[U-Boot] [PATCH v5 4/5] ARM: board: meson: add p200 board
This adds the defconfig and README files for p200 board
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com Acked-by: Neil Armstrong narmstrong@baylibre.com --- board/amlogic/p200/MAINTAINERS | 1 + board/amlogic/p200/README.p200 | 103 +++++++++++++++++++++++++++++++++ configs/p200_defconfig | 41 +++++++++++++ 3 files changed, 145 insertions(+) create mode 100644 board/amlogic/p200/README.p200 create mode 100644 configs/p200_defconfig
diff --git a/board/amlogic/p200/MAINTAINERS b/board/amlogic/p200/MAINTAINERS index 77a055b681d9..96fe92dd0874 100644 --- a/board/amlogic/p200/MAINTAINERS +++ b/board/amlogic/p200/MAINTAINERS @@ -5,3 +5,4 @@ S: Maintained F: board/amlogic/p200/ F: configs/nanopi-k2_defconfig F: configs/odroid-c2_defconfig +F: configs/p200_defconfig diff --git a/board/amlogic/p200/README.p200 b/board/amlogic/p200/README.p200 new file mode 100644 index 000000000000..01d82d1e79e3 --- /dev/null +++ b/board/amlogic/p200/README.p200 @@ -0,0 +1,103 @@ +U-Boot for Amlogic P200 +======================= + +P200 is a reference board manufactured by Amlogic with the following +specifications: + + - Amlogic S905 ARM Cortex-A53 quad-core SoC @ 1.5GHz + - ARM Mali 450 GPU + - 2GB DDR3 SDRAM + - Gigabit Ethernet + - HDMI 2.0 4K/60Hz display + - 2 x USB 2.0 Host + - eMMC, microSD + - Infrared receiver + - SDIO WiFi Module + - CVBS+Stereo Audio Jack + +Schematics are available from Amlogic on demand. + +Currently the u-boot port supports the following devices: + - serial + - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make p200_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz + > tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz + > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + > git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot + > cd amlogic-u-boot + > make gxb_p200_v1_defconfig + > make + > export FIPDIR=$PWD/fip + +Go back to mainline U-boot source tree then : + > mkdir fip + + > cp $FIPDIR/gxl/bl2.bin fip/ + > cp $FIPDIR/gxl/acs.bin fip/ + > cp $FIPDIR/gxl/bl21.bin fip/ + > cp $FIPDIR/gxl/bl30.bin fip/ + > cp $FIPDIR/gxl/bl301.bin fip/ + > cp $FIPDIR/gxl/bl31.img fip/ + > cp u-boot.bin fip/bl33.bin + + > $FIPDIR/blx_fix.sh \ + fip/bl30.bin \ + fip/zero_tmp \ + fip/bl30_zero.bin \ + fip/bl301.bin \ + fip/bl301_zero.bin \ + fip/bl30_new.bin \ + bl30 + + > $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 + + > $FIPDIR/blx_fix.sh \ + fip/bl2_acs.bin \ + fip/zero_tmp \ + fip/bl2_zero.bin \ + fip/bl21.bin \ + fip/bl21_zero.bin \ + fip/bl2_new.bin \ + bl2 + + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig + > $FIPDIR/gxl/aml_encrypt_gxl --bootmk \ + --output fip/u-boot.bin \ + --bl2 fip/bl2.n.bin.sig \ + --bl30 fip/bl30_new.bin.enc \ + --bl31 fip/bl31.img.enc \ + --bl33 fip/bl33.bin.enc + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444 diff --git a/configs/p200_defconfig b/configs/p200_defconfig new file mode 100644 index 000000000000..3980e4eb5f1d --- /dev/null +++ b/configs/p200_defconfig @@ -0,0 +1,41 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" p200" +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p200" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXBB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_BOARD="p200" -- 2.21.0
Mohammad Rasim
