[GIT PULL] please pull fsl-qoriq-next for next
Hi Tom,
Please pull fsl-qoriq-next-2023-3-14 for next CI: https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq/-/pipelines/15599 ----------------------------------------------------- Enable DM_SERIAL for freescale ls2080a Drop non DM_ETH code for freescale: lx2160a/ls2080rdb/ls2080aqds/ls1088a ----------------------------------------------------
Thanks, Peng.
The following changes since commit bcf343146ff365a88481b9a80920ed146c6dee5b:
Merge tag 'dm-next-9mar23' of https://source.denx.de/u-boot/custodians/u-boot-dm into next (2023-03-09 11:22:50 -0500)
https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq.git tags/fsl-qoriq-next-2023-3-14
for you to fetch changes up to b07a62c0219ede896a20e825ab0791fb01d68407:
configs: ls208x: enable DM_SERIAL (2023-03-14 18:56:28 +0800)
---------------------------------------------------------------- Ioana Ciornei (11): board: freescale: lx2160a: remove hardcoded ethernet initialization board: freescale: lx2160a: remove code under !CONFIG_DM_ETH board: freescale: ls2080rdb: remove code under !CONFIG_DM_ETH board: freescale: ls2080aqds: remove code under !CONFIG_DM_ETH board: freescale: ls1088a: remove code under !CONFIG_DM_ETH arm: dts: ls1088a-rdb: replace 'xgmii' with '10gbase-r' arch: arm: dst: fsl-ls2080a.dtsi: add an 'soc' node arch: arm: dst: fsl-ls2080a.dtsi: move the serial nodes under soc arch: arm: dst: fsl-ls2080a.dts: sync serial nodes with Linux arch: arm: dst: fsl-ls2080a.dts: tag serial nodes with bootph-all configs: ls208x: enable DM_SERIAL
arch/arm/dts/fsl-ls1088a-rdb.dts | 4 +- arch/arm/dts/fsl-ls2080a.dtsi | 57 ++++-- board/freescale/ls1088a/eth_ls1088aqds.c | 739 +------------------------------------------------------------------------ board/freescale/ls1088a/eth_ls1088ardb.c | 93 ---------- board/freescale/ls1088a/ls1088a.c | 2 +- board/freescale/ls2080aqds/eth.c | 981 +------------------------------------------------------------------------------------------------ board/freescale/ls2080aqds/ls2080aqds.c | 2 +- board/freescale/ls2080ardb/eth_ls2080rdb.c | 95 ---------- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- board/freescale/lx2160a/eth_lx2160aqds.c | 825 +-------------------------------------------------------------------------------- board/freescale/lx2160a/eth_lx2160ardb.c | 176 ------------------ board/freescale/lx2160a/eth_lx2162aqds.c | 844 +---------------------------------------------------------------------------------- board/freescale/lx2160a/lx2160a.c | 6 +- configs/ls2088aqds_tfa_defconfig | 5 +- configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 4 +- configs/ls2088ardb_tfa_defconfig | 4 +- 16 files changed, 72 insertions(+), 3767 deletions(-)
On Tue, Mar 14, 2023 at 10:16:22AM +0000, Peng Fan wrote:
Hi Tom,
Peng Fan
