[U-Boot] Stale references in the u-boot-samsung repo
Hi Minkyu,
While fetching u-boot-samsung, I could see the following messages:
remote: error: refs/remotes/origin/GPL-Cleanup does not point to a valid object!
remote: error: refs/remotes/origin/i.MX31 does not point to a valid object!
remote: error: refs/remotes/origin/lwmon5 does not point to a valid object!
remote: error: refs/remotes/origin/mkimage does not point to a valid object!
It looks like these branches that were pushed on the remote, then later the commit to which they point was cleaned up.
Can you fix this? Thanks in advance!
Amicalement,
Hi Albert,
On 06/12/13 17:44, Albert ARIBAUD wrote:
Hi Minkyu,
Please let me know how I can fix it!
Amicalement,
Thanks, Minkyu Kang.
Hi Minkyu,
On Fri, 06 Dec 2013 19:44:28 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Hi Albert,
Hi Minkyu,
For branches which you still need to publish and for which are correct in your working repo, you can do a push as you would for master or next, e.g.
git push [...] branchname:branchname
where branchname should be replaced (on both sides of the colon) with the actual name of the branch you want to update.
For branches which you don't need to publish any more, you can remove them on the Denx repo with:
git push [...] :branchname
where there is nothing on the left side of the colon, and branchname is replaced with the actual name of the branch you want to remove.
Amicalement,
On Fri, Dec 06, 2013 at 09:44:22AM +0100, Albert ARIBAUD wrote:
Hi Minkyu,
Note that these aren't a u-boot-samsung specific problem, I see this too for master, but have just ignored it.
Albert ARIBAUD
Minkyu Kang
