[PATCH] usb: Ignore endpoints in non-zero altsettings
We currently do not really handle altsettings properly, and no driver uses them. Ignore the respective endpoint descriptors for secondary altsettings, to avoid creating duplicate endpoint records in the interface.
This will have to be revisited if/when we have a driver that needs altsettings to work properly.
Signed-off-by: Hector Martin marcan@marcan.st --- common/usb.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/common/usb.c b/common/usb.c index aad13fd9c557..90f72fda00bc 100644 --- a/common/usb.c +++ b/common/usb.c @@ -463,6 +463,15 @@ static int usb_parse_config(struct usb_device *dev, puts("Endpoint descriptor out of order!\n"); break; } + if (if_desc->num_altsetting > 1) { + /* + * Ignore altsettings, which can trigger duplicate + * endpoint errors below. Revisit this when some + * driver actually needs altsettings with differing + * endpoint setups. + */ + break; + } epno = dev->config.if_desc[ifno].no_of_ep; if_desc = &dev->config.if_desc[ifno]; if (epno >= USB_MAXENDPOINTS) {
--- base-commit: 8ad1c9c26f7740806a162818b790d4a72f515b7e change-id: 20231029-usb-fixes-4-ba6931acf217
* endpoint setups.
How do you trigger this error ?
* endpoint setups.
Plug in a device with altsettings, like most sound cards or UVC devices.
- Hector
* endpoint setups.
Please add that to the commit message.
* endpoint setups.
break;
Irritating, but makes sense.
Reviewed-by: Neal Gompa neal@gompa.dev
-- 真実はいつも一つ!/ Always, there's only one truth!
Hector Martin
Neal Gompa
