Re: [U-Boot] [PATCH 7/8] mips: bmips: fix ioremap for BCM6358
Am 13.04.2017 um 17:52 schrieb Álvaro Fernández Rojas:
BCM6358 has its internal registers mapped to 0xfffe0000, which is changed to 0x1ffe0000 when ioremap is called.
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com
arch/mips/include/asm/mach-generic/ioremap.h | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/arch/mips/include/asm/mach-generic/ioremap.h b/arch/mips/include/asm/mach-generic/ioremap.h index 6b191d5..b6a920d 100644 --- a/arch/mips/include/asm/mach-generic/ioremap.h +++ b/arch/mips/include/asm/mach-generic/ioremap.h @@ -16,15 +16,28 @@ static inline phys_addr_t fixup_bigphys_addr(phys_addr_t phys_addr, return phys_addr; }
+static inline int is_mips_internal_registers(phys_addr_t offset) +{ +#ifdef CONFIG_SOC_BMIPS_BCM6358
- if (offset >= 0xfffe0000)
return 1;
static inline void __iomem *plat_ioremap(phys_addr_t offset, unsigned long size, unsigned long flags) {
- if (is_mips_internal_registers(offset))
return (void __iomem *)offset;
- return NULL;
static inline int plat_iounmap(const volatile void __iomem *addr) {
- return is_mips_internal_registers((unsigned long)addr);
#define _page_cachable_default _CACHE_CACHABLE_NONCOHERENT
please create a separate ioremap.h in arch/mips/include/asm/mach-bmips/ with the BMIPS specific code. Then this file will be automatically used instead of the generic version. This is working like in Linux kernel.
Hi Daniel,
return 1;
- return NULL;
I will try, but I remember having tested that and I couldn't get it working...
Hi again,
El 15/04/2017 a las 19:18, Álvaro Fernández Rojas escribió:
Hi Daniel,
return 1;
- return NULL;
Nope, it doesn't work...
Am 15.04.2017 um 20:08 schrieb Álvaro Fernández Rojas:
Hi again,
Hi Daniel,
return 1;
- return NULL;
sorry, my fault. The correct path is arch/mips/mach-bmips/include/ioremap.h
Following commit on top of your series works for me: http://git.denx.de/?p=u-boot/u-boot-mips.git;a=commitdiff;h=5f98514bc09d4748...
Hi again,
Hi Daniel,
return 1;
- return NULL;
Great, it's working now :)
Daniel Schwierzeck
