[PATCH] nand: brcmnand: add iproc support
Add support for the iproc Broadcom NAND controller, used in Northstar SoCs for example. Based on the Linux driver.
Cc: Philippe Reynes philippe.reynes@softathome.com Signed-off-by: Linus Walleij linus.walleij@linaro.org --- drivers/mtd/nand/raw/Kconfig | 7 + drivers/mtd/nand/raw/brcmnand/Makefile | 1 + drivers/mtd/nand/raw/brcmnand/iproc_nand.c | 141 +++++++++++++++++++++ 3 files changed, 149 insertions(+) create mode 100644 drivers/mtd/nand/raw/brcmnand/iproc_nand.c
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 5b35da45f584..6a13bc1e228a 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -156,6 +156,13 @@ config NAND_BRCMNAND_63158 help Enable support for broadcom nand driver on bcm63158.
+config NAND_BRCMNAND_IPROC + bool "Support Broadcom NAND controller on the iproc family" + depends on NAND_BRCMNAND + help + Enable support for broadcom nand driver on the Broadcom + iproc family such as Northstar (BCM5301x, BCM4708...) + config NAND_DAVINCI bool "Support TI Davinci NAND controller" select SYS_NAND_SELF_INIT if TARGET_DA850EVM diff --git a/drivers/mtd/nand/raw/brcmnand/Makefile b/drivers/mtd/nand/raw/brcmnand/Makefile index f46a7edae321..0c6325aaa618 100644 --- a/drivers/mtd/nand/raw/brcmnand/Makefile +++ b/drivers/mtd/nand/raw/brcmnand/Makefile @@ -6,5 +6,6 @@ obj-$(CONFIG_NAND_BRCMNAND_6753) += bcm6753_nand.o obj-$(CONFIG_NAND_BRCMNAND_68360) += bcm68360_nand.o obj-$(CONFIG_NAND_BRCMNAND_6838) += bcm6838_nand.o obj-$(CONFIG_NAND_BRCMNAND_6858) += bcm6858_nand.o +obj-$(CONFIG_NAND_BRCMNAND_IPROC) += iproc_nand.o obj-$(CONFIG_NAND_BRCMNAND) += brcmnand.o obj-$(CONFIG_NAND_BRCMNAND) += brcmnand_compat.o diff --git a/drivers/mtd/nand/raw/brcmnand/iproc_nand.c b/drivers/mtd/nand/raw/brcmnand/iproc_nand.c new file mode 100644 index 000000000000..c61a120b6d27 --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/iproc_nand.c @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Code borrowed from the Linux driver + * Copyright (C) 2015 Broadcom Corporation + */ + +#include <common.h> +#include <asm/io.h> +#include <memalign.h> +#include <nand.h> +#include <linux/bitops.h> +#include <linux/err.h> +#include <linux/errno.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <dm.h> + +#include "brcmnand.h" + +struct iproc_nand_soc { + struct brcmnand_soc soc; + void __iomem *idm_base; + void __iomem *ext_base; +}; + +#define IPROC_NAND_CTLR_READY_OFFSET 0x10 +#define IPROC_NAND_CTLR_READY BIT(0) + +#define IPROC_NAND_IO_CTRL_OFFSET 0x00 +#define IPROC_NAND_APB_LE_MODE BIT(24) +#define IPROC_NAND_INT_CTRL_READ_ENABLE BIT(6) + +static bool iproc_nand_intc_ack(struct brcmnand_soc *soc) +{ + struct iproc_nand_soc *priv = + container_of(soc, struct iproc_nand_soc, soc); + void __iomem *mmio = priv->ext_base + IPROC_NAND_CTLR_READY_OFFSET; + u32 val = brcmnand_readl(mmio); + + if (val & IPROC_NAND_CTLR_READY) { + brcmnand_writel(IPROC_NAND_CTLR_READY, mmio); + return true; + } + + return false; +} + +static void iproc_nand_intc_set(struct brcmnand_soc *soc, bool en) +{ + struct iproc_nand_soc *priv = + container_of(soc, struct iproc_nand_soc, soc); + void __iomem *mmio = priv->idm_base + IPROC_NAND_IO_CTRL_OFFSET; + u32 val = brcmnand_readl(mmio); + + if (en) + val |= IPROC_NAND_INT_CTRL_READ_ENABLE; + else + val &= ~IPROC_NAND_INT_CTRL_READ_ENABLE; + + brcmnand_writel(val, mmio); +} + +static void iproc_nand_apb_access(struct brcmnand_soc *soc, bool prepare, + bool is_param) +{ + struct iproc_nand_soc *priv = + container_of(soc, struct iproc_nand_soc, soc); + void __iomem *mmio = priv->idm_base + IPROC_NAND_IO_CTRL_OFFSET; + u32 val; + + val = brcmnand_readl(mmio); + + /* + * In the case of BE or when dealing with NAND data, always configure + * the APB bus to LE mode before accessing the FIFO and back to BE mode + * after the access is done + */ + if (IS_ENABLED(CONFIG_SYS_BIG_ENDIAN) || !is_param) { + if (prepare) + val |= IPROC_NAND_APB_LE_MODE; + else + val &= ~IPROC_NAND_APB_LE_MODE; + } else { /* when in LE accessing the parameter page, keep APB in BE */ + val &= ~IPROC_NAND_APB_LE_MODE; + } + + brcmnand_writel(val, mmio); +} + +static int iproc_nand_probe(struct udevice *dev) +{ + struct udevice *pdev = dev; + struct iproc_nand_soc *priv = dev_get_priv(dev); + struct brcmnand_soc *soc; + struct resource res; + + soc = &priv->soc; + + dev_read_resource_byname(pdev, "iproc-idm", &res); + priv->idm_base = ioremap(res.start, resource_size(&res)); + if (IS_ERR(priv->idm_base)) + return PTR_ERR(priv->idm_base); + + dev_read_resource_byname(pdev, "iproc-ext", &res); + priv->ext_base = ioremap(res.start, resource_size(&res)); + if (IS_ERR(priv->ext_base)) + return PTR_ERR(priv->ext_base); + + soc->ctlrdy_ack = iproc_nand_intc_ack; + soc->ctlrdy_set_enabled = iproc_nand_intc_set; + soc->prepare_data_bus = iproc_nand_apb_access; + + return brcmnand_probe(pdev, soc); +} + +static const struct udevice_id iproc_nand_dt_ids[] = { + { + .compatible = "brcm,nand-iproc", + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(iproc_nand) = { + .name = "iproc-nand", + .id = UCLASS_MTD, + .of_match = iproc_nand_dt_ids, + .probe = iproc_nand_probe, + .priv_auto = sizeof(struct iproc_nand_soc), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_DRIVER_GET(iproc_nand), &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize %s. (error %d)\n", dev->name, + ret); +}
On Sun, Jan 22, 2023 at 12:45 AM Linus Walleij linus.walleij@linaro.org wrote:
It's been 1 1/2 month, could we apply this patch?
Yours, Linus Walleij
Adding the nand custodians.
Thanks Tom, I need to get better at identifying the right people for patches.
Hi
help
- Code borrowed from the Linux driver
- Copyright (C) 2015 Broadcom Corporation
return true;
return false;
if (en)
else
bool is_param)
u32 val;
if (prepare)
else
soc = &priv->soc;
Check the return value of dev_read_resource
To be more close to linux use devm_ioremap.
{ /* sentinel */ }
.id = UCLASS_MTD,
int ret;
ret);
2.39.0
Another then that:
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
Linus Walleij
Michael Nazzareno Trimarchi
