[U-Boot] [PATCH 0/2] cmd: Minor fixes for commands 'mtdparts' and 'nand'
Hei hei,
I reviewed some code today to explore possibilities and came across two minor issues. See the two patches.
Greets Alex
Alexander Dahl (2): cmd: nand: Remove not used declaration cmd: mtdparts: Fix build with option ..._SHOW_NET_SIZES
cmd/Kconfig | 8 ++++++++ cmd/mtdparts.c | 6 +++--- cmd/nand.c | 1 - 3 files changed, 11 insertions(+), 4 deletions(-)
This declaration is not used anywhere in the whole tree. There is a function 'mtd_id_parse()' which was renamed from 'id_parse()' in commit 68d7d65100e8 ("Separate mtdparts command from jffs2"), but that function is not used (anymore?) in cmd nand and build is fine without that declaration, so it's probably just safe to remove.
Signed-off-by: Alexander Dahl ada@thorsis.com --- cmd/nand.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/cmd/nand.c b/cmd/nand.c index 27efef20bc..24c9df89c1 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -34,7 +34,6 @@
/* partition handling routines */ int mtdparts_init(void); -int id_parse(const char *id, const char **ret_id, u8 *dev_type, u8 *dev_num); int find_dev_and_part(const char *id, struct mtd_device **dev, u8 *part_num, struct part_info **part); #endif
That option is currently not used by any defconfig and could not be set anymore since it became mandatory to used Kconfig when introducing new options with U-Boot v2016.11 or commit eed921d92348 ("Kconfig: Add a whitelist of ad-hoc CONFIG options") and commit 371244cb19f9 ("Makefile: Give a build error if ad-hoc CONFIG options are added").
It was also not considered when fixing build warnings in commit 39ac34473f3c ("cmd_mtdparts: use 64 bits for flash size, partition size & offset") and could probably not be compiled anyway after commit dfe64e2c8973 ("mtd: resync with Linux-3.7.1"), which renamed some members of struct mtd_info … so it was probably broken since then, which was U-Boot v2013.07-rc1.
However it still seems to work, see example output below:
U-Boot 2019.10-00035-g06a9b259ca-dirty (Oct 30 2019 - 14:03:44 +0100)
CPU: SAMA5D27 1G bits DDR2 SDRAM Crystal frequency: 24 MHz CPU clock : 492 MHz Master clock : 164 MHz Model: *** DRAM: 128 MiB NAND: 256 MiB Loading Environment from NAND... OK In: serial@f8020000 Out: serial@f8020000 Err: serial@f8020000 Net: eth0: ethernet@f8008000 Hit keys 'tt' to stop autoboot (3 seconds). U-Boot> mtdparts
device nand0 <atmel_nand>, # parts = 8 #: name size net size offset mask_flags 0: bootstrap 0x00040000 0x00040000 0x00000000 1 1: uboot 0x000c0000 0x000c0000 0x00040000 1 2: env1 0x00040000 0x00040000 0x00100000 0 3: env2 0x00040000 0x00040000 0x00140000 0 4: fpga_led 0x00040000 0x00040000 0x00180000 1 5: reserved 0x00040000 0x00040000 0x001c0000 1 6: rootfs_rec 0x03200000 0x03200000 0x00200000 1 7: filesystem 0x0cc00000 0x0cb80000 (!) 0x03400000 0
active partition: nand0,0 - (bootstrap) 0x00040000 @ 0x00000000
defaults: mtdids : nand0=atmel_nand mtdparts: mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256k(env1),256k(env2),256k(fpga_led)ro,256k(reserved)ro,50M(rootfs_rec)ro,-(filesystem)
Signed-off-by: Alexander Dahl ada@thorsis.com --- cmd/Kconfig | 8 ++++++++ cmd/mtdparts.c | 6 +++--- 2 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 82b5d300d2..07cb85e08c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1984,6 +1984,14 @@ config CMD_MTDPARTS_SPREAD at least as large as the size specified in the mtdparts variable and 2) each partition starts on a good block.
+config CMD_MTDPARTS_SHOW_NET_SIZES + bool "Show net size (w/o bad blocks) of partitions" + depends on CMD_MTDPARTS + help + Adds two columns to the printed partition table showing the + effective usable size of a partition, if bad blocks are taken + into account. + config CMD_REISER bool "reiser - Access to reiserfs filesystems" help diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 46155cabf6..b40c2afadd 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -1233,11 +1233,11 @@ static uint64_t net_part_size(struct mtd_info *mtd, struct part_info *part) { uint64_t i, net_size = 0;
- if (!mtd->block_isbad) + if (!mtd->_block_isbad) return part->size;
for (i = 0; i < part->size; i += mtd->erasesize) { - if (!mtd->block_isbad(mtd, part->offset + i)) + if (!mtd->_block_isbad(mtd, part->offset + i)) net_size += mtd->erasesize; }
@@ -1274,7 +1274,7 @@ static void print_partition_table(void) part = list_entry(pentry, struct part_info, link); net_size = net_part_size(mtd, part); size_note = part->size == net_size ? " " : " (!)"; - printf("%2d: %-20s0x%08x\t0x%08x%s\t0x%08x\t%d\n", + printf("%2d: %-20s0x%08llx\t0x%08x%s\t0x%08llx\t%d\n", part_num, part->name, part->size, net_size, size_note, part->offset, part->mask_flags);
Alexander Dahl
