[PATCH] rkspi: only enable padding quirk on SoCs which need it
The workaround for the Mask ROM bug in a lot of Rockchip SoCs is applied unconditionally, but at least on the RK3328 it is not needed and causes a boot failure if applied.
Make a new column in the SoC feature description and skip the workaround if the SoC doesn't need it.
Signed-off-by: Lorenz Brun lorenz@brun.one --- tools/rkcommon.c | 35 ++++++++++++++++++++++------------- tools/rkcommon.h | 9 +++++++++ tools/rkspi.c | 6 ++++++ 3 files changed, 37 insertions(+), 13 deletions(-)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 0db45c2d41..4b4de24f21 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -118,22 +118,24 @@ struct spl_info { const uint32_t spl_size; const bool spl_rc4; const uint32_t header_ver; + const bool has_spi_halfblock_quirk; };
+// Note: has_spi_halfblock_quirk is not certain on all SoCs. static struct spl_info spl_infos[] = { - { "px30", "RK33", 0x2800, false, RK_HEADER_V1 }, - { "rk3036", "RK30", 0x1000, false, RK_HEADER_V1 }, - { "rk3066", "RK30", 0x8000 - 0x800, true, RK_HEADER_V1 }, - { "rk3128", "RK31", 0x1800, false, RK_HEADER_V1 }, - { "rk3188", "RK31", 0x8000 - 0x800, true, RK_HEADER_V1 }, - { "rk322x", "RK32", 0x8000 - 0x1000, false, RK_HEADER_V1 }, - { "rk3288", "RK32", 0x8000, false, RK_HEADER_V1 }, - { "rk3308", "RK33", 0x40000 - 0x1000, false, RK_HEADER_V1 }, - { "rk3328", "RK32", 0x8000 - 0x1000, false, RK_HEADER_V1 }, - { "rk3368", "RK33", 0x8000 - 0x1000, false, RK_HEADER_V1 }, - { "rk3399", "RK33", 0x30000 - 0x2000, false, RK_HEADER_V1 }, - { "rv1108", "RK11", 0x1800, false, RK_HEADER_V1 }, - { "rk3568", "RK35", 0x14000 - 0x1000, false, RK_HEADER_V2 }, + { "px30", "RK33", 0x2800, false, RK_HEADER_V1, true}, + { "rk3036", "RK30", 0x1000, false, RK_HEADER_V1, true }, + { "rk3066", "RK30", 0x8000 - 0x800, true, RK_HEADER_V1, true }, + { "rk3128", "RK31", 0x1800, false, RK_HEADER_V1, true }, + { "rk3188", "RK31", 0x8000 - 0x800, true, RK_HEADER_V1, true }, + { "rk322x", "RK32", 0x8000 - 0x1000, false, RK_HEADER_V1, true }, + { "rk3288", "RK32", 0x8000, false, RK_HEADER_V1, true }, + { "rk3308", "RK33", 0x40000 - 0x1000, false, RK_HEADER_V1, true }, + { "rk3328", "RK32", 0x8000 - 0x1000, false, RK_HEADER_V1, false }, + { "rk3368", "RK33", 0x8000 - 0x1000, false, RK_HEADER_V1, true }, + { "rk3399", "RK33", 0x30000 - 0x2000, false, RK_HEADER_V1, true }, + { "rv1108", "RK11", 0x1800, false, RK_HEADER_V1, true }, + { "rk3568", "RK35", 0x14000 - 0x1000, false, RK_HEADER_V2, true }, };
/** @@ -282,6 +284,13 @@ bool rkcommon_is_header_v2(struct image_tool_params *params) return (info->header_ver == RK_HEADER_V2); }
+bool rkcommon_has_spi_halfblock_quirk(struct image_tool_params *params) +{ + struct spl_info *info = rkcommon_get_spl_info(params->imagename); + + return info->has_spi_halfblock_quirk; +} + static void do_sha256_hash(uint8_t *buf, uint32_t size, uint8_t *out) { sha256_context ctx; diff --git a/tools/rkcommon.h b/tools/rkcommon.h index 49b6df3185..7b0c036dac 100644 --- a/tools/rkcommon.h +++ b/tools/rkcommon.h @@ -41,6 +41,15 @@ const char *rkcommon_get_spl_hdr(struct image_tool_params *params); */ int rkcommon_get_spl_size(struct image_tool_params *params);
+ +/** + * rkcommon_has_spi_halfblock_quirk checks if the SoC MaskROM has the SPI block + * loading quirk. + * SoCs with this quirk load the initial TPL/SPL incorrectly and need each 4K + * block of it to be split into two 2K blocks with the upper half padded. + */ +bool rkcommon_has_spi_halfblock_quirk(struct image_tool_params *params); + /** * rkcommon_set_header() - set up the header for a Rockchip boot image * diff --git a/tools/rkspi.c b/tools/rkspi.c index f2530f7bde..b6f75fae1b 100644 --- a/tools/rkspi.c +++ b/tools/rkspi.c @@ -26,6 +26,9 @@ static void rkspi_set_header(void *buf, struct stat *sbuf, int ifd,
rkcommon_set_header(buf, sbuf, ifd, params);
+ if(!rkcommon_has_spi_halfblock_quirk(params)) + return; + /* * Spread the image out so we only use the first 2KB of each 4KB * region. This is a feature of the SPI format required by the Rockchip @@ -62,6 +65,9 @@ static int rkspi_vrec_header(struct image_tool_params *params, { rkcommon_vrec_header(params, tparams);
+ if(!rkcommon_has_spi_halfblock_quirk(params)) + return 0; + /* * Converting to the SPI format (i.e. splitting each 4K page into two * 2K subpages and then padding these 2K pages up to take a complete
Hi Lorenz,
This is no need because:
- a type rkspi is need because the format is different requirement for the image format;
- when then issue fixed in new SoC, then the image format is the same as rksd, so you can
use rksd for all the image in new SoCs.
Thanks,
- Kever
- const bool has_spi_halfblock_quirk; };
- struct spl_info *info = rkcommon_get_spl_info(params->imagename);
- return info->has_spi_halfblock_quirk;
- static void do_sha256_hash(uint8_t *buf, uint32_t size, uint8_t *out) { sha256_context ctx;
- rkcommon_has_spi_halfblock_quirk checks if the SoC MaskROM has the SPI block
- loading quirk.
- SoCs with this quirk load the initial TPL/SPL incorrectly and need each 4K
- block of it to be split into two 2K blocks with the upper half padded.
- rkcommon_set_header() - set up the header for a Rockchip boot image
- if(!rkcommon_has_spi_halfblock_quirk(params))
return;
- Spread the image out so we only use the first 2KB of each 4KB
- region. This is a feature of the SPI format required by the Rockchip
- Converting to the SPI format (i.e. splitting each 4K page into two
- 2K subpages and then padding these 2K pages up to take a complete
Kever Yang
Lorenz Brun
