[U-Boot] Pull request: u-boot-arm/master
Hi Wolfgang,
The following changes since commit 0a6deb3251a68b5be640ab1b848ca67e906b75ce:
Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-staging (2012-04-30 18:19:28 +0200)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 2ca4a209a5b961ad1be8782c68dabe326d77dfaf:
OMAP4/5: Change omap4_sdp, omap4_panda, omap5_evm maintainer (2012-05-15 08:31:41 +0200)
---------------------------------------------------------------- Aneesh V (6): arm: adapt asm/linkage.h from Linux armv7: add appropriate headers for assembly functions ARM: enable Thumb build armv7: Use -march=armv7-a and thereby enable Thumb-2 omap4+: Avoid using __attribute__ ((__packed__)) OMAP4: enable Thumb build
Anton Staff (3): fdt: Add fdtdec functions to read byte array tegra: fdt: Add keyboard controller definition tegra: fdt: Add keyboard definitions for Seaboard
Balaji T K (3): arm: omap5: correct boot device mode7 for eMMC omap5: pbias ldo9 turn on mmc: omap5evm: Add eMMC saveenv support
Bernie Thompson (1): input: Add support for keyboard matrix decoding from an fdt
Chander Kashyap (1): EXYNOS: Rename exynos5_tzpc structure to exynos_tzpc
David Purdy (1): kirkwood: add support for Cloud Engines Pogoplug E02
Dirk Behme (1): i.MX6: Add ANATOP regulator init
Donghwa Lee (8): EXYNOS: definitions of system resgister and power management registers. EXYNOS: add LCD and MIPI DSI clock interface. LCD: add data structure for EXYNOS display driver EXYNOS: support EXYNOS framebuffer and FIMD display drivers. EXYNOS: support EXYNOS MIPI DSI interface driver. LCD: support S6E8AX0 amoled driver based on EXYNOS MIPI DSI EXYNOS: support TRATS board display function EXYNOS: Change bits per pixel value proper for u-boot.
Enric Balletbo i Serra (2): igep00x0: enable the use of a plain text file igep00x0: change mpurate from 500 to auto
Enric Balletbò i Serra (1): OMAP3: igep00x0: Reduce lines of code for IGEP-based boards.
Eric Nelson (3): i.MX6Q: mx6qsabrelite: Add keypress support to alter boot flow i.MX6: add enable_sata_clock() i.MX6: mx6q_sabrelite: add SATA bindings
Fabio Estevam (19): pmic: Add support for the Dialog DA9053 PMIC mx6qsabrelite: No need to set the direction for GPIO3_23 again mx28evk: Allow to booting a dt kernel m28evk: Allow to booting a dt kernel mx28evk: Allow booting a zImage kernel mx6qsabrelite: Allow booting a zImage kernel mx6qarm2: Allow booting a zImage kernel mx31pdk: Allow booting a zImage kernel imx-common: Factor out get_ahb_clk() mx5: Add clock config interface mx53loco: Allow to print CPU information at a later stage mx53loco: Add support for 1GHz operation for DA9053-based boards pmic: dialog: Avoid name conflicts mx53loco: Add mc34708 support and set mx53 frequency at 1GHz mx53loco: Turn on VUSB regulator mx53loco: Add CONFIG_REVISION_TAG mx53loco: Remove unneeded gpio_set_value() spi: mxs: Introduce spi_cs_is_valid() spi: mxs: Allow other chip selects to work
Grazvydas Ignotas (3): OMAP3: pandora: pin mux updates for DM3730 board variant OMAP3: pandora: revise GPIO configuration OMAP3: pandora: drop console kernel argument
Ian Campbell (1): ARM: dreamplug: Enable FDT support
Jaehoon Chung (1): TRATS: modify the trats's configuration
Jimmy Zhang (3): tegra: Add EMC support for optimal memory timings tegra: Add PMU to manage power supplies tegra: Add EMC settings for Seaboard
Jon Hunter (1): OMAP4: Set fdt_high for OMAP4 devices to enable booting with Device Tree
Jonathan Solnit (1): ARM:OMAP+:MMC: Add parameters to MMC init
Lauri Hintsala (1): mx28evk: add NAND support
Lucas Stach (1): tegra2: trivially enable 13 mhz crystal frequency
Luka Perkov (1): kirkwood: add NAS62x0 board support
Marek Vasut (17): M28: Enable FDT support Revert "i.MX28: Enable additional DRAM address bits" M28: Scan only first 512 MB of DRAM to avoid memory wraparound i.MX28: Add delay after CPU bypass is cleared FEC: Abstract out register setup M28EVK: Implement support for new board V2.0 M28EVK: Add SD update command i.MX28: Improve passing of data from SPL to U-Boot i.MX28: Implement boot pads sampling and reporting i.MX28: Add LCDIF register definitions i.MX28: Shut down the LCD controller before reset i.MX28: Add LRADC register definitions i.MX28: Add LRADC init to i.MX28 SPL i.MX28: Reorder battery status functions in SPL i.MX28: Add battery boot components to SPL i.MX28: Check if WP detection is implemented at all i.MX28: Avoid redefining serial_put[cs]()
Matt Porter (1): arm, omap3: fix warm reset serial output on OMAP36xx/AM/DM37xx
Minkyu Kang (1): SMDK5250: fix compiler warning
Nikita Kiryanov (1): cm-t35: add I2C multi-bus support
Nishanth Menon (3): OMAP3+: Introduce generic logic for OMAP voltage controller OMAP4460: TPS Ensure SET1 is selected after voltage configuration OMAP4: scale voltage of core before MPU scales
Nobuhiro Iwamatsu (2): arm: cam_enc_4xx: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT arm: ea20: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT
Rakesh Iyer (1): tegra: Add tegra keyboard driver
SRICHARAN R (17): OMAP5: clocks: Change clock settings as required for ES1.0 silicon. OMAP5: board: Add pinmux data for omap5_evm board. OMAP5: io: Configure the io settings for omap5430 sevm board. OMAP5: emif/ddr: Change emif settings as required for ES1.0 silicon. OMAP5: palmas: Configure nominal opp vdd values OMAP5: hwinit: Add the missing break statement OMAP4/5: Make the silicon revision variable common. OMAP5: SRAM: Change the SRAM base address. OMAP4/5: Make the sysctrl structure common OMAP4/5: device: Add support to get the device type. OMAP5: defconfig: Align the defconfig for 5430 ES1.0 OMAP5: ddr: Change the ddr device name. OMAP4/5: emif: Correct the emif power mgt shadow register bit fields. power: twl6035: add palmas PMIC support OMAP3+: reset: Create a common reset layer. OMAP5: reset: Use cold reset in case of 5430ES1.0 OMAP4/5: Change omap4_sdp, omap4_panda, omap5_evm maintainer
Simon Glass (19): fdt: Add function to locate an array in the device tree fdt: Add function to return next compatible subnode Add abs() macro to return absolute value i2c: Add TPS6586X driver tegra: Move ap20.h header into arch location tegra: Add functions to access low-level Osc/PLL details tegra: Add tegra_get_chip_type() to detect SKU tegra: Add header file for APB_MISC register tegra: Set up PMU for Nvidia boards tegra: Set up warmboot code on Nvidia boards fdt: tegra: Add EMC node to device tree tegra: i2c: Add function to find DVC bus tegra: fdt: Add EMC data for Tegra2 Seaboard tegra: Enable LP0 on Seaboard input: Add linux/input.h for key code support input: Add generic keyboard input handler tegra: Add keyboard support to funcmux tegra: Switch on console mux and use environment for console tegra: Enable keyboard for Seaboard
Stefano Babic (9): Define UART4 and UART5 base addresses NET: fec_mxc.c: Add a way to disable auto negotiation MX5: Add definitions for SATA controller SATA: check for return value from sata functions MX53: add function to set SATA clock to internal SATA: add driver for MX5 / MX6 SOCs MX53: Add support to ESG ima3 board MX53: mx53loco: Add SATA support MX5: PAD_CTL_DRV_VOT_LOW and PAD_CTL_DRV_VOT_HIGH exchanged
Tero Kristo (3): omap4: panda: disable uart2 pads during boot omap4: do not enable fs-usb module omap4: do not enable auxiliary cores
Timo Ketola (7): i.MX25: esdhc: Add mxc_get_clock infrastructure i.MX25: This architecture has a GPIO4 too imx: nand: Support flash based BBT i.MX25: usb: Set PORTSCx register imx: usb: There is no such register i.MX2: Include asm/types.h in arch-mx25/imx-regs.h imx: Add u-boot.imx as target for ARM9 i.MX SOCs
Tom Rini (11): tools, config.mk: Add gcc-version.sh, cc-version test from Linux Makefile: Add a 'checkthumb' rule omap4: Remove CONFIG_SYS_MMC_SET_DEV omap4+: Remove CONFIG_ARCH_CPU_INIT omap5912osk: Remove empty misc_init_r omap730p2: Remove empty misc_init_r omap3: Introduce weak misc_init_r include/configs: Remove CONFIG_SYS_64BIT_VSPRINTF include/configs: Remove CONFIG_SYS_64BIT_STRTOUL ARM: omap3: Set SPL stack size to 8KB, image to 54KB. ARM: omap3: Add CONFIG_SPL_BOARD_INIT for CONFIG_SPL_MMC_SUPPORT
Vladimir Zapolskiy (3): arm926ejs: add NXP LPC32x0 cpu series support serial: add LPC32X0 high-speed UART devices support devkit3250: add Timll DevKit3250 board initial support
Wei Ni (1): tegra: Turn off power detect in board init
Wolfgang Grandegger (1): USB: ehci-mx6: Fix broken IO access
Yen Lin (5): Add AES crypto library tegra: Add crypto library for warmboot code tegra: Add flow, gp_padctl, fuse, sdram headers tegra: Add warmboot implementation tegra: Setup PMC scratch info from ap20 setup
Łukasz Majewski (3): ARM: Exynos4: ADC: Universal_C210: Enable LDO4 power line for ADC measurement misc:pmic:max8997 MAX8997 support for PMIC driver misc:pmic:samsung Convert TRATS target to use MAX8997 instead of MAX8998
MAINTAINERS | 24 +- Makefile | 7 + README | 8 + arch/arm/config.mk | 27 +- arch/arm/cpu/arm926ejs/config.mk | 6 + arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 45 + arch/arm/cpu/arm926ejs/lpc32xx/clk.c | 117 +++ arch/arm/cpu/arm926ejs/lpc32xx/cpu.c | 70 ++ arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 52 ++ arch/arm/cpu/arm926ejs/lpc32xx/timer.c | 95 ++ arch/arm/cpu/arm926ejs/mx25/generic.c | 27 + arch/arm/cpu/arm926ejs/mx28/Makefile | 2 +- arch/arm/cpu/arm926ejs/mx28/mx28.c | 29 +- arch/arm/cpu/arm926ejs/mx28/mx28_init.h | 4 + arch/arm/cpu/arm926ejs/mx28/spl_boot.c | 57 ++ arch/arm/cpu/arm926ejs/mx28/spl_lradc_init.c | 86 ++ arch/arm/cpu/arm926ejs/mx28/spl_mem_init.c | 14 +- arch/arm/cpu/arm926ejs/mx28/spl_power_init.c | 224 +++-- arch/arm/cpu/armv7/am33xx/board.c | 2 +- arch/arm/cpu/armv7/config.mk | 7 +- arch/arm/cpu/armv7/exynos/Makefile | 2 +- arch/arm/cpu/armv7/exynos/clock.c | 184 ++++ arch/arm/cpu/armv7/exynos/power.c | 54 ++ arch/arm/cpu/armv7/exynos/system.c | 48 + arch/arm/cpu/armv7/imx-common/cpu.c | 15 +- arch/arm/cpu/armv7/mx5/clock.c | 493 +++++++++- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 5 +- arch/arm/cpu/armv7/mx6/clock.c | 50 +- arch/arm/cpu/armv7/mx6/lowlevel_init.S | 5 +- arch/arm/cpu/armv7/mx6/soc.c | 30 + arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/clocks-common.c | 99 +- arch/arm/cpu/armv7/omap-common/emif-common.c | 41 +- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 16 +- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 14 +- .../arm/cpu/armv7/omap-common/{reset.S => reset.c} | 30 +- arch/arm/cpu/armv7/omap-common/spl.c | 1 + arch/arm/cpu/armv7/omap-common/spl_mmc.c | 5 +- arch/arm/cpu/armv7/omap-common/vc.c | 138 +++ arch/arm/cpu/armv7/omap3/board.c | 12 + arch/arm/cpu/armv7/omap3/clock.c | 16 + arch/arm/cpu/armv7/omap3/lowlevel_init.S | 41 +- arch/arm/cpu/armv7/omap4/clocks.c | 85 +- arch/arm/cpu/armv7/omap4/hwinit.c | 24 +- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 4 + arch/arm/cpu/armv7/omap5/Makefile | 2 +- arch/arm/cpu/armv7/omap5/clocks.c | 143 ++- arch/arm/cpu/armv7/omap5/hwinit.c | 104 ++- .../cpu/armv7/omap5/{sdram_elpida.c => sdram.c} | 101 +- arch/arm/cpu/armv7/s5pc1xx/cache.S | 10 +- arch/arm/cpu/armv7/s5pc1xx/reset.S | 5 +- arch/arm/cpu/armv7/start.S | 13 +- arch/arm/cpu/armv7/tegra2/Makefile | 4 + arch/arm/cpu/armv7/tegra2/ap20.c | 44 +- arch/arm/cpu/armv7/tegra2/board.c | 4 +- arch/arm/cpu/armv7/tegra2/clock.c | 37 +- arch/arm/cpu/armv7/tegra2/crypto.c | 230 +++++ arch/arm/cpu/armv7/tegra2/crypto.h | 36 + arch/arm/cpu/armv7/tegra2/emc.c | 286 ++++++ arch/arm/cpu/armv7/tegra2/funcmux.c | 16 + arch/arm/cpu/armv7/tegra2/lowlevel_init.S | 5 +- arch/arm/cpu/armv7/tegra2/pmu.c | 70 ++ arch/arm/cpu/armv7/tegra2/warmboot.c | 386 ++++++++ arch/arm/cpu/armv7/tegra2/warmboot_avp.c | 250 +++++ arch/arm/cpu/armv7/tegra2/warmboot_avp.h | 81 ++ arch/arm/cpu/armv7/u8500/lowlevel.S | 9 +- arch/arm/dts/tegra20.dtsi | 11 + arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 2 +- arch/arm/include/asm/arch-exynos/clk.h | 3 + arch/arm/include/asm/arch-exynos/cpu.h | 5 + arch/arm/include/asm/arch-exynos/dsim.h | 181 ++++ arch/arm/include/asm/arch-exynos/fb.h | 446 +++++++++ arch/arm/include/asm/arch-exynos/mipi_dsim.h | 380 ++++++++ arch/arm/include/asm/arch-exynos/power.h | 6 + arch/arm/include/asm/arch-exynos/system.h | 53 ++ arch/arm/include/asm/arch-exynos/tzpc.h | 2 +- arch/arm/include/asm/arch-lpc32xx/clk.h | 170 ++++ arch/arm/include/asm/arch-lpc32xx/config.h | 76 ++ arch/arm/include/asm/arch-lpc32xx/cpu.h | 64 ++ arch/arm/include/asm/arch-lpc32xx/emc.h | 92 ++ arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 25 + arch/arm/include/asm/arch-lpc32xx/timer.h | 74 ++ arch/arm/include/asm/arch-lpc32xx/uart.h | 114 +++ arch/arm/include/asm/arch-lpc32xx/wdt.h | 51 ++ arch/arm/include/asm/arch-mx25/clock.h | 23 + arch/arm/include/asm/arch-mx25/imx-regs.h | 3 + arch/arm/include/asm/arch-mx28/imx-regs.h | 2 + arch/arm/include/asm/arch-mx28/regs-lcdif.h | 212 +++++ arch/arm/include/asm/arch-mx28/regs-lradc.h | 400 ++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 30 + arch/arm/include/asm/arch-mx5/clock.h | 7 +- arch/arm/include/asm/arch-mx5/crm_regs.h | 6 + arch/arm/include/asm/arch-mx5/imx-regs.h | 11 + arch/arm/include/asm/arch-mx5/iomux.h | 4 +- arch/arm/include/asm/arch-mx5/sys_proto.h | 3 + arch/arm/include/asm/arch-mx6/clock.h | 1 + .../asm/arch-mx6/{ccm_regs.h => crm_regs.h} | 2 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 9 + arch/arm/include/asm/arch-mx6/iomux-v3.h | 111 +++ arch/arm/include/asm/arch-mx6/sys_proto.h | 5 +- arch/arm/include/asm/arch-omap3/cpu.h | 5 +- arch/arm/include/asm/arch-omap3/mmc_host_def.h | 8 +- arch/arm/include/asm/arch-omap3/mux.h | 6 + arch/arm/include/asm/arch-omap4/clocks.h | 18 +- arch/arm/include/asm/arch-omap4/cpu.h | 11 + arch/arm/include/asm/arch-omap4/mmc_host_def.h | 2 +- arch/arm/include/asm/arch-omap4/mux_omap4.h | 2 +- arch/arm/include/asm/arch-omap4/omap.h | 25 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 8 +- arch/arm/include/asm/arch-omap5/clocks.h | 52 +- arch/arm/include/asm/arch-omap5/cpu.h | 11 + arch/arm/include/asm/arch-omap5/mmc_host_def.h | 2 +- arch/arm/include/asm/arch-omap5/mux_omap5.h | 504 +++++----- arch/arm/include/asm/arch-omap5/omap.h | 153 +++- arch/arm/include/asm/arch-omap5/sys_proto.h | 8 +- .../tegra2 => include/asm/arch-tegra2}/ap20.h | 7 + arch/arm/include/asm/arch-tegra2/apb_misc.h | 36 + arch/arm/include/asm/arch-tegra2/clk_rst.h | 3 + arch/arm/include/asm/arch-tegra2/clock.h | 22 + arch/arm/include/asm/arch-tegra2/emc.h | 113 +++ arch/arm/include/asm/arch-tegra2/flow.h | 36 + arch/arm/include/asm/arch-tegra2/fuse.h | 39 + arch/arm/include/asm/arch-tegra2/gp_padctrl.h | 73 ++ arch/arm/include/asm/arch-tegra2/pmu.h | 30 + arch/arm/include/asm/arch-tegra2/sdram_param.h | 148 +++ arch/arm/include/asm/arch-tegra2/tegra2.h | 25 + arch/arm/include/asm/arch-tegra2/tegra_i2c.h | 7 + arch/arm/include/asm/arch-tegra2/warmboot.h | 150 +++ arch/arm/include/asm/emif.h | 76 +- arch/arm/include/asm/linkage.h | 7 + arch/arm/include/asm/omap_common.h | 11 +- board/cloudengines/pogo_e02/Makefile | 43 + board/cloudengines/pogo_e02/kwbimage.cfg | 169 ++++ board/cloudengines/pogo_e02/pogo_e02.c | 118 +++ board/cloudengines/pogo_e02/pogo_e02.h | 44 + board/cm_t35/cm_t35.c | 19 +- board/comelit/dig297/dig297.c | 2 +- board/corscience/tricorder/tricorder.c | 2 +- board/davinci/ea20/ea20.c | 4 +- board/denx/m28evk/m28evk.c | 20 +- board/denx/m28evk/spl_boot.c | 8 +- board/esg/ima3-mx53/Makefile | 41 + board/esg/ima3-mx53/ima3-mx53.c | 302 ++++++ board/esg/ima3-mx53/imximage.cfg | 108 +++ board/freescale/mx28evk/iomux.c | 21 + board/freescale/mx53loco/mx53loco.c | 146 ++- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 155 +++- board/htkw/mcx/mcx.c | 13 +- board/isee/igep0020/igep0020.c | 4 +- board/isee/igep0030/igep0030.c | 4 +- board/logicpd/am3517evm/am3517evm.c | 2 +- board/logicpd/omap3som/omap3logic.c | 13 +- board/logicpd/zoom1/zoom1.c | 2 +- board/logicpd/zoom2/zoom2.c | 2 +- board/matrix_vision/mvblx/mvblx.c | 4 +- board/nvidia/common/Makefile | 1 + board/nvidia/common/board.c | 42 +- board/nvidia/common/emc.c | 53 ++ board/nvidia/common/emc.h | 29 + board/nvidia/dts/tegra2-seaboard.dts | 64 ++ board/overo/overo.c | 2 +- board/pandora/pandora.c | 59 +- board/pandora/pandora.h | 6 + board/raidsonic/ib62x0/Makefile | 43 + board/raidsonic/ib62x0/ib62x0.c | 79 ++ board/raidsonic/ib62x0/ib62x0.h | 40 + board/raidsonic/ib62x0/kwbimage.cfg | 169 ++++ board/samsung/smdk5250/tzpc_init.c | 4 +- board/samsung/trats/trats.c | 173 +++- board/samsung/universal_c210/universal.c | 25 +- board/technexion/twister/twister.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 9 +- board/ti/am3517crane/am3517crane.c | 2 +- board/ti/beagle/beagle.c | 2 +- board/ti/evm/evm.c | 2 +- board/ti/omap5912osk/omap5912osk.c | 7 - board/ti/omap5_evm/evm.c | 10 +- board/ti/omap5_evm/mux_data.h | 489 +++++----- board/ti/omap730p2/omap730p2.c | 6 - board/ti/panda/panda.c | 2 +- board/ti/panda/panda_mux_data.h | 10 +- board/ti/sdp3430/sdp.c | 2 +- board/ti/sdp4430/sdp.c | 4 +- board/ti/sdp4430/sdp4430_mux_data.h | 2 +- board/timll/devkit3250/Makefile | 44 + board/timll/devkit3250/devkit3250.c | 65 ++ board/timll/devkit8000/devkit8000.c | 2 +- boards.cfg | 8 +- common/cmd_sata.c | 9 +- config.mk | 6 +- doc/SPL/README.omap3 | 4 +- drivers/bios_emulator/x86emu/prim_ops.c | 5 - drivers/block/Makefile | 1 + drivers/block/dwc_ahsata.c | 969 ++++++++++++++++++++ drivers/block/dwc_ahsata.h | 335 +++++++ drivers/gpio/mxc_gpio.c | 3 +- drivers/i2c/tegra_i2c.c | 14 + drivers/input/Makefile | 3 + drivers/input/input.c | 430 +++++++++ drivers/input/key_matrix.c | 208 +++++ drivers/input/tegra-kbc.c | 375 ++++++++ drivers/misc/Makefile | 2 + drivers/misc/pmic_dialog.c | 37 + drivers/misc/pmic_max8997.c | 43 + drivers/mmc/mxsmmc.c | 3 +- drivers/mmc/omap_hsmmc.c | 61 +- drivers/mtd/nand/mxc_nand.c | 33 + drivers/net/fec_mxc.c | 88 +- drivers/power/Makefile | 2 + drivers/power/tps6586x.c | 280 ++++++ drivers/power/twl6035.c | 65 ++ drivers/serial/Makefile | 1 + drivers/serial/lpc32xx_hsuart.c | 112 +++ drivers/spi/mxs_spi.c | 23 +- drivers/usb/host/ehci-mx6.c | 5 +- drivers/usb/host/ehci-mxc.c | 4 - drivers/video/Makefile | 4 + drivers/video/exynos_fb.c | 128 +++ drivers/video/exynos_fb.h | 61 ++ drivers/video/exynos_fimd.c | 354 +++++++ drivers/video/exynos_mipi_dsi.c | 253 +++++ drivers/video/exynos_mipi_dsi_common.c | 637 +++++++++++++ drivers/video/exynos_mipi_dsi_common.h | 48 + drivers/video/exynos_mipi_dsi_lowlevel.c | 652 +++++++++++++ drivers/video/exynos_mipi_dsi_lowlevel.h | 111 +++ drivers/video/s6e8ax0.c | 256 ++++++ include/aes.h | 70 ++ include/ahci.h | 5 +- include/common.h | 25 + include/configs/P1023RDS.h | 3 - include/configs/P2020COME.h | 2 - include/configs/am3517_crane.h | 3 +- include/configs/am3517_evm.h | 4 +- include/configs/at91sam9263ek.h | 2 - include/configs/cam_enc_4xx.h | 2 +- include/configs/cm_t35.h | 1 + include/configs/da830evm.h | 1 - include/configs/devkit3250.h | 117 +++ include/configs/devkit8000.h | 2 +- include/configs/dreamplug.h | 2 + include/configs/ea20.h | 3 +- include/configs/eb_cpux9k2.h | 2 - include/configs/flea3.h | 2 - include/configs/hawkboard.h | 1 - include/configs/ib62x0.h | 152 +++ include/configs/igep0030.h | 261 ------ include/configs/{igep0020.h => igep00x0.h} | 45 +- include/configs/ima3-mx53.h | 269 ++++++ include/configs/imx27lite-common.h | 1 - include/configs/m28evk.h | 15 +- include/configs/mcx.h | 4 +- include/configs/meesc.h | 1 - include/configs/mv-common.h | 1 - include/configs/mx25pdk.h | 1 - include/configs/mx28evk.h | 13 + include/configs/mx31pdk.h | 1 + include/configs/mx35pdk.h | 2 - include/configs/mx53loco.h | 29 +- include/configs/mx6qarm2.h | 1 + include/configs/mx6qsabrelite.h | 17 + include/configs/omap3_beagle.h | 3 +- include/configs/omap3_evm_common.h | 3 +- include/configs/omap3_overo.h | 3 +- include/configs/omap3_pandora.h | 3 +- include/configs/omap4_common.h | 5 +- include/configs/omap5912osk.h | 2 - include/configs/omap5_evm.h | 26 +- include/configs/omap730p2.h | 2 - include/configs/otc570.h | 1 - include/configs/p1_p2_rdb_pc.h | 3 - include/configs/pogo_e02.h | 119 +++ include/configs/seaboard.h | 16 + include/configs/spear-common.h | 1 - include/configs/tam3517-common.h | 3 +- include/configs/tegra2-common.h | 26 +- include/configs/trats.h | 15 +- include/configs/tricorder.h | 3 +- include/configs/tx25.h | 2 - include/configs/zmx25.h | 2 - include/dialog_pmic.h | 187 ++++ include/fdtdec.h | 71 ++ include/fsl_pmic.h | 11 + include/input.h | 147 +++ include/key_matrix.h | 99 ++ include/lcd.h | 64 ++ include/linux/input.h | 155 ++++ include/linux/linkage.h | 7 +- include/max8997_pmic.h | 190 ++++ include/max8998_pmic.h | 1 + include/pmic.h | 1 + include/tegra-kbc.h | 33 + include/tps6586x.h | 68 ++ include/twl6035.h | 42 + lib/Makefile | 1 + lib/aes.c | 598 ++++++++++++ lib/fdtdec.c | 53 ++ tools/gcc-version.sh | 32 + 297 files changed, 18126 insertions(+), 1594 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/clk.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/devices.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/timer.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/spl_lradc_init.c create mode 100644 arch/arm/cpu/armv7/exynos/power.c create mode 100644 arch/arm/cpu/armv7/exynos/system.c rename arch/arm/cpu/armv7/omap-common/{reset.S => reset.c} (70%) create mode 100644 arch/arm/cpu/armv7/omap-common/vc.c rename arch/arm/cpu/armv7/omap5/{sdram_elpida.c => sdram.c} (64%) create mode 100644 arch/arm/cpu/armv7/tegra2/crypto.c create mode 100644 arch/arm/cpu/armv7/tegra2/crypto.h create mode 100644 arch/arm/cpu/armv7/tegra2/emc.c create mode 100644 arch/arm/cpu/armv7/tegra2/pmu.c create mode 100644 arch/arm/cpu/armv7/tegra2/warmboot.c create mode 100644 arch/arm/cpu/armv7/tegra2/warmboot_avp.c create mode 100644 arch/arm/cpu/armv7/tegra2/warmboot_avp.h create mode 100644 arch/arm/include/asm/arch-exynos/dsim.h create mode 100644 arch/arm/include/asm/arch-exynos/fb.h create mode 100644 arch/arm/include/asm/arch-exynos/mipi_dsim.h create mode 100644 arch/arm/include/asm/arch-exynos/system.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/clk.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/config.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/cpu.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/emc.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/sys_proto.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/timer.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/uart.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/wdt.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-lcdif.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-lradc.h rename arch/arm/include/asm/arch-mx6/{ccm_regs.h => crm_regs.h} (99%) rename arch/arm/{cpu/armv7/tegra2 => include/asm/arch-tegra2}/ap20.h (96%) create mode 100644 arch/arm/include/asm/arch-tegra2/apb_misc.h create mode 100644 arch/arm/include/asm/arch-tegra2/emc.h create mode 100644 arch/arm/include/asm/arch-tegra2/flow.h create mode 100644 arch/arm/include/asm/arch-tegra2/fuse.h create mode 100644 arch/arm/include/asm/arch-tegra2/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra2/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra2/sdram_param.h create mode 100644 arch/arm/include/asm/arch-tegra2/warmboot.h create mode 100644 arch/arm/include/asm/linkage.h create mode 100644 board/cloudengines/pogo_e02/Makefile create mode 100644 board/cloudengines/pogo_e02/kwbimage.cfg create mode 100644 board/cloudengines/pogo_e02/pogo_e02.c create mode 100644 board/cloudengines/pogo_e02/pogo_e02.h create mode 100644 board/esg/ima3-mx53/Makefile create mode 100644 board/esg/ima3-mx53/ima3-mx53.c create mode 100644 board/esg/ima3-mx53/imximage.cfg create mode 100644 board/nvidia/common/emc.c create mode 100644 board/nvidia/common/emc.h create mode 100644 board/raidsonic/ib62x0/Makefile create mode 100644 board/raidsonic/ib62x0/ib62x0.c create mode 100644 board/raidsonic/ib62x0/ib62x0.h create mode 100644 board/raidsonic/ib62x0/kwbimage.cfg create mode 100644 board/timll/devkit3250/Makefile create mode 100644 board/timll/devkit3250/devkit3250.c create mode 100644 drivers/block/dwc_ahsata.c create mode 100644 drivers/block/dwc_ahsata.h create mode 100644 drivers/input/input.c create mode 100644 drivers/input/key_matrix.c create mode 100644 drivers/input/tegra-kbc.c create mode 100644 drivers/misc/pmic_dialog.c create mode 100644 drivers/misc/pmic_max8997.c create mode 100644 drivers/power/tps6586x.c create mode 100644 drivers/power/twl6035.c create mode 100644 drivers/serial/lpc32xx_hsuart.c create mode 100644 drivers/video/exynos_fb.c create mode 100644 drivers/video/exynos_fb.h create mode 100644 drivers/video/exynos_fimd.c create mode 100644 drivers/video/exynos_mipi_dsi.c create mode 100644 drivers/video/exynos_mipi_dsi_common.c create mode 100644 drivers/video/exynos_mipi_dsi_common.h create mode 100644 drivers/video/exynos_mipi_dsi_lowlevel.c create mode 100644 drivers/video/exynos_mipi_dsi_lowlevel.h create mode 100644 drivers/video/s6e8ax0.c create mode 100644 include/aes.h create mode 100644 include/configs/devkit3250.h create mode 100644 include/configs/ib62x0.h delete mode 100644 include/configs/igep0030.h rename include/configs/{igep0020.h => igep00x0.h} (91%) create mode 100644 include/configs/ima3-mx53.h create mode 100644 include/configs/pogo_e02.h create mode 100644 include/dialog_pmic.h create mode 100644 include/input.h create mode 100644 include/key_matrix.h create mode 100644 include/linux/input.h create mode 100644 include/max8997_pmic.h create mode 100644 include/tegra-kbc.h create mode 100644 include/tps6586x.h create mode 100644 include/twl6035.h create mode 100644 lib/aes.c create mode 100755 tools/gcc-version.sh
Amicalement,
Dear Albert ARIBAUD,
In message 4FB1FE52.6060404@aribaud.net you wrote:
Hi Wolfgang,
Applied, thanks.
Albert ARIBAUD
