[U-Boot] [PATCH 1/1] efi_loader: UninstallMultipleProtocolInterfaces error code
If UninstallMultipleProtocolInterfaces fails, we sometimes return the wrong status code. The UEFI spec mandates to always return EFI_INVALID_PARAMETER.
Update unit test.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 3 ++- .../efi_selftest_manageprotocols.c | 18 +++++++++++++++--- 2 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index ac724b17fd..554997f44a 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2409,7 +2409,8 @@ static efi_status_t EFIAPI efi_uninstall_multiple_protocol_interfaces( } efi_va_end(argptr);
- return EFI_EXIT(r); + /* In case of an error always return EFI_INVALID_PARAMETER */ + return EFI_EXIT(EFI_INVALID_PARAMETER); }
/** diff --git a/lib/efi_selftest/efi_selftest_manageprotocols.c b/lib/efi_selftest/efi_selftest_manageprotocols.c index b09e4cdcfa..0ff35cec8a 100644 --- a/lib/efi_selftest/efi_selftest_manageprotocols.c +++ b/lib/efi_selftest/efi_selftest_manageprotocols.c @@ -189,7 +189,14 @@ static int execute(void) /* * Test error handling in UninstallMultipleProtocols * - * Try to uninstall more protocols than there are installed. + * These are the installed protocol interfaces on handle 2: + * + * guid1 interface4 + * guid2 interface2 + * + * Try to uninstall more protocols than there are installed. This + * should return an error EFI_INVALID_PARAMETER. All deleted protocols + * should be reinstalled. */ ret = boottime->uninstall_multiple_protocol_interfaces( handle2, @@ -197,13 +204,18 @@ static int execute(void) &guid2, &interface2, &guid3, &interface3, NULL); - if (ret == EFI_SUCCESS) { + if (ret != EFI_INVALID_PARAMETER) { + printf("%lx", ret); efi_st_error("UninstallMultipleProtocolInterfaces did not catch error\n"); return EFI_ST_FAILURE; }
/* * Test LocateHandleBuffer with ByProtocol + * + * These are the handles with a guid1 protocol interface installed: + * + * handle1, handle2 */ count = buffer_size; ret = boottime->locate_handle_buffer(BY_PROTOCOL, &guid1, NULL, @@ -213,7 +225,7 @@ static int execute(void) return EFI_ST_FAILURE; } if (count != 2) { - efi_st_error("LocateHandleBuffer failed to locate new handles\n"); + efi_st_error("UninstallMultipleProtocolInterfaces deleted handle\n"); return EFI_ST_FAILURE; } ret = find_in_buffer(handle1, count, buffer);
