[U-Boot] [PATCH 1/3] Update Makefile for new dirs to be included in tag list
Signed-off-by: Li Yang leoli@freescale.com --- Makefile | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index bcb3fe9..4d71366 100644 --- a/Makefile +++ b/Makefile @@ -406,6 +406,8 @@ TAG_SUBDIRS += include TAG_SUBDIRS += lib_generic board/$(BOARDDIR) TAG_SUBDIRS += cpu/$(CPU) TAG_SUBDIRS += lib_$(ARCH) +TAG_SUBDIRS += $(shell if [ -d board/$(VENDOR)/common ]; then echo \ + "board/$(VENDOR)/common"; fi) TAG_SUBDIRS += fs/cramfs TAG_SUBDIRS += fs/fat TAG_SUBDIRS += fs/fdos @@ -414,6 +416,7 @@ TAG_SUBDIRS += fs/yaffs2 TAG_SUBDIRS += net TAG_SUBDIRS += disk TAG_SUBDIRS += common +TAG_SUBDIRS += libfdt TAG_SUBDIRS += drivers/bios_emulator TAG_SUBDIRS += drivers/block TAG_SUBDIRS += drivers/gpio
For removing node easily by path or alias.
Signed-off-by: Li Yang leoli@freescale.com --- common/fdt_support.c | 10 ++++++++++ include/fdt_support.h | 1 + 2 files changed, 11 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index f89a3ee..8f1186e 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -757,3 +757,13 @@ int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size) return -1; } #endif + +int fdt_del_node_by_path(void *fdt, const char *path) +{ + int off = fdt_path_offset(fdt, path); + + if (off >= 0) + return fdt_del_node(fdt, off); + else + return off; +} diff --git a/include/fdt_support.h b/include/fdt_support.h index 0a9dd0d..d0705d1 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -80,6 +80,7 @@ void set_working_fdt_addr(void *addr); int fdt_resize(void *blob);
int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size); +int fdt_del_node_by_path(void *fdt, const char *path);
#endif /* ifdef CONFIG_OF_LIBFDT */ #endif /* ifndef __FDT_SUPPORT_H */
Signed-off-by: Li Yang leoli@freescale.com --- include/asm-ppc/fsl_law.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/fsl_law.h b/include/asm-ppc/fsl_law.h index 31bb754..34c56a2 100644 --- a/include/asm-ppc/fsl_law.h +++ b/include/asm-ppc/fsl_law.h @@ -46,6 +46,8 @@ enum law_size { LAW_SIZE_32G, };
+#define law_size_bits(sz) (__ilog2_u64(sz) - 1) + #ifdef CONFIG_FSL_CORENET enum law_trgt_if { LAW_TRGT_IF_PCIE_1 = 0x00, @@ -78,6 +80,7 @@ enum law_trgt_if { LAW_TRGT_IF_CCSR = 0x08, LAW_TRGT_IF_DDR_INTRLV = 0x0b, LAW_TRGT_IF_RIO = 0x0c, + LAW_TRGT_IF_RIO_2 = 0x0d, LAW_TRGT_IF_DDR = 0x0f, LAW_TRGT_IF_DDR_2 = 0x16, /* 2nd controller */ };
applied to 85xx-next
- k
Hi Li,
- int off = fdt_path_offset(fdt, path);
- if (off >= 0)
- else
return off;
This seems like a reasonable function, but I don't see it used anywhere?
Best regards, gvb
Subject: Re: [U-Boot] [PATCH 2/3] fdt: add fdt_del_node_by_path() API
Hi Li,
return -1; } #endif
+int fdt_del_node_by_path(void *fdt, const char *path) {
- if (off >= 0)
- else
return off;
It will be used in patches to be submitted, we want to remove the nodes of devices which are not enabled depending on the board configuration.
- Leo
Dear "Li Yang-R58472",
In message 3A45394FD742FA419B760BB8D398F9EDE667CD@zch01exm26.fsl.freescale.net you wrote:
The rule is that we don't add dead code, so this patch should be part of a patch series that also adds users of this new code.
In message <3A45394FD742FA419B760BB8D398F9EDE667CD@zch01exm26.fsl.freescal e.net> you wrote:
All right. I will include this in the patch series to come.
- Leo
Dear Li Yang,
- "board/$(VENDOR)/common"; fi)
Would it not be easier to do something like
TAG_SUBDIRS = $(dir $(LIBS))
and get rid of all these duplicated settings?
[Warning: untested!]
Subject: Re: [U-Boot] [PATCH 1/3] Update Makefile for new dirs to be included in tag list
Dear Li Yang,
lib_generic
Should be $(__LIBS)
Great idea! I will come up a patch.
- Leo
On Wednesday 09 December 2009 01:26:06 Li Yang wrote:
diff --git a/Makefile b/Makefile index bcb3fe9..4d71366 100644 --- a/Makefile +++ b/Makefile +TAG_SUBDIRS += $(shell if [ -d board/$(VENDOR)/common ]; then echo \
ugh, dont do that. using $(shell) is awful. if you need to do things based on a dynamic path, use: ifneq ($(wildcard some/path),) ... endif
perhaps even better would be to let each dir define a tags.in or something and have the toplevel Makefile source that -mike
nm, Wolfgang proposed a better idea already -mike
participants (6)
Jerry Van Baren
Kumar Gala
Li Yang
Li Yang-R58472
Mike Frysinger
