[PATCH] dm: Fix OF_BAD_ADDR definition
When OF_LIVE flag is enabled on a 64 bits platform, there is an issue when dev_read_addr() is called and need to perform an address translation using __of_translate_address().
In case of error, __of_translate_address() return value is OF_BAD_ADDR (wich is defined in include/dm/of.h to ((u64)-1) = 0xffffffffffffffff). The return value of dev_read_addr() is often compared to FDT_ADDR_T_NONE which is defined as (-1U) = 0xffffffff. In this case the comparison is always false.
To fix this issue, define OF_BAD_ADDR to FDT_ADDR_T_NONE.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
include/dm/of.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/dm/of.h b/include/dm/of.h index 5cb6f44a6c..0208cc234a 100644 --- a/include/dm/of.h +++ b/include/dm/of.h @@ -95,7 +95,7 @@ static inline bool of_live_active(void) return gd_of_root() != NULL; }
-#define OF_BAD_ADDR ((u64)-1) +#define OF_BAD_ADDR FDT_ADDR_T_NONE
static inline const char *of_node_full_name(const struct device_node *np) {
Hi Patrice,
On Thu, 23 Dec 2021 at 09:09, Patrice Chotard patrice.chotard@foss.st.com wrote:
Would it be better to define FDT_ADDR_T_NONE as something like ((ulong)(-1)) ?
static inline const char *of_node_full_name(const struct device_node *np) { -- 2.17.1
Hi Simon
On 12/24/21 2:17 PM, Simon Glass wrote:
Hi Patrice,
Agree, a v2 will be sent soon.
Thanks Patrice
Patrice CHOTARD
Patrice Chotard
