[U-Boot] [PATCH 00/11] arm: sunxi: Use proper and meaningful Kconfig entries
Current arch/arm/mach-sunxi/Makefile has improper build options which relies mostly on MACH_ options. This series get rid of those and added proper Kconfig options.
All Kconfig entry name are re-used from Linux so-that future dm conversion on these can be meaningful.
Jagan Teki (11): sunxi: Add MFD_SUN6I_PRCM kconfig entry sunxi: Add I2C_SUN6I_P2WI kconfig entry sunxi: Use MFD_SUN6I_PRCM if used sunxi: Add SUNXI_RSB kconfig entry sunxi: Add PMIC_SUNXI kconfig entry sunxi: add DRAM_SUN6I kconfig sunxi: Add DRAM_SUN4I kconfig entry sunxi: Add DRAM_SUN9I kconfig entry sunxi: Add DRAM_SUN8I_A23 kconfig entry sunxi: Add DRAM_SUN8I_A33 kconfig entry sunxi: Add DRAM_SUN8I_A83T kconfig entry
arch/arm/mach-sunxi/Kconfig | 81 ++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-sunxi/Makefile | 30 ++++++---------- drivers/power/Kconfig | 5 +++ 3 files changed, 96 insertions(+), 20 deletions(-)
Add simple and meaningful kconfig option for prcm.c instead of using MACH type on Makefile.
PRCM (Power/Reset/Clock Management) is considered as a Multi-Functional Device, so used the same on Kconfig definition.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 7 +++++++ arch/arm/mach-sunxi/Makefile | 2 +- 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 1fededd..2b9f48b 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -6,6 +6,12 @@ config SPL_LDSCRIPT config IDENT_STRING default " Allwinner Technology"
+config MFD_SUN6I_PRCM + bool "Allwinner A31 PRCM controller" + help + Support for the PRCM (Power/Reset/Clock Management) unit available + in A31 SoC. + config SUNXI_HIGH_SRAM bool default n @@ -87,6 +93,7 @@ config MACH_SUN6I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select MFD_SUN6I_PRCM select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 2a3c379..3c1c660 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -16,7 +16,7 @@ obj-y += pinmux.o ifndef CONFIG_MACH_SUN9I obj-y += usb_phy.o endif -obj-$(CONFIG_MACH_SUN6I) += prcm.o +obj-$(CONFIG_MFD_SUN6I_PRCM) += prcm.o obj-$(CONFIG_MACH_SUN8I) += prcm.o obj-$(CONFIG_MACH_SUN9I) += prcm.o obj-$(CONFIG_MACH_SUN6I) += p2wi.o
Add simple and meaningful kconfig option for p2wi.c instead of using MACH type on Makefile.
p2wi is an I2C controller, so used the same on kconfig definition.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 12 ++++++++++++ arch/arm/mach-sunxi/Makefile | 2 +- 2 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 2b9f48b..319bee1 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -6,6 +6,17 @@ config SPL_LDSCRIPT config IDENT_STRING default " Allwinner Technology"
+config I2C_SUN6I_P2WI + bool "Allwinner sun6i internal P2WI controller" + help + If you say yes to this option, support will be included for the + P2WI (Push/Pull 2 Wire Interface) controller embedded in some sunxi + SOCs. + The P2WI looks like an SMBus controller (which supports only byte + accesses), except that it only supports one slave device. + This interface is used to connect to specific PMIC devices (like the + AXP221). + config MFD_SUN6I_PRCM bool "Allwinner A31 PRCM controller" help @@ -93,6 +104,7 @@ config MACH_SUN6I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select I2C_SUN6I_P2WI select MFD_SUN6I_PRCM select SUNXI_GEN_SUN6I select SUPPORT_SPL diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 3c1c660..22e73d7 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -16,10 +16,10 @@ obj-y += pinmux.o ifndef CONFIG_MACH_SUN9I obj-y += usb_phy.o endif +obj-$(CONFIG_I2C_SUN6I_P2WI) += p2wi.o obj-$(CONFIG_MFD_SUN6I_PRCM) += prcm.o obj-$(CONFIG_MACH_SUN8I) += prcm.o obj-$(CONFIG_MACH_SUN9I) += prcm.o -obj-$(CONFIG_MACH_SUN6I) += p2wi.o obj-$(CONFIG_MACH_SUN8I) += rsb.o obj-$(CONFIG_MACH_SUN9I) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o
MFD_SUN6I_PRCM is also used for SUN8I and SUN9I, so select the same on respective MACH types.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 2 ++ arch/arm/mach-sunxi/Makefile | 2 -- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 319bee1..cf999ab 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -182,6 +182,7 @@ config MACH_SUN8I_V3S config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7 + select MFD_SUN6I_PRCM select SUNXI_HIGH_SRAM select SUNXI_GEN_SUN6I select SUPPORT_SPL @@ -212,6 +213,7 @@ endchoice # The sun8i SoCs share a lot, this helps to avoid a lot of "if A23 || A33" config MACH_SUN8I bool + select MFD_SUN6I_PRCM default y if MACH_SUN8I_A23 default y if MACH_SUN8I_A33 default y if MACH_SUN8I_A83T diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 22e73d7..a6721ad 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -18,8 +18,6 @@ obj-y += usb_phy.o endif obj-$(CONFIG_I2C_SUN6I_P2WI) += p2wi.o obj-$(CONFIG_MFD_SUN6I_PRCM) += prcm.o -obj-$(CONFIG_MACH_SUN8I) += prcm.o -obj-$(CONFIG_MACH_SUN9I) += prcm.o obj-$(CONFIG_MACH_SUN8I) += rsb.o obj-$(CONFIG_MACH_SUN9I) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o
Add simple and meaningful kconfig option for rsb.c instead of using MACH type on Makefile.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 10 ++++++++++ arch/arm/mach-sunxi/Makefile | 3 +-- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index cf999ab..7ab1990 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -23,6 +23,14 @@ config MFD_SUN6I_PRCM Support for the PRCM (Power/Reset/Clock Management) unit available in A31 SoC.
+config SUNXI_RSB + bool "Allwinner sunXi Reduced Serial Bus Driver" + help + Say y here to enable support for Allwinner's Reduced Serial Bus + (RSB) support. This controller is responsible for communicating + with various RSB based devices, such as AXP223, AXP8XX PMICs, + and AC100/AC200 ICs. + config SUNXI_HIGH_SRAM bool default n @@ -185,6 +193,7 @@ config MACH_SUN9I select MFD_SUN6I_PRCM select SUNXI_HIGH_SRAM select SUNXI_GEN_SUN6I + select SUNXI_RSB select SUPPORT_SPL
config MACH_SUN50I @@ -213,6 +222,7 @@ endchoice # The sun8i SoCs share a lot, this helps to avoid a lot of "if A23 || A33" config MACH_SUN8I bool + select SUNXI_RSB select MFD_SUN6I_PRCM default y if MACH_SUN8I_A23 default y if MACH_SUN8I_A33 diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index a6721ad..8f30979 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -18,8 +18,7 @@ obj-y += usb_phy.o endif obj-$(CONFIG_I2C_SUN6I_P2WI) += p2wi.o obj-$(CONFIG_MFD_SUN6I_PRCM) += prcm.o -obj-$(CONFIG_MACH_SUN8I) += rsb.o -obj-$(CONFIG_MACH_SUN9I) += rsb.o +obj-$(CONFIG_SUNXI_RSB) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN5I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN6I) += clock_sun6i.o
+config SUNXI_RSB
Following the rest of the convention we have, that would be SUN8I_RSB.
Maxime
On Tue, Feb 6, 2018 at 9:19 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
+config SUNXI_RSB
Followed Linux notation to sync with, where the driver will also have support AC100.
+config SUNXI_RSB
AC100 is a device connected on that bus, not the bus itself.
Maxime
Add simple and meaningful kconfig option for pmic_bus.c instead of using MACH type on Makefile.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 6 ++++++ arch/arm/mach-sunxi/Makefile | 7 +------ drivers/power/Kconfig | 5 +++++ 3 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 7ab1990..470ef92 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -23,6 +23,12 @@ config MFD_SUN6I_PRCM Support for the PRCM (Power/Reset/Clock Management) unit available in A31 SoC.
+config PMIC_SUNXI + bool "Sunxi PMIC bus access helpers" + help + Select this PMIC bus access helpers for Sunxi platform PRCM or other + AXP family PMIC devices. + config SUNXI_RSB bool "Allwinner sunXi Reduced Serial Bus Driver" help diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 8f30979..921273b 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -18,6 +18,7 @@ obj-y += usb_phy.o endif obj-$(CONFIG_I2C_SUN6I_P2WI) += p2wi.o obj-$(CONFIG_MFD_SUN6I_PRCM) += prcm.o +obj-$(CONFIG_PMIC_SUNXI) += pmic_bus.o obj-$(CONFIG_SUNXI_RSB) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN5I) += clock_sun4i.o @@ -31,12 +32,6 @@ obj-$(CONFIG_MACH_SUN8I) += clock_sun6i.o endif obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o
-obj-$(CONFIG_AXP152_POWER) += pmic_bus.o -obj-$(CONFIG_AXP209_POWER) += pmic_bus.o -obj-$(CONFIG_AXP221_POWER) += pmic_bus.o -obj-$(CONFIG_AXP809_POWER) += pmic_bus.o -obj-$(CONFIG_AXP818_POWER) += pmic_bus.o - ifdef CONFIG_SPL_BUILD obj-$(CONFIG_MACH_SUN4I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN5I) += dram_sun4i.o diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index d8c107e..ec453b6 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -22,6 +22,7 @@ config SUNXI_NO_PMIC config AXP152_POWER bool "axp152 pmic support" depends on MACH_SUN5I + select PMIC_SUNXI select CMD_POWEROFF ---help--- Select this to enable support for the axp152 pmic found on most @@ -30,6 +31,7 @@ config AXP152_POWER config AXP209_POWER bool "axp209 pmic support" depends on MACH_SUN4I || MACH_SUN5I || MACH_SUN7I + select PMIC_SUNXI select CMD_POWEROFF ---help--- Select this to enable support for the axp209 pmic found on most @@ -38,6 +40,7 @@ config AXP209_POWER config AXP221_POWER bool "axp221 / axp223 pmic support" depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40 + select PMIC_SUNXI select CMD_POWEROFF ---help--- Select this to enable support for the axp221/axp223 pmic found on most @@ -46,6 +49,7 @@ config AXP221_POWER config AXP809_POWER bool "axp809 pmic support" depends on MACH_SUN9I + select PMIC_SUNXI select CMD_POWEROFF ---help--- Say y here to enable support for the axp809 pmic found on A80 boards. @@ -53,6 +57,7 @@ config AXP809_POWER config AXP818_POWER bool "axp818 pmic support" depends on MACH_SUN8I_A83T + select PMIC_SUNXI select CMD_POWEROFF ---help--- Say y here to enable support for the axp818 pmic found on
+config PMIC_SUNXI
- bool "Sunxi PMIC bus access helpers"
- help
This is only meant for AXP* PMIC, which Allwinner boards might or might not have. AXP_PMIC or some variation of it would be a better choice.
Maxime
Add proper and simple kconfig option for dram_sun6i.c instead of using MACH type on Makefile.
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 470ef92..c86f5a7 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -6,6 +6,12 @@ config SPL_LDSCRIPT config IDENT_STRING default " Allwinner Technology"
+config DRAM_SUN6I + bool "Sun6i platform dram controller driver" + help + Select this dram controller driver for Sun6i platforms, + like A31/A31s. + config I2C_SUN6I_P2WI bool "Allwinner sun6i internal P2WI controller" help @@ -118,6 +124,7 @@ config MACH_SUN6I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DRAM_SUN6I select I2C_SUN6I_P2WI select MFD_SUN6I_PRCM select SUNXI_GEN_SUN6I diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 921273b..4f7d8f4 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -33,9 +33,9 @@ endif obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o
ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o obj-$(CONFIG_MACH_SUN4I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN5I) += dram_sun4i.o -obj-$(CONFIG_MACH_SUN6I) += dram_sun6i.o obj-$(CONFIG_MACH_SUN7I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o
Add proper and simple kconfig option for dram_sun4i.c instead of using MACH type on Makefile.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 9 +++++++++ arch/arm/mach-sunxi/Makefile | 4 +--- 2 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index c86f5a7..8207f0b 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -6,6 +6,12 @@ config SPL_LDSCRIPT config IDENT_STRING default " Allwinner Technology"
+config DRAM_SUN4I + bool "Sun4/5/7i platform dram controller driver" + help + Select this dram controller driver for Sun4/5/7i platforms, + like A10/A13/A20. + config DRAM_SUN6I bool "Sun6i platform dram controller driver" help @@ -108,6 +114,7 @@ config MACH_SUN4I bool "sun4i (Allwinner A10)" select CPU_V7 select ARM_CORTEX_CPU_IS_UP + select DRAM_SUN4I select SUNXI_GEN_SUN4I select SUPPORT_SPL
@@ -115,6 +122,7 @@ config MACH_SUN5I bool "sun5i (Allwinner A13)" select CPU_V7 select ARM_CORTEX_CPU_IS_UP + select DRAM_SUN4I select SUNXI_GEN_SUN4I select SUPPORT_SPL
@@ -137,6 +145,7 @@ config MACH_SUN7I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DRAM_SUN4I select SUNXI_GEN_SUN4I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 4f7d8f4..6f5fa18 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -33,10 +33,8 @@ endif obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o
ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o -obj-$(CONFIG_MACH_SUN4I) += dram_sun4i.o -obj-$(CONFIG_MACH_SUN5I) += dram_sun4i.o -obj-$(CONFIG_MACH_SUN7I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o
Add proper and simple kconfig option for dram_sun9i.c instead of using MACH type on Makefile.
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 8207f0b..b6115da 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -18,6 +18,12 @@ config DRAM_SUN6I Select this dram controller driver for Sun6i platforms, like A31/A31s.
+config DRAM_SUN9I + bool "Sun9i platform dram controller driver" + help + Select this dram controller driver for Sun9i platforms, + like A80. + config I2C_SUN6I_P2WI bool "Allwinner sun6i internal P2WI controller" help @@ -212,6 +218,7 @@ config MACH_SUN8I_V3S config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7 + select DRAM_SUN9I select MFD_SUN6I_PRCM select SUNXI_HIGH_SRAM select SUNXI_GEN_SUN6I diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 6f5fa18..66ed2ee 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -35,10 +35,10 @@ obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o +obj-$(CONFIG_DRAM_SUN9I) += dram_sun9i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_timings/ -obj-$(CONFIG_MACH_SUN9I) += dram_sun9i.o endif
Add proper and simple kconfig option for dram_sun8i_a23.c instead of using MACH type on Makefile.
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index b6115da..f3a0c49 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -18,6 +18,12 @@ config DRAM_SUN6I Select this dram controller driver for Sun6i platforms, like A31/A31s.
+config DRAM_SUN8I_A23 + bool "Sun8i A23 platform dram controller driver" + help + Select this dram controller driver for Sun8i platforms, + for A23 SOC. + config DRAM_SUN9I bool "Sun9i platform dram controller driver" help @@ -162,6 +168,7 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DRAM_SUN8I_A23 select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 66ed2ee..cfada67 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -35,8 +35,8 @@ obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o +obj-$(CONFIG_DRAM_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_DRAM_SUN9I) += dram_sun9i.o -obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o
Add proper and simple kconfig option for dram_sun8i_a33.c instead of using MACH type on Makefile.
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index f3a0c49..7b06e0d 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -24,6 +24,12 @@ config DRAM_SUN8I_A23 Select this dram controller driver for Sun8i platforms, for A23 SOC.
+config DRAM_SUN8I_A33 + bool "Sun8i A33 platform dram controller driver" + help + Select this dram controller driver for Sun8i platforms, + for A33 SOC. + config DRAM_SUN9I bool "Sun9i platform dram controller driver" help @@ -179,6 +185,7 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DRAM_SUN8I_A33 select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index cfada67..034e434 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -36,8 +36,8 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o obj-$(CONFIG_DRAM_SUN8I_A23) += dram_sun8i_a23.o +obj-$(CONFIG_DRAM_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_DRAM_SUN9I) += dram_sun9i.o -obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_timings/
Add proper and simple kconfig option for dram_sun8i_a83t.c instead of using MACH type on Makefile.
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 7b06e0d..27b957e 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -30,6 +30,12 @@ config DRAM_SUN8I_A33 Select this dram controller driver for Sun8i platforms, for A33 SOC.
+config DRAM_SUN8I_A83T + bool "Sun8i A83T platform dram controller driver" + help + Select this dram controller driver for Sun8i platforms, + for A83T SOC. + config DRAM_SUN9I bool "Sun9i platform dram controller driver" help @@ -193,6 +199,7 @@ config MACH_SUN8I_A33 config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7 + select DRAM_SUN8I_A83T select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE select SUPPORT_SPL diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 034e434..b1d99e9 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -37,8 +37,8 @@ obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o obj-$(CONFIG_DRAM_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_DRAM_SUN8I_A33) += dram_sun8i_a33.o +obj-$(CONFIG_DRAM_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_DRAM_SUN9I) += dram_sun9i.o -obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_timings/ endif
Jagan Teki
Maxime Ripard
