[U-Boot] [PATCH] arm64: zynqmp: Update nand device tree node properties
From: Naga Sureshkumar Relli naga.sureshkumar.relli@xilinx.com
This patch updates the nand device tree node properties as per updated driver.
Signed-off-by: Naga Sureshkumar Relli nagasure@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 104 +++++++++++++---------- arch/arm/dts/zynqmp.dtsi | 4 +- 2 files changed, 59 insertions(+), 49 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts index 1cc469d93fb5..1cc8aaa87976 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts @@ -119,56 +119,66 @@ &nand0 { status = "okay"; arasan,has-mdma; - num-cs = <2>;
- partition@0 { /* for testing purpose */ - label = "nand-fsbl-uboot"; - reg = <0x0 0x0 0x400000>; - }; - partition@1 { /* for testing purpose */ - label = "nand-linux"; - reg = <0x0 0x400000 0x1400000>; - }; - partition@2 { /* for testing purpose */ - label = "nand-device-tree"; - reg = <0x0 0x1800000 0x400000>; - }; - partition@3 { /* for testing purpose */ - label = "nand-rootfs"; - reg = <0x0 0x1C00000 0x1400000>; - }; - partition@4 { /* for testing purpose */ - label = "nand-bitstream"; - reg = <0x0 0x3000000 0x400000>; - }; - partition@5 { /* for testing purpose */ - label = "nand-misc"; - reg = <0x0 0x3400000 0xFCC00000>; - }; + nand@0 { + reg = <0x0>; + #address-cells = <0x2>; + #size-cells = <0x1>;
- partition@6 { /* for testing purpose */ - label = "nand1-fsbl-uboot"; - reg = <0x1 0x0 0x400000>; - }; - partition@7 { /* for testing purpose */ - label = "nand1-linux"; - reg = <0x1 0x400000 0x1400000>; - }; - partition@8 { /* for testing purpose */ - label = "nand1-device-tree"; - reg = <0x1 0x1800000 0x400000>; - }; - partition@9 { /* for testing purpose */ - label = "nand1-rootfs"; - reg = <0x1 0x1C00000 0x1400000>; - }; - partition@10 { /* for testing purpose */ - label = "nand1-bitstream"; - reg = <0x1 0x3000000 0x400000>; + partition@0 { /* for testing purpose */ + label = "nand-fsbl-uboot"; + reg = <0x0 0x0 0x400000>; + }; + partition@1 { /* for testing purpose */ + label = "nand-linux"; + reg = <0x0 0x400000 0x1400000>; + }; + partition@2 { /* for testing purpose */ + label = "nand-device-tree"; + reg = <0x0 0x1800000 0x400000>; + }; + partition@3 { /* for testing purpose */ + label = "nand-rootfs"; + reg = <0x0 0x1c00000 0x1400000>; + }; + partition@4 { /* for testing purpose */ + label = "nand-bitstream"; + reg = <0x0 0x3000000 0x400000>; + }; + partition@5 { /* for testing purpose */ + label = "nand-misc"; + reg = <0x0 0x3400000 0xfcc00000>; + }; }; - partition@11 { /* for testing purpose */ - label = "nand1-misc"; - reg = <0x1 0x3400000 0xFCC00000>; + nand@1 { + reg = <0x1>; + #address-cells = <0x2>; + #size-cells = <0x1>; + + partition@0 { /* for testing purpose */ + label = "nand1-fsbl-uboot"; + reg = <0x0 0x0 0x400000>; + }; + partition@1 { /* for testing purpose */ + label = "nand1-linux"; + reg = <0x0 0x400000 0x1400000>; + }; + partition@2 { /* for testing purpose */ + label = "nand1-device-tree"; + reg = <0x0 0x1800000 0x400000>; + }; + partition@3 { /* for testing purpose */ + label = "nand1-rootfs"; + reg = <0x0 0x1c00000 0x1400000>; + }; + partition@4 { /* for testing purpose */ + label = "nand1-bitstream"; + reg = <0x0 0x3000000 0x400000>; + }; + partition@5 { /* for testing purpose */ + label = "nand1-misc"; + reg = <0x0 0x3400000 0xfcc00000>; + }; }; };
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 06e88ee1b4d2..337922f8a966 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -532,8 +532,8 @@ clock-names = "clk_sys", "clk_flash"; interrupt-parent = <&gic>; interrupts = <0 14 4>; - #address-cells = <2>; - #size-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x872>; };
po 14. 10. 2019 v 16:12 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
num-cs = <2>;
nand@0 {
reg = <0x0>;
nand@1 {
reg = <0x1>;
#size-cells = <1>;
-- 2.17.1
Applied. M
Michal Simek
Michal Simek
