[PATCH v2] arm: imx6: configure NoC on i.MX6DQP
The i.MX6DP and i.MX6QP incorporate NoC interconnect logic which needs to be configured in order to use external DDR memory.
This patch enables the SPL to configure the necessary registers in accordance with the NXP engineering bulletin EB828.
Signed-off-by: Bernhard Messerklinger bernhard.messerklinger@br-automation.com --- This patch is a revised version of the patch "arm: imx6: configure NoC on i.MX6DQP" from the original author Filip Brozovic fbrozovic@gmail.com. It takes care of the review notes for the original patch. patchwork: https://patchwork.ozlabs.org/patch/670208/ mail-archive: https://lists.denx.de/pipermail/u-boot/2016-September/266667.html
I'm not sure how to handle a patch which is based on a patch from another author. Guidance from the maintainers regarding this question would be welcome. My assumption would be that this can be solved by adding "Co-Developed-by:" and "Signed-off-by:" lines to this patch for Filip Brozovic (see [1] for a discussion of this topic on LKML). Filip, would this be ok for you?
[1] http://lkml.iu.edu/hypermail/linux/kernel/1711.2/00256.html
Changes in v2: - Added missing link to lkml discussion
arch/arm/include/asm/arch-mx6/mx6-ddr.h | 19 +++++ arch/arm/mach-imx/mx6/ddr.c | 96 +++++++++++++++++++++++++ 2 files changed, 115 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index 19d2f1d9c5..25168c9865 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -307,6 +307,25 @@ struct mx6dq_iomux_grp_regs { u32 grp_b6ds; };
+/* + * NoC scheduler registers - only on IMX6DQP + */ +#define MX6DQP_NOC_SCHED_BASE 0x00bb0000 +struct mx6dqp_noc_sched_regs { + u32 coreid; + u32 revid; + u32 ddrconf; + u32 ddrtiming; + u32 ddrmode; + u32 rlat; + u32 res1[4]; + u32 ipu1; + u32 ipu2; + u32 res2[2]; + u32 activate; + u32 res3[16]; +}; + #define MX6SDL_IOM_DDR_BASE 0x020e0400 struct mx6sdl_iomux_ddr_regs { u32 res1[25]; diff --git a/arch/arm/mach-imx/mx6/ddr.c b/arch/arm/mach-imx/mx6/ddr.c index 6e5e40dd1a..3521d8eac7 100644 --- a/arch/arm/mach-imx/mx6/ddr.c +++ b/arch/arm/mach-imx/mx6/ddr.c @@ -936,6 +936,27 @@ void mx6sdl_dram_iocfg(unsigned width, mmdc1->entry = value; \ } while (0)
+/* see BOOT_CFG3 description Table 5-4. EIM Boot Fusemap */ +#define BOOT_CFG3_DDR_MASK 0x30 +#define BOOT_CFG3_EXT_DDR_MASK 0x33 + +#define DDR_MMAP_NOC_SINGLE 0 +#define DDR_MMAP_NOC_DUAL 0x31 + +/* NoC ACTIVATE shifts */ +#define NOC_RD_SHIFT 0 +#define NOC_FAW_PERIOD_SHIFT 4 +#define NOC_FAW_BANKS_SHIFT 10 + +/* NoC DdrTiming shifts */ +#define NOC_ACT_TO_ACT_SHIFT 0 +#define NOC_RD_TO_MISS_SHIFT 6 +#define NOC_WR_TO_MISS_SHIFT 12 +#define NOC_BURST_LEN_SHIFT 18 +#define NOC_RD_TO_WR_SHIFT 21 +#define NOC_WR_TO_RD_SHIFT 26 +#define NOC_BW_RATIO_SHIFT 31 + /* * According JESD209-2B-LPDDR2: Table 103 * WL: write latency @@ -1225,6 +1246,8 @@ void mx6_ddr3_cfg(const struct mx6_ddr_sysinfo *sysinfo, { volatile struct mmdc_p_regs *mmdc0; volatile struct mmdc_p_regs *mmdc1; + struct src *src_regs = (struct src *)SRC_BASE_ADDR; + u8 soc_boot_cfg3 = (readl(&src_regs->sbmr1) >> 16) & 0xff; u32 val; u8 tcke, tcksrx, tcksre, txpdll, taofpd, taonpd, trrd; u8 todtlon, taxpd, tanpd, tcwl, txp, tfaw, tcl; @@ -1517,6 +1540,79 @@ void mx6_ddr3_cfg(const struct mx6_ddr_sysinfo *sysinfo, /* Step 12: Configure and activate periodic refresh */ mmdc0->mdref = (sysinfo->refsel << 14) | (sysinfo->refr << 11);
+ /* + * Step 13: i.MX6DQP only: If the NoC scheduler is enabled, + * configure it and disable MMDC arbitration/reordering (see EB828) + */ + if (is_mx6dqp() && + ((soc_boot_cfg3 & BOOT_CFG3_DDR_MASK) == DDR_MMAP_NOC_SINGLE || + (soc_boot_cfg3 & BOOT_CFG3_EXT_DDR_MASK) == DDR_MMAP_NOC_DUAL)) { + struct mx6dqp_noc_sched_regs *noc_sched = + (struct mx6dqp_noc_sched_regs *)MX6DQP_NOC_SCHED_BASE; + + /* + * These values are fixed based on integration parameters and + * should not be modified + */ + noc_sched->rlat = 0x00000040; + noc_sched->ipu1 = 0x00000020; + noc_sched->ipu2 = 0x00000020; + + noc_sched->activate = (1 << NOC_FAW_BANKS_SHIFT) | + (tfaw << NOC_FAW_PERIOD_SHIFT) | + (trrd << NOC_RD_SHIFT); + noc_sched->ddrtiming = (((sysinfo->dsize == 1) ? 1 : 0) + << NOC_BW_RATIO_SHIFT) | + ((tcwl + twtr) << NOC_WR_TO_RD_SHIFT) | + ((tcl - tcwl + 2) << NOC_RD_TO_WR_SHIFT) | + (4 << NOC_BURST_LEN_SHIFT) | /* BL8 */ + ((tcwl + twr + trp + trcd) + << NOC_WR_TO_MISS_SHIFT) | + ((trtp + trp + trcd - 4) + << NOC_RD_TO_MISS_SHIFT) | + (trc << NOC_ACT_TO_ACT_SHIFT); + + if (sysinfo->dsize == 2) { + if (ddr3_cfg->coladdr == 10) { + if (ddr3_cfg->rowaddr == 15 && + sysinfo->ncs == 2) + noc_sched->ddrconf = 4; + else + noc_sched->ddrconf = 0; + } else if (ddr3_cfg->coladdr == 11) { + noc_sched->ddrconf = 1; + } + } else { + if (ddr3_cfg->coladdr == 9) { + if (ddr3_cfg->rowaddr == 13) + noc_sched->ddrconf = 2; + else if (ddr3_cfg->rowaddr == 14) + noc_sched->ddrconf = 15; + } else if (ddr3_cfg->coladdr == 10) { + if (ddr3_cfg->rowaddr == 14 && + sysinfo->ncs == 2) + noc_sched->ddrconf = 14; + else if (ddr3_cfg->rowaddr == 15 && + sysinfo->ncs == 2) + noc_sched->ddrconf = 9; + else + noc_sched->ddrconf = 3; + } else if (ddr3_cfg->coladdr == 11) { + if (ddr3_cfg->rowaddr == 15 && + sysinfo->ncs == 2) + noc_sched->ddrconf = 4; + else + noc_sched->ddrconf = 0; + } else if (ddr3_cfg->coladdr == 12) { + if (ddr3_cfg->rowaddr == 14) + noc_sched->ddrconf = 1; + } + } + + /* Disable MMDC arbitration/reordering */ + mmdc0->maarcr = 0x14420000; + } + /* Step 13: Deassert config request - init complete */ mmdc0->mdscr = 0x00000000;
On Mon, Feb 24, 2020 at 10:38 AM Bernhard Messerklinger bernhard.messerklinger@br-automation.com wrote:
That's fine by me.
Best regards, Filip Brozovic
Filip Brozović
