[U-Boot] ip address confusion.
Our office network runs on
10.213.1.1/24
so all addresses in 10.212 and 10.213 should be local.
and I have a TFTP server on 10.213.1.105
if I set my office pc to 10.212.0.99 I can ping 10.213.1.105
so far so good
----------------------------------------- if I set u-boot up so the printenv at power-on looks like
ethaddr=00:90:46:20:000:99 eth1addr=00:90:46:20:100:99 ipaddr=10.212.000.99 serverip=10.213.1.105 gatewayip=10.213.1.1 netmask=255.254.0.0 bootfile=99/uImage ethact=macb1
then if I do
ping 10.213.1.105
it fails.
but after setting
setenv ipaddr 10.213.0.99
it works
Can anyone suggest why?
David Collier
www.dexdyne.com
10.213.1.1/24
10.213.1.1/15 per your netmask.
so far so good
then if I do
ping 10.213.1.105
it fails.
but after setting
it works
It smells like your netmask is not what you think it is. The difference in the addresses is .212. vs. .213. and it sounds like a gateway issue. Note that your gateway is in .213. land so, if your netmask is 255.255.0.0, the gateway will not be reachable from .212. land.
Please capture your console interaction and post it directly. Your list above is playing Chinese Whispers, resulting in unreliable communications. http://en.wikipedia.org/wiki/Chinese_whispers You may also want to do a printenv before and after (critical) commands to verify things didn't change on you.
FWIIW, when someone asks me "why doesn't the system do X" or says "the system did X", I *always* say "show me" - users often filter out important information because they don't realize that it is important... which is exactly why the system isn't doing X and exactly why the user is surprised by that.
David Collier
gvb
David,
On Fri, Oct 23, 2009 at 5:32 AM, David Collier from_denx_uboot@dexdyne.comwrote:
10.213.1.1/24
As Jerry mentioned, this is not correct. 10.212 and 10.213 are on different subnets if your mask is 24 bits in size:
10.212 = 0b00001010.0b11010100 10.213 = 0b00001010.0b11010101
As you can see, they only have 15 bits in common, so for them to be in the same subnet (no routing required) your network would have to be 10.212.0.0/15 at the minimum.
If this is so and the netmask listed above is correct, there's probably a router on 10.212. Running traceroute will tell you for sure.
so far so good
Try setting this to 10.212.1.1 and see what happens.
then if I do
ping 10.213.1.105
it fails.
but after setting
No surprise.
it works
David Collier
regards,
Ben
pardon me everyone - I'm an idiot.
Sorry.
David
In article <memo.20091023133244.2092V@postmaster+dexdyne.com.cix.co.uk>, from_denx_uboot@dexdyne.com (David Collier) wrote:
*From:* "David Collier" from_denx_uboot@dexdyne.com *To:* u-boot@lists.denx.de *Date:* Fri, 23 Oct 2009 13:32 +0100 (BST)
10.213.1.1/24
so far so good
then if I do
ping 10.213.1.105
it fails.
but after setting
it works
David Collier
www.dexdyne.com _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
David Collier
www.dexdyne.com
right - pardon my stupidity... I mis-typed above...
I've dug into this and I can tftp fine to the server, but it doesn't respond to ping - so I guess it's a setup issue on the ping server s/w
Thanks all for your patience
D.
Ben Warren
David Collier
Jerry Van Baren
