[U-Boot] [PATCH] mx6sabresd: Move the DCD settings to spl code
mx6sabresd_spl.cfg configures CCM registers, GPR registers and CCM_CCOSR.
Move the configuration to the spl code.
CCM_CCOSR setting is no longer required to get audio functionality in the kernel, so remove such setting.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Hi Stefano,
Actually I would like to get rid of mx6sabresd_spl.cfg completely, but when I tried to remove it, I ended up with SPL not being built.
Any suggestions?
board/freescale/mx6sabresd/mx6sabresd.c | 27 +++++++++++++++++++ board/freescale/mx6sabresd/mx6sabresd_spl.cfg | 38 --------------------------- 2 files changed, 27 insertions(+), 38 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 1142e8a..343c3b6 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -729,6 +729,30 @@ static struct mx6_ddr3_cfg mem_ddr = { .trasmin = 3500, };
+static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + /* * This section require the differentiation * between iMX6 Sabre Families. @@ -768,6 +792,9 @@ void board_init_f(ulong dummy) /* setup AIPS and disable watchdog */ arch_cpu_init();
+ ccgr_init(); + gpr_init(); + /* iomux and setup of i2c */ board_early_init_f();
diff --git a/board/freescale/mx6sabresd/mx6sabresd_spl.cfg b/board/freescale/mx6sabresd/mx6sabresd_spl.cfg index 2bf4817..1d031ba 100644 --- a/board/freescale/mx6sabresd/mx6sabresd_spl.cfg +++ b/board/freescale/mx6sabresd/mx6sabresd_spl.cfg @@ -18,41 +18,3 @@ IMAGE_VERSION 2 * spi, sd (the board has no nand neither onenand) */ BOOT_FROM sd - -/* - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ - -/* set the default clock gate to save power */ -DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC03 -DATA 4 0x020c4070 0x0FFFC000 -DATA 4 0x020c4074 0x3FF00000 -DATA 4 0x020c4078 0x00FFF300 -DATA 4 0x020c407c 0x0F0000C3 -DATA 4 0x020c4080 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4 0x020e0010 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4 0x020e0018 0x007F007F -DATA 4 0x020e001c 0x007F007F - -/* - * Setup CCM_CCOSR register as follows: - * - * cko1_en = 1 --> CKO1 enabled - * cko1_div = 111 --> divide by 8 - * cko1_sel = 1011 --> ahb_clk_root - * - * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz - */ -DATA 4 0x020c4060 0x000000fb
Hi Fabio,
Do you know which kernel versions are compatible with this CCM_CCOSR change?
Regards, Nikolay
Since commit a94f8ecb2f778f92 ("ARM: imx6q: remove board specific CLKO setup"), which appeared in 3.12, there is no need to set the CCM_CCOSR register in U-boot.
Regards,
Fabio Estevam
Hi Fabio,
I think it's part of mkimage/Makefile.
I tried to use board/freescale/mx6sabresd/dummy.cfg and the content was BOOT_FROM sd
It compiles. I guess you need to modify the Makefile in order to get rid the .cfg file for SPL.
Regards,
john
Regards,
Fabio Estevam
Is this also included in 3.10.17-1.0.x GA BSP? Otherwise we should keep it.
Hi Otavio,
On Fri, Nov 14, 2014 at 8:17 AM, Otavio Salvador otavio@ossystems.com.br wrote:
Please check FSL U-boot: http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/tree/board/freescale...
It does not have the CCM_CCOSR settings there as well.
It was only mainline kernel that needed this sometime ago. Currently it is not needed to have CCM_CCOSR configured in U-boot anymore, which makes a lot more sense. Now we can safely remove such hack.
Regards,
Fabio Estevam
Hi Fabio,
Hi Stefano,
Any suggestions?
mkimage is called with the .cfg file, and if it is removed, no imx image file is generated. I think that then the i.MX cannot boot, because the resulting image will miss the "magic number" in the headers as described in manuals. So I think that a minimal .cfg is required (without DCD and register setting) to let U-Boot build system to generate an imx image file.
Stefano
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- writel(0x00C03F3F, &ccm->CCGR0);
- writel(0x0030FC03, &ccm->CCGR1);
- writel(0x0FFFC000, &ccm->CCGR2);
- writel(0x3FF00000, &ccm->CCGR3);
- writel(0x00FFF300, &ccm->CCGR4);
- writel(0x0F0000C3, &ccm->CCGR5);
- writel(0x000003FF, &ccm->CCGR6);
- struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR;
- /* enable AXI cache for VDOA/VPU/IPU */
- writel(0xF00000CF, &iomux->gpr[4]);
- /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */
- writel(0x007F007F, &iomux->gpr[6]);
- writel(0x007F007F, &iomux->gpr[7]);
- This section require the differentiation
- between iMX6 Sabre Families.
- ccgr_init();
- gpr_init();
- /* iomux and setup of i2c */ board_early_init_f();
- spi, sd (the board has no nand neither onenand)
*/ BOOT_FROM sd
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- Setup CCM_CCOSR register as follows:
- cko1_en = 1 --> CKO1 enabled
- cko1_div = 111 --> divide by 8
- cko1_sel = 1011 --> ahb_clk_root
- This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz
Got it, so we can keep this minimal .cfg then. After this patch the spl .cfg it will only contain
IMAGE_VERSION 2 BOOT_FROM sd
Regards,
Fabio Estevam
Hi Fabio,
Perfect ! I think that other boards can use this minimal setup as well. What do you think to move it into imx-common ?
Best regards, Stefano Babic
Hi Fabio,
I forgot to asker earlier, but what are the benefits of going from DCD to SPL code to provide HW initialization?
Regards, Nikolay
Hi Nikolay,
On Fri, Nov 14, 2014 at 9:48 AM, Nikolay Dimitrov picmaster@mail.bg wrote:
Hi Fabio,
We already went through the hard part of removing the DDR settings from DCD in the SPL case. Now all is left is a few register writes that could be better placed into SPL code.
Some advantages:
- Shorter and cleaner code - see the stat diff of this series. This will avoid lots of duplication of the same spl DCD settings for several boards. - Do all the register settings in C rather than in a static DCD table. Easier to maintain and provide future changes. - We really don't need to do such simple register settings from DCD ;-)
Hi Fabio,
On 11/14/2014 01:57 PM, Fabio Estevam wrote:
Hi Nikolay,
Hi Fabio,
Some advantages:
OK, understood. Thanks, Nikolay
Hi Nikolay,
On 14/11/2014 13:22, Nikolay Dimitrov wrote:
Hi Fabio,
Hi Nikolay,
Hi Fabio,
Some advantages:
There is another advantage: it is possible to provide a single binary for boards that can mount different processor,sucs as MX6Q or MX6DL. Due to different layout, the registers are not the same, and the DCD is, of course, fix.
With SPL we are able to detect at runtime the SOC and set the registers consequently. With DCD, we need to rebuild U-Boot and deliver different binaries - that is also confusing for the end customer.
Hi Stefano,
On 11/14/2014 03:23 PM, Stefano Babic wrote:
Hi Nikolay,
Hi Fabio,
Hi Nikolay,
Hi Fabio,
Some advantages:
That was a good addition. Thank you guys for taking the time to explain.
Regards, Nikolay
participants (5)
Fabio Estevam
John Tobias
Nikolay Dimitrov
Otavio Salvador
Stefano Babic
