[U-Boot] [PATCH v3 0/3] Kbuild fixes
Changes in v3: - Drop 2/4 ("kbuild: sunxi: fix build rule of sunxi-spl.bin") as well
Changes in v2: - Drop 3/5 ("kbuild: use $(call cmd, ) rather than $(call if_changed, ) where possible") - add tools/fdtgrep to the dependency
Masahiro Yamada (3): kbuild: remove unneeded ifdef conditionals around build rules kbuild: add missing FORCE where $(call if_changed, ) is used kbuild: fix build rule of u-boot-spl.dtb
Makefile | 12 ++++++------ scripts/Makefile.spl | 18 +++++++----------- 2 files changed, 13 insertions(+), 17 deletions(-)
These rules are only used for SOCFPGA, SUNXI, but no need to hide them from other SoCs.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
scripts/Makefile.spl | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index f486feb..adabfcf 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -228,18 +228,14 @@ ifneq ($(CONFIG_SPL_TEXT_BASE),) LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_SPL_TEXT_BASE) endif
-ifdef CONFIG_ARCH_SOCFPGA MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mkimage) -endif
-ifdef CONFIG_SUNXI quiet_cmd_mksunxiboot = MKSUNXI $@ cmd_mksunxiboot = $(objtree)/tools/mksunxiboot $< $@ $(obj)/sunxi-spl.bin: $(obj)/$(SPL_BIN).bin $(call if_changed,mksunxiboot) -endif
quiet_cmd_u-boot-spl = LD $@ cmd_u-boot-spl = (cd $(obj) && $(LD) $(LDFLAGS) $(LDFLAGS_$(@F)) \
On 5 February 2016 at 01:55, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org
FORCE is needed for $(call if_changed,...) to be evaluated every time. Otherwise, the command is not executed when the command line has changed but any prerequisite has not been updated.
Makefile | 12 ++++++------ scripts/Makefile.spl | 10 +++++----- 2 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index 430dd4f..a46c1ae 100644 --- a/Makefile +++ b/Makefile @@ -924,7 +924,7 @@ u-boot.sha1: u-boot.bin u-boot.dis: u-boot $(OBJDUMP) -d $< > $@
-u-boot.cfg: include/config.h +u-boot.cfg: include/config.h FORCE $(call if_changed,cpp_cfg)
ifdef CONFIG_TPL @@ -945,15 +945,15 @@ lpc32xx-spl.img: spl/u-boot-spl.bin FORCE
OBJCOPYFLAGS_lpc32xx-boot-0.bin = -I binary -O binary --pad-to=$(CONFIG_SPL_PAD_TO)
-lpc32xx-boot-0.bin: lpc32xx-spl.img +lpc32xx-boot-0.bin: lpc32xx-spl.img FORCE $(call if_changed,objcopy)
OBJCOPYFLAGS_lpc32xx-boot-1.bin = -I binary -O binary --pad-to=$(CONFIG_SPL_PAD_TO)
-lpc32xx-boot-1.bin: lpc32xx-spl.img +lpc32xx-boot-1.bin: lpc32xx-spl.img FORCE $(call if_changed,objcopy)
-lpc32xx-full.bin: lpc32xx-boot-0.bin lpc32xx-boot-1.bin u-boot.img +lpc32xx-full.bin: lpc32xx-boot-0.bin lpc32xx-boot-1.bin u-boot.img FORCE $(call if_changed,cat)
CLEAN_FILES += lpc32xx-* @@ -1056,7 +1056,7 @@ endif cmd_ifdtool += $(IFDTOOL) $(IFDTOOL_FLAGS) u-boot.tmp; cmd_ifdtool += mv u-boot.tmp $@
-u-boot.rom: u-boot-x86-16bit.bin u-boot.bin +u-boot.rom: u-boot-x86-16bit.bin u-boot.bin FORCE $(call if_changed,ifdtool)
OBJCOPYFLAGS_u-boot-x86-16bit.bin := -O binary -j .start16 -j .resetvec @@ -1171,7 +1171,7 @@ cmd_smap = \ $(CC) $(c_flags) -DSYSTEM_MAP=""$${smap}"" \ -c $(srctree)/common/system_map.c -o common/system_map.o
-u-boot: $(u-boot-init) $(u-boot-main) u-boot.lds +u-boot: $(u-boot-init) $(u-boot-main) u-boot.lds FORCE $(call if_changed,u-boot__) ifeq ($(CONFIG_KALLSYMS),y) $(call cmd,smap) diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index adabfcf..bd333e2 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -114,7 +114,7 @@ MKIMAGEFLAGS_MLO = -T omapimage -a $(CONFIG_SPL_TEXT_BASE)
MKIMAGEFLAGS_MLO.byteswap = -T omapimage -n byteswap -a $(CONFIG_SPL_TEXT_BASE)
-MLO MLO.byteswap: $(obj)/u-boot-spl.bin +MLO MLO.byteswap: $(obj)/u-boot-spl.bin FORCE $(call if_changed,mkimage)
ifeq ($(CONFIG_SYS_SOC),"at91") @@ -126,12 +126,12 @@ MKIMAGEFLAGS_boot.bin += -n $(shell $(obj)/../tools/atmel_pmecc_params) boot.bin: $(obj)/../tools/atmel_pmecc_params endif
-boot.bin: $(obj)/u-boot-spl.bin +boot.bin: $(obj)/u-boot-spl.bin FORCE $(call if_changed,mkimage) else MKIMAGEFLAGS_boot.bin = -T zynqimage
-spl/boot.bin: $(obj)/u-boot-spl.bin +spl/boot.bin: $(obj)/u-boot-spl.bin FORCE $(call if_changed,mkimage) endif
@@ -200,7 +200,7 @@ quiet_cmd_cpp_cfg = CFG $@ cmd_cpp_cfg = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) -ansi \ -DDO_DEPS_ONLY -D__ASSEMBLY__ -x assembler-with-cpp -P -dM -E -o $@ $<
-$(obj)/$(SPL_BIN).cfg: include/config.h +$(obj)/$(SPL_BIN).cfg: include/config.h FORCE $(call if_changed,cpp_cfg)
ifdef CONFIG_SAMSUNG @@ -234,7 +234,7 @@ $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE
quiet_cmd_mksunxiboot = MKSUNXI $@ cmd_mksunxiboot = $(objtree)/tools/mksunxiboot $< $@ -$(obj)/sunxi-spl.bin: $(obj)/$(SPL_BIN).bin +$(obj)/sunxi-spl.bin: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mksunxiboot)
The build command of u-boot-spl.dtb is not constant, but dependent on CONFIG_OF_SPL_REMOVE_PROPS. Use $(call if_changed,...) so that the change of CONFIG_OF_SPL_REMOVE_PROPS is detected.
Also, add tools/fdtgrep to the dependency to make sure u-boot-spl.dtb is generated by the up-to-date fdtgrep in case the tool is modified.
Changes in v3: None Changes in v2: - add tools/fdtgrep to the dependency
scripts/Makefile.spl | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index bd333e2..4424284 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -193,8 +193,8 @@ quiet_cmd_fdtgrep = FDTGREP $@ $(objtree)/tools/fdtgrep -r -O dtb - -o $@ \ $(addprefix -P ,$(subst $",,$(CONFIG_OF_SPL_REMOVE_PROPS)))
-$(obj)/$(SPL_BIN).dtb: dts/dt.dtb - $(call cmd,fdtgrep) +$(obj)/$(SPL_BIN).dtb: dts/dt.dtb $(objtree)/tools/fdtgrep FORCE + $(call if_changed,fdtgrep)
This patch is breaking build for Microblaze SPL. make microblaze-generic_defconfig && make -j
Thanks, Michal
Can you poke around a bit more at what rule is likely needing an update here? FWIW, when this was merged microblaze was broken due to the eth-uclass.c problem so that's how I missed it, sorry!
Hi Michal, Tom, Simon
2016-02-23 1:16 GMT+09:00 Tom Rini trini@konsulko.com:
This breakage is not due to this commit.
Even if I revert commit 35b786780f3 ("kbuild: fix build rule of u-boot-spl.dtb"), this board is still broken.
I suspect the problem is in the fdtgrep tool itself.
This is my log:
yamada@beagle:~/workspace/u-boot$ git clean -d -f -x yamada@beagle:~/workspace/u-boot$ git pull Already up-to-date. yamada@beagle:~/workspace/u-boot$ git describe v2016.03-rc2-84-g595af9d yamada@beagle:~/workspace/u-boot$ git checkout -b revert_test Switched to a new branch 'revert_test' yamada@beagle:~/workspace/u-boot$ git revert 35b78678 [revert_test b0dbed5] Revert "kbuild: fix build rule of u-boot-spl.dtb" 1 file changed, 2 insertions(+), 2 deletions(-) yamada@beagle:~/workspace/u-boot$ make microblaze-generic_defconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o SHIPPED scripts/kconfig/zconf.tab.c SHIPPED scripts/kconfig/zconf.lex.c SHIPPED scripts/kconfig/zconf.hash.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf # # configuration written to .config # yamada@beagle:~/workspace/u-boot$ make CROSS_COMPILE=microblaze-linux- scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h UPD include/config.h GEN include/autoconf.mk GEN include/autoconf.mk.dep GEN spl/include/autoconf.mk CHK include/config/uboot.release UPD include/config/uboot.release CHK include/generated/version_autogenerated.h UPD include/generated/version_autogenerated.h CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CC lib/asm-offsets.s CHK include/generated/generic-asm-offsets.h UPD include/generated/generic-asm-offsets.h HOSTCC tools/envcrc.o WRAP tools/lib/crc32.c HOSTCC tools/lib/crc32.o WRAP tools/common/env_embedded.c HOSTCC tools/common/env_embedded.o WRAP tools/lib/sha1.c HOSTCC tools/lib/sha1.o HOSTLD tools/envcrc HOSTCC tools/gen_eth_addr HOSTCC tools/img2srec HOSTCC tools/mkenvimage.o HOSTCC tools/os_support.o HOSTLD tools/mkenvimage HOSTCC tools/aisimage.o HOSTCC tools/atmelimage.o WRAP tools/common/bootm.c HOSTCC tools/common/bootm.o HOSTCC tools/default_image.o WRAP tools/lib/fdtdec_common.c HOSTCC tools/lib/fdtdec_common.o WRAP tools/lib/fdtdec.c HOSTCC tools/lib/fdtdec.o HOSTCC tools/fit_common.o HOSTCC tools/fit_image.o HOSTCC tools/gpimage.o HOSTCC tools/gpimage-common.o WRAP tools/common/image-fit.c HOSTCC tools/common/image-fit.o HOSTCC tools/image-host.o WRAP tools/common/image.c HOSTCC tools/common/image.o HOSTCC tools/imagetool.o HOSTCC tools/imximage.o HOSTCC tools/kwbimage.o WRAP tools/lib/md5.c HOSTCC tools/lib/md5.o HOSTCC tools/lpc32xximage.o HOSTCC tools/mxsimage.o HOSTCC tools/omapimage.o HOSTCC tools/pblimage.o HOSTCC tools/pbl_crc32.o WRAP tools/lib/rc4.c HOSTCC tools/lib/rc4.o HOSTCC tools/rkcommon.o HOSTCC tools/rkimage.o HOSTCC tools/rksd.o HOSTCC tools/rkspi.o HOSTCC tools/socfpgaimage.o WRAP tools/lib/sha256.c HOSTCC tools/lib/sha256.o WRAP tools/common/hash.c HOSTCC tools/common/hash.o HOSTCC tools/ublimage.o HOSTCC tools/zynqimage.o WRAP tools/lib/libfdt/fdt.c HOSTCC tools/lib/libfdt/fdt.o WRAP tools/lib/libfdt/fdt_ro.c HOSTCC tools/lib/libfdt/fdt_ro.o WRAP tools/lib/libfdt/fdt_rw.c HOSTCC tools/lib/libfdt/fdt_rw.o WRAP tools/lib/libfdt/fdt_strerror.c HOSTCC tools/lib/libfdt/fdt_strerror.o WRAP tools/lib/libfdt/fdt_wip.c HOSTCC tools/lib/libfdt/fdt_wip.o WRAP tools/lib/libfdt/fdt_region.c HOSTCC tools/lib/libfdt/fdt_region.o HOSTCC tools/dumpimage.o HOSTLD tools/dumpimage HOSTCC tools/mkimage.o HOSTLD tools/mkimage HOSTCC tools/ncb HOSTCC tools/proftool HOSTCC tools/fdtgrep.o HOSTLD tools/fdtgrep AS arch/microblaze/cpu/irq.o CC arch/microblaze/cpu/interrupts.o CC arch/microblaze/cpu/cache.o CC arch/microblaze/cpu/exception.o CC arch/microblaze/cpu/timer.o LD arch/microblaze/cpu/built-in.o AS arch/microblaze/cpu/start.o CC arch/microblaze/lib/bootm.o CC arch/microblaze/lib/muldi3.o LD arch/microblaze/lib/built-in.o CC board/xilinx/microblaze-generic/microblaze-generic.o LD board/xilinx/microblaze-generic/built-in.o CC cmd/boot.o CC cmd/bootm.o CC cmd/help.o CC cmd/version.o CC cmd/source.o CC cmd/bdinfo.o CC cmd/console.o CC cmd/echo.o CC cmd/elf.o CC cmd/exit.o CC cmd/fdt.o CC cmd/flash.o CC cmd/gpio.o CC cmd/irq.o CC cmd/itest.o CC cmd/jffs2.o CC cmd/load.o CC cmd/mem.o CC cmd/mfsl.o CC cmd/mii.o CC cmd/mdio.o CC cmd/misc.o CC cmd/mtdparts.o CC cmd/net.o CC cmd/pcmcia.o CC cmd/test.o CC cmd/ubi.o CC cmd/ximg.o CC cmd/spl.o CC cmd/nvedit.o CC cmd/disk.o LD cmd/built-in.o CC common/init/board_init.o LD common/init/built-in.o CC common/main.o CC common/exports.o CC common/hash.o CC common/cli_hush.o CC common/autoboot.o CC common/board_f.o CC common/board_r.o CC common/bootm.o CC common/bootm_os.o CC common/env_attr.o CC common/env_callback.o CC common/env_flags.o CC common/env_flash.o CC common/fdt_support.o CC common/miiphyutil.o CC common/flash.o CC common/splash.o CC common/env_common.o CC common/console.o CC common/dlmalloc.o CC common/malloc_simple.o CC common/image.o CC common/image-fdt.o CC common/image-fit.o CC common/memsize.o CC common/stdio.o CC common/cli_simple.o CC common/cli.o CC common/cli_readline.o CC common/command.o CC common/s_record.o CC common/xyzModem.o LD common/built-in.o CC common/env_embedded.o CC disk/part.o LD disk/built-in.o LD drivers/adc/built-in.o CC drivers/block/disk-uclass.o LD drivers/block/built-in.o CC drivers/core/device.o CC drivers/core/lists.o CC drivers/core/root.o CC drivers/core/uclass.o CC drivers/core/util.o CC drivers/core/device-remove.o CC drivers/core/simple-bus.o CC drivers/core/dump.o LD drivers/core/built-in.o CC drivers/crypto/fsl/sec.o LD drivers/crypto/fsl/built-in.o LD drivers/crypto/rsa_mod_exp/built-in.o LD drivers/crypto/built-in.o LD drivers/dfu/built-in.o LD drivers/hwmon/built-in.o CC drivers/input/input.o CC drivers/input/key_matrix.o LD drivers/input/built-in.o LD drivers/memory/built-in.o LD drivers/misc/built-in.o CC drivers/pcmcia/tqm8xx_pcmcia.o LD drivers/pcmcia/built-in.o LD drivers/pwm/built-in.o CC drivers/rtc/date.o LD drivers/rtc/built-in.o LD drivers/soc/built-in.o LD drivers/sound/built-in.o LD drivers/thermal/built-in.o LD drivers/timer/built-in.o LD drivers/tpm/built-in.o LD drivers/twserial/built-in.o LD drivers/video/bridge/built-in.o LD drivers/video/built-in.o CC drivers/watchdog/xilinx_tb_wdt.o LD drivers/watchdog/built-in.o LD drivers/built-in.o LD drivers/dma/built-in.o CC drivers/gpio/xilinx_gpio.o LD drivers/gpio/built-in.o LD drivers/i2c/built-in.o LD drivers/mmc/built-in.o CC drivers/mtd/mtdcore.o CC drivers/mtd/mtd_uboot.o CC drivers/mtd/mtdpart.o CC drivers/mtd/cfi_flash.o CC drivers/mtd/cfi_mtd.o LD drivers/mtd/built-in.o LD drivers/mtd/onenand/built-in.o LD drivers/mtd/spi/built-in.o CC drivers/mtd/ubi/attach.o CC drivers/mtd/ubi/build.o CC drivers/mtd/ubi/vtbl.o CC drivers/mtd/ubi/vmt.o CC drivers/mtd/ubi/upd.o CC drivers/mtd/ubi/kapi.o CC drivers/mtd/ubi/eba.o CC drivers/mtd/ubi/io.o CC drivers/mtd/ubi/wl.o CC drivers/mtd/ubi/crc32.o CC drivers/mtd/ubi/misc.o CC drivers/mtd/ubi/debug.o LD drivers/mtd/ubi/built-in.o CC drivers/net/netconsole.o CC drivers/net/xilinx_axi_emac.o CC drivers/net/xilinx_emaclite.o LD drivers/net/built-in.o CC drivers/net/phy/phy.o CC drivers/net/phy/atheros.o CC drivers/net/phy/broadcom.o CC drivers/net/phy/davicom.o CC drivers/net/phy/lxt.o CC drivers/net/phy/marvell.o CC drivers/net/phy/micrel.o CC drivers/net/phy/natsemi.o CC drivers/net/phy/realtek.o CC drivers/net/phy/vitesse.o LD drivers/net/phy/built-in.o LD drivers/pci/built-in.o LD drivers/power/built-in.o LD drivers/power/battery/built-in.o LD drivers/power/fuel_gauge/built-in.o LD drivers/power/mfd/built-in.o LD drivers/power/pmic/built-in.o LD drivers/power/regulator/built-in.o CC drivers/serial/serial-uclass.o CC drivers/serial/ns16550.o CC drivers/serial/serial_xuartlite.o LD drivers/serial/built-in.o CC drivers/spi/spi.o LD drivers/spi/built-in.o LD drivers/usb/dwc3/built-in.o LD drivers/usb/emul/built-in.o LD drivers/usb/eth/built-in.o LD drivers/usb/gadget/built-in.o LD drivers/usb/gadget/udc/built-in.o LD drivers/usb/host/built-in.o LD drivers/usb/musb-new/built-in.o LD drivers/usb/musb/built-in.o LD drivers/usb/phy/built-in.o LD drivers/usb/ulpi/built-in.o DTC arch/microblaze/dts/microblaze-generic.dtb SHIPPED dts/dt.dtb DTB dts/dt.dtb.S AS dts/dt.dtb.o LD dts/built-in.o CC fs/fs.o LD fs/fat/built-in.o CC fs/jffs2/compr_rtime.o CC fs/jffs2/compr_rubin.o CC fs/jffs2/compr_zlib.o CC fs/jffs2/jffs2_1pass.o CC fs/jffs2/mini_inflate.o LD fs/jffs2/built-in.o LD fs/built-in.o CC lib/libfdt/fdt.o CC lib/libfdt/fdt_ro.o CC lib/libfdt/fdt_rw.o CC lib/libfdt/fdt_strerror.o CC lib/libfdt/fdt_sw.o CC lib/libfdt/fdt_wip.o CC lib/libfdt/fdt_empty_tree.o CC lib/libfdt/fdt_addresses.o CC lib/libfdt/fdt_region.o LD lib/libfdt/built-in.o CC lib/zlib/zlib.o LD lib/zlib/built-in.o CC lib/crc7.o CC lib/crc8.o CC lib/crc16.o CC lib/fdtdec_common.o CC lib/fdtdec.o CC lib/gunzip.o CC lib/initcall.o CC lib/lmb.o CC lib/ldiv.o CC lib/md5.o CC lib/net_utils.o CC lib/qsort.o CC lib/rc4.o CC lib/sha1.o CC lib/sha256.o CC lib/strmhz.o CC lib/rbtree.o CC lib/list_sort.o CC lib/hashtable.o CC lib/errno.o CC lib/display_options.o CC lib/crc32.o CC lib/ctype.o CC lib/div64.o CC lib/hang.o CC lib/linux_compat.o CC lib/linux_string.o CC lib/membuff.o CC lib/slre.o CC lib/string.o CC lib/time.o CC lib/vsprintf.o CC lib/panic.o CC lib/strto.o LD lib/built-in.o CC net/checksum.o CC net/arp.o CC net/bootp.o CC net/eth-uclass.o CC net/eth_common.o CC net/net.o CC net/nfs.o CC net/ping.o CC net/tftp.o LD net/built-in.o LD test/built-in.o CC test/dm/cmd_dm.o LD test/dm/built-in.o CC examples/standalone/stubs.o LD examples/standalone/libstubs.o CC examples/standalone/hello_world.o LD examples/standalone/hello_world OBJCOPY examples/standalone/hello_world.srec OBJCOPY examples/standalone/hello_world.bin LDS u-boot.lds LD u-boot OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin COPY u-boot.bin SYM u-boot.sym CFG u-boot.cfg AS spl/arch/microblaze/cpu/irq.o CC spl/arch/microblaze/cpu/interrupts.o CC spl/arch/microblaze/cpu/cache.o CC spl/arch/microblaze/cpu/exception.o CC spl/arch/microblaze/cpu/timer.o CC spl/arch/microblaze/cpu/spl.o LD spl/arch/microblaze/cpu/built-in.o AS spl/arch/microblaze/cpu/start.o CC spl/arch/microblaze/lib/bootm.o CC spl/arch/microblaze/lib/muldi3.o LD spl/arch/microblaze/lib/built-in.o CC spl/board/xilinx/microblaze-generic/microblaze-generic.o LD spl/board/xilinx/microblaze-generic/built-in.o CC spl/common/spl/spl.o CC spl/common/spl/spl_nor.o LD spl/common/spl/built-in.o CC spl/common/init/board_init.o LD spl/common/init/built-in.o CC spl/common/env_flash.o CC spl/common/env_common.o CC spl/common/console.o CC spl/common/dlmalloc.o CC spl/common/malloc_simple.o CC spl/common/image.o CC spl/common/image-fdt.o CC spl/common/image-fit.o CC spl/common/memsize.o CC spl/common/stdio.o CC spl/common/cli_simple.o CC spl/common/cli.o CC spl/common/cli_readline.o CC spl/common/command.o CC spl/common/s_record.o CC spl/common/xyzModem.o LD spl/common/built-in.o CC spl/cmd/nvedit.o CC spl/cmd/disk.o LD spl/cmd/built-in.o CC spl/drivers/core/device.o CC spl/drivers/core/lists.o CC spl/drivers/core/root.o CC spl/drivers/core/uclass.o CC spl/drivers/core/util.o CC spl/drivers/core/simple-bus.o CC spl/drivers/core/dump.o LD spl/drivers/core/built-in.o CC spl/drivers/serial/serial-uclass.o CC spl/drivers/serial/ns16550.o CC spl/drivers/serial/serial_xuartlite.o LD spl/drivers/serial/built-in.o LD spl/drivers/built-in.o AS spl/dts/dt.dtb.o LD spl/dts/built-in.o LD spl/fs/built-in.o CC spl/lib/libfdt/fdt.o CC spl/lib/libfdt/fdt_ro.o CC spl/lib/libfdt/fdt_rw.o CC spl/lib/libfdt/fdt_strerror.o CC spl/lib/libfdt/fdt_sw.o CC spl/lib/libfdt/fdt_wip.o CC spl/lib/libfdt/fdt_empty_tree.o CC spl/lib/libfdt/fdt_addresses.o CC spl/lib/libfdt/fdt_region.o LD spl/lib/libfdt/built-in.o CC spl/lib/fdtdec_common.o CC spl/lib/fdtdec.o CC spl/lib/hashtable.o CC spl/lib/errno.o CC spl/lib/display_options.o CC spl/lib/crc32.o CC spl/lib/ctype.o CC spl/lib/div64.o CC spl/lib/hang.o CC spl/lib/linux_compat.o CC spl/lib/linux_string.o CC spl/lib/membuff.o CC spl/lib/slre.o CC spl/lib/string.o CC spl/lib/time.o CC spl/lib/vsprintf.o CC spl/lib/panic.o CC spl/lib/strto.o LD spl/lib/built-in.o LDS spl/u-boot-spl.lds LD spl/u-boot-spl OBJCOPY spl/u-boot-spl-nodtb.bin FDTGREP spl/u-boot-spl.dtb Error: FDT_ERR_BADMAGIC make[1]: *** [spl/u-boot-spl.dtb] Error 1 make: *** [spl/u-boot-spl] Error 2
I saw this problem before when I was porting my new ARMv8 SoC. See below:
http://lists.denx.de/pipermail/u-boot/2016-February/245870.html
I hope Simon could help us figure out the root cause.
That's interesting. I found this commit by bisect.
Anyway I was playing with it and this is supposed to be a fix. fdtgrep tool is expecting more nodes to be present in DTS file. Because mb dts is generic because every hw design is different dts is quite empty.
Masahiro: Can you please try this and build it?
Thanks, Michal
diff --git a/arch/microblaze/dts/microblaze-generic.dts b/arch/microblaze/dts/microblaze-generic.dts index 203330987bda..08a1396f2db2 100644 --- a/arch/microblaze/dts/microblaze-generic.dts +++ b/arch/microblaze/dts/microblaze-generic.dts @@ -4,4 +4,6 @@ #size-cells = <1>; aliases { } ; + chosen { + } ; } ;
Hi Michal,
2016-02-23 16:06 GMT+09:00 Michal Simek monstr@monstr.eu:
Thanks, Michal
chosen {
Yeah, this fixed the error. Thanks!
On 23.2.2016 08:47, Masahiro Yamada wrote:
Hi Michal,
> The build command of u-boot-spl.dtb is not constant, but dependent > on CONFIG_OF_SPL_REMOVE_PROPS. Use $(call if_changed,...) so that > the change of CONFIG_OF_SPL_REMOVE_PROPS is detected. > > Also, add tools/fdtgrep to the dependency to make sure u-boot-spl.dtb > is generated by the up-to-date fdtgrep in case the tool is modified. > > Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com > Reviewed-by: Simon Glass sjg@chromium.org
Thanks, Michal
chosen {
Ok. I will send this as a patch or temporary solution or even maybe final.
Thanks, Michal
participants (5)
Masahiro Yamada
Michal Simek
Michal Simek
