[U-Boot] [PATCH] arm: socfpga: imply SPL options instead of select
For a small SPL, it should be possible to build without SPI(-flash) drivers or wihout MMC drivers.
For this to work, we have to change from 'select'ing options to 'imply'ing them.
With this change, I can have SPL trimmed to my hard-wired starting method (SPI-NOR or MMC) while still including all drivers in U-Boot.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
arch/arm/Kconfig | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 96eadb6fd6..d0acb5a622 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -816,15 +816,11 @@ config ARCH_SOCFPGA select SPL_DM_RESET if DM_RESET select SPL_DM_SERIAL select SPL_LIBCOMMON_SUPPORT - select SPL_LIBDISK_SUPPORT select SPL_LIBGENERIC_SUPPORT - select SPL_MMC_SUPPORT if DM_MMC select SPL_NAND_SUPPORT if SPL_NAND_DENALI select SPL_OF_CONTROL select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 select SPL_SERIAL_SUPPORT - select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT - select SPL_SPI_SUPPORT if DM_SPI select SPL_WATCHDOG_SUPPORT select SUPPORT_SPL select SYS_NS16550 @@ -835,8 +831,12 @@ config ARCH_SOCFPGA imply DM_SPI imply DM_SPI_FLASH imply FAT_WRITE + imply SPL_LIBDISK_SUPPORT + imply SPL_MMC_SUPPORT imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE + imply SPL_SPI_FLASH_SUPPORT + imply SPL_SPI_SUPPORT
config ARCH_SUNXI bool "Support sunxi (Allwinner) SoCs"
Applied, thanks.
Simon Goldschmidt
