[U-Boot] [PATCH v3 00/15] Support for boot image creation for TI secure devices
Adds support for creating bootable images for AM43xx HS and DRA7xx/AM57xx HS devices.
Daniel Allred (9): doc: Add info on using secure devices from TI ti: omap-common: Add commands for generating secure SPL images ti: AM43xx: config.mk: Add support for generating secure boot images ti_omap5_common: Update SPL start address on secure parts spl: build: ti: add support for secure boot images ARM: omap-common: Add device type to CPU string ARM: omap5: add hooks for cpu/SoC fdt fixups ARM: omap5: add ft_board_setup for dra7xx/am57xx defconfig: ti: Add configs for OMAP5-class secure parts
Madan Srinivas (6): arm: am33xx: Kconfig: Add secure device definitions arm: Kconfig: Add support for AM43xx SoC specific Kconfig ti: omap-common: Add Kconfig file for secure device support ti: AM43xx: Use CONFIG options from SOC Kconfig ti: AM43xx: board: Detect AM43xx HS EVM defconfig: Add a config for AM43xx secure part
arch/arm/Kconfig | 23 +-- arch/arm/cpu/armv7/am33xx/Kconfig | 40 ++++++ arch/arm/cpu/armv7/am33xx/config.mk | 20 +++ arch/arm/cpu/armv7/omap-common/Kconfig | 17 +++ arch/arm/cpu/armv7/omap-common/config_secure.mk | 66 +++++++++ arch/arm/cpu/armv7/omap-common/hwinit-common.c | 22 ++- arch/arm/cpu/armv7/omap5/Makefile | 1 + arch/arm/cpu/armv7/omap5/config.mk | 6 + arch/arm/cpu/armv7/omap5/fdt.c | 184 ++++++++++++++++++++++++ arch/arm/include/asm/arch-omap3/cpu.h | 7 +- arch/arm/include/asm/omap_common.h | 11 ++ board/ti/am43xx/board.c | 4 +- board/ti/am43xx/board.h | 14 +- board/ti/am43xx/mux.c | 2 +- board/ti/am57xx/board.c | 9 ++ board/ti/dra7xx/evm.c | 9 ++ configs/am437x_gp_evm_defconfig | 1 + configs/am437x_hs_evm_defconfig | 53 +++++++ configs/am437x_sk_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 2 + configs/am43xx_evm_usbhost_boot_defconfig | 2 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 36 +++++ configs/dra72_evm_defconfig | 1 + configs/dra72_hs_evm_defconfig | 55 +++++++ configs/dra74_evm_defconfig | 1 + configs/dra74_hs_evm_defconfig | 54 +++++++ doc/README.ti-secure | 91 ++++++++++++ include/configs/am43xx_evm.h | 23 ++- include/configs/ti_omap5_common.h | 32 ++++- 32 files changed, 747 insertions(+), 43 deletions(-) create mode 100644 arch/arm/cpu/armv7/am33xx/Kconfig create mode 100644 arch/arm/cpu/armv7/omap-common/Kconfig create mode 100644 arch/arm/cpu/armv7/omap-common/config_secure.mk create mode 100644 arch/arm/cpu/armv7/omap5/fdt.c create mode 100644 configs/am437x_hs_evm_defconfig create mode 100644 configs/am57xx_hs_evm_defconfig create mode 100644 configs/dra72_hs_evm_defconfig create mode 100644 configs/dra74_hs_evm_defconfig create mode 100644 doc/README.ti-secure
Adds doc/README.ti-secure file to explain in generic terms how boot images need to be created for secure devices from Texas Instruments.
Specific details for creating secure boot images for the AM43xx, DRA7xx and AM57xx secure devices from Texas Instruments are also provided in the README file.
Secure devices require a security development package (SECDEV) package that can be downloaded from:
http://www.ti.com/mysecuresoftware
Login is required and access is granted under appropriate NDA and export control restrictions.
Signed-off-by: Madan Srinivas madans@ti.com Signed-off-by: Daniel Allred d-allred@ti.com
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Andreas Dannenberg dannenberg@ti.com Reviewed-by: Tom Rini trini@konsulko.com ---
V3: None
V2: Minor whitespace fixes
doc/README.ti-secure | 91 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 91 insertions(+) create mode 100644 doc/README.ti-secure
diff --git a/doc/README.ti-secure b/doc/README.ti-secure new file mode 100644 index 0000000..7fc9b9b --- /dev/null +++ b/doc/README.ti-secure @@ -0,0 +1,91 @@ +README on how boot images are created for secure TI devices + +CONFIG_TI_SECURE_DEVICE: +Secure TI devices require a boot image that is authenticated by ROM +code to function. Without this, even JTAG remains locked and the +device is essentially useless. In order to create a valid boot image for +a secure device from TI, the initial public software image must be signed +and combined with various headers, certificates, and other binary images. + +Information on the details on the complete boot image format can be obtained +from Texas Instruments. The tools used to generate boot images for secure +devices are part of a secure development package (SECDEV) that can be +downloaded from: + + http://www.ti.com/mysecuresoftware (login required) + +The secure development package is access controlled due to NDA and export +control restrictions. Access must be requested and granted by TI before the +package is viewable and downloadable. Contact TI, either online or by way +of a local TI representative, to request access. + +When CONFIG_TI_SECURE_DEVICE is set, the U-Boot SPL build process requires +the presence and use of these tools in order to create a viable boot image. +The build process will look for the environment variable TI_SECURE_DEV_PKG, +which should be the path of the installed SECDEV package. If the +TI_SECURE_DEV_PKG variable is not defined or if it is defined but doesn't +point to a valid SECDEV package, a warning is issued during the build to +indicate that a final secure bootable image was not created. + +Within the SECDEV package exists an image creation script: + +${TI_SECURE_DEV_PKG}/scripts/create-boot-image.sh + +This is called as part of the SPL/u-boot build process. As the secure boot +image formats and requirements differ between secure SOC from TI, the +purpose of this script is to abstract these details as much as possible. + +The script is basically the only required interface to the TI SECDEV package +for secure TI devices. + +Invoking the script for AM43xx Secure Devices +============================================= + +create-boot-image.sh <IMAGE_FLAG> <INPUT_FILE> <OUTPUT_FILE> <SPL_LOAD_ADDR> + +<IMAGE_FLAG> is a value that specifies the type of the image to generate OR +the action the image generation tool will take. Valid values are: + SPI_X-LOADER - Generates an image for SPI flash (byte swapped) + XIP_X-LOADER - Generates a single stage u-boot for NOR/QSPI XiP + ISSW - Generates an image for all other boot modes + +<INPUT_FILE> is the full path and filename of the public world boot loader +binary file (depending on the boot media, this is usually either +u-boot-spl.bin or u-boot.bin). + +<OUTPUT_FILE> is the full path and filename of the final secure image. The +output binary images should be used in place of the standard non-secure +binary images (see the platform-specific user's guides and releases notes +for how the non-secure images are typically used) + u-boot-spl_HS_SPI_X-LOADER - byte swapped boot image for SPI flash + u-boot_HS_XIP_X-LOADER - boot image for NOR or QSPI flash + u-boot-spl_HS_ISSW - boot image for all other boot media + +<SPL_LOAD_ADDR> is the address at which SOC ROM should load the <INPUT_FILE> + +Invoking the script for DRA7xx/AM57xx Secure Devices +==================================================== + +create-boot-image.sh <IMAGE_TYPE> <INPUT_FILE> <OUTPUT_FILE> + +<IMAGE_TYPE> is a value that specifies the type of the image to generate OR +the action the image generation tool will take. Valid values are: + X-LOADER - Generates an image for NOR or QSPI boot modes + MLO - Generates an image for SD/MMC/eMMC boot modes + ULO - Generates an image for USB/UART peripheral boot modes + Note: ULO is not yet used by the u-boot build process + +<INPUT_FILE> is the full path and filename of the public world boot loader +binary file (for this platform, this is always u-boot-spl.bin). + +<OUTPUT_FILE> is the full path and filename of the final secure image. The +output binary images should be used in place of the standard non-secure +binary images (see the platform-specific user's guides and releases notes +for how the non-secure images are typically used) + u-boot-spl_HS_MLO - boot image for SD/MMC/eMMC. This image is + copied to a file named MLO, which is the name that + the device ROM bootloader requires for loading from + the FAT partition of an SD card (same as on + non-secure devices) + u-boot-spl_HS_X-LOADER - boot image for all other flash memories + including QSPI and NOR flash
Adds a new Kconfig file for AM33xx class devices. We need a common place to define CONFIG parameters for these SOCs, especially for adding support for secure devices.
a) Adds a definition for ISW_ENTRY_ADDR. This is the address to which the ROM branches when the SOC ROM hands off execution to the boot loader. CONFIG_SYS_TEXT_BASE and CONFIG_SPL_TEXT_BASE are set to this value for AM43xx devices.
b) Adds CONFIG_PUB_ROM_DATA_SIZE which is used to calculate CONFIG_SPL_MAX_SIZE. This value indicates the amount of memory needed by the ROM to store data during the boot process.
Currently, these CONFIG options are used only by AM43xx, but in future other AM33xx class SOCs will also use them.
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com Tested-by: Andreas Dannenberg dannenberg@ti.com Reviewed-by: Tom Rini trini@konsulko.com ---
V3: None
V2: None
arch/arm/cpu/armv7/am33xx/Kconfig | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+) create mode 100644 arch/arm/cpu/armv7/am33xx/Kconfig
diff --git a/arch/arm/cpu/armv7/am33xx/Kconfig b/arch/arm/cpu/armv7/am33xx/Kconfig new file mode 100644 index 0000000..39759cd --- /dev/null +++ b/arch/arm/cpu/armv7/am33xx/Kconfig @@ -0,0 +1,27 @@ +config ISW_ENTRY_ADDR + hex "Address in memory or XIP flash of bootloader entry point" + help + After any reset, the boot ROM on the AM43XX SOC + searches the boot media for a valid boot image. + For non-XIP devices, the ROM then copies the + image into internal memory. + For all boot modes, after the ROM processes the + boot image it eventually computes the entry + point address depending on the device type + (secure/non-secure), boot media (xip/non-xip) and + image headers. + default 0x402F4000 + +config PUB_ROM_DATA_SIZE + hex "Size in bytes of the L3 SRAM reserved by ROM to store data" + help + During the device boot, the public ROM uses the top of + the public L3 OCMC RAM to store r/w data like stack, + heap, globals etc. When the ROM is copying the boot + image from the boot media into memory, the image must + not spill over into this area. This value can be used + during compile time to determine the maximum size of a + boot image. Once the ROM transfers control to the boot + image, this area is no longer used, and can be reclaimed + for run time use by the boot image. + default 0x8400
Adding support for AM43xx secure devices require the addition of some SOC specific config options like the amount of memory used by public ROM and the address of the entry point of u-boot or SPL, as seen by the ROM code, for the image to be built correctly.
This mandates the addition of am AM43xx CONFIG option and the ARM Kconfig file has been modified to source this SOC Kconfig file. Moving the TARGET_AM43XX_EVM config option to the SOC KConfig and out of the arch/arm/Kconfig.
Updating defconfigs to add the CONFIG_AM43XX=y statement and removing the #define CONFIG_AM43XX from the header file.
V3: None
V2: Update more defconfigs Replace CREATE_BOARD_SYMLINK with TI_I2C_BOARD_DETECT Rebase against latest master
arch/arm/Kconfig | 19 +++++++++++++------ arch/arm/cpu/armv7/am33xx/Kconfig | 13 +++++++++++++ configs/am437x_gp_evm_defconfig | 1 + configs/am437x_sk_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + include/configs/am43xx_evm.h | 2 -- 9 files changed, 32 insertions(+), 8 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6b65d8e..6577572 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -381,12 +381,6 @@ config TARGET_AM335X_SL50 select DM select DM_SERIAL
-config TARGET_AM43XX_EVM - bool "Support am43xx_evm" - select CPU_V7 - select SUPPORT_SPL - select TI_I2C_BOARD_DETECT - config TARGET_BAV335X bool "Support bav335x" select CPU_V7 @@ -507,6 +501,17 @@ config OMAP54XX select CPU_V7 select SUPPORT_SPL
+config AM43XX + bool "AM43XX SoC" + select CPU_V7 + select SUPPORT_SPL + help + Support for AM43xx SOC from Texas Instruments. + The AM43xx high performance SOC features a Cortex-A9 + ARM core, a quad core PRU-ICSS for industrial Ethernet + protocols, dual camera support, optional 3D graphics + and an optional customer programmable secure boot. + config RMOBILE bool "Renesas ARM SoCs" select CPU_V7 @@ -777,6 +782,8 @@ source "arch/arm/cpu/armv7/omap4/Kconfig"
source "arch/arm/cpu/armv7/omap5/Kconfig"
+source "arch/arm/cpu/armv7/am33xx/Kconfig" + source "arch/arm/mach-orion5x/Kconfig"
source "arch/arm/cpu/armv7/rmobile/Kconfig" diff --git a/arch/arm/cpu/armv7/am33xx/Kconfig b/arch/arm/cpu/armv7/am33xx/Kconfig index 39759cd..dc51e9b 100644 --- a/arch/arm/cpu/armv7/am33xx/Kconfig +++ b/arch/arm/cpu/armv7/am33xx/Kconfig @@ -1,3 +1,15 @@ +if AM43XX +config TARGET_AM43XX_EVM + bool "Support am43xx_evm" + select TI_I2C_BOARD_DETECT + help + This option specifies support for the AM43xx + GP and HS EVM development platforms.The AM437x + GP EVM is a standalone test, development, and + evaluation module system that enables developers + to write software and develop hardware around + an AM43xx processor subsystem. + config ISW_ENTRY_ADDR hex "Address in memory or XIP flash of bootloader entry point" help @@ -25,3 +37,4 @@ config PUB_ROM_DATA_SIZE image, this area is no longer used, and can be reclaimed for run time use by the boot image. default 0x8400 +endif diff --git a/configs/am437x_gp_evm_defconfig b/configs/am437x_gp_evm_defconfig index 03b02ac..f036bc7 100644 --- a/configs/am437x_gp_evm_defconfig +++ b/configs/am437x_gp_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y diff --git a/configs/am437x_sk_evm_defconfig b/configs/am437x_sk_evm_defconfig index 48ec91f..0251270 100644 --- a/configs/am437x_sk_evm_defconfig +++ b/configs/am437x_sk_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_DM_SERIAL=y CONFIG_DM_SPI=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index a6ae011..c9b6e6a 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 662556a..e1499ad 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_ETH_SUPPORT" diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 00fa6be..bda0ae1 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" CONFIG_HUSH_PARSER=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index e3d6b57..d9fc4de 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_USB_HOST_SUPPORT" diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 5b49988..a35541b 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_AM43XX_EVM_H #define __CONFIG_AM43XX_EVM_H
-#define CONFIG_AM43XX - #define CONFIG_BOARD_LATE_INIT #define CONFIG_ARCH_CPU_INIT #define CONFIG_SYS_CACHELINE_SIZE 32
Defines CONFIG_TI_SECURE_DEVICE which needs to be turned on when building images for secure devices. This flag is used to invoke the secure image creation tools for creating a boot image that can be used on secure devices. This flag may also be used to conditionally compile code specific to secure devices.
This terminology will be used by all OMAP architecture devices, hence introducing to a common location.
With the creation of Kconfig for omap-common, moved the sourcing of the Kconfig files for the omap3/4/5 and am33xx devices from arch/arm/KConfig to the omap-common one.
V3: None
V2: None
arch/arm/Kconfig | 8 +------- arch/arm/cpu/armv7/omap-common/Kconfig | 17 +++++++++++++++++ 2 files changed, 18 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6577572..3c545f0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -776,13 +776,7 @@ source "arch/arm/cpu/armv7/mx6/Kconfig"
source "arch/arm/cpu/armv7/mx5/Kconfig"
-source "arch/arm/cpu/armv7/omap3/Kconfig" - -source "arch/arm/cpu/armv7/omap4/Kconfig" - -source "arch/arm/cpu/armv7/omap5/Kconfig" - -source "arch/arm/cpu/armv7/am33xx/Kconfig" +source "arch/arm/cpu/armv7/omap-common/Kconfig"
diff --git a/arch/arm/cpu/armv7/omap-common/Kconfig b/arch/arm/cpu/armv7/omap-common/Kconfig new file mode 100644 index 0000000..7b39506 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/Kconfig @@ -0,0 +1,17 @@ +config TI_SECURE_DEVICE + bool "HS Device Type Support" + depends on OMAP54XX || AM43XX + help + If a high secure (HS) device type is being used, this config + must be set. This option impacts various aspects of the + build system (to create signed boot images that can be + authenticated) and the code. See the doc/README.ti-secure + file for further details. + +source "arch/arm/cpu/armv7/omap3/Kconfig" + +source "arch/arm/cpu/armv7/omap4/Kconfig" + +source "arch/arm/cpu/armv7/omap5/Kconfig" + +source "arch/arm/cpu/armv7/am33xx/Kconfig"
Adds a centralized config_secure.mk in omap-common for OMAP-style TI secure devices to use for boot image generation
Depending on the boot media, different images are needed for secure devices. These commands generates u-boot*_HS_* files that need to be used to boot secure devices.
Please refer to README.ti-secure for more information.
Signed-off-by: Daniel Allred d-allred@ti.com Signed-off-by: Madan Srinivas madans@ti.com
V3: None
V2: None
arch/arm/cpu/armv7/omap-common/config_secure.mk | 66 +++++++++++++++++++++++++ 1 file changed, 66 insertions(+) create mode 100644 arch/arm/cpu/armv7/omap-common/config_secure.mk
diff --git a/arch/arm/cpu/armv7/omap-common/config_secure.mk b/arch/arm/cpu/armv7/omap-common/config_secure.mk new file mode 100644 index 0000000..c7bb101 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/config_secure.mk @@ -0,0 +1,66 @@ +# +# Copyright (C) 2016, Texas Instruments, Incorporated - http://www.ti.com/ +# +# SPDX-License-Identifier: GPL-2.0+ +# +quiet_cmd_mkomapsecimg = MKIMAGE $@ +ifneq ($(TI_SECURE_DEV_PKG),) +ifneq ($(wildcard $(TI_SECURE_DEV_PKG)/scripts/create-boot-image.sh),) +ifneq ($(CONFIG_SPL_BUILD),) +cmd_mkomapsecimg = $(TI_SECURE_DEV_PKG)/scripts/create-boot-image.sh \ + $(patsubst u-boot-spl_HS_%,%,$(@F)) $< $@ $(CONFIG_ISW_ENTRY_ADDR) \ + $(if $(KBUILD_VERBOSE:1=), >/dev/null) +else +cmd_mkomapsecimg = $(TI_SECURE_DEV_PKG)/scripts/create-boot-image.sh \ + $(patsubst u-boot_HS_%,%,$(@F)) $< $@ $(CONFIG_ISW_ENTRY_ADDR) \ + $(if $(KBUILD_VERBOSE:1=), >/dev/null) +endif +else +cmd_mkomapsecimg = echo "WARNING:" \ + "$(TI_SECURE_DEV_PKG)/scripts/create-boot-image.sh not found." \ + "$@ was NOT created!" +endif +else +cmd_mkomapsecimg = echo "WARNING: TI_SECURE_DEV_PKG environment" \ + "variable must be defined for TI secure devices. $@ was NOT created!" +endif + +# Standard X-LOADER target (QPSI, NOR flash) +u-boot-spl_HS_X-LOADER: $(obj)/u-boot-spl.bin + $(call if_changed,mkomapsecimg) + +# For MLO targets (SD card boot) the final file name +# that is copied to the SD card fAT partition must +# be MLO, so we make a copy of the output file to a +# new file with that name +u-boot-spl_HS_MLO: $(obj)/u-boot-spl.bin + $(call if_changed,mkomapsecimg) + @if [ -f $@ ]; then \ + cp -f $@ MLO; \ + fi + +# Standard 2ND target (certain peripheral boot modes) +u-boot-spl_HS_2ND: $(obj)/u-boot-spl.bin + $(call if_changed,mkomapsecimg) + +# Standard ULO target (certain peripheral boot modes) +u-boot-spl_HS_ULO: $(obj)/u-boot-spl.bin + $(call if_changed,mkomapsecimg) + +# Standard ISSW target (certain devices, various boot modes) +u-boot-spl_HS_ISSW: $(obj)/u-boot-spl.bin + $(call if_changed,mkomapsecimg) + +# For SPI flash on AM335x and AM43xx, these +# require special byte swap handling so we use +# the SPI_X-LOADER target instead of X-LOADER +# and let the create-boot-image.sh script handle +# that +u-boot-spl_HS_SPI_X-LOADER: $(obj)/u-boot-spl.bin + $(call if_changed,mkomapsecimg) + +# For supporting single stage XiP QSPI on AM43xx, the +# image is a full u-boot file, not an SPL. In this case +# the mkomapsecimg command looks for a u-boot-HS_* prefix +u-boot_HS_XIP_X-LOADER: $(obj)/u-boot.bin + $(call if_changed,mkomapsecimg)
Modifies the config.mk to build secure images when building the SPL for secure devices.
Depending on the boot media, different images are needed for secure devices. The build generates u-boot*_HS_* files as appropriate for the different boot modes. The same u-boot binary file is processed slightly differently to produce a different boot image, depending on whether the user wants to boot off SPI, QSPI or other boot media.
Refer to README.ti-secure for more information.
V3: None
V2: None
arch/arm/cpu/armv7/am33xx/config.mk | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/cpu/armv7/am33xx/config.mk b/arch/arm/cpu/armv7/am33xx/config.mk index 5294d16..6d95d32 100644 --- a/arch/arm/cpu/armv7/am33xx/config.mk +++ b/arch/arm/cpu/armv7/am33xx/config.mk @@ -3,9 +3,29 @@ # # SPDX-License-Identifier: GPL-2.0+ # + +include $(srctree)/$(CPUDIR)/omap-common/config_secure.mk + ifdef CONFIG_SPL_BUILD +ifeq ($(CONFIG_TI_SECURE_DEVICE),y) +# +# For booting from SPI use +# u-boot-spl_HS_SPI_X-LOADER to program flash +# +# For booting spl from all other media +# use u-boot-spl_HS_ISSW +# +# Refer to README.ti-secure for more info +# +ALL-y += u-boot-spl_HS_ISSW +ALL-$(CONFIG_SPL_SPI_SUPPORT) += u-boot-spl_HS_SPI_X-LOADER +else ALL-y += MLO ALL-$(CONFIG_SPL_SPI_SUPPORT) += MLO.byteswap +endif else +ifeq ($(CONFIG_TI_SECURE_DEVICE),y) +ALL-$(CONFIG_QSPI_BOOT) += u-boot_HS_XIP_X-LOADER +endif ALL-y += u-boot.img endif
Updates configs/am43xx_evm.h to use CONFIG options from SOC specific Kconfig file for various calculations.
On AM43x devices, the address of SPL entry point depends on the device type, i.e. whether it is secure or non-secure.
Further, for non-secure devices, the SPL entry point is different between USB HOST boot mode, other "memory" boot modes (MMC, NAND) and "peripheral" boot modes (UART, USB)
To add to the complexity, on secure devices, in addition to the above differences, the SPL entry point can change because of the space occupied by other components (other than u-boot or spl) that go into a secure boot image.
To prevent the user from having to modify source files every time any component of the secure image changes, the value of CONFIG_SPL_TEXT_BASE has been set using a Kconfig option that is supplied in the am43xx_*_defconfig files
Using the CONFIG options also enables us to do away with some compile time flags that were used to specify CONFIG_SPL_TEXT_BASE for different boot modes.
On QSPI devices, the same problem described above occurs w.r.t. the address of the u-boot entry point in flash, when booting secure devices. To handle this, CONFIG_SYS_TEXT_BASE is also setup via a Kconfig option and the defconfig files.
V3: None
V2: Rebase against current master
configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + include/configs/am43xx_evm.h | 19 +++++++------------ 3 files changed, 9 insertions(+), 12 deletions(-)
diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index bda0ae1..79eac88 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y +CONFIG_ISW_ENTRY_ADDR=0x30000000 CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index d9fc4de..9943be2 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y +CONFIG_ISW_ENTRY_ADDR=0x40300350 CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_USB_HOST_SUPPORT" CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index a35541b..8a48a9a 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -37,17 +37,10 @@ #define CONFIG_POWER_TPS62362
/* SPL defines. */ -#ifdef CONFIG_SPL_USB_HOST_SUPPORT -/* - * For USB host boot, ROM uses DMA for copying MLO from USB storage - * and ARM internal ram is not accessible for DMA, so SPL text base - * should be in OCMC ram - */ -#define CONFIG_SPL_TEXT_BASE 0x40300350 -#else -#define CONFIG_SPL_TEXT_BASE 0x402F4000 -#endif -#define CONFIG_SPL_MAX_SIZE (220 << 10) /* 220KB */ +#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR +#define CONFIG_SPL_MAX_SIZE (NON_SECURE_SRAM_END - \ + CONFIG_PUB_ROM_DATA_SIZE - \ + CONFIG_SPL_TEXT_BASE) #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20)) #define CONFIG_SPL_POWER_SUPPORT @@ -190,7 +183,9 @@ #endif
#ifdef CONFIG_QSPI_BOOT -#define CONFIG_SYS_TEXT_BASE 0x30000000 +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE CONFIG_ISW_ENTRY_ADDR +#endif #undef CONFIG_ENV_IS_IN_FAT #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT
Adds code to detect AM43xx HS EVMS - the string in the I2C EEPROM for HS EVMs differs from GP EVMs. Adds code to for evm detection, regardless of whether the evm is for GP or HS parts, and updates board init to use that.
Modifies findfdt command to pick up am437x-gp-evm.dtb for the HS EVMs also, as the boards are similar except for some security specific changes around power supply and enclosure protection.
Signed-off-by: Madan Srinivas madans@ti.com Signed-off-by: Daniel Allred d-allred@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com ---
V3: None
board/ti/am43xx/board.c | 4 ++-- board/ti/am43xx/board.h | 14 ++++++++++++-- board/ti/am43xx/mux.c | 2 +- include/configs/am43xx_evm.h | 2 ++ 4 files changed, 17 insertions(+), 5 deletions(-)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index d208d2f..7247107 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -341,7 +341,7 @@ const struct dpll_params *get_dpll_ddr_params(void)
if (board_is_eposevm()) return &epos_evm_dpll_ddr[ind]; - else if (board_is_gpevm() || board_is_sk()) + else if (board_is_evm() || board_is_sk()) return &gp_evm_dpll_ddr; else if (board_is_idk()) return &idk_dpll_ddr; @@ -553,7 +553,7 @@ void sdram_init(void) enable_vtt_regulator(); config_ddr(0, &ioregs_ddr3, NULL, NULL, &ddr3_emif_regs_400Mhz_beta, 0); - } else if (board_is_gpevm()) { + } else if (board_is_evm()) { enable_vtt_regulator(); config_ddr(0, &ioregs_ddr3, NULL, NULL, &ddr3_emif_regs_400Mhz, 0); diff --git a/board/ti/am43xx/board.h b/board/ti/am43xx/board.h index 2cf7a77..3f93d13 100644 --- a/board/ti/am43xx/board.h +++ b/board/ti/am43xx/board.h @@ -37,14 +37,24 @@ static inline int board_is_idk(void) return board_ti_is("AM43_IDK"); }
+static inline int board_is_hsevm(void) +{ + return board_ti_is("AM43XXHS"); +} + +static inline int board_is_evm(void) +{ + return board_is_gpevm() || board_is_hsevm(); +} + static inline int board_is_evm_14_or_later(void) { - return (board_is_gpevm() && strncmp("1.4", board_ti_get_rev(), 3) <= 0); + return board_is_evm() && strncmp("1.4", board_ti_get_rev(), 3) <= 0; }
static inline int board_is_evm_12_or_later(void) { - return (board_is_gpevm() && strncmp("1.2", board_ti_get_rev(), 3) <= 0); + return board_is_evm() && strncmp("1.2", board_ti_get_rev(), 3) <= 0; }
void enable_uart0_pin_mux(void); diff --git a/board/ti/am43xx/mux.c b/board/ti/am43xx/mux.c index e03b1bc..f26b21e 100644 --- a/board/ti/am43xx/mux.c +++ b/board/ti/am43xx/mux.c @@ -126,7 +126,7 @@ void enable_board_pin_mux(void) configure_module_pin_mux(i2c0_pin_mux); configure_module_pin_mux(mdio_pin_mux);
- if (board_is_gpevm()) { + if (board_is_evm()) { configure_module_pin_mux(gpio5_7_pin_mux); configure_module_pin_mux(rgmii1_pin_mux); #if defined(CONFIG_NAND) diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 8a48a9a..a54303d 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -289,6 +289,8 @@ "setenv fdtfile am43x-epos-evm.dtb; fi; " \ "if test $board_name = AM43__GP; then " \ "setenv fdtfile am437x-gp-evm.dtb; fi; " \ + "if test $board_name = AM43XXHS; then " \ + "setenv fdtfile am437x-gp-evm.dtb; fi; " \ "if test $board_name = AM43__SK; then " \ "setenv fdtfile am437x-sk-evm.dtb; fi; " \ "if test $board_name = AM43_IDK; then " \
Adds a new defconfig file for the AM43xx secure device. This is the same as for the non-secure part, except for: CONFIG_TI_SECURE_DEVICE option set to 'y' CONFIG_ISW_ENTRY_ADDR updated for secure images.
V3: None
V2: Update to create a single HS defconfig, based off of the one DT+DM version for AM57xx.
configs/am437x_hs_evm_defconfig | 53 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 53 insertions(+) create mode 100644 configs/am437x_hs_evm_defconfig
diff --git a/configs/am437x_hs_evm_defconfig b/configs/am437x_hs_evm_defconfig new file mode 100644 index 0000000..c4accb6 --- /dev/null +++ b/configs/am437x_hs_evm_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_AM43XX=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TARGET_AM43XX_EVM=y +CONFIG_DM_SERIAL=y +CONFIG_DM_GPIO=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +# Device tree file can be same on HS evm +CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" +CONFIG_SPL=y +CONFIG_ISW_ENTRY_ADDR=0x40302ae0 +CONFIG_SPL_STACK_R=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_MMC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0403 +CONFIG_G_DNL_PRODUCT_NUM=0xbd00
Updated the CONFIG_SPL_TEXT_BASE to support secure parts (moving the start address past secure reserved memory and the size of the security certificate that precedes the boot image on secure devices). Updated the related CONFIG_SPL_MAX_SIZE to properly reflect the internal memory actually available on the various device flavors (Common minimum internal RAM guaranteed for various flavors of DRA7xx/AM57xx is 512KB).
Signed-off-by: Daniel Allred d-allred@ti.com Signed-off-by: Madan Srinivas madans@ti.com ---
V3: Rename CONFIG_SPL_BOOT_END to TI_ROM_BOOT_LOAD_END since it is not a a configurable option (fixed based on device ROM).
V2: Rename CONFIG_SECURE_BOOT_SRAM to TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ since it is not configurable (dependent on ROM/secure code).
include/configs/ti_omap5_common.h | 32 +++++++++++++++++++++++++++----- 1 file changed, 27 insertions(+), 5 deletions(-)
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index b049be4..eb7f206 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -130,13 +130,35 @@
/* * SPL related defines. The Public RAM memory map the ROM defines the - * area between 0x40300000 and 0x4031E000 as a download area for OMAP5 - * (dra7xx is larger, but we do not need to be larger at this time). We - * set CONFIG_SPL_DISPLAY_PRINT to have omap_rev_string() called and + * area between 0x40300000 and 0x4031E000 as a download area for OMAP5. + * On DRA7xx/AM57XX the download area is between 0x40300000 and 0x4037E000. + * We set CONFIG_SPL_DISPLAY_PRINT to have omap_rev_string() called and * print some information. */ -#define CONFIG_SPL_TEXT_BASE 0x40300000 -#define CONFIG_SPL_MAX_SIZE (0x4031E000 - CONFIG_SPL_TEXT_BASE) +#ifdef CONFIG_TI_SECURE_DEVICE +/* + * For memory booting on HS parts, the first 4KB of the internal RAM is + * reserved for secure world use and the flash loader image is + * preceded by a secure certificate. The SPL will therefore run in internal + * RAM from address 0x40301350 (0x40300000+0x1000(reserved)+0x350(cert)). + */ +#define TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ 0x1000 +#define CONFIG_SPL_TEXT_BASE 0x40301350 +#else +/* + * For all booting on GP parts, the flash loader image is + * downloaded into internal RAM at address 0x40300000. + */ +#define CONFIG_SPL_TEXT_BASE 0x40300000 +#endif + +/* DRA7xx/AM57xx have 512K of SRAM, OMAP5 only 128K */ +#if defined(CONFIG_DRA7XX) || defined(CONFIG_AM57XX) +#define TI_ROM_BOOT_LOAD_END 0x4037E000 +#else +#define TI_ROM_BOOT_LOAD_END 0x4031E000 +#endif +#define CONFIG_SPL_MAX_SIZE (TI_ROM_BOOT_LOAD_END - CONFIG_SPL_TEXT_BASE) #define CONFIG_SPL_DISPLAY_PRINT #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \
Signed-off-by: Daniel Allred d-allred@ti.com Signed-off-by: Madan Srinivas madans@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Updates the SPL build so that when CONFIG_TI_SECURE_DEVICE is in use (which it should be when building for secure parts), the TI secure development package is used to create a valid secure boot image. The u-boot SPL build processes is NOT aware of the details of creating the boot image - all of that information is encapsulated in the TI secure development package, which is available from TI. More info can be found in README.ti-secure
Right now, two image types are generated, MLO and X-LOADER. The types are important, as certain boot modes implemented by the device's ROM boot loader require one or the other (they are not equivalent). The output filenames are u-boot-spl_HS_MLO and u-boot-spl_HS_X-LOADER. The u-boot-spl_HS_MLO image is also copied to a file named MLO, which is the name that the device ROM bootloader requires for loading from the FAT partition of an SD card (same as on non-secure devices).
V3: None
V2: None
arch/arm/cpu/armv7/omap5/config.mk | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap5/config.mk b/arch/arm/cpu/armv7/omap5/config.mk index ef2725a..a7e55a5 100644 --- a/arch/arm/cpu/armv7/omap5/config.mk +++ b/arch/arm/cpu/armv7/omap5/config.mk @@ -6,8 +6,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
+include $(srctree)/$(CPUDIR)/omap-common/config_secure.mk + ifdef CONFIG_SPL_BUILD +ifeq ($(CONFIG_TI_SECURE_DEVICE),y) +ALL-y += u-boot-spl_HS_MLO u-boot-spl_HS_X-LOADER +else ALL-y += MLO +endif else ALL-y += u-boot.img endif
Update the CPU string output so that the device type is now included as part of the CPU string that is printed as the SPL or u-boot comes up. This update adds a suffix of the form "-GP" or "-HS" for production devices, so that general purpose (GP) and high security (HS) can be distiguished. Applies to all OMAP5 variants.
V3: Rebase on current master
V2: Move device type defines to omap_common.h, remove duplicates
arch/arm/cpu/armv7/omap-common/hwinit-common.c | 22 ++++++++++++++++++++-- arch/arm/include/asm/arch-omap3/cpu.h | 7 +------ arch/arm/include/asm/omap_common.h | 11 +++++++++++ 3 files changed, 32 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 01c2d57..078bdd8 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -65,12 +65,30 @@ static void omap_rev_string(void) u32 major_rev = (omap_rev & 0x00000F00) >> 8; u32 minor_rev = (omap_rev & 0x000000F0) >> 4;
+ const char *sec_s; + + switch (get_device_type()) { + case TST_DEVICE: + sec_s = "TST"; + break; + case EMU_DEVICE: + sec_s = "EMU"; + break; + case HS_DEVICE: + sec_s = "HS"; + break; + case GP_DEVICE: + sec_s = "GP"; + break; + default: + sec_s = "?"; + } + if (soc_variant) printf("OMAP"); else printf("DRA"); - printf("%x ES%x.%x\n", omap_variant, major_rev, - minor_rev); + printf("%x-%s ES%x.%x\n", omap_variant, sec_s, major_rev, minor_rev); }
#ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/include/asm/arch-omap3/cpu.h b/arch/arm/include/asm/arch-omap3/cpu.h index 53cc2b0..e8aa786 100644 --- a/arch/arm/include/asm/arch-omap3/cpu.h +++ b/arch/arm/include/asm/arch-omap3/cpu.h @@ -59,13 +59,8 @@ struct ctrl_id { #endif /* __ASSEMBLY__ */ #endif /* __KERNEL_STRICT_NAMES */
-/* device type */ -#define DEVICE_MASK (0x7 << 8) +/* boot pin mask */ #define SYSBOOT_MASK 0x1F -#define TST_DEVICE 0x0 -#define EMU_DEVICE 0x1 -#define HS_DEVICE 0x2 -#define GP_DEVICE 0x3
/* device speed */ #define SKUID_CLK_MASK 0xf diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 8fb05e1..ac34b0e 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -717,6 +717,17 @@ static inline u8 is_dra72x(void) #define DRA722_ES2_0 0x07220200
/* + * silicon device type + * Moving to common from cpu.h, since it is shared by various omap devices + */ +#define DEVICE_MASK (BIT(8) | BIT(9) | BIT(10)) +#define TST_DEVICE 0x0 +#define EMU_DEVICE 0x1 +#define HS_DEVICE 0x2 +#define GP_DEVICE 0x3 + + +/* * SRAM scratch space entries */ #define OMAP_SRAM_SCRATCH_OMAP_REV SRAM_SCRATCH_SPACE_ADDR
Adds an fdt.c file in that defines the ft_cpu_setup() function, which should be called from a board-specific ft_board_setup()). This ft_cpu_setup() will currently do nothing for non-secure (GP) devices but contains pertinent updates for booting on secure (HS) devices.
Update the omap5 Makefile to include the fdt.c in the build.
V3: None
V2: Change CONFIG_SECURE_BOOT_SRAM to TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ Change CONFIG_SECURE_RUN_SRAM to CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ
arch/arm/cpu/armv7/omap5/Makefile | 1 + arch/arm/cpu/armv7/omap5/fdt.c | 184 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 185 insertions(+) create mode 100644 arch/arm/cpu/armv7/omap5/fdt.c
diff --git a/arch/arm/cpu/armv7/omap5/Makefile b/arch/arm/cpu/armv7/omap5/Makefile index f2930d5..3caba86 100644 --- a/arch/arm/cpu/armv7/omap5/Makefile +++ b/arch/arm/cpu/armv7/omap5/Makefile @@ -12,4 +12,5 @@ obj-y += sdram.o obj-y += prcm-regs.o obj-y += hw_data.o obj-y += abb.o +obj-y += fdt.o obj-$(CONFIG_IODELAY_RECALIBRATION) += dra7xx_iodelay.o diff --git a/arch/arm/cpu/armv7/omap5/fdt.c b/arch/arm/cpu/armv7/omap5/fdt.c new file mode 100644 index 0000000..0493cd1 --- /dev/null +++ b/arch/arm/cpu/armv7/omap5/fdt.c @@ -0,0 +1,184 @@ +/* + * Copyright 2016 Texas Instruments, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <malloc.h> + +#include <asm/omap_common.h> +#include <asm/arch-omap5/sys_proto.h> + +#ifdef CONFIG_TI_SECURE_DEVICE + +/* Give zero values if not already defined */ +#ifndef TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ +#define TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ (0) +#endif +#ifndef CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ +#define CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ (0) +#endif + +static u32 hs_irq_skip[] = { + 8, /* Secure violation reporting interrupt */ + 15, /* One interrupt for SDMA by secure world */ + 118 /* One interrupt for Crypto DMA by secure world */ +}; + +static int ft_hs_fixup_crossbar(void *fdt, bd_t *bd) +{ + const char *path; + int offs; + int ret; + int len, i, old_cnt, new_cnt; + u32 *temp; + const u32 *p_data; + + /* + * Increase the size of the fdt + * so we have some breathing room + */ + ret = fdt_increase_size(fdt, 512); + if (ret < 0) { + printf("Could not increase size of device tree: %s\n", + fdt_strerror(ret)); + return ret; + } + + /* Reserve IRQs that are used/needed by secure world */ + path = "/ocp/crossbar"; + offs = fdt_path_offset(fdt, path); + if (offs < 0) { + debug("Node %s not found.\n", path); + return 0; + } + + /* Get current entries */ + p_data = fdt_getprop(fdt, offs, "ti,irqs-skip", &len); + if (p_data) + old_cnt = len / sizeof(u32); + else + old_cnt = 0; + + new_cnt = sizeof(hs_irq_skip) / + sizeof(hs_irq_skip[0]); + + /* Create new/updated skip list for HS parts */ + temp = malloc(sizeof(u32) * (old_cnt + new_cnt)); + for (i = 0; i < new_cnt; i++) + temp[i] = cpu_to_fdt32(hs_irq_skip[i]); + for (i = 0; i < old_cnt; i++) + temp[i + new_cnt] = p_data[i]; + + /* Blow away old data and set new data */ + fdt_delprop(fdt, offs, "ti,irqs-skip"); + ret = fdt_setprop(fdt, offs, "ti,irqs-skip", + temp, + (old_cnt + new_cnt) * sizeof(u32)); + free(temp); + + /* Check if the update worked */ + if (ret < 0) { + printf("Could not add ti,irqs-skip property to node %s: %s\n", + path, fdt_strerror(ret)); + return ret; + } + + return 0; +} + +static int ft_hs_disable_rng(void *fdt, bd_t *bd) +{ + const char *path; + int offs; + int ret; + + /* Make HW RNG reserved for secure world use */ + path = "/ocp/rng"; + offs = fdt_path_offset(fdt, path); + if (offs < 0) { + debug("Node %s not found.\n", path); + return 0; + } + ret = fdt_setprop_string(fdt, offs, + "status", "disabled"); + if (ret < 0) { + printf("Could not add status property to node %s: %s\n", + path, fdt_strerror(ret)); + return ret; + } + return 0; +} + +#if ((TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ != 0) || \ + (CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ != 0)) +static int ft_hs_fixup_sram(void *fdt, bd_t *bd) +{ + const char *path; + int offs; + int ret; + u32 temp[2]; + + /* + * Update SRAM reservations on secure devices. The OCMC RAM + * is always reserved for secure use from the start of that + * memory region + */ + path = "/ocp/ocmcram@40300000/sram-hs"; + offs = fdt_path_offset(fdt, path); + if (offs < 0) { + debug("Node %s not found.\n", path); + return 0; + } + + /* relative start offset */ + temp[0] = cpu_to_fdt32(0); + /* reservation size */ + temp[1] = cpu_to_fdt32(max(TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ, + CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ)); + fdt_delprop(fdt, offs, "reg"); + ret = fdt_setprop(fdt, offs, "reg", temp, 2 * sizeof(u32)); + if (ret < 0) { + printf("Could not add reg property to node %s: %s\n", + path, fdt_strerror(ret)); + return ret; + } + + return 0; +} +#else +static int ft_hs_fixup_sram(void *fdt, bd_t *bd) { return 0; } +#endif + +static void ft_hs_fixups(void *fdt, bd_t *bd) +{ + /* Check we are running on an HS/EMU device type */ + if (GP_DEVICE != get_device_type()) { + if ((ft_hs_fixup_crossbar(fdt, bd) == 0) && + (ft_hs_disable_rng(fdt, bd) == 0) && + (ft_hs_fixup_sram(fdt, bd) == 0)) + return; + } else { + printf("ERROR: Incorrect device type (GP) detected!"); + } + /* Fixup failed or wrong device type */ + hang(); +} +#else +static void ft_hs_fixups(void *fdt, bd_t *bd) +{ +} +#endif + +/* + * Place for general cpu/SoC FDT fixups. Board specific + * fixups should remain in the board files which is where + * this function should be called from. + */ +void ft_cpu_setup(void *fdt, bd_t *bd) +{ + ft_hs_fixups(fdt, bd); +}
Adds the board specific ft_board_setup() functions that are called when CONFIG_OF_BOARD_SETUP is defined. These functions will currently just call the ft_cpu_setup() function.
Adds CONFIG_OF_BOARD_SETUP to the defconfig files for dra72_evm, dra74_evm, and am57xx_evm.
V3: None
V2: Squash commits 14 and 15 from v1 to this one commit Move CONFIG_OF_BOARD_SETUP to defconfig files, instead of header files
board/ti/am57xx/board.c | 9 +++++++++ board/ti/dra7xx/evm.c | 9 +++++++++ configs/am57xx_evm_defconfig | 1 + configs/dra72_evm_defconfig | 1 + configs/dra74_evm_defconfig | 1 + 5 files changed, 21 insertions(+)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 86b8f6e..9904047 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -686,3 +686,12 @@ int board_early_init_f(void) return 0; } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + + return 0; +} +#endif diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 9bd71d8..d01c785 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -718,3 +718,12 @@ int board_early_init_f(void) return 0; } #endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + + return 0; +} +#endif diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 8fc3ebb..cccdc10 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set diff --git a/configs/dra72_evm_defconfig b/configs/dra72_evm_defconfig index 00c6ac3..c85c0fb 100644 --- a/configs/dra72_evm_defconfig +++ b/configs/dra72_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set diff --git a/configs/dra74_evm_defconfig b/configs/dra74_evm_defconfig index a11dcd5..fc121a1 100644 --- a/configs/dra74_evm_defconfig +++ b/configs/dra74_evm_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set
Adds new defconfig files for DRA7xx and AM57xx secure devices. These are the same as the non-secure parts, but with the addition of the CONFIG_TI_SECURE_DEVICE option set to 'y'.
V3: None
V2: Rebase from current master, create HS copies of defconfigs
configs/am57xx_hs_evm_defconfig | 36 +++++++++++++++++++++++++++ configs/dra72_hs_evm_defconfig | 55 +++++++++++++++++++++++++++++++++++++++++ configs/dra74_hs_evm_defconfig | 54 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 145 insertions(+) create mode 100644 configs/am57xx_hs_evm_defconfig create mode 100644 configs/dra72_hs_evm_defconfig create mode 100644 configs/dra74_hs_evm_defconfig
diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig new file mode 100644 index 0000000..60525cd --- /dev/null +++ b/configs/am57xx_hs_evm_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_OMAP54XX=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TARGET_BEAGLE_X15=y +CONFIG_DM_SERIAL=y +CONFIG_DM_GPIO=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_MMC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SYS_NS16550=y diff --git a/configs/dra72_hs_evm_defconfig b/configs/dra72_hs_evm_defconfig new file mode 100644 index 0000000..01f985e --- /dev/null +++ b/configs/dra72_hs_evm_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_OMAP54XX=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_DRA7XX_EVM=y +CONFIG_DM_SERIAL=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_GPIO=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_DEFAULT_DEVICE_TREE="dra72-evm" +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_MMC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0451 +CONFIG_G_DNL_PRODUCT_NUM=0xd022 diff --git a/configs/dra74_hs_evm_defconfig b/configs/dra74_hs_evm_defconfig new file mode 100644 index 0000000..1b30ad4 --- /dev/null +++ b/configs/dra74_hs_evm_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_OMAP54XX=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TARGET_DRA7XX_EVM=y +CONFIG_DM_SERIAL=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_GPIO=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_MMC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0451 +CONFIG_G_DNL_PRODUCT_NUM=0xd022
Daniel Allred
