[PATCH] ARM: zynq: Fix invalid check on NAND_CMD_NONE.
From: Patrick van Gelder patrick.vangelder@nl.bosch.com
The end_cmd field in the variables cmd_phase_addr and data_phase_addr contains the value 0xFF when the end_cmd equals NAND_CMD_NONE. This should be 0x00.
This is caused by comparing NAND_CMD_NONE (int) with end_cmd (u8). end_cmd will be promoted by the int value -1 and therefore is not equal to 0xFF. Solved by casting NAND_CMD_NONE to u8 which will avoid int promotion.
Signed-off-by: Patrick van Gelder patrick.vangelder@nl.bosch.com Reviewed-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/mtd/nand/raw/zynq_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 0aea83dac0e6..394129741831 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -845,7 +845,7 @@ static void zynq_nand_cmd_function(struct mtd_info *mtd, unsigned int command, if (curr_cmd->end_cmd_valid == ZYNQ_NAND_CMD_PHASE) end_cmd_valid = 1;
- if (curr_cmd->end_cmd == NAND_CMD_NONE) + if (curr_cmd->end_cmd == (u8)NAND_CMD_NONE) end_cmd = 0x0; else end_cmd = curr_cmd->end_cmd;
pá 24. 4. 2020 v 12:25 odesílatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.26.2
Applied. M
Michal Simek
Michal Simek
