rockchip RK3399 emmc booting
I'm trying to run mainline on a custom rk3399 board which boots from eMMC only. Currently I'm using Rockchip SDK which can build an image for the whole system) and then flash it to emmc using (AFAIU using dfu in u-boot). Does anyone have experience with mainline running on rk3399 and have the same functionality? Or is there another way to flash images to eMMC?
Thanks and BR,
marek
1. Does the board has an SD card, then it would boot from SD as well, if so program the Mainline U-Boot into SD card and power on with Recovery button press. eventually, it would skip eMMC and start booting from SD.
2. We have USB Gadget support in Mainline, so you can either use fastboot, ums. refer doc/board/rockchip/rockchip.rst with eMMC. If the existing system is able to stop at U-Boot then use ums since ums available in rockchip SDK If I remember correctly.
3. This procedure similar to Linux as well, you have to configure mass storage gadget via command line lun or configfs so-that the eMMC would mount on host.
Jagan.
Belisko Marek
Jagan Teki
