[U-Boot] [PATCH] serial: pl01x: Get clock from clock node if no clock property found
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch gets clock from clock nodes if no clock property found in serial node.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/serial/serial_pl01x.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index 2a5f256184f2..f4f33b13ff33 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -10,6 +10,7 @@
/* Simple U-Boot driver for the PrimeCell PL010/PL011 UARTs */
+#include <clk.h> #include <common.h> #include <dm.h> #include <errno.h> @@ -341,6 +342,9 @@ int pl01x_serial_ofdata_to_platdata(struct udevice *dev) { struct pl01x_serial_platdata *plat = dev_get_platdata(dev); fdt_addr_t addr; + unsigned long clock; + int ret; + struct clk clk;
addr = devfdt_get_addr(dev); if (addr == FDT_ADDR_T_NONE) @@ -348,6 +352,28 @@ int pl01x_serial_ofdata_to_platdata(struct udevice *dev)
plat->base = addr; plat->clock = dev_read_u32_default(dev, "clock", 1); + if (plat->clock == 1) { + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) { + dev_err(dev, "failed to get clock\n"); + return ret; + } + + clock = clk_get_rate(&clk); + if (IS_ERR_VALUE(clock)) { + dev_err(dev, "failed to get rate\n"); + return clock; + } + debug("%s: CLK %ld\n", __func__, clock); + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } + plat->clock = clock; + } + plat->type = dev_get_driver_data(dev); plat->skip_init = dev_read_bool(dev, "skip-init");
Is this what Linux does? If so, you probably want to explicitly state that.
Alex
yes. Linux does that. On the other hand reading clock property is something what it is out of dt binding spec.
Thanks, Michal
In that case, please at least note that in the patch description or maybe even in a comment in the code, so the next time someone looks at the code they don't get confused :).
Speaking of which, why isn't this handled generically already? I was expecting that find clocks would be a matter of 2 lines of code - or maybe none thanks to magic.
Alex
Right now I have removed this patch from my PR because it is breaking generic arm/arm64 model because there are missing some dt patches on qemu side. Look at our discussing in my PR to Tom done yesterday.
It depends.
M
Alexander Graf
Michal Simek
