[U-Boot-Users] [PATCH 6/7] DaVinci: U-Boot misc files
Add misc files for TI DaVinci boards. Based on initial patch by Sergey Kubushyn ksi@koi8.net.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Index: uboot/common/cmd_nvedit.c =================================================================== --- uboot.orig/common/cmd_nvedit.c +++ uboot/common/cmd_nvedit.c @@ -193,7 +193,12 @@ int _do_setenv (int flag, int argc, char * Ethernet Address and serial# can be set only once, * ver is readonly. */ +#ifdef CONFIG_HAS_UID + /* Allow serial# forced overwrite with 0xdeaf4add flag */ + if ( ((strcmp (name, "serial#") == 0) && (flag != 0xdeaf4add)) || +#else if ( (strcmp (name, "serial#") == 0) || +#endif ((strcmp (name, "ethaddr") == 0) #if defined(CONFIG_OVERWRITE_ETHADDR_ONCE) && defined(CONFIG_ETHADDR) && (strcmp ((char *)env_get_addr(oldval),MK_STR(CONFIG_ETHADDR)) != 0) @@ -397,7 +402,15 @@ void setenv (char *varname, char *varval _do_setenv (0, 3, argv); }
-int do_setenv ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +#ifdef CONFIG_HAS_UID +void forceenv (char *varname, char *varvalue) +{ + char *argv[4] = { "forceenv", varname, varvalue, NULL }; + _do_setenv (0xdeaf4add, 3, argv); +} +#endif + +int do_setenv (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { if (argc < 2) { printf ("Usage:\n%s\n", cmdtp->usage); Index: uboot/drivers/nand/nand_bbt.c =================================================================== --- uboot.orig/drivers/nand/nand_bbt.c +++ uboot/drivers/nand/nand_bbt.c @@ -152,7 +152,7 @@ static int read_bbt (struct mtd_info *mt continue; if (reserved_block_code && (tmp == reserved_block_code)) { - printk (KERN_DEBUG "nand_read_bbt: Reserved block at 0x%08x\n", + DEBUG(MTD_DEBUG_LEVEL0, "nand_read_bbt: Reserved block at 0x%08x\n", ((offs << 2) + (act >> 1)) << this->bbt_erase_shift); this->bbt[offs + (act >> 3)] |= 0x2 << (act & 0x06); continue; @@ -229,14 +229,14 @@ static int read_abs_bbts (struct mtd_inf if (td->options & NAND_BBT_VERSION) { nand_read_raw (mtd, buf, td->pages[0] << this->page_shift, mtd->oobblock, mtd->oobsize); td->version[0] = buf[mtd->oobblock + td->veroffs]; - printk (KERN_DEBUG "Bad block table at page %d, version 0x%02X\n", td->pages[0], td->version[0]); + DEBUG(MTD_DEBUG_LEVEL0, "Bad block table at page %d, version 0x%02X\n", td->pages[0], td->version[0]); }
/* Read the mirror version, if available */ if (md && (md->options & NAND_BBT_VERSION)) { nand_read_raw (mtd, buf, md->pages[0] << this->page_shift, mtd->oobblock, mtd->oobsize); md->version[0] = buf[mtd->oobblock + md->veroffs]; - printk (KERN_DEBUG "Bad block table at page %d, version 0x%02X\n", md->pages[0], md->version[0]); + DEBUG(MTD_DEBUG_LEVEL0, "Bad block table at page %d, version 0x%02X\n", md->pages[0], md->version[0]); }
return 1; @@ -375,7 +375,7 @@ static int search_bbt (struct mtd_info * if (td->pages[i] == -1) printk (KERN_WARNING "Bad block table not found for chip %d\n", i); else - printk (KERN_DEBUG "Bad block table found at page %d, version 0x%02X\n", td->pages[i], td->version[i]); + DEBUG(MTD_DEBUG_LEVEL0, "Bad block table found at page %d, version 0x%02X\n", td->pages[i], td->version[i]); } return 0; } @@ -569,7 +569,7 @@ write: printk (KERN_WARNING "nand_bbt: Error while writing bad block table %d\n", res); return res; } - printk (KERN_DEBUG "Bad block table written to 0x%08x, version 0x%02X\n", + DEBUG(MTD_DEBUG_LEVEL0, "Bad block table written to 0x%08x, version 0x%02X\n", (unsigned int) to, td->version[chip]);
/* Mark it as used */ Index: uboot/lib_arm/board.c =================================================================== --- uboot.orig/lib_arm/board.c +++ uboot/lib_arm/board.c @@ -364,6 +364,13 @@ void start_armboot (void) enable_interrupts ();
/* Perform network card initialisation if necessary */ +#ifdef CONFIG_DRIVER_TI_EMAC +extern void dm644x_eth_set_mac_addr (uchar *addr); + if (getenv ("ethaddr")) { + dm644x_eth_set_mac_addr(gd->bd->bi_enetaddr); + } +#endif + #ifdef CONFIG_DRIVER_CS8900 cs8900_get_enetaddr (gd->bd->bi_enetaddr); #endif Index: uboot/net/eth.c =================================================================== --- uboot.orig/net/eth.c +++ uboot/net/eth.c @@ -464,6 +464,8 @@ extern int at91rm9200_miiphy_initialize( extern int emac4xx_miiphy_initialize(bd_t *bis); extern int mcf52x2_miiphy_initialize(bd_t *bis); extern int ns7520_miiphy_initialize(bd_t *bis); +extern int dm644x_eth_miiphy_initialize(bd_t *bis); +
int eth_initialize(bd_t *bis) { @@ -484,6 +486,9 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_NETARM) ns7520_miiphy_initialize(bis); #endif +#if defined(CONFIG_DRIVER_TI_EMAC) + dm644x_eth_miiphy_initialize(bis); +#endif return 0; } #endif
Index: uboot/MAKEALL =================================================================== --- uboot.orig/MAKEALL +++ uboot/MAKEALL @@ -219,7 +219,7 @@ LIST_ARM9=" \ omap1610h2 omap1610inn omap730p2 sbc2410x \ scb9328 smdk2400 smdk2410 trab \ VCMA9 versatile versatileab versatilepb \ - voiceblue \ + voiceblue davinci_evm davinci_sonata davinci_schmoogie \ "
######################################################################### Index: uboot/Makefile =================================================================== --- uboot.orig/Makefile +++ uboot/Makefile @@ -2018,6 +2018,15 @@ omap1510inn_config : unconfig omap5912osk_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs omap5912osk NULL omap
+davinci_evm_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs davinci NULL davinci + +davinci_schmoogie_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs davinci NULL davinci + +davinci_sonata_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs davinci NULL davinci + omap1610inn_config \ omap1610inn_cs0boot_config \ omap1610inn_cs3boot_config \ Index: uboot/include/linux/types.h =================================================================== --- uboot.orig/include/linux/types.h +++ uboot/include/linux/types.h @@ -127,4 +127,7 @@ struct ustat { char f_fpack[6]; };
+typedef volatile u32 reg32_t; +typedef volatile u32 * reg32p_t; + #endif /* _LINUX_TYPES_H */ Index: uboot/include/common.h =================================================================== --- uboot.orig/include/common.h +++ uboot/include/common.h @@ -233,6 +233,9 @@ int saveenv (void); void inline setenv (char *, char *); #else void setenv (char *, char *); +#ifdef CONFIG_HAS_UID +void forceenv (char *, char *); +#endif #endif /* CONFIG_PPC */ #ifdef CONFIG_ARM # include <asm/mach-types.h> Index: uboot/include/dp83848.h =================================================================== --- /dev/null +++ uboot/include/dp83848.h @@ -0,0 +1,88 @@ +/* + * DP83848 ethernet Physical layer + * + * Copyright (C) Sergey Kubushyn ksi@koi8.net, 2007. + * + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + */ + + +/* National Semiconductor PHYSICAL LAYER TRANSCEIVER DP83848 */ + +#define DP83848_CTL_REG 0x0 /* Basic Mode Control Reg */ +#define DP83848_STAT_REG 0x1 /* Basic Mode Status Reg */ +#define DP83848_PHYID1_REG 0x2 /* PHY Idendifier Reg 1 */ +#define DP83848_PHYID2_REG 0x3 /* PHY Idendifier Reg 2 */ +#define DP83848_ANA_REG 0x4 /* Auto_Neg Advt Reg */ +#define DP83848_ANLPA_REG 0x5 /* Auto_neg Link Partner Ability Reg */ +#define DP83848_ANE_REG 0x6 /* Auto-neg Expansion Reg */ +#define DP83848_PHY_STAT_REG 0x10 /* PHY Status Register */ +#define DP83848_PHY_INTR_CTRL_REG 0x11 /* PHY Interrupt Control Register */ +#define DP83848_PHY_CTRL_REG 0x19 /* PHY Status Register */ + +/*--Bit definitions: DP83848_CTL_REG */ +#define DP83848_RESET (1 << 15) /* 1= S/W Reset */ +#define DP83848_LOOPBACK (1 << 14) /* 1=loopback Enabled */ +#define DP83848_SPEED_SELECT (1 << 13) +#define DP83848_AUTONEG (1 << 12) +#define DP83848_POWER_DOWN (1 << 11) +#define DP83848_ISOLATE (1 << 10) +#define DP83848_RESTART_AUTONEG (1 << 9) +#define DP83848_DUPLEX_MODE (1 << 8) +#define DP83848_COLLISION_TEST (1 << 7) + +/*--Bit definitions: DP83848_STAT_REG */ +#define DP83848_100BASE_T4 (1 << 15) +#define DP83848_100BASE_TX_FD (1 << 14) +#define DP83848_100BASE_TX_HD (1 << 13) +#define DP83848_10BASE_T_FD (1 << 12) +#define DP83848_10BASE_T_HD (1 << 11) +#define DP83848_MF_PREAMB_SUPPR (1 << 6) +#define DP83848_AUTONEG_COMP (1 << 5) +#define DP83848_RMT_FAULT (1 << 4) +#define DP83848_AUTONEG_ABILITY (1 << 3) +#define DP83848_LINK_STATUS (1 << 2) +#define DP83848_JABBER_DETECT (1 << 1) +#define DP83848_EXTEND_CAPAB (1 << 0) + +/*--definitions: DP83848_PHYID1 */ +#define DP83848_PHYID1_OUI 0x2000 +#define DP83848_PHYID2_OUI 0x5c90 + +/*--Bit definitions: DP83848_ANAR, DP83848_ANLPAR */ +#define DP83848_NP (1 << 15) +#define DP83848_ACK (1 << 14) +#define DP83848_RF (1 << 13) +#define DP83848_PAUSE (1 << 10) +#define DP83848_T4 (1 << 9) +#define DP83848_TX_FDX (1 << 8) +#define DP83848_TX_HDX (1 << 7) +#define DP83848_10_FDX (1 << 6) +#define DP83848_10_HDX (1 << 5) +#define DP83848_AN_IEEE_802_3 0x0001 + +/*--Bit definitions: DP83848_ANER */ +#define DP83848_PDF (1 << 4) +#define DP83848_LP_NP_ABLE (1 << 3) +#define DP83848_NP_ABLE (1 << 2) +#define DP83848_PAGE_RX (1 << 1) +#define DP83848_LP_AN_ABLE (1 << 0) + +/*--Bit definitions: DP83848_PHY_STAT */ +#define DP83848_RX_ERR_LATCH (1 << 13) +#define DP83848_POLARITY_STAT (1 << 12) +#define DP83848_FALSE_CAR_SENSE (1 << 11) +#define DP83848_SIG_DETECT (1 << 10) +#define DP83848_DESCRAM_LOCK (1 << 9) +#define DP83848_PAGE_RCV (1 << 8) +#define DP83848_PHY_RMT_FAULT (1 << 6) +#define DP83848_JABBER (1 << 5) +#define DP83848_AUTONEG_COMPLETE (1 << 4) +#define DP83848_LOOPBACK_STAT (1 << 3) +#define DP83848_DUPLEX (1 << 2) +#define DP83848_SPEED (1 << 1) +#define DP83848_LINK (1 << 0) Index: uboot/include/_exports.h =================================================================== --- uboot.orig/include/_exports.h +++ uboot/include/_exports.h @@ -14,6 +14,9 @@ EXPORT_FUNC(vprintf) EXPORT_FUNC(do_reset) EXPORT_FUNC(getenv) EXPORT_FUNC(setenv) +#ifdef CONFIG_HAS_UID +EXPORT_FUNC(forceenv) +#endif EXPORT_FUNC(simple_strtoul) #if (CONFIG_COMMANDS & CFG_CMD_I2C) EXPORT_FUNC(i2c_write) Index: uboot/include/exports.h =================================================================== --- uboot.orig/include/exports.h +++ uboot/include/exports.h @@ -23,6 +23,9 @@ void do_reset (void); unsigned long simple_strtoul(const char *cp,char **endp,unsigned int base); char *getenv (char *name); void setenv (char *varname, char *varvalue); +#ifdef CONFIG_HAS_UID +void forceenv (char *varname, char *varvalue); +#endif #if (CONFIG_COMMANDS & CFG_CMD_I2C) int i2c_write (uchar, uint, int , uchar* , int); int i2c_read (uchar, uint, int , uchar* , int); Index: uboot/include/linux/mtd/mtd.h =================================================================== --- uboot.orig/include/linux/mtd/mtd.h +++ uboot/include/linux/mtd/mtd.h @@ -11,6 +11,9 @@ #include <linux/types.h> #include <linux/mtd/mtd-abi.h>
+//#define CONFIG_MTD_DEBUG 1 +//#define CONFIG_MTD_DEBUG_VERBOSE 3 + #define MAX_MTD_DEVICES 16
#define MTD_ERASE_PENDING 0x01 @@ -202,9 +205,9 @@ static inline void mtd_erase_callback(st
#ifdef CONFIG_MTD_DEBUG #define DEBUG(n, args...) \ - do { \ + do { \ if (n <= CONFIG_MTD_DEBUG_VERBOSE) \ - printk(KERN_INFO args); \ + printf(args); \ } while(0) #else /* CONFIG_MTD_DEBUG */ #define DEBUG(n, args...) do { } while(0)
Dirk Behme
