[U-Boot] [PATCH] mmc: introduce mmc_power_init
In device tree, there is vmmc-supply property for SD/MMC. Introduce mmc_power_init function to handle vmmc-supply.
mmc_power_init will first invoke board_mmc_power_init to avoid break boards which already implement board_mmc_power_init.
If DM_MMC and DM_REGULATOR is defined, the regulator will be enabled to power up the device.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com ---
The RFC patset thread: http://lists.denx.de/pipermail/u-boot/2016-April/251019.html V1: Use a generic way to handle vmmc supply, but not let vendor driver to handle it.
drivers/mmc/mmc.c | 30 +++++++++++++++++++++++++++++- 1 file changed, 29 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 0312da9..c361098 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -15,6 +15,7 @@ #include <errno.h> #include <mmc.h> #include <part.h> +#include <power/regulator.h> #include <malloc.h> #include <memalign.h> #include <linux/list.h> @@ -1582,6 +1583,31 @@ __weak void board_mmc_power_init(void) { }
+int mmc_power_init(struct mmc *mmc) +{ + board_mmc_power_init(); + +#if defined(CONFIG_DM_MMC) && defined(CONFIG_DM_REGULATOR) && \ + !defined(CONFIG_SPL_BUILD) + struct udevice *vmmc_supply; + int ret; + + ret = device_get_supply_regulator(mmc->dev, "vmmc-supply", + &vmmc_supply); + if (ret) { + debug("No vmmc supply\n"); + return 0; + } + + ret = regulator_set_enable(vmmc_supply, true); + if (ret) { + puts("Error enabling VMMC supply\n"); + return ret; + } +#endif + return 0; +} + int mmc_start_init(struct mmc *mmc) { bool no_card; @@ -1606,7 +1632,9 @@ int mmc_start_init(struct mmc *mmc) #ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT mmc_adapter_card_type_ident(); #endif - board_mmc_power_init(); + err = mmc_power_init(mmc); + if (err) + return err;
#ifdef CONFIG_DM_MMC_OPS /* The device has already been probed ready for use */
Hi Peng,
As i know, vqmmc-supply should be optional. Do you have a plan to add this?
Can be static?
- !defined(CONFIG_SPL_BUILD)
- struct udevice *vmmc_supply;
- int ret;
- ret = device_get_supply_regulator(mmc->dev, "vmmc-supply",
&vmmc_supply);
- if (ret) {
"return 0" is Right? Doesn't need to return error?
- ret = regulator_set_enable(vmmc_supply, true);
- if (ret) {
return ret;
- err = mmc_power_init(mmc);
- if (err)
return err;
Hi Jaehoon, On Mon, Oct 10, 2016 at 01:19:41PM +0900, Jaehoon Chung wrote:
Hi Peng,
In the dts for my board, there is no vqmmc-supply. So I did not add this. Let me add it in V2 as the following.
" ret = device_get_supply_regulator(mmc->dev, "vqmmc-supply", &vqmmc_supply); if (ret) { debug("No vqmmc supply\n"); return 0; }
ret = regulator_set_enable(vqmmc_supply, true); if (ret) { puts("Error enabling VQMMC supply\n"); return ret; } "
Can be static?
Sure. Fix in V2.
- int ret;
&vmmc_supply);
- if (ret) {
In U-Boot, not every board supports regulator now. Some boards may supports DM MMC, but DM REGULATOR not supported now. So I did not use error code here. Or use puts, but not debug?
Any comments?
Regards, Peng.
Hi Peng,
Hi Peng,
Then just remain this as future work. :) I think there is no use-case in uboot yet..
Can be static?
Sure. Fix in V2.
- int ret;
&vmmc_supply);
- if (ret) {
Ok. Nothing. When you send patch v2, I will apply on u-boot-mmc, after checking. Thanks!
Best Reagrds, Jaehoon Chung
Any comments?
Regards, Peng.
Jaehoon Chung
Peng Fan
Peng Fan
