[PATCH 1/2] ARM: rmobile: Identify R-Car M3-W R8A7796 r1.1/1.2 SoC
From: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com
r8a7796 cpu revision v1.2 has the same information as revision v1.1. This patch fixes revision display at startup to "rev 1.1/1.2".
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com Signed-off-by: Hai Pham hai.pham.ud@renesas.com [Marek: Slight update to commit message, spell out the SoC model] --- arch/arm/mach-rmobile/cpu_info.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-rmobile/cpu_info.c b/arch/arm/mach-rmobile/cpu_info.c index 71a856ea879..1d33e2aa9da 100644 --- a/arch/arm/mach-rmobile/cpu_info.c +++ b/arch/arm/mach-rmobile/cpu_info.c @@ -120,6 +120,13 @@ int print_cpuinfo(void) { int i = rmobile_cpuinfo_idx();
+ if (rmobile_cpuinfo[i].cpu_type == RMOBILE_CPU_TYPE_R8A7796 && + rmobile_get_cpu_rev_integer() == 1 && + rmobile_get_cpu_rev_fraction() == 1) { + printf("CPU: Renesas Electronics %s rev 1.1/1.2\n", get_cpu_name(i)); + return 0; + } + printf("CPU: Renesas Electronics %s rev %d.%d\n", get_cpu_name(i), rmobile_get_cpu_rev_integer(), rmobile_get_cpu_rev_fraction());
Add support to identify R8A77995 r1.1 SoC.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Hai Pham hai.pham.ud@renesas.com [Marek: Slight update to commit message, spell out the SoC model] --- arch/arm/mach-rmobile/cpu_info-rcar.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rmobile/cpu_info-rcar.c b/arch/arm/mach-rmobile/cpu_info-rcar.c index 62017f52c3b..8fc4cd7f9de 100644 --- a/arch/arm/mach-rmobile/cpu_info-rcar.c +++ b/arch/arm/mach-rmobile/cpu_info-rcar.c @@ -11,6 +11,7 @@ #define R8A7796_REV_1_0 0x5200 #define R8A7796_REV_1_1 0x5210 #define R8A7796_REV_1_3 0x5211 +#define R8A77995_REV_1_1 0x5810
static u32 rmobile_get_prr(void) { @@ -30,7 +31,8 @@ u32 rmobile_get_cpu_rev_integer(void) const u32 prr = rmobile_get_prr(); const u32 rev = prr & PRR_MASK;
- if (rev == R8A7796_REV_1_1 || rev == R8A7796_REV_1_3) + if (rev == R8A7796_REV_1_1 || rev == R8A7796_REV_1_3 || + rev == R8A77995_REV_1_1) return 1; else return ((prr & 0x000000F0) >> 4) + 1; @@ -41,7 +43,7 @@ u32 rmobile_get_cpu_rev_fraction(void) const u32 prr = rmobile_get_prr(); const u32 rev = prr & PRR_MASK;
- if (rev == R8A7796_REV_1_1) + if (rev == R8A7796_REV_1_1 || rev == R8A77995_REV_1_1) return 1; else if (rev == R8A7796_REV_1_3) return 3;
