[U-Boot] [PATCH 1/4] usb: Remove unused ppc4xx EHCI host driver
ppc4xx support was removed some time ago. Lets remove the now unused EHCI driver and all its references for this platform as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Marek Vasut marex@denx.de --- drivers/usb/host/Makefile | 1 - drivers/usb/host/ehci-ppc4xx.c | 35 ----------------------------------- 2 files changed, 36 deletions(-) delete mode 100644 drivers/usb/host/ehci-ppc4xx.c
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 7f9ba24cfe..98194893b9 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -35,7 +35,6 @@ obj-$(CONFIG_USB_EHCI_MX5) += ehci-mx5.o obj-$(CONFIG_USB_EHCI_MX6) += ehci-mx6.o obj-$(CONFIG_USB_EHCI_MX7) += ehci-mx6.o obj-$(CONFIG_USB_EHCI_OMAP) += ehci-omap.o -obj-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o obj-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o obj-$(CONFIG_USB_EHCI_MSM) += ehci-msm.o obj-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o diff --git a/drivers/usb/host/ehci-ppc4xx.c b/drivers/usb/host/ehci-ppc4xx.c deleted file mode 100644 index 9d23577642..0000000000 --- a/drivers/usb/host/ehci-ppc4xx.c +++ /dev/null @@ -1,35 +0,0 @@ -/* - * (C) Copyright 2010, Chris Zhang chris@seamicro.com - * - * Author: Chris Zhang chris@seamicro.com - * This code is based on ehci freescale driver - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#include <common.h> -#include <usb.h> -#include <asm/io.h> - -#include "ehci.h" - -/* - * Create the appropriate control structures to manage - * a new EHCI host controller. - */ -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - *hccr = (struct ehci_hccr *)(CONFIG_SYS_PPC4XX_USB_ADDR); - *hcor = (struct ehci_hcor *)((uint32_t) *hccr + - HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); - return 0; -} - -/* - * Destroy the appropriate control structures corresponding - * the the EHCI host controller. - */ -int ehci_hcd_stop(int index) -{ - return 0; -}
ppc4xx support was removed some time ago. Lets remove the now unused NAND driver and all its references for this platform as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Scott Wood oss@buserror.net --- drivers/mtd/nand/Makefile | 1 - drivers/mtd/nand/nand_ecc.c | 16 ---- drivers/mtd/nand/ndfc.c | 200 ------------------------------------------- scripts/config_whitelist.txt | 2 - 4 files changed, 219 deletions(-) delete mode 100644 drivers/mtd/nand/ndfc.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 9f7d9d6ff7..332d905a3a 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -57,7 +57,6 @@ obj-$(CONFIG_NAND_LPC32XX_SLC) += lpc32xx_nand_slc.o obj-$(CONFIG_NAND_VF610_NFC) += vf610_nfc.o obj-$(CONFIG_NAND_MXC) += mxc_nand.o obj-$(CONFIG_NAND_MXS) += mxs_nand.o -obj-$(CONFIG_NAND_NDFC) += ndfc.o obj-$(CONFIG_NAND_PXA3XX) += pxa3xx_nand.o obj-$(CONFIG_NAND_SPEAR) += spr_nand.o obj-$(CONFIG_TEGRA_NAND) += tegra_nand.o diff --git a/drivers/mtd/nand/nand_ecc.c b/drivers/mtd/nand/nand_ecc.c index 8b548b204d..13a6535bd5 100644 --- a/drivers/mtd/nand/nand_ecc.c +++ b/drivers/mtd/nand/nand_ecc.c @@ -29,11 +29,6 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/nand_ecc.h>
-/* The PPC4xx NDFC uses Smart Media (SMC) bytes order */ -#ifdef CONFIG_NAND_NDFC -#define CONFIG_MTD_NAND_ECC_SMC -#endif - /* * NAND-SPL has no sofware ECC for now, so don't include nand_calculate_ecc(), * only nand_correct_data() is needed @@ -110,13 +105,8 @@ int nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, tmp2 |= (reg2 & 0x01) << 0; /* B7 -> B0 */
/* Calculate final ECC code */ -#ifdef CONFIG_MTD_NAND_ECC_SMC - ecc_code[0] = ~tmp2; - ecc_code[1] = ~tmp1; -#else ecc_code[0] = ~tmp1; ecc_code[1] = ~tmp2; -#endif ecc_code[2] = ((~reg1) << 2) | 0x03;
return 0; @@ -146,15 +136,9 @@ int nand_correct_data(struct mtd_info *mtd, u_char *dat, { uint8_t s0, s1, s2;
-#ifdef CONFIG_MTD_NAND_ECC_SMC - s0 = calc_ecc[0] ^ read_ecc[0]; - s1 = calc_ecc[1] ^ read_ecc[1]; - s2 = calc_ecc[2] ^ read_ecc[2]; -#else s1 = calc_ecc[0] ^ read_ecc[0]; s0 = calc_ecc[1] ^ read_ecc[1]; s2 = calc_ecc[2] ^ read_ecc[2]; -#endif if ((s0 | s1 | s2) == 0) return 0;
diff --git a/drivers/mtd/nand/ndfc.c b/drivers/mtd/nand/ndfc.c deleted file mode 100644 index 0a9849e9bc..0000000000 --- a/drivers/mtd/nand/ndfc.c +++ /dev/null @@ -1,200 +0,0 @@ -/* - * Overview: - * Platform independent driver for NDFC (NanD Flash Controller) - * integrated into IBM/AMCC PPC4xx cores - * - * (C) Copyright 2006-2009 - * Stefan Roese, DENX Software Engineering, sr@denx.de. - * - * Based on original work by - * Thomas Gleixner - * Copyright 2006 IBM - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <nand.h> -#include <linux/mtd/ndfc.h> -#include <linux/mtd/nand_ecc.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <asm/ppc4xx.h> - -#ifndef CONFIG_SYS_NAND_BCR -#define CONFIG_SYS_NAND_BCR 0x80002222 -#endif -#ifndef CONFIG_SYS_NDFC_EBC0_CFG -#define CONFIG_SYS_NDFC_EBC0_CFG 0xb8400000 -#endif - -/* - * We need to store the info, which chip-select (CS) is used for the - * chip number. For example on Sequoia NAND chip #0 uses - * CS #3. - */ -static int ndfc_cs[NDFC_MAX_BANKS]; - -static void ndfc_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) -{ - struct nand_chip *this = mtd_to_nand(mtd); - ulong base = (ulong) this->IO_ADDR_W & 0xffffff00; - - if (cmd == NAND_CMD_NONE) - return; - - if (ctrl & NAND_CLE) - out_8((u8 *)(base + NDFC_CMD), cmd & 0xFF); - else - out_8((u8 *)(base + NDFC_ALE), cmd & 0xFF); -} - -static int ndfc_dev_ready(struct mtd_info *mtdinfo) -{ - struct nand_chip *this = mtd_to_nand(mtdinfo); - ulong base = (ulong) this->IO_ADDR_W & 0xffffff00; - - return (in_be32((u32 *)(base + NDFC_STAT)) & NDFC_STAT_IS_READY); -} - -static void ndfc_enable_hwecc(struct mtd_info *mtdinfo, int mode) -{ - struct nand_chip *this = mtd_to_nand(mtdinfo); - ulong base = (ulong) this->IO_ADDR_W & 0xffffff00; - u32 ccr; - - ccr = in_be32((u32 *)(base + NDFC_CCR)); - ccr |= NDFC_CCR_RESET_ECC; - out_be32((u32 *)(base + NDFC_CCR), ccr); -} - -static int ndfc_calculate_ecc(struct mtd_info *mtdinfo, - const u_char *dat, u_char *ecc_code) -{ - struct nand_chip *this = mtd_to_nand(mtdinfo); - ulong base = (ulong) this->IO_ADDR_W & 0xffffff00; - u32 ecc; - u8 *p = (u8 *)&ecc; - - ecc = in_be32((u32 *)(base + NDFC_ECC)); - - /* The NDFC uses Smart Media (SMC) bytes order - */ - ecc_code[0] = p[1]; - ecc_code[1] = p[2]; - ecc_code[2] = p[3]; - - return 0; -} - -/* - * Speedups for buffer read/write/verify - * - * NDFC allows 32bit read/write of data. So we can speed up the buffer - * functions. No further checking, as nand_base will always read/write - * page aligned. - */ -static void ndfc_read_buf(struct mtd_info *mtdinfo, uint8_t *buf, int len) -{ - struct nand_chip *this = mtd_to_nand(mtdinfo); - ulong base = (ulong) this->IO_ADDR_W & 0xffffff00; - uint32_t *p = (uint32_t *) buf; - - for (;len > 0; len -= 4) - *p++ = in_be32((u32 *)(base + NDFC_DATA)); -} - -/* - * Don't use these speedup functions in NAND boot image, since the image - * has to fit into 4kByte. - */ -static void ndfc_write_buf(struct mtd_info *mtdinfo, const uint8_t *buf, int len) -{ - struct nand_chip *this = mtd_to_nand(mtdinfo); - ulong base = (ulong) this->IO_ADDR_W & 0xffffff00; - uint32_t *p = (uint32_t *) buf; - - for (; len > 0; len -= 4) - out_be32((u32 *)(base + NDFC_DATA), *p++); -} - -/* - * Read a byte from the NDFC. - */ -static uint8_t ndfc_read_byte(struct mtd_info *mtd) -{ - - struct nand_chip *chip = mtd_to_nand(mtd); - -#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT - return (uint8_t) readw(chip->IO_ADDR_R); -#else - return readb(chip->IO_ADDR_R); -#endif - -} - -void board_nand_select_device(struct nand_chip *nand, int chip) -{ - /* - * Don't use "chip" to address the NAND device, - * generate the cs from the address where it is encoded. - */ - ulong base = (ulong)nand->IO_ADDR_W & 0xffffff00; - int cs = ndfc_cs[chip]; - - /* Set NandFlash Core Configuration Register */ - /* 1 col x 2 rows */ - out_be32((u32 *)(base + NDFC_CCR), 0x00000000 | (cs << 24)); - out_be32((u32 *)(base + NDFC_BCFG0 + (cs << 2)), CONFIG_SYS_NAND_BCR); -} - -static void ndfc_select_chip(struct mtd_info *mtd, int chip) -{ - /* - * Nothing to do here! - */ -} - -int board_nand_init(struct nand_chip *nand) -{ - int cs = (ulong)nand->IO_ADDR_W & 0x00000003; - ulong base = (ulong)nand->IO_ADDR_W & 0xffffff00; - static int chip = 0; - - /* - * Save chip-select for this chip # - */ - ndfc_cs[chip] = cs; - - /* - * Select required NAND chip in NDFC - */ - board_nand_select_device(nand, chip); - - nand->IO_ADDR_R = (void __iomem *)(base + NDFC_DATA); - nand->IO_ADDR_W = (void __iomem *)(base + NDFC_DATA); - nand->cmd_ctrl = ndfc_hwcontrol; - nand->chip_delay = 50; - nand->read_buf = ndfc_read_buf; - nand->dev_ready = ndfc_dev_ready; - nand->ecc.correct = nand_correct_data; - nand->ecc.hwctl = ndfc_enable_hwecc; - nand->ecc.calculate = ndfc_calculate_ecc; - nand->ecc.mode = NAND_ECC_HW; - nand->ecc.size = 256; - nand->ecc.bytes = 3; - nand->ecc.strength = 1; - nand->select_chip = ndfc_select_chip; - -#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT - nand->options |= NAND_BUSWIDTH_16; -#endif - - nand->write_buf = ndfc_write_buf; - nand->read_byte = ndfc_read_byte; - - chip++; - - return 0; -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3606585c05..0ae6ec77c5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1335,7 +1335,6 @@ CONFIG_MSHC_FREQ CONFIG_MTD_CONCAT CONFIG_MTD_DEVICE CONFIG_MTD_ECC_SOFT -CONFIG_MTD_NAND_ECC_SMC CONFIG_MTD_NAND_MUSEUM_IDS CONFIG_MTD_NAND_VERIFY_WRITE CONFIG_MTD_ONENAND_VERIFY_WRITE @@ -1416,7 +1415,6 @@ CONFIG_NAND_LPC32XX_MLC CONFIG_NAND_LPC32XX_SLC CONFIG_NAND_MODE_REG CONFIG_NAND_MXC_V1_1 -CONFIG_NAND_NDFC CONFIG_NAND_OMAP_ECCSCHEME CONFIG_NAND_OMAP_GPMC_WSCFG CONFIG_NAND_SECBOOT
ppc4xx support was removed some time ago. Lets remove the now unused "pci_fb" variable from "struct pci_controller" as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org --- include/pci.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/pci.h b/include/pci.h index 7adc04301c..31dc7608a7 100644 --- a/include/pci.h +++ b/include/pci.h @@ -585,8 +585,6 @@ struct pci_controller { /* Used by auto config */ struct pci_region *pci_mem, *pci_io, *pci_prefetch;
- /* Used by ppc405 autoconfig*/ - struct pci_region *pci_fb; #ifndef CONFIG_DM_PCI int current_busno;
ppc4xx support was removed some time ago. Lets remove the now unused entry in MAINTAINERS as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Heinrich Schuchardt xypron.glpk@gmx.de --- MAINTAINERS | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index d5059f611d..dd9df8fd07 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -426,12 +426,6 @@ S: Maintained T: git git://git.denx.de/u-boot-mpc86xx.git F: arch/powerpc/cpu/mpc86xx/
-POWERPC PPC4XX -M: Stefan Roese sr@denx.de -S: Maintained -T: git git://git.denx.de/u-boot-ppc4xx.git -F: arch/powerpc/cpu/ppc4xx/ - RISC-V M: Rick Chen rick@andestech.com S: Maintained
Sad ... applied, thanks
Stefan Roese
