[U-Boot] [PATCH] sunxi: musb: Properly put the musb controller back in reset on exit
Assert reset and disable the clock to properly put the musb controller back in reset on exit.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- drivers/usb/musb-new/sunxi.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index e8a3a23..e2c9d5a 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -284,6 +284,8 @@ static int sunxi_musb_init(struct musb *musb)
static int sunxi_musb_exit(struct musb *musb) { + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + pr_debug("%s():\n", __func__);
USBC_DisableDpDmPullUp(musb->mregs); @@ -291,6 +293,11 @@ static int sunxi_musb_exit(struct musb *musb) sunxi_usb_phy_power_off(0); sunxi_usb_phy_exit(0);
+#ifdef CONFIG_SUNXI_GEN_SUN6I + clrbits_le32(&ccm->ahb_reset0_cfg, 1 << AHB_GATE_OFFSET_USB0); +#endif + clrbits_le32(&ccm->ahb_gate0, 1 << AHB_GATE_OFFSET_USB0); + return 0; }
Last I checked the exit functions are not called except for error handling in the probe sequence. Has this been fixed?
ChenYu
pr_debug("%s():\n", __func__); USBC_DisableDpDmPullUp(musb->mregs);
-- 2.4.1
It seems not, I made this patch because Paul (added to the Cc) was having some troubles when changing the gadget role. It looks like you're right and unfortunately this function never gets called though ...
Worse it seems that in gadget mode even all calls to musb_stop() are commented out of the musb-new code...
Note all this does not mean that this patch is incorrect though, just that it is not really useful atm.
Regards,
Hans
ChenYu
}return 0;
-- 2.4.1
It seems to be the problem here. I added an explicit call to musb_stop in usb_gadget_unregister_driver and it seems to solve the problem: I can run fastboot multiple times and the host always enumerates it correctly.
I'll submit some patches implementing this correctly, probably next week-end.
However, it doesn't work as well with the USB mass storage function. I'll have to take a closer look at it later.
Regards,
Hans
ChenYu
}return 0;
-- 2.4.1
Chen-Yu Tsai
Hans de Goede
Paul Kocialkowski
