[PATCH v1 0/3] arm: xea: Regression fixes for i.MX28 based XEA board
This patch set provides boot regression fix and some enhancements for i.MX28 based XEA board.
The most notably one is the disablement of CONFIG_SPL_OF_PLATDATA_PARENT which prevents from having the board bricked.
Lukasz Majewski (3): xea: spl: Disable pull UP for GPIO0_2{35} xea: config: Use CONFIG_PREBOOT from Kconfig xea: config: Disable CONFIG_SPL_OF_PLATDATA_PARENT on XEA (imx28)
board/liebherr/xea/spl_xea.c | 2 +- configs/imx28_xea_defconfig | 3 +++ include/configs/xea.h | 1 - 3 files changed, 4 insertions(+), 2 deletions(-)
On the imx287 pin GPMI_WRN (GPIO0_25) no PullUP is available that can be enabled.
To get the same behavior for both boot select pins (i.e. GPIO0_2{35}) disable pull UPs on both.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
board/liebherr/xea/spl_xea.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c index d88b75bb3a..192f68fca5 100644 --- a/board/liebherr/xea/spl_xea.c +++ b/board/liebherr/xea/spl_xea.c @@ -20,7 +20,7 @@ #include <asm/arch/sys_proto.h>
#define MUX_CONFIG_LCD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) -#define MUX_CONFIG_BOOT (MXS_PAD_3V3 | MXS_PAD_PULLUP) +#define MUX_CONFIG_BOOT (MXS_PAD_3V3) #define MUX_CONFIG_TSC (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) #define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_PULLUP) #define MUX_CONFIG_SSP2 (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_PULLUP)
The usage of the preboot feature is now controlled via a separate Kconfig option - namely CONFIG_USE_PREBOOT. It must be enabled for preboot code executing commands now defined in CONFIG_PREBOOT (also moved to the Kconfig).
After defining both CONFIG_USE_PREBOOT and CONFIG_PREBOOT in imx28_xea_defconfig the define of CONFIG_PREBOOT shall be removed from xea.h as it is redundant.
configs/imx28_xea_defconfig | 2 ++ include/configs/xea.h | 1 - 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index dc42e30a1f..e418d8c9e9 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -25,6 +25,8 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200n8" +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="run prebootcmd" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set diff --git a/include/configs/xea.h b/include/configs/xea.h index df058193d6..1207f75017 100644 --- a/include/configs/xea.h +++ b/include/configs/xea.h @@ -47,7 +47,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
/* Extra Environment */ -#define CONFIG_PREBOOT "run prebootcmd" #define CONFIG_HOSTNAME "xea"
#define CONFIG_EXTRA_ENV_SETTINGS \
On the XEA board (imx28) one needs in the SPL support for GPIO, MMC and SPI. Two last ones are necessary for booting the device. The GPIO support allows deciding which medium will be used. For example the GPIO DTS node (gpio@0 at imx28.dtsi) has pinctrl parent (pinctrl@80018000) for which we don't need driver asigned for correct operation. In the spl/dts/dt-platdata.c the gpio@0 has index 4 and its parent - pinctrl@80018000 has index 5.
In the bind_drivers_pass() function (at drivers/core/lists.c) call to device_bind_by_name() for `fsl_imx23_pinctrl` returns -2, which is expected.
With current setup - when the SPL_OF_PLATDATA_PARENT=y The gpio@0 node with index 4 is skipped as its parent with 5 is not yet bound. It cannot be as we don't need and provide the driver for it. As a result the gpio@0 is never bound and we end up with bricked board in the SPL stage.
When CONFIG_SPL_OF_PLATDATA_PARENT is NOT set, all entries from spl/dts/dt-platdata.c are scanned in ascending index order, so gpio@0 is properly initialized. For `fsl_imx_pinctrl` we simply check 10 times if the driver for is available (which is not) and exit.
As a result the GPIOs are initialized and can be used in early SPL stage. This commit fixes XEA regression introduced with e41651fffda7da55f6.
configs/imx28_xea_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index e418d8c9e9..2e1d060024 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -65,6 +65,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent interrupts" CONFIG_SPL_OF_PLATDATA=y +# CONFIG_SPL_OF_PLATDATA_PARENT is not set CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y
Hi Lukasz,
Would it not be better to provide the parent driver?
With the new of-platdata I don't think this is going to work.
Anyway, to fix for this release:
Lukasz Majewski
