_mipi_priv), +};
Hi Eric
2017-04-18 15:09 GMT+08:00 Eric Gao eric.gao@rock-chips.com:
Can you split this patch into 4 patches. other comment as below.
1. grf changes 2. mipi driver 3. makefile change 4. kconfig
/* GRF_SOC_CON20 */
GRF_DSI0_VOP_SEL_L,
/* GRF_SOC_CON22 */
alphabetical order please
- Copyright (C) 2017-2025 Fuzhou Rockchip Electronics Co., Ltd
this year is 2017. so should be "Copyright (C) 2017 Fuzhou Rockchip Electronics Co., Ltd"
- author: Eric Gao eric.gao@rock-chips.com
this driver is not only for rk33. we may use it on rk32 or other chips. So please use ROCKCHIP_MIPI_DSI_H
- All these mipi controller register declaration provide reg address
offset,
- bits width, bit offset for a specified register bits. With these
message, we
- can set or clear every bits individually for a 32bit widthregister. We
use
- DSI_HOST_BITS macro definition to combinat these message using the
following
- format: val(32bit) = addr(16bit) | width(8bit) | offest(8bit)
- For example:
- #define SHUTDOWNZ DSI_HOST_BITS(0x004, 1, 0)
- means SHUTDOWNZ is a signal reg bit with bit offset qual 0,and it's
reg addr
- offset is 0x004.The conbinat result = (0x004 << 16) | (1 << 8) | 0
BURST_MODE,
VIDEO_MODE = 0,
CMD_MODE,
DPI_16BIT_CFG_2,
DPI_16BIT_CFG_3,
DPI_18BIT_CFG_1,
DPI_18BIT_CFG_2,
DPI_24BIT,
DPI_30BIT,
DPI_36BIT,
VOP_B = 0,
VOP_L,
+#endif /* end of RK33_MIPI_DSI_H */ diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/ Kconfig index 09c4ea2..3f57d5c 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -37,7 +37,14 @@ if VIDEO_ROCKCHIP bool "HDMI port" depends on VIDEO_ROCKCHIP help
display support.
support.
config DISPLAY_MIPI
bool "MIPI Port"
help
rk3399 support
ratio. endif
diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/ Makefile index 3bb0519..f9d1abf 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -10,4 +10,5 @@ obj-y += rk_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o ../dw_hdmi.o +obj-$(CONFIG_DISPLAY_MIPI) += rk_mipi.o
to follow the naming rule of other rockchip display driver. it should be CONFIG_DISPLAY_ROCKCHIP_MIPI
endif diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_ mipi.c new file mode 100644 index 0000000..de59f65 --- /dev/null +++ b/drivers/video/rockchip/rk_mipi.c @@ -0,0 +1,484 @@ +/*
- Copyright (c) 2016, Fuzhou Rockchip Electronics Co., Ltd
2017 please
- Author: Eric Gao eric.gao@rock-chips.com
- Private information for rk mipi
- @regs: mipi controller address
- @grf: GRF register
- @panel: panel assined by device tree
- @ref_clk: reference clock for mipi dsi pll
- @sysclk: config clock for mipi dsi register
- @pix_clk: pixel clock for vop->dsi data transmission
- @phy_clk: mipi dphy output clock
- @txbyte_clk: clock for dsi->dphy high speed data transmission
- @txesc_clk: clock for tx esc mode
void __iomem *regs;
u32 ref_clk;
u32 sys_clk;
u32 pix_clk;
u32 phy_clk;
u32 txbyte_clk;
u32 txesc_clk;
0, timing)) {
can you print the return value here if fdtdec_decode_display_timing failed?
return -EINVAL;
- Register write function used only for mipi dsi controller.
- Parameter:
- reg: combination of regaddr(16bit)|bitswidth(8bit)|offset(8bit) you
can use
- val: value that will be write to specified bits of register
lost the meaning of val
u32 dat;
u32 mask;
bits)));
dat = readl(addr);
dat &= mask;
writel(dat, addr);
int val;
case VOP_B:
break;
case VOP_L:
break;
default:
return -EINVAL;
val);
val);
SHIFT;
"display-timings");
switch (val) {
case 16:
break;
case 24:
break;
case 30:
break;
default:
/* Power on */
int i = 0;
- Mipi dphy config function. Calculate the suitable prediv, feedback div,
- fsfreqrang value ,cap ,lpf and so on according to the given pix clk
rate,
- and then enable phy.
int i;
u64 fbdiv;
u64 prediv = 1;
/* Shutdown mode */
/* Pll locking */
test_data[0] = 0x8;
break;
return -EINVAL;
the
* Otherwise,
5MHz
1);
max_prediv,
min_prediv);
return -EINVAL;
pll */
prediv = i;
phyclk=%llu\n",
/* rest config */
test_data[0] = 0x7;
1);
1);
test_data, 1);
test_data, 1);
test_data, 1);
- This function is called by rk_display_init() using
- rk_mipi_phy_enable() to initialize mipi controller and dphy. If
success,
- enable backlight.
int ret;
if (ret) {
__func__, ret);
return ret;
if (ret) {
__func__, ret);
return ret;
if (ret) {
__func__, ret);
return ret;
if (!priv->grf) {
can you print the return value from syscon_get_first_range?
return -ENXIO;
if (!priv->regs) {
can you print the return value from dev_get_addr?
return -ENXIO;
- Probe function: check panel existence and readingit's timing. Then
config
- mipi dsi controller and enable it according to the timing parameter.
int ret;
"rockchip,panel",
&priv->panel);
if (ret) {
return ret;
1.9.1
Add mipi display mode for rk3399 vop, so that we can use mipi panel for display.
Changes in v2: -Add mipi display mode for vop. -Add compatible items for rk3399 vop.
arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 1 + drivers/video/rockchip/rk_vop.c | 6 ++++++ 2 files changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h index 0ce3d67..d5599ec 100644 --- a/arch/arm/include/asm/arch-rockchip/vop_rk3288.h +++ b/arch/arm/include/asm/arch-rockchip/vop_rk3288.h @@ -90,6 +90,7 @@ enum vop_modes { VOP_MODE_EDP = 0, VOP_MODE_HDMI, VOP_MODE_LVDS, + VOP_MODE_MIPI, VOP_MODE_NONE, VOP_MODE_AUTO_DETECT, VOP_MODE_UNKNOWN, diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index bc02f80..84d6627 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -117,6 +117,10 @@ void rkvop_mode_set(struct rk3288_vop *regs, clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_RGB_OUT_EN(1)); break; + case VOP_MODE_MIPI: + clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, + V_MIPI_OUT_EN(1)); + break; }
if (mode == VOP_MODE_HDMI || mode == VOP_MODE_EDP) @@ -350,6 +354,8 @@ static const struct video_ops rk_vop_ops = { };
static const struct udevice_id rk_vop_ids[] = { + { .compatible = "rockchip,rk3399-vop-big" }, + { .compatible = "rockchip,rk3399-vop-lit" }, { .compatible = "rockchip,rk3288-vop" }, { } };
Reviewed-by: Eddie Cai eddie.cai.linux@gmail.com
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_ vop.c index bc02f80..84d6627 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -117,6 +117,10 @@ void rkvop_mode_set(struct rk3288_vop *regs, clrsetbits_le32(®s->sys_ctrl, M_ALL_OUT_EN, V_RGB_OUT_EN(1)); break;
case VOP_MODE_MIPI:
V_MIPI_OUT_EN(1));
break; } if (mode == VOP_MODE_HDMI || mode == VOP_MODE_EDP)
1.9.1
Because the bitwidth is different for different display mode, so we need to set them according to demand.
Changes in v2: -Change the bitwidth for different display mode.
drivers/video/rockchip/rk_vop.c | 20 ++++++++++++++++---- 1 file changed, 16 insertions(+), 4 deletions(-)
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index 84d6627..a637f7d 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -181,13 +181,11 @@ void rkvop_mode_set(struct rk3288_vop *regs, * * @dev: VOP device that we want to connect to the display * @fbbase: Frame buffer address - * @l2bpp Log2 of bits-per-pixels for the display * @ep_node: Device tree node to process - this is the offset of an endpoint * node within the VOP's 'port' list. * @return 0 if OK, -ve if something went wrong */ -int rk_display_init(struct udevice *dev, ulong fbbase, - enum video_log2_bpp l2bpp, int ep_node) +int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) { struct video_priv *uc_priv = dev_get_uclass_priv(dev); const void *blob = gd->fdt_blob; @@ -199,6 +197,7 @@ int rk_display_init(struct udevice *dev, ulong fbbase, int ret, remote, i, offset; struct display_plat *disp_uc_plat; struct clk clk; + enum video_log2_bpp l2bpp;
vop_id = fdtdec_get_int(blob, ep_node, "reg", -1); debug("vop_id=%d\n", vop_id); @@ -253,6 +252,19 @@ int rk_display_init(struct udevice *dev, ulong fbbase, return ret; }
+ /* Set bitwidth for vop display according to vop mode */ + switch (vop_id) { + case VOP_MODE_EDP: + case VOP_MODE_HDMI: + case VOP_MODE_LVDS: + l2bpp = VIDEO_BPP16; + break; + case VOP_MODE_MIPI: + l2bpp = VIDEO_BPP32; + break; + default: + l2bpp = VIDEO_BPP16; + } rkvop_mode_set(regs, &timing, vop_id);
rkvop_enable(regs, fbbase, 1 << l2bpp, &timing); @@ -330,7 +342,7 @@ static int rk_vop_probe(struct udevice *dev) for (node = fdt_first_subnode(blob, port); node > 0; node = fdt_next_subnode(blob, node)) { - ret = rk_display_init(dev, plat->base, VIDEO_BPP16, node); + ret = rk_display_init(dev, plat->base, node); if (ret) debug("Device failed: ret=%d\n", ret); if (!ret)
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_ vop.c index 84d6627..a637f7d 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -181,13 +181,11 @@ void rkvop_mode_set(struct rk3288_vop *regs,
- @dev: VOP device that we want to connect to the display
- @fbbase: Frame buffer address
- @l2bpp Log2 of bits-per-pixels for the display
- @ep_node: Device tree node to process - this is the offset of an
endpoint
- @return 0 if OK, -ve if something went wrong
enum video_log2_bpp l2bpp; vop_id = fdtdec_get_int(blob, ep_node, "reg", -1); debug("vop_id=%d\n", vop_id);
switch (vop_id) {
case VOP_MODE_EDP:
case VOP_MODE_HDMI:
case VOP_MODE_LVDS:
break;
case VOP_MODE_MIPI:
break;
default:
} rkvop_mode_set(regs, &timing, vop_id); rkvop_enable(regs, fbbase, 1 << l2bpp, &timing);
-- 1.9.1
plat->size here is used to reserve enough frame buffer space befor relocation. our mipi display mode need more space, so reset it.
Changes in v2: -Extend frame buffer size for mipi display
drivers/video/rockchip/rk_vop.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index a637f7d..ac9e7db 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -357,7 +357,7 @@ static int rk_vop_bind(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev);
- plat->size = 1920 * 1080 * 2; + plat->size = 1920 * 1200 * 4;
return 0; }
I don't understand why need reserve more space. Can you explain more?
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_ vop.c index a637f7d..ac9e7db 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -357,7 +357,7 @@ static int rk_vop_bind(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev);
plat->size = 1920 * 1200 * 4; return 0;
1.9.1
Changes in v2: -Add pwm0 pinctrl init for lcd backlight.
board/rockchip/evb_rk3399/evb-rk3399.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/board/rockchip/evb_rk3399/evb-rk3399.c b/board/rockchip/evb_rk3399/evb-rk3399.c index 362fa0b..76ab467 100644 --- a/board/rockchip/evb_rk3399/evb-rk3399.c +++ b/board/rockchip/evb_rk3399/evb-rk3399.c @@ -28,6 +28,13 @@ int board_init(void) goto out; }
+ /* Enable pwm0 for panel backlight */ + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_PWM0); + if (ret) { + debug("%s PWM0 pinctrl init fail!\n", __func__); + goto out; + } + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_PWM2); if (ret) { debug("%s PWM2 pinctrl init fail!\n", __func__);
if (ret) {
can you also print the ret value?
goto out;
-- 1.9.1
Add dts config for mipi display, include vop, mipi controller, panel, backlight . And Enable rk808 for lcd_3v3 in another patch.
Changes in v2: -Add dts config for mipi display.
arch/arm/dts/rk3399-evb.dts | 84 +++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3399.dtsi | 72 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 156 insertions(+)
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index e1f867b..3d6f3ce 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -59,6 +59,15 @@ gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; };
+ backlight: backlight { + compatible = "pwm-backlight"; + status = "disabled"; + }; + + panel:panel { + compatible = "simple-panel"; + status = "disabled"; + }; };
&emmc_phy { @@ -141,6 +150,7 @@ status = "okay";
vcc12-supply = <&vcc3v3_sys>; + regulators { vcc33_lcd: SWITCH_REG2 { regulator-always-on; @@ -151,6 +161,80 @@ }; };
+&backlight { + power-supply = <&vccsys>; + enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; + brightness-levels = < + 0 1 2 3 4 5 6 7 + 8 9 10 11 12 13 14 15 + 16 17 18 19 20 21 22 23 + 24 25 26 27 28 29 30 31 + 32 33 34 35 36 37 38 39 + 40 41 42 43 44 45 46 47 + 48 49 50 51 52 53 54 55 + 56 57 58 59 60 61 62 63 + 64 65 66 67 68 69 70 71 + 72 73 74 75 76 77 78 79 + 80 81 82 83 84 85 86 87 + 88 89 90 91 92 93 94 95 + 96 97 98 99 100 101 102 103 + 104 105 106 107 108 109 110 111 + 112 113 114 115 116 117 118 119 + 120 121 122 123 124 125 126 127 + 128 129 130 131 132 133 134 135 + 136 137 138 139 140 141 142 143 + 144 145 146 147 148 149 150 151 + 152 153 154 155 156 157 158 159 + 160 161 162 163 164 165 166 167 + 168 169 170 171 172 173 174 175 + 176 177 178 179 180 181 182 183 + 184 185 186 187 188 189 190 191 + 192 193 194 195 196 197 198 199 + 200 201 202 203 204 205 206 207 + 208 209 210 211 212 213 214 215 + 216 217 218 219 220 221 222 223 + 224 225 226 227 228 229 230 231 + 232 233 234 235 236 237 238 239 + 240 241 242 243 244 245 246 247 + 248 249 250 251 252 253 254 255>; + default-brightness-level = <200>; + pwms = <&pwm0 0 25000 0>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm0_pin>; + pwm-delay-us = <10000>; + status = "okay"; + }; + +&panel { + power-supply = <&vcc33_lcd>; + backlight = <&backlight>; + /*enable-gpios = <&gpio4 18 GPIO_ACTIVE_HIGH>;*/ + status = "okay"; +}; + +&mipi_dsi { + status = "okay"; + rockchip,panel = <&panel>; + display-timings { + timing0 { + bits-per-pixel = <24>; + clock-frequency = <160000000>; + hfront-porch = <120>; + hsync-len = <20>; + hback-porch = <21>; + hactive = <1200>; + vfront-porch = <21>; + vsync-len = <3>; + vback-porch = <18>; + vactive = <1920>; + hsync-active = <0>; + vsync-active = <0>; + de-active = <1>; + pixelclk-active = <0>; + }; + }; +}; + &pinctrl { pmic { pmic_int_l: pmic-int-l { diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index d94d780..9344a43 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -684,6 +684,78 @@ status = "disabled"; };
+ vopl: vop@ff8f0000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3399-vop-lit"; + reg = <0x0 0xff8f0000 0x0 0x3efc>; + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; + clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + resets = <&cru SRST_A_VOP1>, <&cru SRST_H_VOP1>, <&cru SRST_D_VOP1>; + reset-names = "axi", "ahb", "dclk"; + status = "okay"; + vopl_out: port { + #address-cells = <1>; + #size-cells = <0>; + vopl_out_mipi: endpoint@0 { + reg = <3>; + remote-endpoint = <&mipi_in_vopl>; + }; + }; + }; + + vopb: vop@ff900000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3399-vop-big"; + reg = <0x0 0xff900000 0x0 0x3efc>; + interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; + #clock-cells = <0>; + clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + resets = <&cru SRST_A_VOP0>, <&cru SRST_H_VOP0>, <&cru SRST_D_VOP0>; + reset-names = "axi", "ahb", "dclk"; + /*power-domains = <&power RK3399_PD_VOPB>;*/ + status = "okay"; + vopb_out: port { + #address-cells = <1>; + #size-cells = <0>; + vopb_out_mipi: endpoint@0 { + reg = <3>; + remote-endpoint = <&mipi_in_vopb>; + }; + }; + }; + + mipi_dsi: mipi@ff960000 { + compatible = "rockchip,rk3399_mipi_dsi"; + reg = <0x0 0xff960000 0x0 0x8000>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_MIPIDPHY_REF>, <&cru PCLK_MIPI_DSI0>, + <&cru SCLK_DPHY_TX0_CFG>; + clock-names = "ref", "pclk", "phy_cfg"; + rockchip,grf = <&grf>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + ports { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + mipi_in: port { + #address-cells = <1>; + #size-cells = <0>; + mipi_in_vopb: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_mipi>; + }; + mipi_in_vopl: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_mipi>; + }; + }; + }; + }; + pinctrl: pinctrl { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pinctrl";
Enable mipi dsi by default for rk3399-evb board
Changes in v2: -Add defconfigs for mipi display, so that it can be enabled by default.
configs/evb-rk3399_defconfig | 6 ++++++ drivers/video/rockchip/Kconfig | 2 +- drivers/video/rockchip/Makefile | 2 +- 3 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index cef8506..3405857 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -66,3 +66,9 @@ CONFIG_PMIC_CHILDREN=y CONFIG_SPL_PMIC_CHILDREN=y CONFIG_PMIC_RK808=y CONFIG_REGULATOR_RK808=y +CONFIG_DM_VIDEO=y +CONFIG_DM_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_MIPI=y diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/Kconfig index 3f57d5c..1383efa 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -40,7 +40,7 @@ if VIDEO_ROCKCHIP This enable High-Definition Multimedia Interface(HDMI) display support.
- config DISPLAY_MIPI + config DISPLAY_ROCKCHIP_MIPI bool "MIPI Port" depends on VIDEO_ROCKCHIP help diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index f9d1abf..c742902 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -10,5 +10,5 @@ obj-y += rk_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o ../dw_hdmi.o -obj-$(CONFIG_DISPLAY_MIPI) += rk_mipi.o +obj-$(CONFIG_DISPLAY_ROCKCHIP_MIPI) += rk_mipi.o endif
some part of mipi driver should move here. see comment in patch 1 please.
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index cef8506..3405857 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -66,3 +66,9 @@ CONFIG_PMIC_CHILDREN=y CONFIG_SPL_PMIC_CHILDREN=y CONFIG_PMIC_RK808=y CONFIG_REGULATOR_RK808=y +CONFIG_DM_VIDEO=y +CONFIG_DM_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_MIPI=y diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/ Kconfig index 3f57d5c..1383efa 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -40,7 +40,7 @@ if VIDEO_ROCKCHIP This enable High-Definition Multimedia Interface(HDMI) display support.
config DISPLAY_MIPI
diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/ Makefile index f9d1abf..c742902 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -10,5 +10,5 @@ obj-y += rk_vop.o obj-$(CONFIG_DISPLAY_ROCKCHIP_EDP) += rk_edp.o obj-$(CONFIG_DISPLAY_ROCKCHIP_LVDS) += rk_lvds.o obj-$(CONFIG_DISPLAY_ROCKCHIP_HDMI) += rk_hdmi.o ../dw_hdmi.o -obj-$(CONFIG_DISPLAY_MIPI) += rk_mipi.o +obj-$(CONFIG_DISPLAY_ROCKCHIP_MIPI) += rk_mipi.o endif -- 1.9.1
The function clk_set_rate() will return it's input parameter, so it's return value in normal condition is nonzero. In this case, we should report an error when it return zero rather than return a nonzero value.
Changes in v2: -Fix rk_display_init() function report error(err:-19).
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index ac9e7db..e8fa177 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -247,7 +247,7 @@ int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) ret = clk_get_by_index(dev, 1, &clk); if (!ret) ret = clk_set_rate(&clk, timing.pixelclock.typ); - if (ret) { + if (!ret) { debug("%s: Failed to set pixel clock: ret=%d\n", __func__, ret); return ret; }
diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_ vop.c index ac9e7db..e8fa177 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -247,7 +247,7 @@ int rk_display_init(struct udevice *dev, ulong fbbase, int ep_node) ret = clk_get_by_index(dev, 1, &clk); if (!ret) ret = clk_set_rate(&clk, timing.pixelclock.typ);
if (ret) {
ret); return ret; }
should be ret = clk_get_by_index(dev, 1, &clk); if (!ret){ ret = clk_set_rate(&clk, timing.pixelclock.typ); if (!ret) { debug("%s: Failed to set pixel clock: ret=%d\n", __func__, ret); return ret; } }
-- 1.9.1
Eddie Cai
Eric Gao
