[U-Boot] Please pull ARC changes
Hi Tom,
he following changes since commit a1588ac8228881f9fe65539fa8e31f0ee3556864:
Merge tag 'rockchip-for-v2018.11' of git://git.denx.de/u-boot-rockchip (2018-10-03 12:09:19 -0400)
git://git.denx.de/u-boot-arc.git tags/arc-updates-for-2018.11-rc2
for you to fetch changes up to 5396e8b1dd0ad9741b04f506ef88b5fb49d4c82a:
arc: Add support for IoT development kit (2018-10-05 16:57:00 +0300)
---------------------------------------------------------------- Here we do a couple of impovements for all ARC boards as well as introduce yet another developemnt board.
1. Now for ARC boards we print CPU and board info which is useful for users and helps with analysis of logs "post-mortem".
2. Synopsys IoT development kit support is added This one might be a bit too late as we're past RC1 but: 1) This doesn't affect any other arches etc as we change purely ARC code. 2) I've got a chance to talk about U-Boot on IoT platforms during ELCE (my proposal was on a wait list and only this week I've got an update and invitation to talk) so it would be good to have this board as a primer in upstream code-base by the time of ELCE 2018. 3) For complete support of IoT devkit I'm yet to significantly rework regmap subsystem in U-Boot but that's a different topic and hopefully it will be done sometime soon... though not this release cycle for sure.
---------------------------------------------------------------- Alexey Brodkin (5): ARC: Don't pre-define CROSS_COMPILE ARC: Add model property to boards .dts ARC: Implement print_cpuinfo() ARC: Enable DISPLAY_CPUINFO & DISPLAY_BOARDINFO arc: Add support for IoT development kit
arch/arc/Kconfig | 5 +++++ arch/arc/config.mk | 6 ------ arch/arc/dts/Makefile | 1 + arch/arc/dts/abilis_tb100.dts | 2 ++ arch/arc/dts/axs101.dts | 2 ++ arch/arc/dts/axs103.dts | 2 ++ arch/arc/dts/emdk.dts | 2 ++ arch/arc/dts/hsdk.dts | 2 ++ arch/arc/dts/iot_devkit.dts | 45 ++++++++++++++++++++++++++++++++++++++++++++ arch/arc/dts/nsim.dts | 2 ++ arch/arc/lib/cpu.c | 35 ++++++++++++++++++++++++++++++++++- board/synopsys/iot_devkit/Kconfig | 12 ++++++++++++ board/synopsys/iot_devkit/MAINTAINERS | 5 +++++ board/synopsys/iot_devkit/Makefile | 7 +++++++ board/synopsys/iot_devkit/config.mk | 2 ++ board/synopsys/iot_devkit/iot_devkit.c | 168 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++ board/synopsys/iot_devkit/u-boot.lds | 77 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ common/Kconfig | 4 ++-- configs/iot_devkit_defconfig | 38 ++++++++++++++++++++++++++++++++++++++ include/configs/iot_devkit.h | 84 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 20 files changed, 492 insertions(+), 9 deletions(-) create mode 100644 arch/arc/dts/iot_devkit.dts create mode 100644 board/synopsys/iot_devkit/Kconfig create mode 100644 board/synopsys/iot_devkit/MAINTAINERS create mode 100644 board/synopsys/iot_devkit/Makefile create mode 100644 board/synopsys/iot_devkit/config.mk create mode 100644 board/synopsys/iot_devkit/iot_devkit.c create mode 100644 board/synopsys/iot_devkit/u-boot.lds create mode 100644 configs/iot_devkit_defconfig create mode 100644 include/configs/iot_devkit.h
-Alexey
On Fri, Oct 05, 2018 at 02:10:16PM +0000, Alexey Brodkin wrote:
Hi Tom,
Alexey Brodkin
