[U-Boot] Please pull u-boot-mpc85xx.git
arm:samsung:trats:fix: Restore proper orientation of TRATS's LCD panel (2013-07-16 09:20:16 -0400)
git://www.denx.de/git/u-boot-mpc85xx.git master
for you to fetch changes up to 2a6936059a1f393d828274bf5d33dd54c0a3c882:
powerpc/mpc85xx:Disable Debug TLB entry for non-minimal SPL (2013-07-16 17:44:30 -0500)
---------------------------------------------------------------- Dirk Eibach (3): Add Atmel I2C tpm Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTM mpc85xx: Add gdsys ControlCenter Digital board
Prabhakar Kushwaha (1): powerpc/mpc85xx:Disable Debug TLB entry for non-minimal SPL
Reinhard Pfau (2): tpm: add AUTH1 cmds for LoadKey2 and GetPubKey i2c: fsl_i2c: i2c_read(): dont try to write address w/ alen=0
MAINTAINERS | 3 +- README | 17 + arch/arm/lib/Makefile | 2 +- arch/avr32/lib/Makefile | 2 +- arch/m68k/lib/Makefile | 2 +- arch/microblaze/lib/Makefile | 2 +- arch/mips/lib/Makefile | 4 +- arch/nds32/lib/Makefile | 3 +- arch/nios2/lib/Makefile | 2 +- arch/openrisc/lib/Makefile | 2 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 4 +- arch/powerpc/lib/Makefile | 2 +- arch/sh/lib/Makefile | 2 +- arch/sparc/lib/Makefile | 3 +- arch/x86/lib/Makefile | 2 +- board/gdsys/common/Makefile | 1 + board/gdsys/common/dp501.c | 107 +++ board/gdsys/common/dp501.h | 30 + board/gdsys/p1022/Makefile | 37 + board/gdsys/p1022/controlcenterd-id.c | 1224 +++++++++++++++++++++++++++++ board/gdsys/p1022/controlcenterd-id.h | 29 + board/gdsys/p1022/controlcenterd.c | 425 ++++++++++ board/gdsys/p1022/ddr.c | 71 ++ board/gdsys/p1022/diu.c | 87 ++ board/gdsys/p1022/law.c | 20 + board/gdsys/p1022/sdhc_boot.c | 63 ++ board/gdsys/p1022/tlb.c | 77 ++ boards.cfg | 4 + common/cmd_tpm.c | 100 +++ drivers/i2c/fsl_i2c.c | 9 +- drivers/tpm/Makefile | 1 + drivers/tpm/tpm_atmel_twi.c | 121 +++ include/configs/controlcenterd.h | 522 ++++++++++++ include/tpm.h | 174 ++++ lib/tpm.c | 351 ++++++++- 35 files changed, 3486 insertions(+), 19 deletions(-) create mode 100644 board/gdsys/common/dp501.c create mode 100644 board/gdsys/common/dp501.h create mode 100644 board/gdsys/p1022/Makefile create mode 100644 board/gdsys/p1022/controlcenterd-id.c create mode 100644 board/gdsys/p1022/controlcenterd-id.h create mode 100644 board/gdsys/p1022/controlcenterd.c create mode 100644 board/gdsys/p1022/ddr.c create mode 100644 board/gdsys/p1022/diu.c create mode 100644 board/gdsys/p1022/law.c create mode 100644 board/gdsys/p1022/sdhc_boot.c create mode 100644 board/gdsys/p1022/tlb.c create mode 100644 drivers/tpm/tpm_atmel_twi.c create mode 100644 include/configs/controlcenterd.h
Andy Fleming
