[U-Boot] [PATCH 0/1] mmc: S5P: Support DMA restarts at buffer boundaries
I don't actually have an S5P machine to test this patch with. I wrote this code while fixing an issue with the in progress Tegra MMC device driver that is based on the S5P driver. I have tested this patch on that platform. If someone with an S5P could give this a whirl that would be great.
Cc: Minkyu Kang mk7.kang@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net
Anton Staaf (1): mmc: S5P: Support DMA restarts at buffer boundaries
drivers/mmc/s5p_mmc.c | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-)
Currently if a DMA buffer straddles a buffer alignment boundary (512KiB) then the DMA engine will pause and generate a DMA interrupt. Since the DMA interrupt is not enabled it will hang the MMC driver.
This patch adds support for restarting the DMA transfer. The SYSTEM_ADDRESS register contains the next address that would have been read/written when a boundary is hit. So we can read that and write it back. The write triggers the resumption of the transfer.
Signed-off-by: Anton Staaf robotboy@chromium.org Cc: Minkyu Kang mk7.kang@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net --- drivers/mmc/s5p_mmc.c | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/s5p_mmc.c b/drivers/mmc/s5p_mmc.c index 280738f..62a7abf 100644 --- a/drivers/mmc/s5p_mmc.c +++ b/drivers/mmc/s5p_mmc.c @@ -232,9 +232,15 @@ static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, __func__, mask); return -1; } else if (mask & (1 << 3)) { - /* DMA Interrupt */ + /* + * DMA Interrupt, restart the transfer where + * it was interrupted. + */ + unsigned int address = readl(&host->reg->sysad); + debug("DMA end\n"); - break; + writel((1 << 3), &host->reg->norintsts); + writel(address, &host->reg->sysad); } else if (mask & (1 << 1)) { /* Transfer Complete */ debug("r/w is done\n"); @@ -425,12 +431,13 @@ static int mmc_core_init(struct mmc *mmc) * NORMAL Interrupt Status Enable Register init * [5] ENSTABUFRDRDY : Buffer Read Ready Status Enable * [4] ENSTABUFWTRDY : Buffer write Ready Status Enable + * [3] ENSTADMAINT : DMA Interrupt Status Enable * [1] ENSTASTANSCMPLT : Transfre Complete Status Enable * [0] ENSTACMDCMPLT : Command Complete Status Enable - */ + */ mask = readl(&host->reg->norintstsen); mask &= ~(0xffff); - mask |= (1 << 5) | (1 << 4) | (1 << 1) | (1 << 0); + mask |= (1 << 5) | (1 << 4) | (1 << 3) | (1 << 1) | (1 << 0); writel(mask, &host->reg->norintstsen);
Tested-by : Jaehoon Chung jh80.chung@samsung.com
Dear Anton Staaf,
applied to u-boot-samsung
Thanks Minkyu Kang
Anton Staaf
Jaehoon Chung
Minkyu Kang
