[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 782acf7b52db6bec1a796773e3033b4afcd6c9e2:
Merge git://git.denx.de/u-boot-rockchip (2016-01-15 08:11:15 -0500)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to 217db227df40e29d6a4726272303499a7cd7b904:
socfpga: Modify qts-filter args to allow input for bsp generated files and quartus project directories (2016-01-16 07:07:23 +0100)
---------------------------------------------------------------- Dalon Westergreen (1): socfpga: Modify qts-filter args to allow input for bsp generated files and quartus project directories
Dinh Nguyen (1): arm: socfpga: set the fpga global bit to disable HPS to FPGA signals
Marek Vasut (1): ddr: altera: Init the rule ID in debug code
arch/arm/mach-socfpga/qts-filter.sh | 76 +++++++++++++++++++++++++++++++++++++++++++++------------------------------- drivers/ddr/altera/sdram.c | 1 + drivers/fpga/socfpga.c | 2 +- 3 files changed, 47 insertions(+), 32 deletions(-)
