[U-Boot] [PATCH] powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up.
All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk
We do not need to have both of them. This commit keeps only CONFIG_MPC8260.
This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
This commit edits lots of files. So I built all PowerPC boards and compared MD5SUM to confirm the same binaries should still be produced with or without this patch.
api/api_platform-powerpc.c | 2 +- arch/powerpc/cpu/mpc8260/config.mk | 2 +- arch/powerpc/cpu/mpc8260/kgdb.S | 2 -- arch/powerpc/cpu/mpc8260/start.S | 2 -- arch/powerpc/include/asm/processor.h | 2 +- arch/powerpc/include/asm/status_led.h | 2 +- arch/powerpc/include/asm/u-boot.h | 2 +- arch/powerpc/lib/board.c | 6 ++--- arch/powerpc/lib/kgdb.c | 10 ++++---- board/cogent/mb.c | 4 ++-- board/cogent/serial.c | 2 +- board/hymod/hymod.h | 2 +- common/board_f.c | 6 ++--- common/cmd_bdinfo.c | 2 +- common/cmd_immap.c | 44 +++++++++++++++++------------------ examples/standalone/Makefile | 2 +- include/asm-generic/u-boot.h | 2 +- include/common.h | 11 ++++----- include/configs/CPU86.h | 1 - include/configs/CPU87.h | 1 - include/configs/IDS8247.h | 1 - include/configs/IPHASE4539.h | 1 - include/configs/ISPAN.h | 1 - include/configs/MPC8260ADS.h | 2 -- include/configs/MPC8266ADS.h | 1 - include/configs/PM826.h | 1 - include/configs/PM828.h | 1 - include/configs/RPXsuper.h | 1 - include/configs/Rattler.h | 1 - include/configs/TQM8260.h | 1 - include/configs/TQM8272.h | 1 - include/configs/ZPC1900.h | 1 - include/configs/atc.h | 1 - include/configs/ep8260.h | 1 - include/configs/ep82xxm.h | 1 - include/configs/gw8260.h | 1 - include/configs/hymod.h | 1 - include/configs/muas3001.h | 2 -- include/configs/ppmc8260.h | 1 - include/configs/rsdproto.h | 1 - include/configs/sacsng.h | 1 - include/ppc_asm.tmpl | 2 +- 42 files changed, 50 insertions(+), 82 deletions(-)
diff --git a/api/api_platform-powerpc.c b/api/api_platform-powerpc.c index eb421d6..f23f175 100644 --- a/api/api_platform-powerpc.c +++ b/api/api_platform-powerpc.c @@ -30,7 +30,7 @@ int platform_sys_info(struct sys_info *si) si->clk_bus = gd->bus_clk; si->clk_cpu = gd->cpu_clk;
-#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_8260) || \ +#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_MPC8260) || \ defined(CONFIG_E500) || defined(CONFIG_MPC86xx) #define bi_bar bi_immr_base #elif defined(CONFIG_MPC5xxx) diff --git a/arch/powerpc/cpu/mpc8260/config.mk b/arch/powerpc/cpu/mpc8260/config.mk index dfac710..59f152d 100644 --- a/arch/powerpc/cpu/mpc8260/config.mk +++ b/arch/powerpc/cpu/mpc8260/config.mk @@ -5,5 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-PLATFORM_CPPFLAGS += -DCONFIG_8260 -DCONFIG_CPM2 \ +PLATFORM_CPPFLAGS += -DCONFIG_MPC8260 -DCONFIG_CPM2 \ -mstring -mcpu=603e -mmultiple diff --git a/arch/powerpc/cpu/mpc8260/kgdb.S b/arch/powerpc/cpu/mpc8260/kgdb.S index dd04d6b..1432344 100644 --- a/arch/powerpc/cpu/mpc8260/kgdb.S +++ b/arch/powerpc/cpu/mpc8260/kgdb.S @@ -9,8 +9,6 @@ #include <mpc8260.h> #include <version.h>
-#define CONFIG_8260 1 /* needed for Linux kernel header files */ - #include <ppc_asm.tmpl> #include <ppc_defs.h>
diff --git a/arch/powerpc/cpu/mpc8260/start.S b/arch/powerpc/cpu/mpc8260/start.S index 65510fa..324f132 100644 --- a/arch/powerpc/cpu/mpc8260/start.S +++ b/arch/powerpc/cpu/mpc8260/start.S @@ -14,8 +14,6 @@ #include <mpc8260.h> #include <version.h>
diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 831804c..72f30fe 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1356,7 +1356,7 @@ void _nmask_and_or_msr(unsigned long nmask, unsigned long or_val); #elif defined(CONFIG_GEMINI) #define _machine _MACH_gemini #define have_of 0 -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) #define _machine _MACH_8260 #define have_of 0 #elif defined(CONFIG_SANDPOINT) diff --git a/arch/powerpc/include/asm/status_led.h b/arch/powerpc/include/asm/status_led.h index 0375709..4416190 100644 --- a/arch/powerpc/include/asm/status_led.h +++ b/arch/powerpc/include/asm/status_led.h @@ -11,7 +11,7 @@ #ifndef CONFIG_BOARD_SPECIFIC_LED # if defined(CONFIG_8xx) # include <mpc8xx.h> -# elif defined(CONFIG_8260) +# elif defined(CONFIG_MPC8260) # include <mpc8260.h> # elif defined(CONFIG_5xx) # include <mpc5xx.h> diff --git a/arch/powerpc/include/asm/u-boot.h b/arch/powerpc/include/asm/u-boot.h index 5916f7c..3c28420 100644 --- a/arch/powerpc/include/asm/u-boot.h +++ b/arch/powerpc/include/asm/u-boot.h @@ -35,7 +35,7 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ -#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_8260) \ +#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_MPC8260) \ || defined(CONFIG_E500) || defined(CONFIG_MPC86xx) unsigned long bi_immr_base; /* base of IMMR register */ #endif diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 13d761c..f86c6f3 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -277,10 +277,10 @@ static init_fnc_t *init_sequence[] = { serial_init, console_init_f, display_options, -#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) prt_8260_rsr, prt_8260_clks, -#endif /* CONFIG_8260 */ +#endif /* CONFIG_MPC8260 */ #if defined(CONFIG_MPC83xx) prt_83xx_rsr, #endif @@ -504,7 +504,7 @@ void board_init_f(ulong bootflag) bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE; /* size of SRAM */ #endif
-#if defined(CONFIG_8xx) || defined(CONFIG_8260) || defined(CONFIG_5xx) || \ +#if defined(CONFIG_8xx) || defined(CONFIG_MPC8260) || defined(CONFIG_5xx) || \ defined(CONFIG_E500) || defined(CONFIG_MPC86xx) bd->bi_immr_base = CONFIG_SYS_IMMR; /* base of IMMR register */ #endif diff --git a/arch/powerpc/lib/kgdb.c b/arch/powerpc/lib/kgdb.c index 19a56db..01a7708 100644 --- a/arch/powerpc/lib/kgdb.c +++ b/arch/powerpc/lib/kgdb.c @@ -159,7 +159,7 @@ kgdb_trap(struct pt_regs *regs)
#define SPACE_REQUIRED ((32*4)+(32*8)+(6*4))
-#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 /* store floating double indexed */ #define STFDI(n,p) __asm__ __volatile__ ("stfd " #n ",%0" : "=o"(p[2*n])) /* store floating double multiple */ @@ -190,7 +190,7 @@ kgdb_getregs(struct pt_regs *regs, char *buf, int max) *ptr++ = regs->gpr[i];
/* Floating Point Regs */ -#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 STFDM(ptr); ptr += 32*2; #else @@ -213,7 +213,7 @@ kgdb_getregs(struct pt_regs *regs, char *buf, int max)
/* set the value of the CPU registers */
-#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 /* load floating double */ #define LFD(n,v) __asm__ __volatile__ ("lfd " #n ",%0" :: "o"(v)) /* load floating double indexed */ @@ -252,7 +252,7 @@ kgdb_putreg(struct pt_regs *regs, int regno, char *buf, int length) regs->gpr[regno] = *ptr; else switch (regno) {
-#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 #define caseF(n) \ case (n) + 32: LFD(n, *ptr); break;
@@ -298,7 +298,7 @@ kgdb_putregs(struct pt_regs *regs, char *buf, int length) regs->gpr[i] = *ptr++;
/* Floating Point Regs */ -#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 LFDM(ptr); #endif ptr += 32*2; diff --git a/board/cogent/mb.c b/board/cogent/mb.c index 3eea47d..c025643 100644 --- a/board/cogent/mb.c +++ b/board/cogent/mb.c @@ -14,7 +14,7 @@
#include <ioports.h>
@@ -186,7 +186,7 @@ const iop_conf_t iop_conf_tab[4][32] = { } };
diff --git a/board/cogent/serial.c b/board/cogent/serial.c index f0d6b22..95c8120 100644 --- a/board/cogent/serial.c +++ b/board/cogent/serial.c @@ -13,7 +13,7 @@ DECLARE_GLOBAL_DATA_PTR; #if (CMA_MB_CAPS & CMA_MB_CAP_SERPAR)
#if (defined(CONFIG_8xx) && defined(CONFIG_8xx_CONS_NONE)) || \ - (defined(CONFIG_8260) && defined(CONFIG_CONS_NONE)) + (defined(CONFIG_MPC8260) && defined(CONFIG_CONS_NONE))
#if CONFIG_CONS_INDEX == 1 #define CMA_MB_SERIAL_BASE CMA_MB_SERIALA_BASE diff --git a/board/hymod/hymod.h b/board/hymod/hymod.h index 3ab3794..7024d8a 100644 --- a/board/hymod/hymod.h +++ b/board/hymod/hymod.h @@ -8,7 +8,7 @@ #ifndef _HYMOD_H_ #define _HYMOD_H_
-#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 #include <asm/iopin_8260.h> #endif
diff --git a/common/board_f.c b/common/board_f.c index e591a0e..4856975 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -642,7 +642,7 @@ static int setup_board_part1(void) bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE; /* size of SRAM */ #endif
-#if defined(CONFIG_8xx) || defined(CONFIG_8260) || defined(CONFIG_5xx) || \ +#if defined(CONFIG_8xx) || defined(CONFIG_MPC8260) || defined(CONFIG_5xx) || \ defined(CONFIG_E500) || defined(CONFIG_MPC86xx) bd->bi_immr_base = CONFIG_SYS_IMMR; /* base of IMMR register */ #endif @@ -858,10 +858,10 @@ static init_fnc_t init_sequence_f[] = { #endif display_options, /* say that we are here */ display_text_info, /* show debugging info if required */ -#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) prt_8260_rsr, prt_8260_clks, -#endif /* CONFIG_8260 */ +#endif /* CONFIG_MPC8260 */ #if defined(CONFIG_MPC83xx) prt_83xx_rsr, #endif diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 15119a7..238cadb 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -88,7 +88,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) print_num("sramstart", bd->bi_sramstart); print_num("sramsize", bd->bi_sramsize); #if defined(CONFIG_5xx) || defined(CONFIG_8xx) || \ - defined(CONFIG_8260) || defined(CONFIG_E500) + defined(CONFIG_MPC8260) || defined(CONFIG_E500) print_num("immr_base", bd->bi_immr_base); #endif print_num("bootflags", bd->bi_bootflags); diff --git a/common/cmd_immap.c b/common/cmd_immap.c index bdf53a4..1414f9a 100644 --- a/common/cmd_immap.c +++ b/common/cmd_immap.c @@ -12,13 +12,13 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_8xx) || defined(CONFIG_8260) +#if defined(CONFIG_8xx) || defined(CONFIG_MPC8260)
#if defined(CONFIG_8xx) #include <asm/8xx_immap.h> #include <commproc.h> #include <asm/iopin_8xx.h> -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) #include <asm/immap_8260.h> #include <asm/cpm_8260.h> #include <asm/iopin_8260.h> @@ -40,7 +40,7 @@ do_siuinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_8xx) volatile sysconf8xx_t *sc = &immap->im_siu_conf; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) volatile sysconf8260_t *sc = &immap->im_siu_conf; #endif
@@ -50,7 +50,7 @@ do_siuinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf ("SIPEND= %08x SIMASK= %08x\n", sc->sc_sipend, sc->sc_simask); printf ("SIEL = %08x SIVEC = %08x\n", sc->sc_siel, sc->sc_sivec); printf ("TESR = %08x SDCR = %08x\n", sc->sc_tesr, sc->sc_sdcr); -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) printf ("BCR = %08x\n", sc->sc_bcr); printf ("P_ACR = %02x P_ALRH= %08x P_ALRL= %08x\n", sc->sc_ppc_acr, sc->sc_ppc_alrh, sc->sc_ppc_alrl); @@ -72,7 +72,7 @@ do_memcinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_8xx) volatile memctl8xx_t *memctl = &immap->im_memctl; int nbanks = 8; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) volatile memctl8260_t *memctl = &immap->im_memctl; int nbanks = 12; #endif @@ -92,19 +92,19 @@ do_memcinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf ("MAR = %08x", memctl->memc_mar); #if defined(CONFIG_8xx) printf (" MCR = %08x\n", memctl->memc_mcr); -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) putc ('\n'); #endif printf ("MAMR = %08x MBMR = %08x", memctl->memc_mamr, memctl->memc_mbmr); #if defined(CONFIG_8xx) printf ("\nMSTAT = %04x\n", memctl->memc_mstat); -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) printf (" MCMR = %08x\n", memctl->memc_mcmr); #endif printf ("MPTPR = %04x MDR = %08x\n", memctl->memc_mptpr, memctl->memc_mdr); -#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) printf ("PSDMR = %08x LSDMR = %08x\n", memctl->memc_psdmr, memctl->memc_lsdmr); printf ("PURT = %02x PSRT = %02x\n", @@ -123,7 +123,7 @@ do_sitinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
-#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 int do_icinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -139,7 +139,7 @@ do_carinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_8xx) volatile car8xx_t *car = &immap->im_clkrst; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) volatile car8260_t *car = &immap->im_clkrst; #endif
@@ -147,7 +147,7 @@ do_carinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf ("SCCR = %08x\n", car->car_sccr); printf ("PLPRCR= %08x\n", car->car_plprcr); printf ("RSR = %08x\n", car->car_rsr); -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) printf ("SCCR = %08x\n", car->car_sccr); printf ("SCMR = %08x\n", car->car_scmr); printf ("RSR = %08x\n", car->car_rsr); @@ -207,7 +207,7 @@ static void binary (char *label, uint value, int nbits) #define PB_NB_ODR 16 #define PC_NBITS 12 #define PD_NBITS 13 -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) #define PA_NBITS 32 #define PA_NB_ODR 32 #define PB_NBITS 28 @@ -224,7 +224,7 @@ do_iopinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_8xx) volatile iop8xx_t *iop = &immap->im_ioport; volatile ushort *l, *r; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) volatile iop8260_t *iop = &immap->im_ioport; volatile uint *l, *r; #endif @@ -240,7 +240,7 @@ do_iopinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_8xx) l = &iop->iop_padir; R = &immap->im_cpm.cp_pbdir; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) l = &iop->iop_pdira; R = &iop->iop_pdirb; #endif @@ -248,7 +248,7 @@ do_iopinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) binary ("PB_DIR", *R++, PB_NBITS); binary ("PA_PAR", *l++, PA_NBITS); binary ("PB_PAR", *R++, PB_NBITS); -#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) binary ("PA_SOR", *l++, PA_NBITS); binary ("PB_SOR", *R++, PB_NBITS); #endif @@ -266,7 +266,7 @@ do_iopinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_8xx) l = &iop->iop_pcdir; r = &iop->iop_pddir; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) l = &iop->iop_pdirc; r = &iop->iop_pdird; #endif @@ -278,7 +278,7 @@ do_iopinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) binary ("PC_SO ", *l++, PC_NBITS); binary (" ", 0, 0); r++; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) binary ("PC_SOR", *l++, PC_NBITS); binary ("PD_SOR", *r++, PD_NBITS); binary ("PC_ODR", *l++, PC_NBITS); @@ -436,7 +436,7 @@ static void prbrg (int n, uint val)
#if defined(CONFIG_8xx) ulong clock = gd->cpu_clk; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) ulong clock = gd->arch.brg_clk; #endif
@@ -489,7 +489,7 @@ do_brginfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_8xx) volatile cpm8xx_t *cp = &immap->im_cpm; volatile uint *p = &cp->cp_brgc1; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) volatile uint *p = &immap->im_brgc1; #endif int i = 1; @@ -497,7 +497,7 @@ do_brginfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) while (i <= 4) prbrg (i++, *p++);
-#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) p = &immap->im_brgc5; while (i <= 8) prbrg (i++, *p++); @@ -514,7 +514,7 @@ do_i2cinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) volatile i2c8xx_t *i2c = &immap->im_i2c; volatile cpm8xx_t *cp = &immap->im_cpm; volatile iic_t *iip = (iic_t *) & cp->cp_dparam[PROFF_IIC]; -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) volatile i2c8260_t *i2c = &immap->im_i2c; volatile iic_t *iip; uint dpaddr; @@ -614,7 +614,7 @@ U_BOOT_CMD( "" );
-#ifdef CONFIG_8260 +#ifdef CONFIG_MPC8260 U_BOOT_CMD( icinfo, 1, 1, do_icinfo, "print Interrupt Controller registers", diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index 7e0e5b7..9ab5446 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -11,7 +11,7 @@ extra-$(CONFIG_SMC911X) += smc911x_eeprom extra-$(CONFIG_SPI_FLASH_ATMEL) += atmel_df_pow2 extra-$(CONFIG_MPC5xxx) += interrupt extra-$(CONFIG_8xx) += test_burst timer -extra-$(CONFIG_8260) += mem_to_mem_idma2intr +extra-$(CONFIG_MPC8260) += mem_to_mem_idma2intr extra-$(CONFIG_PPC) += sched
# diff --git a/include/asm-generic/u-boot.h b/include/asm-generic/u-boot.h index 4387201..e781967 100644 --- a/include/asm-generic/u-boot.h +++ b/include/asm-generic/u-boot.h @@ -37,7 +37,7 @@ typedef struct bd_info { unsigned long bi_dsp_freq; /* dsp core frequency */ unsigned long bi_ddr_freq; /* ddr frequency */ #endif -#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_8260) \ +#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_MPC8260) \ || defined(CONFIG_E500) || defined(CONFIG_MPC86xx) unsigned long bi_immr_base; /* base of IMMR register */ #endif diff --git a/include/common.h b/include/common.h index 2ceb1d9..5fdb9f0 100644 --- a/include/common.h +++ b/include/common.h @@ -52,16 +52,13 @@ typedef volatile unsigned char vu_char; #include <mpc5xxx.h> #elif defined(CONFIG_MPC512X) #include <asm/immap_512x.h> -#elif defined(CONFIG_8260) +#elif defined(CONFIG_MPC8260) #if defined(CONFIG_MPC8247) \ || defined(CONFIG_MPC8248) \ || defined(CONFIG_MPC8271) \ || defined(CONFIG_MPC8272) #define CONFIG_MPC8272_FAMILY 1 #endif -#if defined(CONFIG_MPC8272_FAMILY) -#define CONFIG_MPC8260 1 -#endif #include <asm/immap_8260.h> #endif #ifdef CONFIG_MPC86xx @@ -669,7 +666,7 @@ int get_clocks (void); int get_clocks_866 (void); int sdram_adjust_866 (void); int adjust_sdram_tbs_8xx (void); -#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) int prt_8260_clks (void); #elif defined(CONFIG_MPC5xxx) int prt_mpc5xxx_clks (void); @@ -736,7 +733,7 @@ void get_sys_info ( sys_info_t * ); #endif
/* $(CPU)/cpu_init.c */ -#if defined(CONFIG_8xx) || defined(CONFIG_8260) +#if defined(CONFIG_8xx) || defined(CONFIG_MPC8260) void cpu_init_f (volatile immap_t *immr); #endif #if defined(CONFIG_4xx) || defined(CONFIG_MPC85xx) || defined(CONFIG_MCF52x2) ||defined(CONFIG_MPC86xx) @@ -744,7 +741,7 @@ void cpu_init_f (void); #endif
int cpu_init_r (void); -#if defined(CONFIG_8260) +#if defined(CONFIG_MPC8260) int prt_8260_rsr (void); #elif defined(CONFIG_MPC83xx) int prt_83xx_rsr (void); diff --git a/include/configs/CPU86.h b/include/configs/CPU86.h index a033a3a..7be83b0 100644 --- a/include/configs/CPU86.h +++ b/include/configs/CPU86.h @@ -17,7 +17,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_CPU86 1 /* ...on a CPU86 board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/CPU87.h b/include/configs/CPU87.h index 0687674..d3a59e8 100644 --- a/include/configs/CPU87.h +++ b/include/configs/CPU87.h @@ -17,7 +17,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_CPU87 1 /* ...on a CPU87 board */ #define CONFIG_PCI #define CONFIG_CPM2 1 /* Has a CPM2 */ diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index 7aaa776..8ccb0ff 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -17,7 +17,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is a MPC8260 CPU */ #define CONFIG_MPC8272_FAMILY 1 #define CONFIG_IDS8247 1 #define CPU_ID_STR "MPC8247" diff --git a/include/configs/IPHASE4539.h b/include/configs/IPHASE4539.h index a543855..e402075 100644 --- a/include/configs/IPHASE4539.h +++ b/include/configs/IPHASE4539.h @@ -19,7 +19,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_IPHASE4539 1 /* ...on a Interphase 4539 PMC */
#define CONFIG_SYS_TEXT_BASE 0xffb00000 diff --git a/include/configs/ISPAN.h b/include/configs/ISPAN.h index a5cea8b..a2fdfd3 100644 --- a/include/configs/ISPAN.h +++ b/include/configs/ISPAN.h @@ -13,7 +13,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_MPC8260 /* This is an MPC8260 CPU */ #define CONFIG_ISPAN /* ...on one of Interphase iSPAN boards */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/MPC8260ADS.h b/include/configs/MPC8260ADS.h index 3def269..39f7564 100644 --- a/include/configs/MPC8260ADS.h +++ b/include/configs/MPC8260ADS.h @@ -64,8 +64,6 @@ * details. :-( */ #define CONFIG_MPC8272 1 -#else -#define CONFIG_MPC8260 1 #endif /* CONFIG_ADSTYPE == CONFIG_SYS_8272ADS */
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ diff --git a/include/configs/MPC8266ADS.h b/include/configs/MPC8266ADS.h index 39c90aa..8d9c8fb 100644 --- a/include/configs/MPC8266ADS.h +++ b/include/configs/MPC8266ADS.h @@ -33,7 +33,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_MPC8266ADS 1 /* ...on motorola ADS board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/PM826.h b/include/configs/PM826.h index 5aeba4d..6416ad5 100644 --- a/include/configs/PM826.h +++ b/include/configs/PM826.h @@ -19,7 +19,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is a MPC8260 CPU */ #define CONFIG_PM826 1 /* ...on a PM8260 module */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/PM828.h b/include/configs/PM828.h index 49b4571..e17fbfb 100644 --- a/include/configs/PM828.h +++ b/include/configs/PM828.h @@ -19,7 +19,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is a MPC8260 CPU */ #define CONFIG_PM828 1 /* ...on a PM828 module */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/RPXsuper.h b/include/configs/RPXsuper.h index 2888429..f5e0968 100644 --- a/include/configs/RPXsuper.h +++ b/include/configs/RPXsuper.h @@ -184,7 +184,6 @@ * *****************************************************************************/
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_RPXSUPER 1 /* on an Embedded Planet RPX Super Board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/Rattler.h b/include/configs/Rattler.h index 1cdd18c..a1e2ae9 100644 --- a/include/configs/Rattler.h +++ b/include/configs/Rattler.h @@ -13,7 +13,6 @@ #ifdef CONFIG_MPC8248 #define CPU_ID_STR "MPC8248" #else -#define CONFIG_MPC8260 #define CPU_ID_STR "MPC8250" #endif /* CONFIG_MPC8248 */
diff --git a/include/configs/TQM8260.h b/include/configs/TQM8260.h index b34b0a8..7fd12d3 100644 --- a/include/configs/TQM8260.h +++ b/include/configs/TQM8260.h @@ -30,7 +30,6 @@
#define CONFIG_SYS_TEXT_BASE 0x40000000
#if 0 #define CONFIG_TQM8260 100 /* ...on a TQM8260 module Rev.100 */ diff --git a/include/configs/TQM8272.h b/include/configs/TQM8272.h index 78e8b03..9c7e163 100644 --- a/include/configs/TQM8272.h +++ b/include/configs/TQM8272.h @@ -17,7 +17,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is a MPC8260 CPU */ #define CONFIG_MPC8272_FAMILY 1 #define CONFIG_TQM8272 1
diff --git a/include/configs/ZPC1900.h b/include/configs/ZPC1900.h index 01cb2c8..d76a140 100644 --- a/include/configs/ZPC1900.h +++ b/include/configs/ZPC1900.h @@ -11,7 +11,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_ZPC1900 1 /* ...on Zephyr ZPC.1900 board */
#define CONFIG_SYS_TEXT_BASE 0xFE000000 diff --git a/include/configs/atc.h b/include/configs/atc.h index fa391b6..77fa79a 100644 --- a/include/configs/atc.h +++ b/include/configs/atc.h @@ -17,7 +17,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_ATC 1 /* ...on a ATC board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/ep8260.h b/include/configs/ep8260.h index 56b4ecf..9cd3054 100644 --- a/include/configs/ep8260.h +++ b/include/configs/ep8260.h @@ -325,7 +325,6 @@ * *****************************************************************************/
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_EP8260 11 /* on an Embedded Planet EP8260 Board, Rev. 11 */
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ diff --git a/include/configs/ep82xxm.h b/include/configs/ep82xxm.h index 18e4daf..cf31f0f 100644 --- a/include/configs/ep82xxm.h +++ b/include/configs/ep82xxm.h @@ -9,7 +9,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_MPC8260 #define CPU_ID_STR "MPC8270"
#define CONFIG_EP82XXM /* Embedded Planet EP82xxM H 1.0 board */ diff --git a/include/configs/gw8260.h b/include/configs/gw8260.h index 3416fe3..262c9e9 100644 --- a/include/configs/gw8260.h +++ b/include/configs/gw8260.h @@ -325,7 +325,6 @@ * *****************************************************************************/
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_GW8260 1 /* on an GW8260 Board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/hymod.h b/include/configs/hymod.h index cc25064..c973365 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -17,7 +17,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_HYMOD 1 /* ...on a Hymod board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h index 87c0638..7343c94 100644 --- a/include/configs/muas3001.h +++ b/include/configs/muas3001.h @@ -13,8 +13,6 @@ * (easy to change) */
-#define CONFIG_8260 1 -#define CONFIG_MPC8260 1 #define CONFIG_MUAS3001 1
#define CONFIG_SYS_TEXT_BASE 0xFF000000 diff --git a/include/configs/ppmc8260.h b/include/configs/ppmc8260.h index 760dcac..5dcd9cc 100644 --- a/include/configs/ppmc8260.h +++ b/include/configs/ppmc8260.h @@ -293,7 +293,6 @@ * *****************************************************************************/
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_PPMC8260 1 /* on an Wind River PPMC8260 Board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/rsdproto.h b/include/configs/rsdproto.h index 92318c3..0621138 100644 --- a/include/configs/rsdproto.h +++ b/include/configs/rsdproto.h @@ -19,7 +19,6 @@ * (easy to change) */
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_RSD_PROTO 1 /* on a R&S Protocol Board */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/configs/sacsng.h b/include/configs/sacsng.h index 3750ad2..0a694fb 100644 --- a/include/configs/sacsng.h +++ b/include/configs/sacsng.h @@ -524,7 +524,6 @@ * *****************************************************************************/
-#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */ #define CONFIG_SACSng 1 /* munged for the SACSng */ #define CONFIG_CPM2 1 /* Has a CPM2 */
diff --git a/include/ppc_asm.tmpl b/include/ppc_asm.tmpl index 331b666..5fcef9c 100644 --- a/include/ppc_asm.tmpl +++ b/include/ppc_asm.tmpl @@ -135,7 +135,7 @@
#define PLPRCR 0x00000284
#define HID2 1011
This commit does:
Masahiro Yamada
