[U-Boot] [PATCH v2 0/3] spi: cadence_spi: Adopt Linux DT bindings
Adopt the Linux DT bindings. This also fixes an issue with the indaddrtrig register on the Cadence QSPI device being programmed with the wrong value for the socfpga arch.
Tested on Terasic SoCKit dev board (Altera Cyclone V)
Jason Rush (3): spi: cadence_spi: Sync DT bindings with Linux dts: cadence_spi: Sync DT bindings with Linux config: cadence_spi: Remove defines read from DT
arch/arm/dts/keystone-k2g.dtsi | 5 +++-- arch/arm/dts/socfpga.dtsi | 5 +++-- arch/arm/dts/socfpga_arria10.dtsi | 4 ++-- arch/arm/dts/socfpga_arria5_socdk.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_is1.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_socdk.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_sockit.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_socrates.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_vining_fpga.dts | 18 ++++++++---------- arch/arm/dts/stv0991.dts | 12 +++++++----- drivers/spi/cadence_qspi.c | 20 ++++++++++++-------- drivers/spi/cadence_qspi.h | 6 +++++- drivers/spi/cadence_qspi_apb.c | 15 ++++----------- include/configs/k2g_evm.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/stv0991.h | 1 - 17 files changed, 68 insertions(+), 74 deletions(-)
-- 2.1.4
Adopt the Linux DT bindings. This also fixes an issue with the indaddrtrig register on the Cadence QSPI device being programmed with the wrong value for the socfpga arch. --- drivers/spi/cadence_qspi.c | 20 ++++++++++++-------- drivers/spi/cadence_qspi.h | 6 +++++- drivers/spi/cadence_qspi_apb.c | 15 ++++----------- 3 files changed, 21 insertions(+), 20 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 9a6e41f..991a716 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -212,7 +212,7 @@ static int cadence_spi_xfer(struct udevice *dev, unsigned int bitlen,
/* Set Chip select */ cadence_qspi_apb_chipselect(base, spi_chip_select(dev), - CONFIG_CQSPI_DECODER); + plat->is_decoded_cs);
if ((flags & SPI_XFER_END) || (flags == 0)) { if (priv->cmd_len == 0) { @@ -296,7 +296,11 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus)
plat->regbase = (void *)data[0]; plat->ahbbase = (void *)data[2]; - plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128); + plat->is_decoded_cs = fdtdec_get_bool(blob, node, "cdns,is-decoded-cs"); + plat->fifo_depth = fdtdec_get_uint(blob, node, "cdns,fifo-depth", 128); + plat->fifo_width = fdtdec_get_uint(blob, node, "cdns,fifo-width", 4); + plat->trigger_address = fdtdec_get_uint(blob, node, + "cdns,trigger-address", 0);
/* All other paramters are embedded in the child node */ subnode = fdt_first_subnode(blob, node); @@ -310,12 +314,12 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) 500000);
/* Read other parameters from DT */ - plat->page_size = fdtdec_get_int(blob, subnode, "page-size", 256); - plat->block_size = fdtdec_get_int(blob, subnode, "block-size", 16); - plat->tshsl_ns = fdtdec_get_int(blob, subnode, "tshsl-ns", 200); - plat->tsd2d_ns = fdtdec_get_int(blob, subnode, "tsd2d-ns", 255); - plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20); - plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); + plat->page_size = fdtdec_get_uint(blob, subnode, "page-size", 256); + plat->block_size = fdtdec_get_uint(blob, subnode, "block-size", 16); + plat->tshsl_ns = fdtdec_get_uint(blob, subnode, "cdns,tshsl-ns", 200); + plat->tsd2d_ns = fdtdec_get_uint(blob, subnode, "cdns,tsd2d-ns", 255); + plat->tchsh_ns = fdtdec_get_uint(blob, subnode, "cdns,tchsh-ns", 20); + plat->tslch_ns = fdtdec_get_uint(blob, subnode, "cdns,tslch-ns", 20);
debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->ahbbase, plat->max_hz, diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index d1927a4..8315421 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -18,14 +18,18 @@ struct cadence_spi_platdata { unsigned int max_hz; void *regbase; void *ahbbase; + bool is_decoded_cs; + u32 fifo_depth; + u32 fifo_width; + u32 trigger_address;
+ // Flash parameters u32 page_size; u32 block_size; u32 tshsl_ns; u32 tsd2d_ns; u32 tchsh_ns; u32 tslch_ns; - u32 sram_size; };
struct cadence_spi_priv { diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index e02f221..8309ab8 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -37,10 +37,6 @@ #define CQSPI_REG_RETRY 10000 #define CQSPI_POLL_IDLE_RETRY 3
-#define CQSPI_FIFO_WIDTH 4 - -#define CQSPI_REG_SRAM_THRESHOLD_WORDS 50 - /* Transfer mode */ #define CQSPI_INST_TYPE_SINGLE 0 #define CQSPI_INST_TYPE_DUAL 1 @@ -51,9 +47,6 @@ #define CQSPI_DUMMY_CLKS_PER_BYTE 8 #define CQSPI_DUMMY_BYTES_MAX 4
-#define CQSPI_REG_SRAM_FILL_THRESHOLD \ - ((CQSPI_REG_SRAM_SIZE_WORD / 2) * CQSPI_FIFO_WIDTH) - /**************************************************************************** * Controller's configuration and status register (offset from QSPI_BASE) ****************************************************************************/ @@ -400,7 +393,7 @@ void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat) writel(0, plat->regbase + CQSPI_REG_REMAP);
/* Indirect mode configurations */ - writel((plat->sram_size/2), plat->regbase + CQSPI_REG_SRAMPARTITION); + writel((plat->fifo_depth/2), plat->regbase + CQSPI_REG_SRAMPARTITION);
/* Disable all interrupts */ writel(0, plat->regbase + CQSPI_REG_IRQMASK); @@ -560,7 +553,7 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat, addr_bytes = cmdlen - 1;
/* Setup the indirect trigger address */ - writel((u32)plat->ahbbase, + writel(plat->trigger_address, plat->regbase + CQSPI_REG_INDIRECTTRIGGER);
/* Configure the opcode */ @@ -659,7 +652,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, bytes_to_read = ret;
while (bytes_to_read != 0) { - bytes_to_read *= CQSPI_FIFO_WIDTH; + bytes_to_read *= plat->fifo_width; bytes_to_read = bytes_to_read > remaining ? remaining : bytes_to_read; readsl(plat->ahbbase, bb_rxbuf, bytes_to_read >> 2); @@ -710,7 +703,7 @@ int cadence_qspi_apb_indirect_write_setup(struct cadence_spi_platdata *plat, return -EINVAL; } /* Setup the indirect trigger address */ - writel((u32)plat->ahbbase, + writel(plat->trigger_address, plat->regbase + CQSPI_REG_INDIRECTTRIGGER);
Adopt the Linux DT bindings and clean-up duplicate and unused values. --- arch/arm/dts/keystone-k2g.dtsi | 5 +++-- arch/arm/dts/socfpga.dtsi | 5 +++-- arch/arm/dts/socfpga_arria10.dtsi | 4 ++-- arch/arm/dts/socfpga_arria5_socdk.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_is1.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_socdk.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_sockit.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_socrates.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_vining_fpga.dts | 18 ++++++++---------- arch/arm/dts/stv0991.dts | 12 +++++++----- 11 files changed, 47 insertions(+), 51 deletions(-)
diff --git a/arch/arm/dts/keystone-k2g.dtsi b/arch/arm/dts/keystone-k2g.dtsi index 191e3f1..c099011 100644 --- a/arch/arm/dts/keystone-k2g.dtsi +++ b/arch/arm/dts/keystone-k2g.dtsi @@ -96,8 +96,9 @@ <0x24000000 0x4000000>; interrupts = <GIC_SPI 198 IRQ_TYPE_EDGE_RISING>; num-cs = <4>; - fifo-depth = <256>; - sram-size = <256>; + cdns,fifo-depth = <256>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x24000000>; status = "disabled"; };
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 8588221..7557aa0 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -644,8 +644,9 @@ clocks = <&qspi_clk>; ext-decoder = <0>; /* external decoder */ num-cs = <4>; - fifo-depth = <128>; - sram-size = <128>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x00000000>; bus-num = <2>; status = "disabled"; }; diff --git a/arch/arm/dts/socfpga_arria10.dtsi b/arch/arm/dts/socfpga_arria10.dtsi index 377700d..abfd0bc 100644 --- a/arch/arm/dts/socfpga_arria10.dtsi +++ b/arch/arm/dts/socfpga_arria10.dtsi @@ -734,8 +734,8 @@ clocks = <&l4_main_clk>; ext-decoder = <0>; /* external decoder */ num-chipselect = <4>; - fifo-depth = <128>; - sram-size = <512>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; bus-num = <2>; status = "disabled"; }; diff --git a/arch/arm/dts/socfpga_arria5_socdk.dts b/arch/arm/dts/socfpga_arria5_socdk.dts index 7265058..1e91a65 100644 --- a/arch/arm/dts/socfpga_arria5_socdk.dts +++ b/arch/arm/dts/socfpga_arria5_socdk.dts @@ -94,10 +94,9 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; }; diff --git a/arch/arm/dts/socfpga_cyclone5_is1.dts b/arch/arm/dts/socfpga_cyclone5_is1.dts index 16a3283..2e2b71f 100644 --- a/arch/arm/dts/socfpga_cyclone5_is1.dts +++ b/arch/arm/dts/socfpga_cyclone5_is1.dts @@ -93,11 +93,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; };
diff --git a/arch/arm/dts/socfpga_cyclone5_socdk.dts b/arch/arm/dts/socfpga_cyclone5_socdk.dts index f175ef2..95a8e65 100644 --- a/arch/arm/dts/socfpga_cyclone5_socdk.dts +++ b/arch/arm/dts/socfpga_cyclone5_socdk.dts @@ -104,11 +104,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; };
diff --git a/arch/arm/dts/socfpga_cyclone5_sockit.dts b/arch/arm/dts/socfpga_cyclone5_sockit.dts index e45c2ab..6f42b88 100644 --- a/arch/arm/dts/socfpga_cyclone5_sockit.dts +++ b/arch/arm/dts/socfpga_cyclone5_sockit.dts @@ -84,11 +84,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; };
diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index bdd9324..e3ae8a8 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -74,11 +74,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; };
diff --git a/arch/arm/dts/socfpga_cyclone5_sr1500.dts b/arch/arm/dts/socfpga_cyclone5_sr1500.dts index 739bbb7..e24830a 100644 --- a/arch/arm/dts/socfpga_cyclone5_sr1500.dts +++ b/arch/arm/dts/socfpga_cyclone5_sr1500.dts @@ -92,10 +92,9 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; }; diff --git a/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts b/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts index f168e4f..a0febe9 100644 --- a/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts +++ b/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts @@ -79,11 +79,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; };
flash1: n25q00@1 { @@ -96,11 +95,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - read-delay = <4>; /* delay value in read data capture register */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; };
diff --git a/arch/arm/dts/stv0991.dts b/arch/arm/dts/stv0991.dts index fa3fd64..bceac09 100644 --- a/arch/arm/dts/stv0991.dts +++ b/arch/arm/dts/stv0991.dts @@ -32,7 +32,9 @@ reg = <0x80203000 0x100>, <0x40000000 0x1000000>; clocks = <3750000>; - sram-size = <256>; + cdns,fifo-depth = <256>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x40000000>; status = "okay";
flash0: n25q32@0 { @@ -44,10 +46,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */ - tshsl-ns = <50>; - tsd2d-ns = <50>; - tchsh-ns = <4>; - tslch-ns = <4>; + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; }; }; };
Thanks for doing this patch! Could you change the bindings for delay values in arch/arm/dts/keystone-k2g-evm.dts as well? Since, you are removing support for old bindings, QSPI will no longer in U-Boot on K2G. These bindings don't exist in upstream kernel DT as K2G is not completely supported in mainline yet, but will be added shortly.
Thanks indeed, someone finally did what needed to be done for a LONG time. Appreciated.
I must have missed that dts file. I'll submit a v3 with it included.
Cleanup unused #define values that are read from the DT. --- include/configs/k2g_evm.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/stv0991.h | 1 - 3 files changed, 3 deletions(-)
diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index bee1be7..eb3a03a 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -75,7 +75,6 @@ #ifndef CONFIG_SPL_BUILD #define CONFIG_CADENCE_QSPI #define CONFIG_CQSPI_REF_CLK 384000000 -#define CONFIG_CQSPI_DECODER 0x0 #define CONFIG_BOUNCE_BUFFER #endif
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index da7e4ad..0923cf0 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -200,7 +200,6 @@ unsigned int cm_get_l4_sp_clk_hz(void); unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_CQSPI_REF_CLK cm_get_qspi_controller_clk_hz() #endif -#define CONFIG_CQSPI_DECODER 0 #define CONFIG_BOUNCE_BUFFER
/* diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 2f808c6..a13f5bf 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -68,7 +68,6 @@ + * QSPI support + */ #ifdef CONFIG_OF_CONTROL /* QSPI is controlled via DT */ -#define CONFIG_CQSPI_DECODER 0 #define CONFIG_CQSPI_REF_CLK ((30/4)/2)*1000*1000 #define CONFIG_BOUNCE_BUFFER
Jason Rush
Vignesh R
