[U-Boot-Users] [PATCH]ppc_4xx: Netstal HCU4 board. Added POST. Various fixes
Various fixes. Reduced rom_size from 384 to 320 kB. Environment is now in flash. Added POST, support for OF.
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- board/netstal/hcu4/config.mk | 2 +- include/configs/hcu4.h | 33 ++++++++++++++++++++------------- 2 files changed, 21 insertions(+), 14 deletions(-)
diff --git a/board/netstal/hcu4/config.mk b/board/netstal/hcu4/config.mk index 376609a..2c0d595 100644 --- a/board/netstal/hcu4/config.mk +++ b/board/netstal/hcu4/config.mk @@ -21,7 +21,7 @@ # Netstal Maschinen AG: HCU4 boards #
-TEXT_BASE = 0xFFFa0000 +TEXT_BASE = 0xFFFb0000
ifeq ($(debug),1) PLATFORM_CPPFLAGS += -DDEBUG -g diff --git a/include/configs/hcu4.h b/include/configs/hcu4.h index 0e259bb..037bda5 100644 --- a/include/configs/hcu4.h +++ b/include/configs/hcu4.h @@ -46,7 +46,7 @@ * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) *----------------------------------------------------------------------*/ -#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MONITOR_LEN (320 * 1024) /* Reserve 320 kB for Monitor */ #define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */
@@ -105,8 +105,7 @@ *----------------------------------------------------------------------*/
#undef CFG_ENV_IS_IN_NVRAM -#undef CFG_ENV_IS_IN_FLASH -#define CFG_ENV_IS_IN_EEPROM +#define CFG_ENV_IS_IN_FLASH #undef CFG_ENV_IS_NOWHERE
#ifdef CFG_ENV_IS_IN_EEPROM @@ -120,7 +119,7 @@ /* Put the environment in Flash */ #define CFG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ #define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) -#define CFG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ +#define CFG_ENV_SIZE 8*1024 /* 8 KB Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) @@ -158,7 +157,7 @@
/* Setup some board specific values for the default environment variables */ #define CONFIG_HOSTNAME hcu4 -#define CONFIG_IPADDR 172.25.1.42 +#define CONFIG_IPADDR 172.25.1.99 #define CONFIG_ETHADDR 00:60:13:00:00:00 /* Netstal Machines AG MAC */ #define CONFIG_OVERWRITE_ETHADDR_ONCE #define CONFIG_SERVERIP 172.25.1.3 @@ -180,12 +179,12 @@ "rootpath=/home/diagnose/eldk/ppc_4xx\0" \ "bootfile=/tftpboot/hcu4/uImage\0" \ "load=tftp 100000 hcu4/u-boot.bin\0" \ - "update=protect off FFFa0000 FFFFFFFF;era FFFa0000 FFFFFFFF;" \ - "cp.b 100000 FFFa0000 60000\0" \ + "update=protect off FFFB0000 FFFFFFFF;era FFFC0000 FFFFFFFF;" \ + "cp.b 100000 FFFB0000 50000\0" \ "upd=run load;run update\0" \ "vx=tftp ${loadaddr} hcu4_vx_rom;" \ - "setenv bootargs emac(0,0)hcu4_vx_rom e=${ipaddr} " \ - " h=${serverip} u=dpu pw=netstal8752 tn=hcu4 f=0x3008;" \ + "vx=tftp ${loadaddr} hcu4/hcu4_vx_rom;" \ + "setenv bootargs emac(0,0)c:hcu4/hcu4_vx_rom e=${ipaddr} " \ "bootvx ${loadaddr}\0" \ "" #define CONFIG_BOOTCOMMAND "run vx" @@ -221,7 +220,6 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BSP #define CONFIG_CMD_CACHE #define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG @@ -250,9 +248,10 @@ CFG_POST_ETHER | \ CFG_POST_SPR)
+#define CFG_POST_UART_TABLE {UART0_BASE} #define CFG_POST_WORD_ADDR (CFG_GBL_DATA_OFFSET - 0x4) #define CONFIG_LOGBUFFER -#define CFG_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */ +#define CFG_POST_CACHE_ADDR 0x00800000 /* free virtual address */ #define CFG_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */
/*----------------------------------------------------------------------- @@ -280,13 +279,14 @@
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_LOOPW 1 /* enable loopw command */ -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup */
+#define CFG_EBC_CFG 0x98400000 + /* Memory Bank 0 (Flash Bank 0) initialization */ #define CFG_EBC_PB0AP 0x02005400 #define CFG_EBC_PB0CR 0xFFF18000 /* BAS=0xFFF,BS=1MB,BU=R/W,BW=8bit */ @@ -303,7 +303,9 @@ #define CFG_EBC_PB4AP 0x01800300 #define CFG_EBC_PB4CR 0x7e0ba000 /* BAS=,BS=MB,BU=R/W,BW=bit */
-#define CFG_GPIO0_TCR 0x7ffe0000 /* GPIO value */ +#define CFG_GPIO0_OR 0xF27FFFFF /* GPIO value */ +#define CFG_GPIO0_TCR 0x7FFE0000 /* GPIO value */ +#define CFG_GPIO0_ODR 0x00E897FC /* GPIO value */
/* * For booting Linux, the board info and command line data @@ -352,4 +354,9 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + #endif /* __CONFIG_H */
Either use lower case or upper case characters but don't mix them in one define. I know it was present in the original version too and must have slipped through. Please clean up and resubmit.
Thanks.
Best regards, Stefan
Niklaus Giger
Stefan Roese
