[U-Boot] [PATCH] mtd: ubi: Add missing newlines in ubi_init()
I just stumbled over some cluttered UBI messages. It seems some newline chars are missing in the current U-Boot UBI source. Lets fix this in U-Boot as well (Linux has those fixes already).
Signed-off-by: Stefan Roese sr@denx.de Cc: Heiko Schocher hs@denx.de --- drivers/mtd/ubi/build.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c index 0198d8bfa8..42c5270c7f 100644 --- a/drivers/mtd/ubi/build.c +++ b/drivers/mtd/ubi/build.c @@ -1250,7 +1250,7 @@ int ubi_init(void) BUILD_BUG_ON(sizeof(struct ubi_vid_hdr) != 64);
if (mtd_devs > UBI_MAX_DEVICES) { - pr_err("UBI error: too many MTD devices, maximum is %d", + pr_err("UBI error: too many MTD devices, maximum is %d\n", UBI_MAX_DEVICES); return -EINVAL; } @@ -1262,7 +1262,7 @@ int ubi_init(void)
err = misc_register(&ubi_ctrl_cdev); if (err) { - pr_err("UBI error: cannot register device"); + pr_err("UBI error: cannot register device\n"); goto out; }
@@ -1289,7 +1289,7 @@ int ubi_init(void) mtd = open_mtd_device(p->name); if (IS_ERR(mtd)) { err = PTR_ERR(mtd); - pr_err("UBI error: cannot open mtd %s, error %d", + pr_err("UBI error: cannot open mtd %s, error %d\n", p->name, err); /* See comment below re-ubi_is_module(). */ if (ubi_is_module()) @@ -1302,7 +1302,7 @@ int ubi_init(void) p->vid_hdr_offs, p->max_beb_per1024); mutex_unlock(&ubi_devices_mutex); if (err < 0) { - pr_err("UBI error: cannot attach mtd%d", + pr_err("UBI error: cannot attach mtd%d\n", mtd->index); put_mtd_device(mtd);
@@ -1326,7 +1326,7 @@ int ubi_init(void)
err = ubiblock_init(); if (err) { - pr_err("UBI error: block: cannot initialize, error %d", err); + pr_err("UBI error: block: cannot initialize, error %d\n", err);
/* See comment above re-ubi_is_module(). */ if (ubi_is_module()) @@ -1353,7 +1353,7 @@ out: mtd_devs = 0; #endif class_unregister(&ubi_class); - pr_err("UBI error: cannot initialize UBI, error %d", err); + pr_err("UBI error: cannot initialize UBI, error %d\n", err); return err; } late_initcall(ubi_init);
Hello Stefan,
Am 29.05.2018 um 15:28 schrieb Stefan Roese:
Applied to u-boot-ubi.git master
Thanks!
bye, Heiko
Heiko Schocher
Stefan Roese
