[U-Boot] [PATCH 0/4] ARM: uniphier: UniPhier updates for v2016.11-rc1
Masahiro Yamada (4): ARM: uniphier: remove unneeded initializer ARM: uniphier: remove unneeded parentheses ARM: uniphier: disable CONFIG_ARCH_FIXUP_FDT_MEMORY ARM: dts: uniphier: sync Device Tree with Linux
arch/arm/dts/uniphier-common32.dtsi | 177 ------ arch/arm/dts/uniphier-ld11.dtsi | 111 +++- arch/arm/dts/uniphier-ld20.dtsi | 188 +++++-- arch/arm/dts/uniphier-ld4.dtsi | 652 +++++++++++++--------- arch/arm/dts/uniphier-pro4-ref.dts | 10 +- arch/arm/dts/uniphier-pro4.dtsi | 903 +++++++++++++++++------------- arch/arm/dts/uniphier-pro5.dtsi | 925 +++++++++++++++++++------------ arch/arm/dts/uniphier-pxs2-gentil.dts | 2 +- arch/arm/dts/uniphier-pxs2-vodka.dts | 2 +- arch/arm/dts/uniphier-pxs2.dtsi | 878 +++++++++++++++++------------ arch/arm/dts/uniphier-sld3.dtsi | 37 +- arch/arm/dts/uniphier-sld8.dtsi | 650 +++++++++++++--------- arch/arm/mach-uniphier/dram/umc-ld20.c | 6 +- arch/arm/mach-uniphier/memconf/memconf.c | 2 +- configs/uniphier_ld11_defconfig | 1 + configs/uniphier_ld20_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + 20 files changed, 2694 insertions(+), 1855 deletions(-) delete mode 100644 arch/arm/dts/uniphier-common32.dtsi
This will be used to store the return value of readl().
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/memconf/memconf.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-uniphier/memconf/memconf.c b/arch/arm/mach-uniphier/memconf/memconf.c index 3d4b504..2a77f32 100644 --- a/arch/arm/mach-uniphier/memconf/memconf.c +++ b/arch/arm/mach-uniphier/memconf/memconf.c @@ -14,7 +14,7 @@
int memconf_init(const struct uniphier_board_data *bd) { - u32 tmp = 0; + u32 tmp; unsigned long size_per_word;
tmp = readl(SG_MEMCONF);
Just a cosmetic cleanup.
arch/arm/mach-uniphier/dram/umc-ld20.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/umc-ld20.c b/arch/arm/mach-uniphier/dram/umc-ld20.c index b8c0f59..ecbe101 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld20.c +++ b/arch/arm/mach-uniphier/dram/umc-ld20.c @@ -1,7 +1,7 @@ /* * Copyright (C) 2016 Socionext Inc. * - * based on commit a7a36122aa072fe1bb06e02b73b3634b7a6c555a of Diag + * based on commit 5e1cb0f1caeabc6c99469dd997cb6b4f46834443 of Diag * * SPDX-License-Identifier: GPL-2.0+ */ @@ -264,8 +264,8 @@ static int ddrphy_ip_dq_shift_val[DRAM_BOARD_NR][DRAM_CH_NR][32] = { static void ddrphy_select_lane(void __iomem *phy_base, unsigned int lane, unsigned int bit) { - WARN_ON(lane >= (1 << PHY_LANE_SEL_LANE_WIDTH)); - WARN_ON(bit >= (1 << PHY_LANE_SEL_BIT_WIDTH)); + WARN_ON(lane >= 1 << PHY_LANE_SEL_LANE_WIDTH); + WARN_ON(bit >= 1 << PHY_LANE_SEL_BIT_WIDTH);
writel((bit << PHY_LANE_SEL_BIT_SHIFT) | (lane << PHY_LANE_SEL_LANE_SHIFT),
Do not overwrite the memory nodes in the kernel DT where some parts of the memory region might be carved out.
configs/uniphier_ld11_defconfig | 1 + configs/uniphier_ld20_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/uniphier_ld11_defconfig b/configs/uniphier_ld11_defconfig index c0ac5ac..d8199f8 100644 --- a/configs/uniphier_ld11_defconfig +++ b/configs/uniphier_ld11_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_UNIPHIER_LD11=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld11-ref" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_XIMG is not set diff --git a/configs/uniphier_ld20_defconfig b/configs/uniphier_ld20_defconfig index 3e802d3..449093a 100644 --- a/configs/uniphier_ld20_defconfig +++ b/configs/uniphier_ld20_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_UNIPHIER_LD20=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld20-ref" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_XIMG is not set diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index b141561..8391a0a 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -8,6 +8,7 @@ CONFIG_ARCH_UNIPHIER_LD4_SLD8=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld4-ref" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig index f71ef56..c8a7573 100644 --- a/configs/uniphier_pro4_defconfig +++ b/configs/uniphier_pro4_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-pro4-ref" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index ba3867f..560b11b 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -8,6 +8,7 @@ CONFIG_ARCH_UNIPHIER_PRO5_PXS2_LD6B=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-pxs2-vodka" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/uniphier_sld3_defconfig b/configs/uniphier_sld3_defconfig index 3568f7a..7e30acc 100644 --- a/configs/uniphier_sld3_defconfig +++ b/configs/uniphier_sld3_defconfig @@ -8,6 +8,7 @@ CONFIG_ARCH_UNIPHIER_SLD3=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-sld3-ref" +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y
arch/arm/dts/uniphier-common32.dtsi | 177 ------- arch/arm/dts/uniphier-ld11.dtsi | 111 +++- arch/arm/dts/uniphier-ld20.dtsi | 188 +++++-- arch/arm/dts/uniphier-ld4.dtsi | 652 ++++++++++++++---------- arch/arm/dts/uniphier-pro4-ref.dts | 10 +- arch/arm/dts/uniphier-pro4.dtsi | 903 +++++++++++++++++++-------------- arch/arm/dts/uniphier-pro5.dtsi | 925 +++++++++++++++++++++------------- arch/arm/dts/uniphier-pxs2-gentil.dts | 2 +- arch/arm/dts/uniphier-pxs2-vodka.dts | 2 +- arch/arm/dts/uniphier-pxs2.dtsi | 878 +++++++++++++++++++------------- arch/arm/dts/uniphier-sld3.dtsi | 37 +- arch/arm/dts/uniphier-sld8.dtsi | 650 ++++++++++++++---------- 12 files changed, 2684 insertions(+), 1851 deletions(-) delete mode 100644 arch/arm/dts/uniphier-common32.dtsi
diff --git a/arch/arm/dts/uniphier-common32.dtsi b/arch/arm/dts/uniphier-common32.dtsi deleted file mode 100644 index f87e320..0000000 --- a/arch/arm/dts/uniphier-common32.dtsi +++ /dev/null @@ -1,177 +0,0 @@ -/* - * Device Tree Source commonly used by UniPhier ARM SoCs - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ X11 - */ - -/include/ "skeleton.dtsi" - -/ { - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - clocks { - refclk: ref { - #clock-cells = <0>; - compatible = "fixed-clock"; - }; - }; - - soc: soc { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges; - interrupt-parent = <&intc>; - u-boot,dm-pre-reloc; - - serial0: serial@54006800 { - compatible = "socionext,uniphier-uart"; - status = "disabled"; - reg = <0x54006800 0x40>; - interrupts = <0 33 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart0>; - clocks = <&peri_clk 0>; - }; - - serial1: serial@54006900 { - compatible = "socionext,uniphier-uart"; - status = "disabled"; - reg = <0x54006900 0x40>; - interrupts = <0 35 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - clocks = <&peri_clk 1>; - }; - - serial2: serial@54006a00 { - compatible = "socionext,uniphier-uart"; - status = "disabled"; - reg = <0x54006a00 0x40>; - interrupts = <0 37 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - clocks = <&peri_clk 2>; - }; - - serial3: serial@54006b00 { - compatible = "socionext,uniphier-uart"; - status = "disabled"; - reg = <0x54006b00 0x40>; - interrupts = <0 177 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart3>; - clocks = <&peri_clk 3>; - }; - - system_bus: system-bus@58c00000 { - compatible = "socionext,uniphier-system-bus"; - status = "disabled"; - reg = <0x58c00000 0x400>; - #address-cells = <2>; - #size-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_system_bus>; - }; - - smpctrl@59800000 { - compatible = "socionext,uniphier-smpctrl"; - reg = <0x59801000 0x400>; - }; - - mioctrl@59810000 { - compatible = "socionext,uniphier-mioctrl", - "simple-mfd", "syscon"; - reg = <0x59810000 0x800>; - u-boot,dm-pre-reloc; - - mio_clk: clock { - #clock-cells = <1>; - }; - - mio_rst: reset { - #reset-cells = <1>; - }; - }; - - perictrl@59820000 { - compatible = "socionext,uniphier-perictrl", - "simple-mfd", "syscon"; - reg = <0x59820000 0x200>; - - peri_clk: clock { - #clock-cells = <1>; - }; - - peri_rst: reset { - #reset-cells = <1>; - }; - }; - - timer@60000200 { - compatible = "arm,cortex-a9-global-timer"; - reg = <0x60000200 0x20>; - interrupts = <1 11 0x104>; - clocks = <&arm_timer_clk>; - }; - - timer@60000600 { - compatible = "arm,cortex-a9-twd-timer"; - reg = <0x60000600 0x20>; - interrupts = <1 13 0x104>; - clocks = <&arm_timer_clk>; - }; - - intc: interrupt-controller@60001000 { - compatible = "arm,cortex-a9-gic"; - reg = <0x60001000 0x1000>, - <0x60000100 0x100>; - #interrupt-cells = <3>; - interrupt-controller; - }; - - soc-glue@5f800000 { - compatible = "socionext,uniphier-soc-glue", - "simple-mfd", "syscon"; - reg = <0x5f800000 0x2000>; - u-boot,dm-pre-reloc; - - pinctrl: pinctrl { - /* specify compatible in each SoC DTSI */ - u-boot,dm-pre-reloc; - }; - }; - - sysctrl@61840000 { - compatible = "socionext,uniphier-sysctrl", - "simple-mfd", "syscon"; - reg = <0x61840000 0x4000>; - - sys_clk: clock { - #clock-cells = <1>; - }; - - sys_rst: reset { - #reset-cells = <1>; - }; - }; - - nand: nand@68000000 { - compatible = "denali,denali-nand-dt"; - status = "disabled"; - reg-names = "nand_data", "denali_reg"; - reg = <0x68000000 0x20>, <0x68100000 0x1000>; - interrupts = <0 65 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_nand>; - }; - }; -}; - -/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index a95cb6e..eef4dce 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
-/memreserve/ 0x80000000 0x00000008; /* cpu-release-addr */ +/memreserve/ 0x80000000 0x00080000;
/ { compatible = "socionext,uniphier-ld11"; @@ -34,31 +34,66 @@ device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x000>; - enable-method = "spin-table"; - cpu-release-addr = <0 0x80000000>; + clocks = <&sys_clk 33>; + enable-method = "psci"; + operating-points-v2 = <&cluster0_opp>; };
cpu1: cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x001>; - enable-method = "spin-table"; - cpu-release-addr = <0 0x80000000>; + clocks = <&sys_clk 33>; + enable-method = "psci"; + operating-points-v2 = <&cluster0_opp>; }; };
+ cluster0_opp: opp_table { + compatible = "operating-points-v2"; + opp-shared; + + opp@245000000 { + opp-hz = /bits/ 64 <245000000>; + clock-latency-ns = <300>; + }; + opp@250000000 { + opp-hz = /bits/ 64 <250000000>; + clock-latency-ns = <300>; + }; + opp@490000000 { + opp-hz = /bits/ 64 <490000000>; + clock-latency-ns = <300>; + }; + opp@500000000 { + opp-hz = /bits/ 64 <500000000>; + clock-latency-ns = <300>; + }; + opp@653334000 { + opp-hz = /bits/ 64 <653334000>; + clock-latency-ns = <300>; + }; + opp@666667000 { + opp-hz = /bits/ 64 <666667000>; + clock-latency-ns = <300>; + }; + opp@980000000 { + opp-hz = /bits/ 64 <980000000>; + clock-latency-ns = <300>; + }; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + clocks { refclk: ref { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <25000000>; }; - - i2c_clk: i2c_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <50000000>; - }; };
timer { @@ -129,7 +164,7 @@ interrupts = <0 41 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 4>; clock-frequency = <100000>; };
@@ -142,7 +177,7 @@ interrupts = <0 42 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 5>; clock-frequency = <100000>; };
@@ -152,7 +187,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 43 4>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 6>; clock-frequency = <400000>; };
@@ -165,7 +200,7 @@ interrupts = <0 44 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 7>; clock-frequency = <100000>; };
@@ -178,7 +213,7 @@ interrupts = <0 45 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c4>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 8>; clock-frequency = <100000>; };
@@ -188,7 +223,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 25 4>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 9>; clock-frequency = <400000>; };
@@ -207,8 +242,19 @@ reg = <0x59801000 0x400>; };
+ sdctrl@59810000 { + compatible = "socionext,uniphier-ld11-sdctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x400>; + + sd_rst: reset { + compatible = "socionext,uniphier-ld11-sd-reset"; + #reset-cells = <1>; + }; + }; + perictrl@59820000 { - compatible = "socionext,uniphier-perictrl", + compatible = "socionext,uniphier-ld11-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
@@ -223,6 +269,19 @@ }; };
+ emmc: sdhc@5a000000 { + compatible = "cdns,sd4hc"; + reg = <0x5a000000 0x400>; + interrupts = <0 78 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_emmc_1v8>; + clocks = <&sys_clk 4>; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + /* mmc-hs400-1_8v; support depends on board design */ + }; + usb0: usb@5a800100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; @@ -277,7 +336,7 @@ };
soc-glue@5f800000 { - compatible = "socionext,uniphier-soc-glue", + compatible = "socionext,uniphier-ld11-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; u-boot,dm-pre-reloc; @@ -305,7 +364,7 @@ sysctrl@61840000 { compatible = "socionext,uniphier-ld11-sysctrl", "simple-mfd", "syscon"; - reg = <0x61840000 0x4000>; + reg = <0x61840000 0x10000>;
sys_clk: clock { compatible = "socionext,uniphier-ld11-clock"; @@ -317,6 +376,18 @@ #reset-cells = <1>; }; }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5b"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; }; };
diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index 29a84ae..1b41945 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
/ { compatible = "socionext,uniphier-ld20"; @@ -43,47 +43,126 @@ device_type = "cpu"; compatible = "arm,cortex-a72", "arm,armv8"; reg = <0 0x000>; - enable-method = "spin-table"; - cpu-release-addr = <0 0x80000000>; + clocks = <&sys_clk 32>; + enable-method = "psci"; + operating-points-v2 = <&cluster0_opp>; };
cpu1: cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a72", "arm,armv8"; reg = <0 0x001>; - enable-method = "spin-table"; - cpu-release-addr = <0 0x80000000>; + clocks = <&sys_clk 32>; + enable-method = "psci"; + operating-points-v2 = <&cluster0_opp>; };
cpu2: cpu@100 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x100>; - enable-method = "spin-table"; - cpu-release-addr = <0 0x80000000>; + clocks = <&sys_clk 33>; + enable-method = "psci"; + operating-points-v2 = <&cluster1_opp>; };
cpu3: cpu@101 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0 0x101>; - enable-method = "spin-table"; - cpu-release-addr = <0 0x80000000>; + clocks = <&sys_clk 33>; + enable-method = "psci"; + operating-points-v2 = <&cluster1_opp>; }; };
+ cluster0_opp: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp@250000000 { + opp-hz = /bits/ 64 <250000000>; + clock-latency-ns = <300>; + }; + opp@275000000 { + opp-hz = /bits/ 64 <275000000>; + clock-latency-ns = <300>; + }; + opp@500000000 { + opp-hz = /bits/ 64 <500000000>; + clock-latency-ns = <300>; + }; + opp@550000000 { + opp-hz = /bits/ 64 <550000000>; + clock-latency-ns = <300>; + }; + opp@666667000 { + opp-hz = /bits/ 64 <666667000>; + clock-latency-ns = <300>; + }; + opp@733334000 { + opp-hz = /bits/ 64 <733334000>; + clock-latency-ns = <300>; + }; + opp@1000000000 { + opp-hz = /bits/ 64 <1000000000>; + clock-latency-ns = <300>; + }; + opp@1100000000 { + opp-hz = /bits/ 64 <1100000000>; + clock-latency-ns = <300>; + }; + }; + + cluster1_opp: opp_table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp@250000000 { + opp-hz = /bits/ 64 <250000000>; + clock-latency-ns = <300>; + }; + opp@275000000 { + opp-hz = /bits/ 64 <275000000>; + clock-latency-ns = <300>; + }; + opp@500000000 { + opp-hz = /bits/ 64 <500000000>; + clock-latency-ns = <300>; + }; + opp@550000000 { + opp-hz = /bits/ 64 <550000000>; + clock-latency-ns = <300>; + }; + opp@666667000 { + opp-hz = /bits/ 64 <666667000>; + clock-latency-ns = <300>; + }; + opp@733334000 { + opp-hz = /bits/ 64 <733334000>; + clock-latency-ns = <300>; + }; + opp@1000000000 { + opp-hz = /bits/ 64 <1000000000>; + clock-latency-ns = <300>; + }; + opp@1100000000 { + opp-hz = /bits/ 64 <1100000000>; + clock-latency-ns = <300>; + }; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + clocks { refclk: ref { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <25000000>; }; - - i2c_clk: i2c_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <50000000>; - }; };
timer { @@ -154,7 +233,7 @@ interrupts = <0 41 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 4>; clock-frequency = <100000>; };
@@ -167,7 +246,7 @@ interrupts = <0 42 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 5>; clock-frequency = <100000>; };
@@ -177,7 +256,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 43 4>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 6>; clock-frequency = <400000>; };
@@ -190,7 +269,7 @@ interrupts = <0 44 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 7>; clock-frequency = <100000>; };
@@ -203,7 +282,7 @@ interrupts = <0 45 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c4>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 8>; clock-frequency = <100000>; };
@@ -213,7 +292,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 25 4>; - clocks = <&i2c_clk>; + clocks = <&peri_clk 9>; clock-frequency = <400000>; };
@@ -232,24 +311,24 @@ reg = <0x59801000 0x400>; };
- mioctrl@59810000 { - compatible = "socionext,uniphier-mioctrl", + sdctrl@59810000 { + compatible = "socionext,uniphier-ld20-sdctrl", "simple-mfd", "syscon"; reg = <0x59810000 0x800>;
- mio_clk: clock { - compatible = "socionext,uniphier-ld20-mio-clock"; + sd_clk: clock { + compatible = "socionext,uniphier-ld20-sd-clock"; #clock-cells = <1>; };
- mio_rst: reset { - compatible = "socionext,uniphier-ld20-mio-reset"; + sd_rst: reset { + compatible = "socionext,uniphier-ld20-sd-reset"; #reset-cells = <1>; }; };
perictrl@59820000 { - compatible = "socionext,uniphier-perictrl", + compatible = "socionext,uniphier-ld20-perictrl", "simple-mfd", "syscon"; reg = <0x59820000 0x200>;
@@ -264,6 +343,19 @@ }; };
+ emmc: sdhc@5a000000 { + compatible = "cdns,sd4hc"; + reg = <0x5a000000 0x400>; + interrupts = <0 78 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_emmc_1v8>; + clocks = <&sys_clk 4>; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + /* mmc-hs400-1_8v; support depends on board design */ + }; + sd: sdhc@5a400000 { compatible = "socionext,uniphier-sdhc"; status = "disabled"; @@ -271,14 +363,15 @@ interrupts = <0 76 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_sd>; - clocks = <&mio_clk 0>; + clocks = <&sd_clk 0>; reset-names = "host"; - resets = <&mio_rst 0>; + resets = <&sd_rst 0>; bus-width = <4>; + cap-sd-highspeed; };
soc-glue@5f800000 { - compatible = "socionext,uniphier-soc-glue", + compatible = "socionext,uniphier-ld20-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; u-boot,dm-pre-reloc; @@ -304,9 +397,9 @@ };
sysctrl@61840000 { - compatible = "socionext,uniphier-sysctrl", + compatible = "socionext,uniphier-ld20-sysctrl", "simple-mfd", "syscon"; - reg = <0x61840000 0x4000>; + reg = <0x61840000 0x10000>;
sys_clk: clock { compatible = "socionext,uniphier-ld20-clock"; @@ -318,6 +411,35 @@ #reset-cells = <1>; }; }; + + usb: usb@65b00000 { + compatible = "socionext,uniphier-ld20-dwc3"; + reg = <0x65b00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb1>, + <&pinctrl_usb2>, <&pinctrl_usb3>; + dwc3@65a00000 { + compatible = "snps,dwc3"; + reg = <0x65a00000 0x10000>; + interrupts = <0 134 4>; + tx-fifo-resize; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5b"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; }; };
diff --git a/arch/arm/dts/uniphier-ld4.dtsi b/arch/arm/dts/uniphier-ld4.dtsi index 9f555df..2f8ecad 100644 --- a/arch/arm/dts/uniphier-ld4.dtsi +++ b/arch/arm/dts/uniphier-ld4.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
-/include/ "uniphier-common32.dtsi" +/include/ "skeleton.dtsi"
/ { compatible = "socionext,uniphier-ld4"; @@ -25,313 +25,439 @@ }; };
+ psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + clocks { - arm_timer_clk: arm_timer_clk { - #clock-cells = <0>; + refclk: ref { compatible = "fixed-clock"; - clock-frequency = <50000000>; + #clock-cells = <0>; + clock-frequency = <24576000>; };
- iobus_clk: iobus_clk { + arm_timer_clk: arm_timer_clk { #clock-cells = <0>; compatible = "fixed-clock"; - clock-frequency = <100000000>; + clock-frequency = <50000000>; }; }; -};
-&soc { - l2: l2-cache@500c0000 { - compatible = "socionext,uniphier-system-cache"; - reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>; - cache-unified; - cache-size = <(512 * 1024)>; - cache-sets = <256>; - cache-line-size = <128>; - cache-level = <2>; - }; + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + u-boot,dm-pre-reloc; + + l2: l2-cache@500c0000 { + compatible = "socionext,uniphier-system-cache"; + reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, + <0x506c0000 0x400>; + interrupts = <0 174 4>, <0 175 4>; + cache-unified; + cache-size = <(512 * 1024)>; + cache-sets = <256>; + cache-line-size = <128>; + cache-level = <2>; + };
- port0x: gpio@55000008 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000008 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&peri_clk 0>; + clock-frequency = <36864000>; + };
- port1x: gpio@55000010 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000010 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&peri_clk 1>; + clock-frequency = <36864000>; + };
- port2x: gpio@55000018 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000018 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + clocks = <&peri_clk 2>; + clock-frequency = <36864000>; + };
- port3x: gpio@55000020 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000020 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + interrupts = <0 29 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + clocks = <&peri_clk 3>; + clock-frequency = <36864000>; + };
- port4: gpio@55000028 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000028 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port0x: gpio@55000008 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000008 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port5x: gpio@55000030 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000030 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port1x: gpio@55000010 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000010 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port6x: gpio@55000038 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000038 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port2x: gpio@55000018 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000018 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port7x: gpio@55000040 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000040 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port3x: gpio@55000020 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000020 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port8x: gpio@55000048 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000048 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port4: gpio@55000028 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000028 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port9x: gpio@55000050 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000050 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port5x: gpio@55000030 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000030 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port10x: gpio@55000058 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000058 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port6x: gpio@55000038 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000038 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port11x: gpio@55000060 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000060 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port7x: gpio@55000040 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000040 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port12x: gpio@55000068 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000068 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port8x: gpio@55000048 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000048 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port13x: gpio@55000070 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000070 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port9x: gpio@55000050 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000050 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port14x: gpio@55000078 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000078 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port10x: gpio@55000058 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000058 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port16x: gpio@55000088 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000088 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port11x: gpio@55000060 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000060 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c0: i2c@58400000 { - compatible = "socionext,uniphier-i2c"; - status = "disabled"; - reg = <0x58400000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 41 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&iobus_clk>; - clock-frequency = <100000>; - }; + port12x: gpio@55000068 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000068 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c1: i2c@58480000 { - compatible = "socionext,uniphier-i2c"; - status = "disabled"; - reg = <0x58480000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 42 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&iobus_clk>; - clock-frequency = <100000>; - }; + port13x: gpio@55000070 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000070 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- /* chip-internal connection for DMD */ - i2c2: i2c@58500000 { - compatible = "socionext,uniphier-i2c"; - reg = <0x58500000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 43 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - clocks = <&iobus_clk>; - clock-frequency = <400000>; - }; + port14x: gpio@55000078 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000078 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c3: i2c@58580000 { - compatible = "socionext,uniphier-i2c"; - status = "disabled"; - reg = <0x58580000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 44 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&iobus_clk>; - clock-frequency = <100000>; - }; + port16x: gpio@55000088 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000088 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- sd: sdhc@5a400000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a400000 0x200>; - interrupts = <0 76 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_sd>; - pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio_clk 0>; - reset-names = "host", "bridge"; - resets = <&mio_rst 0>, <&mio_rst 3>; - bus-width = <4>; - }; + i2c0: i2c@58400000 { + compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58400000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 41 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clocks = <&peri_clk 4>; + clock-frequency = <100000>; + };
- emmc: sdhc@5a500000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a500000 0x200>; - interrupts = <0 78 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_emmc>; - pinctrl-1 = <&pinctrl_emmc_1v8>; - clocks = <&mio_clk 1>; - reset-names = "host", "bridge", "hw-reset"; - resets = <&mio_rst 1>, <&mio_rst 4>, <&mio_rst 6>; - bus-width = <8>; - non-removable; - }; + i2c1: i2c@58480000 { + compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58480000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 42 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clocks = <&peri_clk 5>; + clock-frequency = <100000>; + };
- usb0: usb@5a800100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a800100 0x100>; - interrupts = <0 80 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>; - clocks = <&mio_clk 7>, <&mio_clk 8>, <&mio_clk 12>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 8>, - <&mio_rst 12>; - }; + /* chip-internal connection for DMD */ + i2c2: i2c@58500000 { + compatible = "socionext,uniphier-i2c"; + reg = <0x58500000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 43 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clocks = <&peri_clk 6>; + clock-frequency = <400000>; + };
- usb1: usb@5a810100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a810100 0x100>; - interrupts = <0 81 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>; - clocks = <&mio_clk 7>, <&mio_clk 9>, <&mio_clk 13>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 9>, - <&mio_rst 13>; - }; + i2c3: i2c@58580000 { + compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58580000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 44 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clocks = <&peri_clk 7>; + clock-frequency = <100000>; + };
- usb2: usb@5a820100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a820100 0x100>; - interrupts = <0 82 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio_clk 7>, <&mio_clk 10>, <&mio_clk 14>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 10>, - <&mio_rst 14>; - }; + system_bus: system-bus@58c00000 { + compatible = "socionext,uniphier-system-bus"; + status = "disabled"; + reg = <0x58c00000 0x400>; + #address-cells = <2>; + #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; + };
- aidet@61830000 { - compatible = "simple-mfd", "syscon"; - reg = <0x61830000 0x200>; - }; -}; + smpctrl@59800000 { + compatible = "socionext,uniphier-smpctrl"; + reg = <0x59801000 0x400>; + };
-&refclk { - clock-frequency = <24576000>; -}; + mioctrl@59810000 { + compatible = "socionext,uniphier-ld4-mioctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x800>; + u-boot,dm-pre-reloc; + + mio_clk: clock { + compatible = "socionext,uniphier-ld4-mio-clock"; + #clock-cells = <1>; + }; + + mio_rst: reset { + compatible = "socionext,uniphier-ld4-mio-reset"; + #reset-cells = <1>; + }; + };
-&serial0 { - clock-frequency = <36864000>; -}; + perictrl@59820000 { + compatible = "socionext,uniphier-ld4-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>;
-&serial1 { - clock-frequency = <36864000>; -}; + peri_clk: clock { + compatible = "socionext,uniphier-ld4-peri-clock"; + #clock-cells = <1>; + };
-&serial2 { - clock-frequency = <36864000>; -}; + peri_rst: reset { + compatible = "socionext,uniphier-ld4-peri-reset"; + #reset-cells = <1>; + }; + };
-&serial3 { - interrupts = <0 29 4>; - clock-frequency = <36864000>; -}; + sd: sdhc@5a400000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a400000 0x200>; + interrupts = <0 76 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_sd>; + pinctrl-1 = <&pinctrl_sd_1v8>; + clocks = <&mio_clk 0>; + reset-names = "host", "bridge"; + resets = <&mio_rst 0>, <&mio_rst 3>; + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + };
-&mio_clk { - compatible = "socionext,uniphier-ld4-mio-clock"; -}; + emmc: sdhc@5a500000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a500000 0x200>; + interrupts = <0 78 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_emmc>; + pinctrl-1 = <&pinctrl_emmc_1v8>; + clocks = <&mio_clk 1>; + reset-names = "host", "bridge"; + resets = <&mio_rst 1>, <&mio_rst 4>; + bus-width = <8>; + non-removable; + cap-mmc-highspeed; + cap-mmc-hw-reset; + };
-&mio_rst { - compatible = "socionext,uniphier-ld4-mio-reset"; -}; + usb0: usb@5a800100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a800100 0x100>; + interrupts = <0 80 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + clocks = <&mio_clk 7>, <&mio_clk 8>, <&mio_clk 12>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 8>, + <&mio_rst 12>; + };
-&peri_clk { - compatible = "socionext,uniphier-ld4-peri-clock"; -}; + usb1: usb@5a810100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a810100 0x100>; + interrupts = <0 81 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>; + clocks = <&mio_clk 7>, <&mio_clk 9>, <&mio_clk 13>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 9>, + <&mio_rst 13>; + };
-&peri_rst { - compatible = "socionext,uniphier-ld4-peri-reset"; -}; + usb2: usb@5a820100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a820100 0x100>; + interrupts = <0 82 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb2>; + clocks = <&mio_clk 7>, <&mio_clk 10>, <&mio_clk 14>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 10>, + <&mio_rst 14>; + };
-&pinctrl { - compatible = "socionext,uniphier-ld4-pinctrl"; -}; + soc-glue@5f800000 { + compatible = "socionext,uniphier-ld4-soc-glue", + "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc;
-&sys_clk { - compatible = "socionext,uniphier-ld4-clock"; -}; + pinctrl: pinctrl { + compatible = "socionext,uniphier-ld4-pinctrl"; + u-boot,dm-pre-reloc; + }; + }; + + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0x104>; + clocks = <&arm_timer_clk>; + };
-&sys_rst { - compatible = "socionext,uniphier-ld4-reset"; + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0x104>; + clocks = <&arm_timer_clk>; + }; + + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + #interrupt-cells = <3>; + interrupt-controller; + }; + + aidet@61830000 { + compatible = "simple-mfd", "syscon"; + reg = <0x61830000 0x200>; + }; + + sysctrl@61840000 { + compatible = "socionext,uniphier-ld4-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x10000>; + + sys_clk: clock { + compatible = "socionext,uniphier-ld4-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-ld4-reset"; + #reset-cells = <1>; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5a"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; + }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-pro4-ref.dts b/arch/arm/dts/uniphier-pro4-ref.dts index 2d49b3e..9714fb0 100644 --- a/arch/arm/dts/uniphier-pro4-ref.dts +++ b/arch/arm/dts/uniphier-pro4-ref.dts @@ -68,15 +68,19 @@ status = "okay"; };
-&usb0 { +&usb2 { status = "okay"; };
-&usb2 { +&usb3 { status = "okay"; };
-&usb3 { +&usb0 { + status = "okay"; +}; + +&usb1 { status = "okay"; };
diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index aa80ea4..9b881f6 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
/ { compatible = "socionext,uniphier-pro4"; @@ -33,452 +33,593 @@ }; };
+ psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + clocks { + refclk: ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + arm_timer_clk: arm_timer_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <50000000>; }; + };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + u-boot,dm-pre-reloc; + + l2: l2-cache@500c0000 { + compatible = "socionext,uniphier-system-cache"; + reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, + <0x506c0000 0x400>; + interrupts = <0 174 4>, <0 175 4>; + cache-unified; + cache-size = <(768 * 1024)>; + cache-sets = <256>; + cache-line-size = <128>; + cache-level = <2>; + }; + + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&peri_clk 0>; clock-frequency = <73728000>; };
- i2c_clk: i2c_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <50000000>; + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&peri_clk 1>; + clock-frequency = <73728000>; }; - }; -};
-&soc { - l2: l2-cache@500c0000 { - compatible = "socionext,uniphier-system-cache"; - reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>; - cache-unified; - cache-size = <(768 * 1024)>; - cache-sets = <256>; - cache-line-size = <128>; - cache-level = <2>; - }; + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + clocks = <&peri_clk 2>; + clock-frequency = <73728000>; + };
- port0x: gpio@55000008 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000008 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + interrupts = <0 177 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + clocks = <&peri_clk 3>; + clock-frequency = <73728000>; + };
- port1x: gpio@55000010 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000010 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port0x: gpio@55000008 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000008 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port2x: gpio@55000018 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000018 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port1x: gpio@55000010 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000010 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port3x: gpio@55000020 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000020 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port2x: gpio@55000018 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000018 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port4: gpio@55000028 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000028 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port3x: gpio@55000020 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000020 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port5x: gpio@55000030 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000030 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port4: gpio@55000028 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000028 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port6x: gpio@55000038 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000038 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port5x: gpio@55000030 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000030 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port7x: gpio@55000040 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000040 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port6x: gpio@55000038 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000038 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port8x: gpio@55000048 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000048 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port7x: gpio@55000040 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000040 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port9x: gpio@55000050 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000050 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port8x: gpio@55000048 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000048 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port10x: gpio@55000058 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000058 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port9x: gpio@55000050 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000050 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port11x: gpio@55000060 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000060 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port10x: gpio@55000058 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000058 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port12x: gpio@55000068 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000068 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port11x: gpio@55000060 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000060 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port13x: gpio@55000070 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000070 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port12x: gpio@55000068 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000068 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port14x: gpio@55000078 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000078 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port13x: gpio@55000070 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000070 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port17x: gpio@550000a0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000a0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port14x: gpio@55000078 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000078 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port18x: gpio@550000a8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000a8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port17x: gpio@550000a0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000a0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port19x: gpio@550000b0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000b0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port18x: gpio@550000a8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000a8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port20x: gpio@550000b8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000b8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port19x: gpio@550000b0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000b0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port21x: gpio@550000c0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000c0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port20x: gpio@550000b8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000b8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port22x: gpio@550000c8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000c8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port21x: gpio@550000c0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000c0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port23x: gpio@550000d0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000d0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port22x: gpio@550000c8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000c8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port24x: gpio@550000d8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000d8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port23x: gpio@550000d0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000d0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port25x: gpio@550000e0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000e0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port24x: gpio@550000d8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000d8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port26x: gpio@550000e8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000e8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port25x: gpio@550000e0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000e0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port27x: gpio@550000f0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000f0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port26x: gpio@550000e8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000e8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port28x: gpio@550000f8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000f8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port27x: gpio@550000f0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000f0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port29x: gpio@55000100 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000100 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port28x: gpio@550000f8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000f8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port30x: gpio@55000108 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000108 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port29x: gpio@55000100 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000100 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c0: i2c@58780000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58780000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 41 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port30x: gpio@55000108 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000108 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c1: i2c@58781000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58781000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 42 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + i2c0: i2c@58780000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 41 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clocks = <&peri_clk 4>; + clock-frequency = <100000>; + };
- i2c2: i2c@58782000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58782000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 43 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + i2c1: i2c@58781000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 42 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clocks = <&peri_clk 5>; + clock-frequency = <100000>; + };
- i2c3: i2c@58783000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58783000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 44 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + i2c2: i2c@58782000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 43 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clocks = <&peri_clk 6>; + clock-frequency = <100000>; + };
- /* i2c4 does not exist */ + i2c3: i2c@58783000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 44 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clocks = <&peri_clk 7>; + clock-frequency = <100000>; + };
- /* chip-internal connection for DMD */ - i2c5: i2c@58785000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58785000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 25 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + /* i2c4 does not exist */ + + /* chip-internal connection for DMD */ + i2c5: i2c@58785000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58785000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 25 4>; + clocks = <&peri_clk 9>; + clock-frequency = <400000>; + };
- /* chip-internal connection for HDMI */ - i2c6: i2c@58786000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58786000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 26 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + /* chip-internal connection for HDMI */ + i2c6: i2c@58786000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 26 4>; + clocks = <&peri_clk 10>; + clock-frequency = <400000>; + };
- sd: sdhc@5a400000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a400000 0x200>; - interrupts = <0 76 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_sd>; - pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio_clk 0>; - reset-names = "host", "bridge"; - resets = <&mio_rst 0>, <&mio_rst 3>; - bus-width = <4>; - }; + system_bus: system-bus@58c00000 { + compatible = "socionext,uniphier-system-bus"; + status = "disabled"; + reg = <0x58c00000 0x400>; + #address-cells = <2>; + #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; + };
- emmc: sdhc@5a500000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a500000 0x200>; - interrupts = <0 78 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_emmc>; - pinctrl-1 = <&pinctrl_emmc_1v8>; - clocks = <&mio_clk 1>; - reset-names = "host", "bridge", "hw-reset"; - resets = <&mio_rst 1>, <&mio_rst 4>, <&mio_rst 6>; - bus-width = <8>; - non-removable; - }; + smpctrl@59800000 { + compatible = "socionext,uniphier-smpctrl"; + reg = <0x59801000 0x400>; + };
- sd1: sdhc@5a600000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a600000 0x200>; - interrupts = <0 85 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_sd1>; - pinctrl-1 = <&pinctrl_sd1_1v8>; - clocks = <&mio_clk 2>; - resets = <&mio_rst 2>, <&mio_rst 5>; - bus-width = <4>; - }; + mioctrl@59810000 { + compatible = "socionext,uniphier-pro4-mioctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x800>; + u-boot,dm-pre-reloc; + + mio_clk: clock { + compatible = "socionext,uniphier-pro4-mio-clock"; + #clock-cells = <1>; + }; + + mio_rst: reset { + compatible = "socionext,uniphier-pro4-mio-reset"; + #reset-cells = <1>; + }; + };
- usb2: usb@5a800100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a800100 0x100>; - interrupts = <0 80 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio_clk 7>, <&mio_clk 8>, <&mio_clk 12>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 8>, - <&mio_rst 12>; - }; + perictrl@59820000 { + compatible = "socionext,uniphier-pro4-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>;
- usb3: usb@5a810100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a810100 0x100>; - interrupts = <0 81 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb3>; - clocks = <&mio_clk 7>, <&mio_clk 9>, <&mio_clk 13>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 9>, - <&mio_rst 13>; - }; + peri_clk: clock { + compatible = "socionext,uniphier-pro4-peri-clock"; + #clock-cells = <1>; + };
- aidet@5fc20000 { - compatible = "simple-mfd", "syscon"; - reg = <0x5fc20000 0x200>; - }; + peri_rst: reset { + compatible = "socionext,uniphier-pro4-peri-reset"; + #reset-cells = <1>; + }; + };
- usb0: usb@65a00000 { - compatible = "socionext,uniphier-xhci", "generic-xhci"; - status = "disabled"; - reg = <0x65a00000 0x100>; - interrupts = <0 134 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>; - }; + sd: sdhc@5a400000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a400000 0x200>; + interrupts = <0 76 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_sd>; + pinctrl-1 = <&pinctrl_sd_1v8>; + clocks = <&mio_clk 0>; + reset-names = "host", "bridge"; + resets = <&mio_rst 0>, <&mio_rst 3>; + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + };
- usb1: usb@65c00000 { - compatible = "socionext,uniphier-xhci", "generic-xhci"; - status = "disabled"; - reg = <0x65c00000 0x100>; - interrupts = <0 137 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>; - }; -}; + emmc: sdhc@5a500000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a500000 0x200>; + interrupts = <0 78 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_emmc>; + pinctrl-1 = <&pinctrl_emmc_1v8>; + clocks = <&mio_clk 1>; + reset-names = "host", "bridge"; + resets = <&mio_rst 1>, <&mio_rst 4>; + bus-width = <8>; + non-removable; + cap-mmc-highspeed; + cap-mmc-hw-reset; + };
-&refclk { - clock-frequency = <25000000>; -}; + sd1: sdhc@5a600000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a600000 0x200>; + interrupts = <0 85 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_sd1>; + pinctrl-1 = <&pinctrl_sd1_1v8>; + clocks = <&mio_clk 2>; + resets = <&mio_rst 2>, <&mio_rst 5>; + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + };
-&serial0 { - clock-frequency = <73728000>; -}; + usb2: usb@5a800100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a800100 0x100>; + interrupts = <0 80 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb2>; + clocks = <&mio_clk 7>, <&mio_clk 8>, <&mio_clk 12>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 8>, + <&mio_rst 12>; + };
-&serial1 { - clock-frequency = <73728000>; -}; + usb3: usb@5a810100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a810100 0x100>; + interrupts = <0 81 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb3>; + clocks = <&mio_clk 7>, <&mio_clk 9>, <&mio_clk 13>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 9>, + <&mio_rst 13>; + };
-&serial2 { - clock-frequency = <73728000>; -}; + soc-glue@5f800000 { + compatible = "socionext,uniphier-pro4-soc-glue", + "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc;
-&serial3 { - clock-frequency = <73728000>; -}; + pinctrl: pinctrl { + compatible = "socionext,uniphier-pro4-pinctrl"; + u-boot,dm-pre-reloc; + }; + };
-&mio_clk { - compatible = "socionext,uniphier-pro4-mio-clock"; -}; + aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + };
-&mio_rst { - compatible = "socionext,uniphier-pro4-mio-reset"; -}; + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0x304>; + clocks = <&arm_timer_clk>; + };
-&peri_clk { - compatible = "socionext,uniphier-pro4-peri-clock"; -}; + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0x304>; + clocks = <&arm_timer_clk>; + };
-&peri_rst { - compatible = "socionext,uniphier-pro4-peri-reset"; -}; + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + #interrupt-cells = <3>; + interrupt-controller; + };
-&pinctrl { - compatible = "socionext,uniphier-pro4-pinctrl"; -}; + sysctrl@61840000 { + compatible = "socionext,uniphier-pro4-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x10000>;
-&sys_clk { - compatible = "socionext,uniphier-pro4-clock"; -}; + sys_clk: clock { + compatible = "socionext,uniphier-pro4-clock"; + #clock-cells = <1>; + };
-&sys_rst { - compatible = "socionext,uniphier-pro4-reset"; + sys_rst: reset { + compatible = "socionext,uniphier-pro4-reset"; + #reset-cells = <1>; + }; + }; + + usb0: usb@65b00000 { + compatible = "socionext,uniphier-pro4-dwc3"; + status = "disabled"; + reg = <0x65b00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + dwc3@65a00000 { + compatible = "snps,dwc3"; + reg = <0x65a00000 0x10000>; + interrupts = <0 134 4>; + tx-fifo-resize; + }; + }; + + usb1: usb@65d00000 { + compatible = "socionext,uniphier-pro4-dwc3"; + status = "disabled"; + reg = <0x65d00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>; + dwc3@65c00000 { + compatible = "snps,dwc3"; + reg = <0x65c00000 0x10000>; + interrupts = <0 137 4>; + tx-fifo-resize; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5a"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; + }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-pro5.dtsi b/arch/arm/dts/uniphier-pro5.dtsi index 97edc89..68866e1 100644 --- a/arch/arm/dts/uniphier-pro5.dtsi +++ b/arch/arm/dts/uniphier-pro5.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
/ { compatible = "socionext,uniphier-pro5"; @@ -20,433 +20,652 @@ device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0>; + clocks = <&sys_clk 32>; enable-method = "psci"; next-level-cache = <&l2>; + operating-points-v2 = <&cpu_opp>; };
cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <1>; + clocks = <&sys_clk 32>; enable-method = "psci"; next-level-cache = <&l2>; + operating-points-v2 = <&cpu_opp>; }; };
+ cpu_opp: opp_table { + compatible = "operating-points-v2"; + opp-shared; + + opp@100000000 { + opp-hz = /bits/ 64 <100000000>; + clock-latency-ns = <300>; + }; + opp@116667000 { + opp-hz = /bits/ 64 <116667000>; + clock-latency-ns = <300>; + }; + opp@150000000 { + opp-hz = /bits/ 64 <150000000>; + clock-latency-ns = <300>; + }; + opp@175000000 { + opp-hz = /bits/ 64 <175000000>; + clock-latency-ns = <300>; + }; + opp@200000000 { + opp-hz = /bits/ 64 <200000000>; + clock-latency-ns = <300>; + }; + opp@233334000 { + opp-hz = /bits/ 64 <233334000>; + clock-latency-ns = <300>; + }; + opp@300000000 { + opp-hz = /bits/ 64 <300000000>; + clock-latency-ns = <300>; + }; + opp@350000000 { + opp-hz = /bits/ 64 <350000000>; + clock-latency-ns = <300>; + }; + opp@400000000 { + opp-hz = /bits/ 64 <400000000>; + clock-latency-ns = <300>; + }; + opp@466667000 { + opp-hz = /bits/ 64 <466667000>; + clock-latency-ns = <300>; + }; + opp@600000000 { + opp-hz = /bits/ 64 <600000000>; + clock-latency-ns = <300>; + }; + opp@700000000 { + opp-hz = /bits/ 64 <700000000>; + clock-latency-ns = <300>; + }; + opp@800000000 { + opp-hz = /bits/ 64 <800000000>; + clock-latency-ns = <300>; + }; + opp@933334000 { + opp-hz = /bits/ 64 <933334000>; + clock-latency-ns = <300>; + }; + opp@1200000000 { + opp-hz = /bits/ 64 <1200000000>; + clock-latency-ns = <300>; + }; + opp@1400000000 { + opp-hz = /bits/ 64 <1400000000>; + clock-latency-ns = <300>; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + clocks { - arm_timer_clk: arm_timer_clk { - #clock-cells = <0>; + refclk: ref { compatible = "fixed-clock"; - clock-frequency = <50000000>; + #clock-cells = <0>; + clock-frequency = <20000000>; };
- i2c_clk: i2c_clk { + arm_timer_clk: arm_timer_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <50000000>; }; }; -};
-&soc { - l2: l2-cache@500c0000 { - compatible = "socionext,uniphier-system-cache"; - reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, <0x506c0000 0x400>; - interrupts = <0 190 4>, <0 191 4>; - cache-unified; - cache-size = <(2 * 1024 * 1024)>; - cache-sets = <512>; - cache-line-size = <128>; - cache-level = <2>; - next-level-cache = <&l3>; - }; + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + u-boot,dm-pre-reloc; + + l2: l2-cache@500c0000 { + compatible = "socionext,uniphier-system-cache"; + reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, + <0x506c0000 0x400>; + interrupts = <0 190 4>, <0 191 4>; + cache-unified; + cache-size = <(2 * 1024 * 1024)>; + cache-sets = <512>; + cache-line-size = <128>; + cache-level = <2>; + next-level-cache = <&l3>; + };
- l3: l3-cache@500c8000 { - compatible = "socionext,uniphier-system-cache"; - reg = <0x500c8000 0x2000>, <0x503c8100 0x8>, <0x506c8000 0x400>; - interrupts = <0 174 4>, <0 175 4>; - cache-unified; - cache-size = <(2 * 1024 * 1024)>; - cache-sets = <512>; - cache-line-size = <256>; - cache-level = <3>; - }; + l3: l3-cache@500c8000 { + compatible = "socionext,uniphier-system-cache"; + reg = <0x500c8000 0x2000>, <0x503c8100 0x8>, + <0x506c8000 0x400>; + interrupts = <0 174 4>, <0 175 4>; + cache-unified; + cache-size = <(2 * 1024 * 1024)>; + cache-sets = <512>; + cache-line-size = <256>; + cache-level = <3>; + };
- port0x: gpio@55000008 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000008 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&peri_clk 0>; + clock-frequency = <73728000>; + };
- port1x: gpio@55000010 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000010 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&peri_clk 1>; + clock-frequency = <73728000>; + };
- port2x: gpio@55000018 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000018 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + clocks = <&peri_clk 2>; + clock-frequency = <73728000>; + };
- port3x: gpio@55000020 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000020 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + interrupts = <0 177 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + clocks = <&peri_clk 3>; + clock-frequency = <73728000>; + };
- port17x: gpio@550000a0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000a0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port11x: gpio@55000060 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000060 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port18x: gpio@550000a8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000a8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port12x: gpio@55000068 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000068 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port19x: gpio@550000b0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000b0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port13x: gpio@55000070 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000070 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port20x: gpio@550000b8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000b8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port14x: gpio@55000078 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000078 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port21x: gpio@550000c0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000c0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port17x: gpio@550000a0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000a0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port22x: gpio@550000c8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000c8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port18x: gpio@550000a8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000a8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port23x: gpio@550000d0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000d0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port19x: gpio@550000b0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000b0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port24x: gpio@550000d8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000d8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port20x: gpio@550000b8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000b8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port25x: gpio@550000e0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000e0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port21x: gpio@550000c0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000c0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port26x: gpio@550000e8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000e8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port22x: gpio@550000c8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000c8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port27x: gpio@550000f0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000f0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port23x: gpio@550000d0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000d0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port28x: gpio@550000f8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000f8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port24x: gpio@550000d8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000d8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port29x: gpio@55000100 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000100 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port25x: gpio@550000e0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000e0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port30x: gpio@55000108 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000108 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port26x: gpio@550000e8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000e8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c0: i2c@58780000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58780000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 41 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port27x: gpio@550000f0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000f0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c1: i2c@58781000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58781000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 42 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port28x: gpio@550000f8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000f8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c2: i2c@58782000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58782000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 43 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port29x: gpio@55000100 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000100 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c3: i2c@58783000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58783000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 44 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port30x: gpio@55000108 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000108 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- /* i2c4 does not exist */ + i2c0: i2c@58780000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 41 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clocks = <&peri_clk 4>; + clock-frequency = <100000>; + };
- /* chip-internal connection for DMD */ - i2c5: i2c@58785000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58785000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 25 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + i2c1: i2c@58781000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 42 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clocks = <&peri_clk 5>; + clock-frequency = <100000>; + };
- /* chip-internal connection for HDMI */ - i2c6: i2c@58786000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58786000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 26 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + i2c2: i2c@58782000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 43 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clocks = <&peri_clk 6>; + clock-frequency = <100000>; + };
- aidet@5fc20000 { - compatible = "simple-mfd", "syscon"; - reg = <0x5fc20000 0x200>; - }; + i2c3: i2c@58783000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 44 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clocks = <&peri_clk 7>; + clock-frequency = <100000>; + };
- emmc: sdhc@68400000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x68400000 0x800>; - interrupts = <0 78 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_emmc>; - clocks = <&mio_clk 1>; - reset-names = "host", "hw-reset"; - resets = <&mio_rst 1>, <&mio_rst 6>; - bus-width = <8>; - non-removable; - }; + /* i2c4 does not exist */ + + /* chip-internal connection for DMD */ + i2c5: i2c@58785000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58785000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 25 4>; + clocks = <&peri_clk 9>; + clock-frequency = <400000>; + };
- sd: sdhc@68800000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x68800000 0x800>; - interrupts = <0 76 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_sd>; - pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio_clk 0>; - reset-names = "host"; - resets = <&mio_rst 0>; - bus-width = <4>; - }; + /* chip-internal connection for HDMI */ + i2c6: i2c@58786000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 26 4>; + clocks = <&peri_clk 10>; + clock-frequency = <400000>; + };
- usb0: usb@65a00000 { - compatible = "socionext,uniphier-xhci", "generic-xhci"; - status = "disabled"; - reg = <0x65a00000 0x100>; - interrupts = <0 134 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>; - }; + system_bus: system-bus@58c00000 { + compatible = "socionext,uniphier-system-bus"; + status = "disabled"; + reg = <0x58c00000 0x400>; + #address-cells = <2>; + #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; + };
- usb1: usb@65c00000 { - compatible = "socionext,uniphier-xhci", "generic-xhci"; - status = "disabled"; - reg = <0x65c00000 0x100>; - interrupts = <0 137 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb2>; - }; -}; + smpctrl@59800000 { + compatible = "socionext,uniphier-smpctrl"; + reg = <0x59801000 0x400>; + };
-&refclk { - clock-frequency = <20000000>; -}; + sdctrl@59810000 { + compatible = "socionext,uniphier-pro5-sdctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x800>; + u-boot,dm-pre-reloc; + + sd_clk: clock { + compatible = "socionext,uniphier-pro5-sd-clock"; + #clock-cells = <1>; + }; + + sd_rst: reset { + compatible = "socionext,uniphier-pro5-sd-reset"; + #reset-cells = <1>; + }; + };
-&serial0 { - clock-frequency = <73728000>; -}; + perictrl@59820000 { + compatible = "socionext,uniphier-pro5-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>;
-&serial1 { - clock-frequency = <73728000>; -}; + peri_clk: clock { + compatible = "socionext,uniphier-pro5-peri-clock"; + #clock-cells = <1>; + };
-&serial2 { - clock-frequency = <73728000>; -}; + peri_rst: reset { + compatible = "socionext,uniphier-pro5-peri-reset"; + #reset-cells = <1>; + }; + };
-&serial3 { - clock-frequency = <73728000>; -}; + soc-glue@5f800000 { + compatible = "socionext,uniphier-pro5-soc-glue", + "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc;
-&mio_clk { - compatible = "socionext,uniphier-pro5-mio-clock"; -}; + pinctrl: pinctrl { + compatible = "socionext,uniphier-pro5-pinctrl"; + u-boot,dm-pre-reloc; + }; + };
-&mio_rst { - compatible = "socionext,uniphier-pro5-mio-reset"; -}; + aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + };
-&peri_clk { - compatible = "socionext,uniphier-pro5-peri-clock"; -}; + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0x304>; + clocks = <&arm_timer_clk>; + };
-&peri_rst { - compatible = "socionext,uniphier-pro5-peri-reset"; -}; + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0x304>; + clocks = <&arm_timer_clk>; + };
-&pinctrl { - compatible = "socionext,uniphier-pro5-pinctrl"; -}; + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + #interrupt-cells = <3>; + interrupt-controller; + };
-&sys_clk { - compatible = "socionext,uniphier-pro5-clock"; -}; + sysctrl@61840000 { + compatible = "socionext,uniphier-pro5-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x10000>; + + sys_clk: clock { + compatible = "socionext,uniphier-pro5-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-pro5-reset"; + #reset-cells = <1>; + }; + }; + + usb0: usb@65b00000 { + compatible = "socionext,uniphier-pro5-dwc3"; + status = "disabled"; + reg = <0x65b00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + dwc3@65a00000 { + compatible = "snps,dwc3"; + reg = <0x65a00000 0x10000>; + interrupts = <0 134 4>; + tx-fifo-resize; + }; + };
-&sys_rst { - compatible = "socionext,uniphier-pro5-reset"; + usb1: usb@65d00000 { + compatible = "socionext,uniphier-pro5-dwc3"; + status = "disabled"; + reg = <0x65d00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb2>; + dwc3@65c00000 { + compatible = "snps,dwc3"; + reg = <0x65c00000 0x10000>; + interrupts = <0 137 4>; + tx-fifo-resize; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5b"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; + + emmc: sdhc@68400000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x68400000 0x800>; + interrupts = <0 78 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_emmc>; + clocks = <&sd_clk 1>; + reset-names = "host"; + resets = <&sd_rst 1>; + bus-width = <8>; + non-removable; + cap-mmc-highspeed; + cap-mmc-hw-reset; + no-3-3-v; + }; + + sd: sdhc@68800000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x68800000 0x800>; + interrupts = <0 76 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_sd>; + pinctrl-1 = <&pinctrl_sd_1v8>; + clocks = <&sd_clk 0>; + reset-names = "host"; + resets = <&sd_rst 0>; + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + }; + }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-pxs2-gentil.dts b/arch/arm/dts/uniphier-pxs2-gentil.dts index a98e758..0a6d46c 100644 --- a/arch/arm/dts/uniphier-pxs2-gentil.dts +++ b/arch/arm/dts/uniphier-pxs2-gentil.dts @@ -71,7 +71,7 @@ u-boot,dm-pre-reloc; };
-&mio_clk { +&sd_clk { u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/uniphier-pxs2-vodka.dts b/arch/arm/dts/uniphier-pxs2-vodka.dts index 78a52a8..770edca 100644 --- a/arch/arm/dts/uniphier-pxs2-vodka.dts +++ b/arch/arm/dts/uniphier-pxs2-vodka.dts @@ -55,7 +55,7 @@ u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index b64107b..da62070 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
/ { compatible = "socionext,uniphier-pxs2"; @@ -20,36 +20,93 @@ device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0>; + clocks = <&sys_clk 32>; enable-method = "psci"; next-level-cache = <&l2>; + operating-points-v2 = <&cpu_opp>; };
cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <2>; + clocks = <&sys_clk 32>; enable-method = "psci"; next-level-cache = <&l2>; + operating-points-v2 = <&cpu_opp>; };
cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <3>; + clocks = <&sys_clk 32>; enable-method = "psci"; next-level-cache = <&l2>; + operating-points-v2 = <&cpu_opp>; }; };
+ cpu_opp: opp_table { + compatible = "operating-points-v2"; + opp-shared; + + opp@100000000 { + opp-hz = /bits/ 64 <100000000>; + clock-latency-ns = <300>; + }; + opp@150000000 { + opp-hz = /bits/ 64 <150000000>; + clock-latency-ns = <300>; + }; + opp@200000000 { + opp-hz = /bits/ 64 <200000000>; + clock-latency-ns = <300>; + }; + opp@300000000 { + opp-hz = /bits/ 64 <300000000>; + clock-latency-ns = <300>; + }; + opp@400000000 { + opp-hz = /bits/ 64 <400000000>; + clock-latency-ns = <300>; + }; + opp@600000000 { + opp-hz = /bits/ 64 <600000000>; + clock-latency-ns = <300>; + }; + opp@800000000 { + opp-hz = /bits/ 64 <800000000>; + clock-latency-ns = <300>; + }; + opp@1200000000 { + opp-hz = /bits/ 64 <1200000000>; + clock-latency-ns = <300>; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + clocks { + refclk: ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + arm_timer_clk: arm_timer_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -62,397 +119,536 @@ clock-frequency = <50000000>; }; }; -};
-&soc { - l2: l2-cache@500c0000 { - compatible = "socionext,uniphier-system-cache"; - reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>, <0 190 4>, <0 191 4>; - cache-unified; - cache-size = <(1280 * 1024)>; - cache-sets = <512>; - cache-line-size = <128>; - cache-level = <2>; - }; + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + u-boot,dm-pre-reloc; + + l2: l2-cache@500c0000 { + compatible = "socionext,uniphier-system-cache"; + reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, + <0x506c0000 0x400>; + interrupts = <0 174 4>, <0 175 4>, <0 190 4>, <0 191 4>; + cache-unified; + cache-size = <(1280 * 1024)>; + cache-sets = <512>; + cache-line-size = <128>; + cache-level = <2>; + };
- port0x: gpio@55000008 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000008 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&peri_clk 0>; + clock-frequency = <88900000>; + };
- port1x: gpio@55000010 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000010 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&peri_clk 1>; + clock-frequency = <88900000>; + };
- port2x: gpio@55000018 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000018 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + clocks = <&peri_clk 2>; + clock-frequency = <88900000>; + };
- port3x: gpio@55000020 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000020 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + interrupts = <0 177 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + clocks = <&peri_clk 3>; + clock-frequency = <88900000>; + };
- port4: gpio@55000028 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000028 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port0x: gpio@55000008 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000008 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port5x: gpio@55000030 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000030 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port1x: gpio@55000010 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000010 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port6x: gpio@55000038 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000038 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port2x: gpio@55000018 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000018 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port7x: gpio@55000040 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000040 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port3x: gpio@55000020 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000020 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port8x: gpio@55000048 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000048 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port4: gpio@55000028 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000028 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port9x: gpio@55000050 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000050 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port5x: gpio@55000030 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000030 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port10x: gpio@55000058 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000058 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port6x: gpio@55000038 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000038 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port12x: gpio@55000068 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000068 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port7x: gpio@55000040 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000040 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port13x: gpio@55000070 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000070 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port8x: gpio@55000048 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000048 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port14x: gpio@55000078 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000078 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port9x: gpio@55000050 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000050 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port15x: gpio@55000080 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000080 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port10x: gpio@55000058 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000058 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port16x: gpio@55000088 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000088 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port12x: gpio@55000068 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000068 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port17x: gpio@550000a0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000a0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port13x: gpio@55000070 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000070 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port18x: gpio@550000a8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000a8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port14x: gpio@55000078 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000078 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port19x: gpio@550000b0 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000b0 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port15x: gpio@55000080 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000080 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port20x: gpio@550000b8 { - compatible = "socionext,uniphier-gpio"; - reg = <0x550000b8 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port16x: gpio@55000088 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000088 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c0: i2c@58780000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58780000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 41 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port25x: gpio@550000e0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000e0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c1: i2c@58781000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58781000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 42 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port26x: gpio@550000e8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000e8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c2: i2c@58782000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58782000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - interrupts = <0 43 4>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port27x: gpio@550000f0 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000f0 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c3: i2c@58783000 { - compatible = "socionext,uniphier-fi2c"; - status = "disabled"; - reg = <0x58783000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 44 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&i2c_clk>; - clock-frequency = <100000>; - }; + port28x: gpio@550000f8 { + compatible = "socionext,uniphier-gpio"; + reg = <0x550000f8 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- /* chip-internal connection for DMD */ - i2c4: i2c@58784000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58784000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 45 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + i2c0: i2c@58780000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 41 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + };
- /* chip-internal connection for STM */ - i2c5: i2c@58785000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58785000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 25 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + i2c1: i2c@58781000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 42 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + };
- /* chip-internal connection for HDMI */ - i2c6: i2c@58786000 { - compatible = "socionext,uniphier-fi2c"; - reg = <0x58786000 0x80>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 26 4>; - clocks = <&i2c_clk>; - clock-frequency = <400000>; - }; + i2c2: i2c@58782000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 43 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + };
- emmc: sdhc@5a000000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a000000 0x800>; - interrupts = <0 78 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_emmc>; - clocks = <&mio_clk 1>; - reset-names = "host", "hw-reset"; - resets = <&mio_rst 1>, <&mio_rst 6>; - bus-width = <8>; - non-removable; - }; + i2c3: i2c@58783000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 44 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + };
- sd: sdhc@5a400000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a400000 0x800>; - interrupts = <0 76 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_sd>; - pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio_clk 0>; - reset-names = "host"; - resets = <&mio_rst 0>; - bus-width = <4>; - }; + /* chip-internal connection for DMD */ + i2c4: i2c@58784000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58784000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 45 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + };
- aidet@5fc20000 { - compatible = "simple-mfd", "syscon"; - reg = <0x5fc20000 0x200>; - }; + /* chip-internal connection for STM */ + i2c5: i2c@58785000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58785000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 25 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + };
- usb0: usb@65a00000 { - compatible = "socionext,uniphier-xhci", "generic-xhci"; - status = "disabled"; - reg = <0x65a00000 0x100>; - interrupts = <0 134 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb2>; - }; + /* chip-internal connection for HDMI */ + i2c6: i2c@58786000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 26 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + };
- usb1: usb@65c00000 { - compatible = "socionext,uniphier-xhci", "generic-xhci"; - status = "disabled"; - reg = <0x65c00000 0x100>; - interrupts = <0 137 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb3>; - }; -}; + system_bus: system-bus@58c00000 { + compatible = "socionext,uniphier-system-bus"; + status = "disabled"; + reg = <0x58c00000 0x400>; + #address-cells = <2>; + #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; + };
-&refclk { - clock-frequency = <25000000>; -}; + smpctrl@59800000 { + compatible = "socionext,uniphier-smpctrl"; + reg = <0x59801000 0x400>; + };
-&serial0 { - clock-frequency = <88900000>; -}; + sdctrl@59810000 { + compatible = "socionext,uniphier-pxs2-sdctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x800>; + u-boot,dm-pre-reloc; + + sd_clk: clock { + compatible = "socionext,uniphier-pxs2-sd-clock"; + #clock-cells = <1>; + }; + + sd_rst: reset { + compatible = "socionext,uniphier-pxs2-sd-reset"; + #reset-cells = <1>; + }; + };
-&serial1 { - clock-frequency = <88900000>; -}; + perictrl@59820000 { + compatible = "socionext,uniphier-pxs2-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>;
-&serial2 { - clock-frequency = <88900000>; -}; + peri_clk: clock { + compatible = "socionext,uniphier-pxs2-peri-clock"; + #clock-cells = <1>; + };
-&serial3 { - clock-frequency = <88900000>; -}; + peri_rst: reset { + compatible = "socionext,uniphier-pxs2-peri-reset"; + #reset-cells = <1>; + }; + };
-&mio_clk { - compatible = "socionext,uniphier-pxs2-mio-clock"; -}; + emmc: sdhc@5a000000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a000000 0x800>; + interrupts = <0 78 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_emmc>; + clocks = <&sd_clk 1>; + reset-names = "host"; + resets = <&sd_rst 1>; + bus-width = <8>; + non-removable; + cap-mmc-highspeed; + cap-mmc-hw-reset; + no-3-3-v; + };
-&mio_rst { - compatible = "socionext,uniphier-pxs2-mio-reset"; -}; + sd: sdhc@5a400000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a400000 0x800>; + interrupts = <0 76 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_sd>; + pinctrl-1 = <&pinctrl_sd_1v8>; + clocks = <&sd_clk 0>; + reset-names = "host"; + resets = <&sd_rst 0>; + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + };
-&peri_clk { - compatible = "socionext,uniphier-pxs2-peri-clock"; -}; + soc-glue@5f800000 { + compatible = "socionext,uniphier-pxs2-soc-glue", + "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc;
-&peri_rst { - compatible = "socionext,uniphier-pxs2-peri-reset"; -}; + pinctrl: pinctrl { + compatible = "socionext,uniphier-pxs2-pinctrl"; + u-boot,dm-pre-reloc; + }; + };
-&pinctrl { - compatible = "socionext,uniphier-pxs2-pinctrl"; -}; + aidet@5fc20000 { + compatible = "simple-mfd", "syscon"; + reg = <0x5fc20000 0x200>; + };
-&sys_clk { - compatible = "socionext,uniphier-pxs2-clock"; -}; + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0xf04>; + clocks = <&arm_timer_clk>; + }; + + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0xf04>; + clocks = <&arm_timer_clk>; + }; + + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + #interrupt-cells = <3>; + interrupt-controller; + }; + + sysctrl@61840000 { + compatible = "socionext,uniphier-pxs2-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x4000>; + + sys_clk: clock { + compatible = "socionext,uniphier-pxs2-clock"; + #clock-cells = <1>; + };
-&sys_rst { - compatible = "socionext,uniphier-pxs2-reset"; + sys_rst: reset { + compatible = "socionext,uniphier-pxs2-reset"; + #reset-cells = <1>; + }; + }; + + usb0: usb@65b00000 { + compatible = "socionext,uniphier-pxs2-dwc3"; + status = "disabled"; + reg = <0x65b00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb2>; + dwc3@65a00000 { + compatible = "snps,dwc3"; + reg = <0x65a00000 0x10000>; + interrupts = <0 134 4>; + tx-fifo-resize; + }; + }; + + usb1: usb@65d00000 { + compatible = "socionext,uniphier-pxs2-dwc3"; + status = "disabled"; + reg = <0x65d00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>, <&pinctrl_usb3>; + dwc3@65c00000 { + compatible = "snps,dwc3"; + reg = <0x65c00000 0x10000>; + interrupts = <0 137 4>; + tx-fifo-resize; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5b"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; + }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-sld3.dtsi b/arch/arm/dts/uniphier-sld3.dtsi index f5c5487..919cbff 100644 --- a/arch/arm/dts/uniphier-sld3.dtsi +++ b/arch/arm/dts/uniphier-sld3.dtsi @@ -50,12 +50,6 @@ compatible = "fixed-clock"; clock-frequency = <50000000>; }; - - iobus_clk: iobus_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <100000000>; - }; };
soc { @@ -251,7 +245,7 @@ interrupts = <0 41 1>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&iobus_clk>; + clocks = <&sys_clk 1>; clock-frequency = <100000>; };
@@ -262,7 +256,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 42 1>; - clocks = <&iobus_clk>; + clocks = <&sys_clk 1>; clock-frequency = <100000>; };
@@ -273,7 +267,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 43 1>; - clocks = <&iobus_clk>; + clocks = <&sys_clk 1>; clock-frequency = <100000>; };
@@ -284,7 +278,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 44 1>; - clocks = <&iobus_clk>; + clocks = <&sys_clk 1>; clock-frequency = <100000>; };
@@ -295,7 +289,7 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <0 45 1>; - clocks = <&iobus_clk>; + clocks = <&sys_clk 1>; clock-frequency = <400000>; };
@@ -339,9 +333,12 @@ pinctrl-0 = <&pinctrl_emmc>; pinctrl-1 = <&pinctrl_emmc_1v8>; clocks = <&mio_clk 1>; + reset-names = "host", "bridge"; resets = <&mio_rst 1>, <&mio_rst 4>; bus-width = <8>; non-removable; + cap-mmc-highspeed; + cap-mmc-hw-reset; };
sd: sdhc@5a500000 { @@ -353,8 +350,13 @@ pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; clocks = <&mio_clk 0>; + reset-names = "host", "bridge"; resets = <&mio_rst 0>, <&mio_rst 3>; bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; };
usb0: usb@5a800100 { @@ -406,7 +408,8 @@ };
soc-glue@5f800000 { - compatible = "simple-mfd", "syscon"; + compatible = "socionext,uniphier-sld3-soc-glue", + "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; u-boot,dm-pre-reloc;
@@ -422,7 +425,7 @@ };
sysctrl@f1840000 { - compatible = "socionext,uniphier-sysctrl", + compatible = "socionext,uniphier-sld3-sysctrl", "simple-mfd", "syscon"; reg = <0xf1840000 0x4000>;
@@ -438,9 +441,13 @@ };
nand: nand@f8000000 { - compatible = "denali,denali-nand-dt"; - reg = <0xf8000000 0x20>, <0xf8100000 0x1000>; + compatible = "socionext,denali-nand-v5a"; + status = "disabled"; reg-names = "nand_data", "denali_reg"; + reg = <0xf8000000 0x20>, <0xf8100000 0x1000>; + interrupts = <0 65 4>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; }; }; }; diff --git a/arch/arm/dts/uniphier-sld8.dtsi b/arch/arm/dts/uniphier-sld8.dtsi index b8f6d67..31252a4 100644 --- a/arch/arm/dts/uniphier-sld8.dtsi +++ b/arch/arm/dts/uniphier-sld8.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ X11 */
-/include/ "uniphier-common32.dtsi" +/include/ "skeleton.dtsi"
/ { compatible = "socionext,uniphier-sld8"; @@ -25,313 +25,437 @@ }; };
+ psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + clocks { - arm_timer_clk: arm_timer_clk { - #clock-cells = <0>; + refclk: ref { compatible = "fixed-clock"; - clock-frequency = <50000000>; + #clock-cells = <0>; + clock-frequency = <25000000>; };
- iobus_clk: iobus_clk { + arm_timer_clk: arm_timer_clk { #clock-cells = <0>; compatible = "fixed-clock"; - clock-frequency = <100000000>; + clock-frequency = <50000000>; }; }; -};
-&soc { - l2: l2-cache@500c0000 { - compatible = "socionext,uniphier-system-cache"; - reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; - interrupts = <0 174 4>, <0 175 4>; - cache-unified; - cache-size = <(256 * 1024)>; - cache-sets = <256>; - cache-line-size = <128>; - cache-level = <2>; - }; + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + u-boot,dm-pre-reloc; + + l2: l2-cache@500c0000 { + compatible = "socionext,uniphier-system-cache"; + reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, + <0x506c0000 0x400>; + interrupts = <0 174 4>, <0 175 4>; + cache-unified; + cache-size = <(256 * 1024)>; + cache-sets = <256>; + cache-line-size = <128>; + cache-level = <2>; + };
- port0x: gpio@55000008 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000008 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&peri_clk 0>; + clock-frequency = <80000000>; + };
- port1x: gpio@55000010 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000010 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&peri_clk 1>; + clock-frequency = <80000000>; + };
- port2x: gpio@55000018 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000018 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + clocks = <&peri_clk 2>; + clock-frequency = <80000000>; + };
- port3x: gpio@55000020 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000020 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + interrupts = <0 29 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + clocks = <&peri_clk 3>; + clock-frequency = <80000000>; + };
- port11x: gpio@55000060 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000060 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port7x: gpio@55000040 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000040 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port12x: gpio@55000068 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000068 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port8x: gpio@55000048 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000048 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port13x: gpio@55000070 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000070 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port9x: gpio@55000050 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000050 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port14x: gpio@55000078 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000078 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port10x: gpio@55000058 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000058 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- port16x: gpio@55000088 { - compatible = "socionext,uniphier-gpio"; - reg = <0x55000088 0x8>; - gpio-controller; - #gpio-cells = <2>; - }; + port11x: gpio@55000060 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000060 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c0: i2c@58400000 { - compatible = "socionext,uniphier-i2c"; - status = "disabled"; - reg = <0x58400000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 41 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c0>; - clocks = <&iobus_clk>; - clock-frequency = <100000>; - }; + port12x: gpio@55000068 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000068 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c1: i2c@58480000 { - compatible = "socionext,uniphier-i2c"; - status = "disabled"; - reg = <0x58480000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 42 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - clocks = <&iobus_clk>; - clock-frequency = <100000>; - }; + port13x: gpio@55000070 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000070 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- /* chip-internal connection for DMD */ - i2c2: i2c@58500000 { - compatible = "socionext,uniphier-i2c"; - reg = <0x58500000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 43 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - clocks = <&iobus_clk>; - clock-frequency = <400000>; - }; + port14x: gpio@55000078 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000078 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- i2c3: i2c@58580000 { - compatible = "socionext,uniphier-i2c"; - status = "disabled"; - reg = <0x58580000 0x40>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <0 44 1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - clocks = <&iobus_clk>; - clock-frequency = <100000>; - }; + port16x: gpio@55000088 { + compatible = "socionext,uniphier-gpio"; + reg = <0x55000088 0x8>; + gpio-controller; + #gpio-cells = <2>; + };
- sd: sdhc@5a400000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - reg = <0x5a400000 0x200>; - interrupts = <0 76 4>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_sd>; - pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio_clk 0>; - reset-names = "host", "bridge"; - resets = <&mio_rst 0>, <&mio_rst 3>; - bus-width = <4>; - }; + i2c0: i2c@58400000 { + compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58400000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 41 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clocks = <&peri_clk 4>; + clock-frequency = <100000>; + };
- emmc: sdhc@5a500000 { - compatible = "socionext,uniphier-sdhc"; - status = "disabled"; - interrupts = <0 78 4>; - reg = <0x5a500000 0x200>; - pinctrl-names = "default", "1.8v"; - pinctrl-0 = <&pinctrl_emmc>; - pinctrl-1 = <&pinctrl_emmc_1v8>; - clocks = <&mio_clk 1>; - reset-names = "host", "bridge", "hw-reset"; - resets = <&mio_rst 1>, <&mio_rst 4>, <&mio_rst 6>; - bus-width = <8>; - non-removable; - }; + i2c1: i2c@58480000 { + compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58480000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 42 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clocks = <&peri_clk 5>; + clock-frequency = <100000>; + };
- usb0: usb@5a800100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a800100 0x100>; - interrupts = <0 80 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb0>; - clocks = <&mio_clk 7>, <&mio_clk 8>, <&mio_clk 12>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 8>, - <&mio_rst 12>; - }; + /* chip-internal connection for DMD */ + i2c2: i2c@58500000 { + compatible = "socionext,uniphier-i2c"; + reg = <0x58500000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 43 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clocks = <&peri_clk 6>; + clock-frequency = <400000>; + };
- usb1: usb@5a810100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a810100 0x100>; - interrupts = <0 81 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1>; - clocks = <&mio_clk 7>, <&mio_clk 9>, <&mio_clk 13>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 9>, - <&mio_rst 13>; - }; + i2c3: i2c@58580000 { + compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58580000 0x40>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 44 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clocks = <&peri_clk 7>; + clock-frequency = <100000>; + };
- usb2: usb@5a820100 { - compatible = "socionext,uniphier-ehci", "generic-ehci"; - status = "disabled"; - reg = <0x5a820100 0x100>; - interrupts = <0 82 4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio_clk 7>, <&mio_clk 10>, <&mio_clk 14>; - resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 10>, - <&mio_rst 14>; - }; + system_bus: system-bus@58c00000 { + compatible = "socionext,uniphier-system-bus"; + status = "disabled"; + reg = <0x58c00000 0x400>; + #address-cells = <2>; + #size-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_system_bus>; + };
- aidet@61830000 { - compatible = "simple-mfd", "syscon"; - reg = <0x61830000 0x200>; - }; -}; + smpctrl@59800000 { + compatible = "socionext,uniphier-smpctrl"; + reg = <0x59801000 0x400>; + };
-&refclk { - clock-frequency = <25000000>; -}; + mioctrl@59810000 { + compatible = "socionext,uniphier-sld8-mioctrl", + "simple-mfd", "syscon"; + reg = <0x59810000 0x800>;
-&serial0 { - clock-frequency = <80000000>; -}; + mio_clk: clock { + compatible = "socionext,uniphier-sld8-mio-clock"; + #clock-cells = <1>; + };
-&serial1 { - clock-frequency = <80000000>; -}; + mio_rst: reset { + compatible = "socionext,uniphier-sld8-mio-reset"; + #reset-cells = <1>; + }; + };
-&serial2 { - clock-frequency = <80000000>; -}; + perictrl@59820000 { + compatible = "socionext,uniphier-sld8-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>;
-&serial3 { - interrupts = <0 29 4>; - clock-frequency = <80000000>; -}; + peri_clk: clock { + compatible = "socionext,uniphier-sld8-peri-clock"; + #clock-cells = <1>; + };
-&mio_clk { - compatible = "socionext,uniphier-sld8-mio-clock"; -}; + peri_rst: reset { + compatible = "socionext,uniphier-sld8-peri-reset"; + #reset-cells = <1>; + }; + };
-&mio_rst { - compatible = "socionext,uniphier-sld8-mio-reset"; -}; + sd: sdhc@5a400000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a400000 0x200>; + interrupts = <0 76 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_sd>; + pinctrl-1 = <&pinctrl_sd_1v8>; + clocks = <&mio_clk 0>; + reset-names = "host", "bridge"; + resets = <&mio_rst 0>, <&mio_rst 3>; + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + };
-&peri_clk { - compatible = "socionext,uniphier-sld8-peri-clock"; -}; + emmc: sdhc@5a500000 { + compatible = "socionext,uniphier-sdhc"; + status = "disabled"; + reg = <0x5a500000 0x200>; + interrupts = <0 78 4>; + pinctrl-names = "default", "1.8v"; + pinctrl-0 = <&pinctrl_emmc>; + pinctrl-1 = <&pinctrl_emmc_1v8>; + clocks = <&mio_clk 1>; + reset-names = "host", "bridge"; + resets = <&mio_rst 1>, <&mio_rst 4>; + bus-width = <8>; + non-removable; + cap-mmc-highspeed; + cap-mmc-hw-reset; + };
-&peri_rst { - compatible = "socionext,uniphier-sld8-peri-reset"; -}; + usb0: usb@5a800100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a800100 0x100>; + interrupts = <0 80 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + clocks = <&mio_clk 7>, <&mio_clk 8>, <&mio_clk 12>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 8>, + <&mio_rst 12>; + };
-&pinctrl { - compatible = "socionext,uniphier-sld8-pinctrl"; -}; + usb1: usb@5a810100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a810100 0x100>; + interrupts = <0 81 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>; + clocks = <&mio_clk 7>, <&mio_clk 9>, <&mio_clk 13>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 9>, + <&mio_rst 13>; + };
-&sys_clk { - compatible = "socionext,uniphier-sld8-clock"; -}; + usb2: usb@5a820100 { + compatible = "socionext,uniphier-ehci", "generic-ehci"; + status = "disabled"; + reg = <0x5a820100 0x100>; + interrupts = <0 82 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb2>; + clocks = <&mio_clk 7>, <&mio_clk 10>, <&mio_clk 14>; + resets = <&sys_rst 8>, <&mio_rst 7>, <&mio_rst 10>, + <&mio_rst 14>; + }; + + soc-glue@5f800000 { + compatible = "socionext,uniphier-sld8-soc-glue", + "simple-mfd", "syscon"; + reg = <0x5f800000 0x2000>; + u-boot,dm-pre-reloc; + + pinctrl: pinctrl { + compatible = "socionext,uniphier-sld8-pinctrl"; + }; + }; + + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0x104>; + clocks = <&arm_timer_clk>; + };
-&sys_rst { - compatible = "socionext,uniphier-sld8-reset"; + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0x104>; + clocks = <&arm_timer_clk>; + }; + + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + #interrupt-cells = <3>; + interrupt-controller; + }; + + aidet@61830000 { + compatible = "simple-mfd", "syscon"; + reg = <0x61830000 0x200>; + }; + + sysctrl@61840000 { + compatible = "socionext,uniphier-sld8-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x10000>; + + sys_clk: clock { + compatible = "socionext,uniphier-sld8-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-sld8-reset"; + #reset-cells = <1>; + }; + }; + + nand: nand@68000000 { + compatible = "socionext,denali-nand-v5a"; + status = "disabled"; + reg-names = "nand_data", "denali_reg"; + reg = <0x68000000 0x20>, <0x68100000 0x1000>; + interrupts = <0 65 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand>; + clocks = <&sys_clk 2>; + nand-ecc-strength = <8>; + }; + }; }; + +/include/ "uniphier-pinctrl.dtsi"
2016-12-05 18:31 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Masahiro Yamada (4): ARM: uniphier: remove unneeded initializer ARM: uniphier: remove unneeded parentheses ARM: uniphier: disable CONFIG_ARCH_FIXUP_FDT_MEMORY ARM: dts: uniphier: sync Device Tree with Linux
Applied to u-boot-uniphier/master.
Masahiro Yamada
