[U-Boot] problem with read only nanad
Hi, I'm working on a system having 2 NAND chips, the first one has the U-Boot and a basic firmware, and is read only, and the second has a new firmware. when the second chip is empty, the system should boot from the first chip. but it gives me many errors, probably related to the fact that it's readonly, does the u-boot tries to write something to the nand during startup? how can i solve this issue?
thanks in advance Alex
Depending on what the NAND controller driver requests, it could be trying to create an on-chip bad block table. If your flash is read only, then do not set NAND_USE_FLASH_BBT in the options -- or if you want to use an existing BBT but not create one if absent, provide a BBT description that lacks the NAND_BBT_CREATE option.
If that's not it, then tell us which controller it is, and what sort of errors you're getting.
-Scott
alex889
Scott Wood
