[U-Boot] [PATCH] video, ipu: make ldb clock frequenz overwriteable through board code
the ldb clock can be setup in board code (for example set through PLL5). Update the ldb_clock rate also through board code.
This should be removed, if a clock framework is availiable.
Signed-off-by: Heiko Schocher hs@denx.de ---
drivers/video/ipu.h | 1 + drivers/video/ipu_common.c | 11 +++++++++++ 2 files changed, 12 insertions(+)
diff --git a/drivers/video/ipu.h b/drivers/video/ipu.h index 091b58f..f13934f 100644 --- a/drivers/video/ipu.h +++ b/drivers/video/ipu.h @@ -266,4 +266,5 @@ void ipu_dp_uninit(ipu_channel_t channel); void ipu_dp_dc_disable(ipu_channel_t channel, unsigned char swap); ipu_color_space_t format_to_colorspace(uint32_t fmt);
+int ipu_set_ldb_clock(int rate); #endif diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 1a209d4..dc054bc 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -1198,3 +1198,14 @@ ipu_color_space_t format_to_colorspace(uint32_t fmt) } return RGB; } + +/* should removed when clk framework is availiable */ +int ipu_set_ldb_clock(int rate) +{ + if (g_ldb_clk == NULL) + return -ENOENT; + + g_ldb_clk->rate = rate; + + return 0; +}
Hi Heiko,
Any chance you're up to the task?
Searching for 'clk_get' in the sources shows a proliferation of attempts for various SOCs and drivers.
I'd rather see this in imx-common/video.h to avoid #includes out of the driver tree.
This forces a tight dependency on when this is called that using ldb_clk directly would prevent.
- if (g_ldb_clk == NULL)
return -ENOENT;
- g_ldb_clk->rate = rate;
The use of g_ldb_clk seems pretty dodgy everywhere in the IPU driver.
Otherwise:
Tested-by: Eric Nelson eric.nelson@boundarydevices.com
Hello Eric,
Am 16.04.2015 02:27, schrieb Eric Nelson:
Hi Heiko,
Yes ... but it seems, I get no time for such a job :-(
ok, moved.
Sorry, did not understand you here ...
return -ENOENT;
Otherwise:
Thanks for testing.
bye, Heiko
Hi Heiko,
The variable g_ldb is initialized in ipu_probe(), so this routine must be called at a very particular time.
You must have noticed it, since you put in a check for NULL.
return -ENOENT;
If you replace this with ldb_clk.rate, the dependency goes away.
Separately, I don't see any reason not to have g_ldb_clk statically initialized... i.e.
struct clk *g_ldb_clk = &ldb_clk;
Eric Nelson
Heiko Schocher
