[U-Boot] [PATCH 1/1] efi_loader: efi_add_runtime_mmio()
The first parameter of efi_add_runtime_mmio() is a pointer to a pointer. This should be reflected in the documentation.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 only change a comment --- lib/efi_loader/efi_runtime.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index a9e94f78c30..1ce39f0156a 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -518,7 +518,8 @@ static efi_status_t EFIAPI efi_set_virtual_address_map( * This function adds a memory-mapped IO region to the memory map to make it * available at runtime. * - * @mmio_ptr: address of the memory-mapped IO region + * @mmio_ptr: pointer to a pointer to the start of the memory-mapped + * IO region * @len: size of the memory-mapped IO region * Returns: status code */
