[PATCH 0/4] boot: android: rework the bootargs concatenation
Rework the bootargs concatenation logic to make the logic clearer and address several issues such as: - checking the value at the address kcmdline_extra instead of checking the address value itself - freeing the string that was malloced for the concatenation - making sure to malloc the right amount of bytes for the concatenated string, not forgetting the byte for the NULL termination
Signed-off-by: Nicolas Belin nbelin@baylibre.com --- Nicolas Belin (4): boot: android: fix extra command line support boot: android: free newbootargs when done boot: android: rework bootargs concatenation boot: android: reorder the length calculation order
boot/image-android.c | 26 ++++++++++++++------------ 1 file changed, 14 insertions(+), 12 deletions(-) --- base-commit: b841e559cd26ffcb20f22e8ee75debed9616c002 change-id: 20241211-fix-bootargs-concatenation-8b616c110b63
Check that the value at the address kcmdline_extra is not 0 instead of checking the address value itself keeping it consistent with what is done for kcmdline.
Fixes: b36b227b ("android: boot: support extra command line") Signed-off-by: Nicolas Belin nbelin@baylibre.com --- boot/image-android.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/boot/image-android.c b/boot/image-android.c index cd01278f211d63262f2bdad7aa1176e2c1bbfedd..57158280b41c6552c82838e21384d925d5f7cde4 100644 --- a/boot/image-android.c +++ b/boot/image-android.c @@ -292,7 +292,7 @@ int android_image_get_kernel(const void *hdr, len += strlen(img_data.kcmdline); }
- if (img_data.kcmdline_extra) { + if (*img_data.kcmdline_extra) { printf("Kernel extra command line: %s\n", img_data.kcmdline_extra); len += strlen(img_data.kcmdline_extra); } @@ -316,7 +316,7 @@ int android_image_get_kernel(const void *hdr, if (*img_data.kcmdline) strcat(newbootargs, img_data.kcmdline);
- if (img_data.kcmdline_extra) { + if (*img_data.kcmdline_extra) { strcat(newbootargs, " "); strcat(newbootargs, img_data.kcmdline_extra); }
Hi Nicolas,
Thank you for the patch.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- if (*img_data.kcmdline_extra) { printf("Kernel extra command line: %s\n", img_data.kcmdline_extra); len += strlen(img_data.kcmdline_extra); }
- if (*img_data.kcmdline_extra) { strcat(newbootargs, " "); strcat(newbootargs, img_data.kcmdline_extra); }
-- 2.34.1
Free newbootargs when the concatenation is done and bootargs env is set.
Fixes: 86f4695b ("image: Fix Android boot image support") Signed-off-by: Nicolas Belin nbelin@baylibre.com --- boot/image-android.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/boot/image-android.c b/boot/image-android.c index 57158280b41c6552c82838e21384d925d5f7cde4..362a5c7435a3a8bcf7b674b96e31069a91a892b5 100644 --- a/boot/image-android.c +++ b/boot/image-android.c @@ -322,6 +322,7 @@ int android_image_get_kernel(const void *hdr, }
env_set("bootargs", newbootargs); + free(newbootargs);
if (os_data) { if (image_get_magic(ihdr) == IH_MAGIC) {
Hi Nicolas,
free(newbootargs);
-- 2.34.1
Rework the bootargs concatenation allocating more accurately the length that is needed. Do not forget an extra byte for the null termination byte as, in some cases, the allocation was 1 byte short.
Fixes: 86f4695b ("image: Fix Android boot image support") Signed-off-by: Nicolas Belin nbelin@baylibre.com --- boot/image-android.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/boot/image-android.c b/boot/image-android.c index 362a5c7435a3a8bcf7b674b96e31069a91a892b5..ed72a5c30424a453c1800bc61edbe8f33b31b341 100644 --- a/boot/image-android.c +++ b/boot/image-android.c @@ -289,7 +289,7 @@ int android_image_get_kernel(const void *hdr, int len = 0; if (*img_data.kcmdline) { printf("Kernel command line: %s\n", img_data.kcmdline); - len += strlen(img_data.kcmdline); + len += strlen(img_data.kcmdline) + 1; /* Extra space character needed */ }
if (*img_data.kcmdline_extra) { @@ -299,28 +299,28 @@ int android_image_get_kernel(const void *hdr,
char *bootargs = env_get("bootargs"); if (bootargs) - len += strlen(bootargs); + len += strlen(bootargs) + 1; /* Extra space character needed */
- char *newbootargs = malloc(len + 2); + char *newbootargs = malloc(len + 1); /* +1 for the '\0' */ if (!newbootargs) { puts("Error: malloc in android_image_get_kernel failed!\n"); return -ENOMEM; } - *newbootargs = '\0'; + *newbootargs = '\0'; /* set to NULL in case no components below are present */
if (bootargs) { strcpy(newbootargs, bootargs); strcat(newbootargs, " "); }
- if (*img_data.kcmdline) + if (*img_data.kcmdline) { strcat(newbootargs, img_data.kcmdline); - - if (*img_data.kcmdline_extra) { strcat(newbootargs, " "); - strcat(newbootargs, img_data.kcmdline_extra); }
+ if (*img_data.kcmdline_extra) + strcat(newbootargs, img_data.kcmdline_extra); + env_set("bootargs", newbootargs); free(newbootargs);
Hi Nicolas,
In some cases, we will allocate for an extra space character when this is not needed.
For example, with: * bootargs = "b" * kcmdline = NULL * kcmdline_extra = NULL
We will allocate strlen("b") + 1 + 1. But we only need to allocate strlen("b") + 1.
Another example: * bootargs = "b" * kcmdline = "k" * kcmdline_extra = NULL
Will allocate strlen("b") + 1 + strlen("k") + 1 + 1. But we only need: strlen("b") + 1 + strlen("k") + 1.
How about we count the amount of elements that are not NULL to compute the amount of spaces: * 0 -> 0 space * 1 -> 0 space * 2 -> 1 space * 3 -> 2 spaces
- char *newbootargs = malloc(len + 1); /* +1 for the '\0' */ if (!newbootargs) { puts("Error: malloc in android_image_get_kernel failed!\n"); return -ENOMEM; }
- *newbootargs = '\0'; /* set to NULL in case no components below are present */
The comment should state Null, not NULL. NULL is the pointer and Null is the \0 character.
A similar thing can be stated here. Sometimes, we add spaces which are not needed.
Can we rework this a little to only add what is needed?
- if (*img_data.kcmdline) { strcat(newbootargs, img_data.kcmdline);
}strcat(newbootargs, img_data.kcmdline_extra);
- env_set("bootargs", newbootargs); free(newbootargs);
-- 2.34.1
Le lun. 16 déc. 2024 à 09:41, Mattijs Korpershoek mkorpershoek@baylibre.com a écrit :
Hi Nicolas,
len += strlen(img_data.kcmdline) + 1; /* Extra space character needed */ } if (*img_data.kcmdline_extra) {
For example, with:
- bootargs = "b"
- kcmdline = NULL
- kcmdline_extra = NULL
Another example:
- bootargs = "b"
- kcmdline = "k"
- 0 -> 0 space
- 1 -> 0 space
- 2 -> 1 space
- 3 -> 2 spaces
Will do for v2
-- 2.34.1
Keep the same order (bootargs then kcmdline then kcmdline_extra) for both the length calculation and the string concatenation steps.
Signed-off-by: Nicolas Belin nbelin@baylibre.com --- boot/image-android.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/boot/image-android.c b/boot/image-android.c index ed72a5c30424a453c1800bc61edbe8f33b31b341..a76f028090d0470842bbf559b638175949c527f0 100644 --- a/boot/image-android.c +++ b/boot/image-android.c @@ -287,6 +287,11 @@ int android_image_get_kernel(const void *hdr, kernel_addr, DIV_ROUND_UP(img_data.kernel_size, 1024));
int len = 0; + char *bootargs = env_get("bootargs"); + + if (bootargs) + len += strlen(bootargs) + 1; /* Extra space character needed */ + if (*img_data.kcmdline) { printf("Kernel command line: %s\n", img_data.kcmdline); len += strlen(img_data.kcmdline) + 1; /* Extra space character needed */ @@ -297,10 +302,6 @@ int android_image_get_kernel(const void *hdr, len += strlen(img_data.kcmdline_extra); }
- char *bootargs = env_get("bootargs"); - if (bootargs) - len += strlen(bootargs) + 1; /* Extra space character needed */ - char *newbootargs = malloc(len + 1); /* +1 for the '\0' */ if (!newbootargs) { puts("Error: malloc in android_image_get_kernel failed!\n");
Hi Nicolas,
int len = 0;
- if (bootargs)
- if (*img_data.kcmdline) { printf("Kernel command line: %s\n", img_data.kcmdline); len += strlen(img_data.kcmdline) + 1; /* Extra space character needed */
- if (bootargs)
-- 2.34.1
Mattijs Korpershoek
Nicolas Belin
