[U-Boot] [PATCH] arc: Update exception & interrupt handling for ARCv2
Initially IVT for ARCv2 was simply copypasted from ARCompact with some selected fixes so basic stuff works.
Now we update it with more ARCv2 specific vectors like * Software Interrupt * Division by zero * Data cache consistency error * Misaligned access
Also normal interrupts are now implemented properly and extened to all possible 240 items.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- arch/arc/cpu/arcv2/ivt.S | 31 ++++++++++++++++++------------- arch/arc/lib/interrupts.c | 26 ++++++++++++++++++++++++++ arch/arc/lib/ints_low.S | 28 ++++++++++++++++++++++++++++ 3 files changed, 72 insertions(+), 13 deletions(-)
diff --git a/arch/arc/cpu/arcv2/ivt.S b/arch/arc/cpu/arcv2/ivt.S index d110b5b..7924375 100644 --- a/arch/arc/cpu/arcv2/ivt.S +++ b/arch/arc/cpu/arcv2/ivt.S @@ -7,21 +7,26 @@ .section .ivt, "a",@progbits .align 4 /* Critical system events */ -.word _start /* 0 - 0x000 */ -.word memory_error /* 1 - 0x008 */ -.word instruction_error /* 2 - 0x010 */ +.word _start /* 0x00 - Reset */ +.word memory_error /* 0x01 - Memory Error */ +.word instruction_error /* 0x02 - Instruction Error */
/* Exceptions */ -.word EV_MachineCheck /* 0x100, Fatal Machine check (0x20) */ -.word EV_TLBMissI /* 0x108, Intruction TLB miss (0x21) */ -.word EV_TLBMissD /* 0x110, Data TLB miss (0x22) */ -.word EV_TLBProtV /* 0x118, Protection Violation (0x23) - or Misaligned Access */ -.word EV_PrivilegeV /* 0x120, Privilege Violation (0x24) */ -.word EV_Trap /* 0x128, Trap exception (0x25) */ -.word EV_Extension /* 0x130, Extn Intruction Excp (0x26) */ +.word EV_MachineCheck /* 0x03 - Fatal Machine check */ +.word EV_TLBMissI /* 0x04 - Intruction TLB miss */ +.word EV_TLBMissD /* 0x05 - Data TLB miss */ +.word EV_TLBProtV /* 0x06 - Protection Violation or Misaligned Access */ +.word EV_PrivilegeV /* 0x07 - Privilege Violation */ +.word EV_SWI /* 0x08 - Software Interrupt */ +.word EV_Trap /* 0x09 - Trap */ +.word EV_Extension /* 0x0A - Extension Intruction Exception */ +.word EV_DivZero /* 0x0B - Division by Zero */ +.word EV_DCError /* 0x0C - Data cache consistency error */ +.word EV_Maligned /* 0x0D - Misaligned data access */ +.word 0 /* 0x0E - Unused */ +.word 0 /* 0x0F - Unused */
/* Device interrupts */ -.rept 29 - j interrupt_handler /* 3:31 - 0x018:0xF8 */ +.rept 240 +.word interrupt_handler /* 0x10 - 0xFF */ .endr diff --git a/arch/arc/lib/interrupts.c b/arch/arc/lib/interrupts.c index d7cab3b..ee638d5 100644 --- a/arch/arc/lib/interrupts.c +++ b/arch/arc/lib/interrupts.c @@ -141,3 +141,29 @@ void do_extension(struct pt_regs *regs) printf("Extension instruction exception\n"); bad_mode(regs); } + +#ifdef CONFIG_ISA_ARCV2 +void do_swi(struct pt_regs *regs) +{ + printf("Software Interrupt exception\n"); + bad_mode(regs); +} + +void do_divzero(unsigned long address, struct pt_regs *regs) +{ + printf("Division by zero exception @ 0x%lx\n", address); + bad_mode(regs); +} + +void do_dcerror(struct pt_regs *regs) +{ + printf("Data cache consistency error exception\n"); + bad_mode(regs); +} + +void do_maligned(unsigned long address, struct pt_regs *regs) +{ + printf("Misaligned data access exception @ 0x%lx\n", address); + bad_mode(regs); +} +#endif diff --git a/arch/arc/lib/ints_low.S b/arch/arc/lib/ints_low.S index 161cf37..e377884 100644 --- a/arch/arc/lib/ints_low.S +++ b/arch/arc/lib/ints_low.S @@ -149,3 +149,31 @@ ENTRY(EV_Extension) mov %r0, %sp j do_extension ENDPROC(EV_Extension) + +#ifdef CONFIG_ISA_ARCV2 +ENTRY(EV_SWI) + SAVE_ALL_SYS + mov %r0, %sp + j do_swi +ENDPROC(EV_SWI) + +ENTRY(EV_DivZero) + SAVE_ALL_SYS + SAVE_EXCEPTION_SOURCE + mov %r1, %sp + j do_divzero +ENDPROC(EV_DivZero) + +ENTRY(EV_DCError) + SAVE_ALL_SYS + mov %r0, %sp + j do_dcerror +ENDPROC(EV_DCError) + +ENTRY(EV_Maligned) + SAVE_ALL_SYS + SAVE_EXCEPTION_SOURCE + mov %r1, %sp + j do_maligned +ENDPROC(EV_Maligned) +#endif
Hi!
Applied, Thanks!
-Alexey
Alexey Brodkin
