[UBOOT PATCH] arm64: zynqmp: Enable the config CMD_KASLRSEED
Kernel Address Space Layout Randomization (KASLR) is a hardening feature that aims to make it more difficult to take advantage of known exploits in the kernel, by placing kernel data structures at a random address at each boot.The bootloader supports randomizing the virtual address at which the kernel image is loaded. The bootloader must provide entropy by passing a random u64 value in the /chosen/kaslr-seed device tree node. When we run "kaslrseed" command from U-Boot, the bootloader will genarate the kaslr-seed and update the /chosen/kaslr-seed DT property.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- configs/xilinx_zynqmp_virt_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index acab38fefe..b67b637e52 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -91,6 +91,7 @@ CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y CONFIG_CMD_GETTIME=y CONFIG_CMD_RNG=y +CONFIG_CMD_KASLRSEED=y CONFIG_CMD_TIMER=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_SMC=y
Applied. M
Michal Simek
