[U-Boot] Zoom2 Fix serial setup
This patch is against u-boot-ti/master
I run tested this on Zoom2.
Tom
The offset to the chip select is incorrect.
The change 187af954cf7958c24efcf0fd62289bbdb4f1f24e,
omap3: embedd gpmc_cs into gpmc config struct
introduced a problem with the serial gpmc setup.
This patch reverts the chip select to its previous value.
The symptoms of this problem are that the Zoom2 currently hangs.
This was run tested on Zoom2.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- board/logicpd/zoom2/zoom2.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/logicpd/zoom2/zoom2.c b/board/logicpd/zoom2/zoom2.c index d9e2ae5..cd8c9fe 100644 --- a/board/logicpd/zoom2/zoom2.c +++ b/board/logicpd/zoom2/zoom2.c @@ -129,7 +129,7 @@ int board_init (void)
/* Configure console support on zoom2 */ gpmc_config = gpmc_serial_TL16CP754C; - enable_gpmc_cs_config(gpmc_config, &gpmc_cfg->cs[4], + enable_gpmc_cs_config(gpmc_config, &gpmc_cfg->cs[3], SERIAL_TL16CP754C_BASE, GPMC_SIZE_16M);
/* board id for Linux */
-- 1.6.0.6
Tom,
I'll push this the moment we resolves some of our OMAP3 issues.
Thanks, Sandeep
-- 1.6.0.6
Tom,
Thanks! Tom
Thanks, Sandeep
Pushed to u-boot-ti master
http://git.denx.de/?p=u-boot/u-boot-ti.git;a=commitdiff;h=277651e76c7af164bc...
Once we resolve some of our OMAP3 issues I will push the appropriate patches to u-boot-ti master. Those patches are currently in u-boot-ti next
Thanks, Sandeep
Paulraj, Sandeep
Tom Rix
Tom Rix
