[U-Boot] [RFC][PATCH] cmd: fdt: Fix fdt address information after the movement
From: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com
This patch fixes the address information of fdt.
wrong case: => fdt addr 0x48000000 => fdt move 0x48000000 0x41000000 0xa000 => fdt addr The address of the fdt is 48000000
Active address in this case is 0x41000000.
Signed-off-by: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Pantelis Antoniou pantelis.antoniou@konsulko.com --- cmd/fdt.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/cmd/fdt.c b/cmd/fdt.c index b783b0df42..1245bc24eb 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -204,6 +204,8 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; } working_fdt = newaddr; + env_set_hex("fdtaddr", (ulong)working_fdt); + #ifdef CONFIG_OF_SYSTEM_SETUP /* Call the board-specific fixup routine */ } else if (strncmp(argv[1], "sys", 3) == 0) {
Hi Marek,
Shouldn't this be map_to_sysmem(working_fdt)?
#ifdef CONFIG_OF_SYSTEM_SETUP /* Call the board-specific fixup routine */ } else if (strncmp(argv[1], "sys", 3) == 0) { -- 2.16.1
On 04/01/2018 04:14 PM, Simon Glass wrote:
Hi Marek,
Should it ?
The other question I have is, is this possibly changing the U-Boot API and is that a problem ?
btw sorry, must've missed this mail.
Hi Marek,
Hi Marek,
Should it ?
Yes, because you are converting a pointer to a ulong address. That's what that function is for. If you use it, you will allow this code to work on sandbox.
Probably this code should use set_working_fdt_addr() instead. Then we have all the env_sets in one place.
But no I don't think it is a problem to make this change. After all, working_fdt should match the 'fdtaddr' environment variable, right?
That's OK, I do that a lot I suspect...
