Hi Tom,
please pull video updates for v2023.07.
CI: https://source.denx.de/u-boot/custodians/u-boot-video/-/pipelines/15944
Thanks, Anatolij
The following changes since commit 340bebf9c799793affefd166875d5776744988bd:
Merge branch '2023-04-06-assorted-updates' (2023-04-07 10:44:19 -0400)
https://source.denx.de/u-boot/custodians/u-boot-video.git tags/video-20230407
for you to fetch changes up to cc54a924cd28a2d1b0f0035bd7d78532b6bc4ad8:
simple_panel: support simple MIPI DSI panels (2023-04-07 19:54:31 +0200)
---------------------------------------------------------------- - fix building sandbox without SDL - improve tegra DC driver to work with panel ops and implement native 180 degree panel rotation support - add T30 support to tegra DC driver - add DSI driver (based on mainline Linux one with minor adjustments, only T30 tested) - add get_display_timing ops to simple panel driver - extend simple panel driver to use it for MIPI DSI panels which do not require additional DSI commands for setup
---------------------------------------------------------------- Marcel Ziswiler (1): tegra: lcd: video: integrate display driver for t30
Simon Glass (1): sandbox: video: Fix building without SDL
Svyatoslav Ryhel (10): video: move tegra dc driver into own folder video: tegra-dc: get clocks from device tree video: tegra-dc: request timings from panel driver first video: tegra-dc: assign regmap directly video: tegra-dc: add 180 degree panel rotation video: tegra-dc: add panel_set_backlight call video: tegra-dc: pass DC regmap to internal devices video: tegra20: add DSI controller driver simple_panel: add support for get_display_timing simple_panel: support simple MIPI DSI panels
arch/arm/dts/tegra30-u-boot.dtsi | 9 + arch/arm/include/asm/arch-tegra/dc.h | 8 + arch/arm/include/asm/arch-tegra30/display.h | 28 + arch/arm/include/asm/arch-tegra30/dsi.h | 217 +++++++ arch/arm/include/asm/arch-tegra30/pwm.h | 13 + arch/sandbox/include/asm/test.h | 8 + drivers/video/Kconfig | 11 +- drivers/video/Makefile | 2 +- drivers/video/simple_panel.c | 47 +- drivers/video/tegra20/Kconfig | 17 + drivers/video/tegra20/Makefile | 4 + drivers/video/tegra20/mipi-phy.c | 134 ++++ drivers/video/tegra20/mipi-phy.h | 48 ++ drivers/video/{tegra.c => tegra20/tegra-dc.c} | 123 ++-- drivers/video/tegra20/tegra-dsi.c | 864 ++++++++++++++++++++++++++ 15 files changed, 1484 insertions(+), 49 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra30/display.h create mode 100644 arch/arm/include/asm/arch-tegra30/dsi.h create mode 100644 arch/arm/include/asm/arch-tegra30/pwm.h create mode 100644 drivers/video/tegra20/Kconfig create mode 100644 drivers/video/tegra20/Makefile create mode 100644 drivers/video/tegra20/mipi-phy.c create mode 100644 drivers/video/tegra20/mipi-phy.h rename drivers/video/{tegra.c => tegra20/tegra-dc.c} (82%) create mode 100644 drivers/video/tegra20/tegra-dsi.c
On Fri, Apr 07, 2023 at 09:51:26PM +0200, Anatolij Gustschin wrote:
Hi Tom,
Thanks, Anatolij
Anatolij Gustschin
