[U-Boot] [PATCH v3 0/9] Add pinmux command
For debug purpose, it's useful to know the pins muxing to check if a pin is configured as a GPIO or as an alternate function and to get information about this alternate function configuration. For this purpose a new command pinmux is implemented.
This series adds: - Add get_pin_muxing ops to UCLASS pinctrl - Add pinmux command - Add get_function() support to stm32 gpio driver - Add get_pins_count() support to stm32 pinctrl driver - Add get_pin_name() support to stm32 pinctrl driver - Add get_pin_muxing() support to stm32 pinctrl driver
Changes in v3: - Replace const char **buf parameter by char *buf, int size parameters for pinctrl_get_pin_muxing() - Replace const char **buf parameter by char *buf, int size parameters for pinctrl_get_pin_name() - Update calls to pinctrl_get_pin_name() and pinctrl_get_pin_muxing due to prototype update. - Fix typo
Changes in v2: - Replace pinmux_show ops which displayed the complete pin-controller muxing by get_pin_muxing ops which displays the muxing of one pin - In order to make pin muxing display less SoC specific, use pinctrl_pins_count(), pinctrl_get_pin_name() and pinctrl_get_pin_muxing() methods instead of previous pinctrl_pinmux_show() method.
Patrice Chotard (9): dm: pinctrl: Add get_pin_muxing() ops dm: pinctrl: Add pinctrl_get_pin_name and pinctrl_get_pins_count dm: uclass: Add uclass_foreach_dev_probe cmd: pinmux: Add pinmux command pinctrl: stm32: Add get_pins_count() ops pinctrl: stm32: Add get_pin_name() ops pinctrl: stm32: Add get_pin_muxing() ops gpio: stm32f7: Add ops get_function pinctrl: sandbox: Add get_pin_muxing ops support
cmd/Kconfig | 8 ++ cmd/Makefile | 1 + cmd/pinmux.c | 144 +++++++++++++++++++++++++ drivers/gpio/stm32f7_gpio.c | 20 ++++ drivers/pinctrl/pinctrl-sandbox.c | 15 +++ drivers/pinctrl/pinctrl-uclass.c | 36 +++++++ drivers/pinctrl/pinctrl_stm32.c | 218 +++++++++++++++++++++++++++++++++++++- include/dm/pinctrl.h | 55 ++++++++++ include/dm/uclass.h | 16 +++ 9 files changed, 508 insertions(+), 5 deletions(-) create mode 100644 cmd/pinmux.c
Add get_pin_muxing() which allows to display the muxing of a given pin belonging to a pin-controller.
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/pinctrl/pinctrl-uclass.c | 13 +++++++++++++ include/dm/pinctrl.h | 32 ++++++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index c38bb212ed74..cd2ca4e4950e 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -249,6 +249,19 @@ int pinctrl_get_gpio_mux(struct udevice *dev, int banknum, int index) return ops->get_gpio_mux(dev, banknum, index); }
+int pinctrl_get_pin_muxing(struct udevice *dev, int selector, char *buf, + int size) +{ + struct pinctrl_ops *ops = pinctrl_get_ops(dev); + + if (!ops->get_pin_muxing) + return -ENOSYS; + + snprintf(buf, size, ops->get_pin_muxing(dev, selector)); + + return 0; +} + /** * pinconfig_post_bind() - post binding for PINCTRL uclass * Recursively bind child nodes as pinconfig devices in case of full pinctrl. diff --git a/include/dm/pinctrl.h b/include/dm/pinctrl.h index 80de3f3fed2b..4cfaddcaebbf 100644 --- a/include/dm/pinctrl.h +++ b/include/dm/pinctrl.h @@ -66,6 +66,7 @@ struct pinconf_param { * pointing a config node. (necessary for pinctrl_full) * @set_state_simple: do needed pinctrl operations for a peripherl @periph. * (necessary for pinctrl_simple) + * @get_pin_muxing: display the muxing of a given pin. */ struct pinctrl_ops { int (*get_pins_count)(struct udevice *dev); @@ -129,6 +130,22 @@ struct pinctrl_ops { * @return mux value (SoC-specific, e.g. 0 for input, 1 for output) */ int (*get_gpio_mux)(struct udevice *dev, int banknum, int index); + + /** + * get_pin_muxing() - show pin muxing + * + * This allows to display the muxing of a given pin. It's useful for + * debug purpose to know if a pin is configured as GPIO or as an + * alternate function and which one. + * Typically it is used by a PINCTRL driver with knowledge of the SoC + * pinctrl setup. + * + * @dev: Pinctrl device to use + * @selector: Pin selector + * @return a string wich contains the muxing description + */ + const char *(*get_pin_muxing)(struct udevice *dev, + unsigned int selector); };
#define pinctrl_get_ops(dev) ((struct pinctrl_ops *)(dev)->driver->ops) @@ -348,4 +365,19 @@ int pinctrl_decode_pin_config(const void *blob, int node); */ int pinctrl_get_gpio_mux(struct udevice *dev, int banknum, int index);
+/** + * pinctrl_get_pin_muxing() - Returns the muxing description + * + * This allows to display the muxing description of the given pin for + * debug purpose + * + * @dev: Pinctrl device to use + * @selector Pin index within pin-controller + * @buf Pin's muxing description + * @size Pin's muxing description length + * @return 0 if OK, -ve on error + */ +int pinctrl_get_pin_muxing(struct udevice *dev, int selector, char *buf, + int size); + #endif /* __PINCTRL_H */
Hi Patrice,
Changes in v3:
Changes in v2:
But please see below.
int size)
return -ENOSYS;
I wonder if it would be easy to return -ENOSPC if the string is too long?
Hi Simon
On 10/19/18 5:28 AM, Simon Glass wrote:
Hi Patrice,
Changes in v3:
Changes in v2:
int size)
return -ENOSYS;
Not so easy, for example in pinctrl_stm32.c, depending of the pin's muxing mode, i not only copy but also, in some case, concatenate additional information. It would complexify the pinctrl code.
Patrice
Hi Patrice,
On 23 October 2018 at 00:41, Patrice CHOTARD patrice.chotard@st.com wrote:
Hi Simon
Hi Patrice,
Changes in v3:
Changes in v2:
int size)
return -ENOSYS;
OK. Well snprintf() should return a useful value, but I'm not sure if it tells you when the buffer is exhausted.
Add pinctrl_get_pin_name() and pinctrl_get_pins_count() methods to obtain pin's name and pin's muxing given a pin reference.
This will be used by the new pinmux command.
Changes in v3: - Replace const char **buf parameter by char *buf, int size parameters for pinctrl_get_pin_name()
Changes in v2: None
drivers/pinctrl/pinctrl-uclass.c | 23 +++++++++++++++++++++++ include/dm/pinctrl.h | 23 +++++++++++++++++++++++ 2 files changed, 46 insertions(+)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index cd2ca4e4950e..bbaf830d65b9 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -249,6 +249,29 @@ int pinctrl_get_gpio_mux(struct udevice *dev, int banknum, int index) return ops->get_gpio_mux(dev, banknum, index); }
+int pinctrl_get_pins_count(struct udevice *dev) +{ + struct pinctrl_ops *ops = pinctrl_get_ops(dev); + + if (!ops->get_pins_count) + return -ENOSYS; + + return ops->get_pins_count(dev); +} + +int pinctrl_get_pin_name(struct udevice *dev, int selector, char *buf, + int size) +{ + struct pinctrl_ops *ops = pinctrl_get_ops(dev); + + if (!ops->get_pin_name) + return -ENOSYS; + + snprintf(buf, size, ops->get_pin_name(dev, selector)); + + return 0; +} + int pinctrl_get_pin_muxing(struct udevice *dev, int selector, char *buf, int size) { diff --git a/include/dm/pinctrl.h b/include/dm/pinctrl.h index 4cfaddcaebbf..0b73f28eae97 100644 --- a/include/dm/pinctrl.h +++ b/include/dm/pinctrl.h @@ -380,4 +380,27 @@ int pinctrl_get_gpio_mux(struct udevice *dev, int banknum, int index); int pinctrl_get_pin_muxing(struct udevice *dev, int selector, char *buf, int size);
+/** + * pinctrl_get_pins_count() - display pin-controller pins number + * + * This allows to know the number of pins owned by a given pin-controller + * + * @dev: Pinctrl device to use + * @return pins number if OK, -ve on error + */ +int pinctrl_get_pins_count(struct udevice *dev); + +/** + * pinctrl_get_pin_name() - Returns the pin's name + * + * This allows to display the pin's name for debug purpose + * + * @dev: Pinctrl device to use + * @selector Pin index within pin-controller + * @buf Pin's name + * @return 0 if OK, -ve on error + */ +int pinctrl_get_pin_name(struct udevice *dev, int selector, char *buf, + int size); + #endif /* __PINCTRL_H */
Changes in v3:
Changes in v2: None
Add uclass_foreach_dev_probe() which iterates through devices of a given uclass. Devices are probed if necessary and are ready to use.
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org ---
include/dm/uclass.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/include/dm/uclass.h b/include/dm/uclass.h index 6e7c1cd3e8bc..10ccfdce951e 100644 --- a/include/dm/uclass.h +++ b/include/dm/uclass.h @@ -376,4 +376,20 @@ int uclass_resolve_seq(struct udevice *dev); #define uclass_foreach_dev_safe(pos, next, uc) \ list_for_each_entry_safe(pos, next, &uc->dev_head, uclass_node)
+/** + * uclass_foreach_dev_probe() - Helper function to iteration through devices + * of given uclass + * + * This creates a for() loop which works through the available devices in + * a uclass in order from start to end. Devices are probed if necessary, + * and ready for use. + * + * @id: Uclass ID + * @dev: struct udevice * to hold the current device. Set to NULL when there + * are no more devices. + */ +#define uclass_foreach_dev_probe(id, dev) \ + for (uclass_first_device(id, &dev); dev; \ + uclass_next_device(&dev)) + #endif
Hi Patrice,
- uclass_foreach_dev_probe() - Helper function to iteration through devices
- of given uclass
- This creates a for() loop which works through the available devices in
- a uclass in order from start to end. Devices are probed if necessary,
- and ready for use.
- @id: Uclass ID
- @dev: struct udevice * to hold the current device. Set to NULL when there
- are no more devices.
Shouldn't we check the return value of uclass_first_device() and uclass_next_device()?
#endif
Regards, Bin
Hi Bin
On 10/11/2018 11:06 AM, Bin Meng wrote:
Hi Patrice,
- of given uclass
- @id: Uclass ID
It's not necessary to check the return value of uclass_first_device(id, &dev) because in any error case, dev is NULL, which is the loop output condition. This is only for the first iteration.
For the other iteration, dev comes from uclass_next_device(&dev), similarly to uclass_first_device(), in any error case dev is NULL.
Thanks
Patrice
#endif
Regards, Bin
Hi Patrice,
On Fri, Oct 12, 2018 at 3:51 PM Patrice CHOTARD patrice.chotard@st.com wrote:
Hi Bin
Hi Patrice,
- of given uclass
- @id: Uclass ID
Please see the comment of uclass_first_device().
* @devp: Returns pointer to the first device in that uclass if no error * occurred, or NULL if there is no first device, or an error occurred with * that device. * @return 0 if OK (found or not found), other -ve on error
So it can return error with a valid dev.
Similar please see the comment of uclass_next_device().
Regards, Bin
Hi Bin
On 10/12/2018 12:13 PM, Bin Meng wrote:
Hi Patrice,
Hi Bin
Hi Patrice,
- of given uclass
- @id: Uclass ID
- @devp: Returns pointer to the first device in that uclass if no error
- occurred, or NULL if there is no first device, or an error occurred with
- that device.
- @return 0 if OK (found or not found), other -ve on error
I checked the uclass_first_device() implementation and the comment seems not aligned with what is coded. When uclass_first_device() returns a valid dev, return value is always 0. (see uclass_get_device_tail() return value).
In any case uclass_first_device() returns a valid dev with an error.
Simon, Bin do you confirm ?
I have the same remark regarding uclass_next_device().
Thanks
Patrice
Regards, Bin
Hi Patrick,
On 15 October 2018 at 03:01, Patrice CHOTARD patrice.chotard@st.com wrote:
Hi Bin
Hi Patrice,
Hi Bin
Hi Patrice,
- of given uclass
- @id: Uclass ID
- that device.
I actually don't like this function. Let's use uclass_first_device_err() when we care about errors. I am wondering if we should delete uclass_first_device().
I don't see how, no.
Hi Simon
On 10/19/18 5:27 AM, Simon Glass wrote:
Hi Patrick,
Hi Bin
Hi Patrice,
Hi Bin
Hi Patrice,
- of given uclass
- @id: Uclass ID
- that device.
Ok i will use uclass_first_device_err() instead
I will add a new uclass_next_device_err()
Thanks
Patrice
pinmux command allows to : - list all pin-controllers available on platforms - select a pin-controller - display the muxing of all pins of the current pin-controller or all pin-controllers depending of given options
Changes in v3: - Update calls to pinctrl_get_pin_name() and pinctrl_get_pin_muxing due to prototype update.
Changes in v2: - In order to make pin muxing display less SoC specific, use pinctrl_pins_count(), pinctrl_get_pin_name() and pinctrl_get_pin_muxing() methods instead of previous pinctrl_pinmux_show() method.
cmd/Kconfig | 8 ++++ cmd/Makefile | 1 + cmd/pinmux.c | 144 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 153 insertions(+) create mode 100644 cmd/pinmux.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 7ed3c9c3b30b..f041e57a7ff3 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -953,6 +953,14 @@ config CMD_PCMCIA about 1990. These devices are typically removable memory or network cards using a standard 68-pin connector.
+config CMD_PINMUX + bool "pinmux - show pins muxing" + default y if PINCTRL + help + Parse all available pin-controllers and show pins muxing. This + is useful for debug purpoer to check the pin muxing and to know if + a pin is configured as a GPIO or as an alternate function. + config CMD_POWEROFF bool "poweroff" help diff --git a/cmd/Makefile b/cmd/Makefile index d9cdaf6064b8..4e562ae32c5b 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -104,6 +104,7 @@ ifdef CONFIG_PCI obj-$(CONFIG_CMD_PCI) += pci.o endif obj-y += pcmcia.o +obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PXE) += pxe.o obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_CMD_QFW) += qfw.o diff --git a/cmd/pinmux.c b/cmd/pinmux.c new file mode 100644 index 000000000000..55d5230a1657 --- /dev/null +++ b/cmd/pinmux.c @@ -0,0 +1,144 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <errno.h> +#include <dm/pinctrl.h> +#include <dm/uclass-internal.h> + +#define LIMIT_DEVNAME 30 +#define LIMIT_PINNAME 10 +#define LIMIT_PINMUX 40 + +static struct udevice *currdev; + +static int do_dev(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + const char *name; + int ret; + + switch (argc) { + case 2: + name = argv[1]; + ret = uclass_get_device_by_name(UCLASS_PINCTRL, name, &currdev); + if (ret) { + printf("Can't get the pin-controller: %s!\n", name); + return CMD_RET_FAILURE; + } + case 1: + if (!currdev) { + printf("Pin-controller device is not set!\n"); + return CMD_RET_USAGE; + } + + printf("dev: %s\n", currdev->name); + } + + return CMD_RET_SUCCESS; +} + +static int show_pinmux(struct udevice *dev) +{ + char pin_name[LIMIT_PINNAME]; + char pin_mux[LIMIT_PINMUX]; + int pins_count; + int i; + int ret; + + pins_count = pinctrl_get_pins_count(dev); + + if (pins_count == -ENOSYS) { + printf("Ops get_pins_count not supported\n"); + return pins_count; + } + + for (i = 0; i < pins_count; i++) { + ret = pinctrl_get_pin_name(dev, i, pin_name, LIMIT_PINNAME); + if (ret == -ENOSYS) { + printf("Ops get_pin_name not supported\n"); + return ret; + } + + ret = pinctrl_get_pin_muxing(dev, i, pin_mux, LIMIT_PINMUX); + if (ret == -ENOSYS) { + printf("Ops get_pin_muxing not supported\n"); + return ret; + } + + printf("%-*s: %-*s\n", LIMIT_PINNAME, pin_name, + LIMIT_PINMUX, pin_mux); + } + + return 0; +} + +static int do_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct udevice *dev; + int ret = 0; + + if (currdev && (argc < 2 || strcmp(argv[1], "-a"))) + return show_pinmux(currdev); + + uclass_foreach_dev_probe(UCLASS_PINCTRL, dev) { + /* insert a separator between each pin-controller display */ + printf("--------------------------\n"); + printf("%s:\n", dev->name); + ret = show_pinmux(dev); + if (ret) + printf("Can't display pin muxing for %s\n", dev->name); + } + + return ret; +} + +static int do_list(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct udevice *dev; + + printf("| %-*.*s| %-*.*s| %s\n", + LIMIT_DEVNAME, LIMIT_DEVNAME, "Device", + LIMIT_DEVNAME, LIMIT_DEVNAME, "Driver", + "Parent"); + + uclass_foreach_dev_probe(UCLASS_PINCTRL, dev) { + printf("| %-*.*s| %-*.*s| %s\n", + LIMIT_DEVNAME, LIMIT_DEVNAME, dev->name, + LIMIT_DEVNAME, LIMIT_DEVNAME, dev->driver->name, + dev->parent->name); + } + + return CMD_RET_SUCCESS; +} + +static cmd_tbl_t pinmux_subcmd[] = { + U_BOOT_CMD_MKENT(dev, 2, 1, do_dev, "", ""), + U_BOOT_CMD_MKENT(list, 1, 1, do_list, "", ""), + U_BOOT_CMD_MKENT(status, 2, 1, do_status, "", ""), +}; + +static int do_pinmux(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + cmd_tbl_t *cmd; + + argc--; + argv++; + + cmd = find_cmd_tbl(argv[0], pinmux_subcmd, ARRAY_SIZE(pinmux_subcmd)); + if (!cmd || argc > cmd->maxargs) + return CMD_RET_USAGE; + + return cmd->cmd(cmdtp, flag, argc, argv); +} + +U_BOOT_CMD(pinmux, CONFIG_SYS_MAXARGS, 1, do_pinmux, + "show pin-controller muxing", + "list - list UCLASS_PINCTRL devices\n" + "pinmux dev [pincontroller-name] - select pin-controller device\n" + "pinmux status [-a] - print pin-controller muxing [for all]\n" +)
Changes in v3:
Changes in v2:
Add get_pins_count ops to obtain the number of pins owns by a pin-controller. On STM32 SoCs bindings, each pin-controller owns several gpio banks. Each GPIO bank can own up to 16 pins.
To obtain the total pins count, walk through each sub-nodes (ie GPIO banks) and sum each GPIO banks pins number. For that in probe() we build a list with each GPIO device reference found. This list will also be used with future get_pin_muxing and get_pin_name ops to speed up and optimize walk through all GPIO banks.
As this code is common to all STM32 SoCs, this code is put under SPL_BUILD compilation flag to avoid to increase SPL code size for STM32F7 which is limited to 32Ko.
drivers/pinctrl/pinctrl_stm32.c | 94 ++++++++++++++++++++++++++++++++++++++--- 1 file changed, 89 insertions(+), 5 deletions(-)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index 31285cdd5784..82ac261dafea 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -14,6 +14,83 @@ DECLARE_GLOBAL_DATA_PTR; #define OTYPE_MSK 1 #define AFR_MASK 0xF
+#ifndef CONFIG_SPL_BUILD +struct stm32_pinctrl_priv { + int pinctrl_ngpios; + struct list_head gpio_dev; +}; + +struct stm32_gpio_bank { + struct udevice *gpio_dev; + struct list_head list; +}; + +static int stm32_pinctrl_get_pins_count(struct udevice *dev) +{ + struct stm32_pinctrl_priv *priv = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv; + struct stm32_gpio_bank *gpio_bank; + + /* + * if get_pins_count has already been executed once on this + * pin-controller, no need to run it again + */ + if (priv->pinctrl_ngpios) + return priv->pinctrl_ngpios; + + /* + * walk through all banks to retrieve the pin-controller + * pins number + */ + list_for_each_entry(gpio_bank, &priv->gpio_dev, list) { + uc_priv = dev_get_uclass_priv(gpio_bank->gpio_dev); + + priv->pinctrl_ngpios += uc_priv->gpio_count; + } + + return priv->pinctrl_ngpios; +} + +int stm32_pinctrl_probe(struct udevice *dev) +{ + struct stm32_pinctrl_priv *priv = dev_get_priv(dev); + struct udevice *gpio_dev; + struct udevice *child; + struct stm32_gpio_bank *gpio_bank; + int ret; + + INIT_LIST_HEAD(&priv->gpio_dev); + + /* + * parse pin-controller sub-nodes (ie gpio bank nodes) and fill + * a list with all gpio device reference which belongs to the + * current pin-controller. This list is used to find pin_name and + * pin muxing + */ + list_for_each_entry(child, &dev->child_head, sibling_node) { + ret = uclass_get_device_by_name(UCLASS_GPIO, child->name, + &gpio_dev); + + if (ret < 0 && ret != -ENODEV) { + dev_err(dev, "Failed to find %s device ret = %d\n", + child->name, ret); + return ret; + } + + gpio_bank = malloc(sizeof(*gpio_bank)); + if (!gpio_bank) { + dev_err(dev, "Not enough memory\n"); + return -ENOMEM; + } + + gpio_bank->gpio_dev = gpio_dev; + list_add_tail(&gpio_bank->list, &priv->gpio_dev); + } + + return 0; +} +#endif + static int stm32_gpio_config(struct gpio_desc *desc, const struct stm32_gpio_ctl *ctl) { @@ -182,6 +259,9 @@ static struct pinctrl_ops stm32_pinctrl_ops = { #else /* PINCTRL_FULL */ .set_state_simple = stm32_pinctrl_set_state_simple, #endif /* PINCTRL_FULL */ +#ifndef CONFIG_SPL_BUILD + .get_pins_count = stm32_pinctrl_get_pins_count, +#endif };
static const struct udevice_id stm32_pinctrl_ids[] = { @@ -195,9 +275,13 @@ static const struct udevice_id stm32_pinctrl_ids[] = { };
U_BOOT_DRIVER(pinctrl_stm32) = { - .name = "pinctrl_stm32", - .id = UCLASS_PINCTRL, - .of_match = stm32_pinctrl_ids, - .ops = &stm32_pinctrl_ops, - .bind = dm_scan_fdt_dev, + .name = "pinctrl_stm32", + .id = UCLASS_PINCTRL, + .of_match = stm32_pinctrl_ids, + .ops = &stm32_pinctrl_ops, + .bind = dm_scan_fdt_dev, +#ifndef CONFIG_SPL_BUILD + .probe = stm32_pinctrl_probe, + .priv_auto_alloc_size = sizeof(struct stm32_pinctrl_priv), +#endif };
Add get_pin_name ops to obtain a pin name given a pin index of a specified pin-controller.
drivers/pinctrl/pinctrl_stm32.c | 47 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index 82ac261dafea..e0bee4b97bd5 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -25,6 +25,10 @@ struct stm32_gpio_bank { struct list_head list; };
+#define MAX_PIN_PER_BANK 16 + +#define MAX_PIN_NAME_LEN 12 +static char pin_name[MAX_PIN_NAME_LEN]; static int stm32_pinctrl_get_pins_count(struct udevice *dev) { struct stm32_pinctrl_priv *priv = dev_get_priv(dev); @@ -51,6 +55,48 @@ static int stm32_pinctrl_get_pins_count(struct udevice *dev) return priv->pinctrl_ngpios; }
+static struct udevice *stm32_pinctrl_get_gpio_dev(struct udevice *dev, + unsigned int selector) +{ + struct stm32_pinctrl_priv *priv = dev_get_priv(dev); + struct stm32_gpio_bank *gpio_bank; + struct gpio_dev_priv *uc_priv; + int first_pin = 0; + + /* look up for the bank which owns the requested pin */ + list_for_each_entry(gpio_bank, &priv->gpio_dev, list) { + uc_priv = dev_get_uclass_priv(gpio_bank->gpio_dev); + + if (selector < (first_pin + uc_priv->gpio_count)) + /* we found the bank */ + return gpio_bank->gpio_dev; + + first_pin += uc_priv->gpio_count; + } + + return NULL; +} + +static const char *stm32_pinctrl_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + struct gpio_dev_priv *uc_priv; + struct udevice *gpio_dev; + + /* look up for the bank which owns the requested pin */ + gpio_dev = stm32_pinctrl_get_gpio_dev(dev, selector); + if (!gpio_dev) { + snprintf(pin_name, MAX_PIN_NAME_LEN, "Error"); + } else { + uc_priv = dev_get_uclass_priv(gpio_dev); + + snprintf(pin_name, MAX_PIN_NAME_LEN, "%s%d", + uc_priv->bank_name, + selector % MAX_PIN_PER_BANK); + } + + return pin_name; +} int stm32_pinctrl_probe(struct udevice *dev) { struct stm32_pinctrl_priv *priv = dev_get_priv(dev); @@ -260,6 +306,7 @@ static struct pinctrl_ops stm32_pinctrl_ops = { .set_state_simple = stm32_pinctrl_set_state_simple, #endif /* PINCTRL_FULL */ #ifndef CONFIG_SPL_BUILD + .get_pin_name = stm32_pinctrl_get_pin_name, .get_pins_count = stm32_pinctrl_get_pins_count, #endif };
Add get_pin_muxing() ops to obtain the pin muxing description a given pin index.
drivers/pinctrl/pinctrl_stm32.c | 77 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 77 insertions(+)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index e0bee4b97bd5..588efda8df4b 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -27,8 +27,34 @@ struct stm32_gpio_bank {
+#define MAX_PIN_MUX_LEN 40 +static char pin_mux[MAX_PIN_MUX_LEN]; + #define MAX_PIN_NAME_LEN 12 static char pin_name[MAX_PIN_NAME_LEN]; +#define PINMUX_MODE_COUNT 5 +static const char * const pinmux_mode[PINMUX_MODE_COUNT] = { + "gpio input", + "gpio output", + "analog", + "unknown", + "alt function", +}; + +static int stm32_pinctrl_get_af(struct udevice *dev, unsigned int offset) +{ + struct stm32_gpio_priv *priv = dev_get_priv(dev); + struct stm32_gpio_regs *regs = priv->regs; + u32 af; + u32 alt_shift = (offset % 8) * 4; + u32 alt_index = offset / 8; + + af = (readl(®s->afr[alt_index]) & + GENMASK(alt_shift + 3, alt_shift)) >> alt_shift; + + return af; +} + static int stm32_pinctrl_get_pins_count(struct udevice *dev) { struct stm32_pinctrl_priv *priv = dev_get_priv(dev); @@ -97,6 +123,56 @@ static const char *stm32_pinctrl_get_pin_name(struct udevice *dev,
return pin_name; } + +static const char *stm32_pinctrl_get_pin_muxing(struct udevice *dev, + unsigned int selector) +{ + struct udevice *gpio_dev; + const char *label; + int gpio_pin; + int mode; + int af_num; + + /* look up for the bank which owns the requested pin */ + gpio_dev = stm32_pinctrl_get_gpio_dev(dev, selector); + + if (!gpio_dev) { + snprintf(pin_mux, MAX_PIN_MUX_LEN, "Error"); + return pin_mux; + } + + /* translate pin-controller pin number to gpio pin number */ + gpio_pin = selector % MAX_PIN_PER_BANK; + + mode = gpio_get_raw_function(gpio_dev, gpio_pin, &label); + + dev_dbg(dev, "selector = %d gpio_pin = %d mode = %d\n", + selector, gpio_pin, mode); + + switch (mode) { + case GPIOF_UNKNOWN: + /* should never happen */ + snprintf(pin_mux, MAX_PIN_MUX_LEN, "Error !!"); + break; + case GPIOF_UNUSED: + snprintf(pin_mux, MAX_PIN_MUX_LEN, "%s", + pinmux_mode[mode]); + break; + case GPIOF_FUNC: + af_num = stm32_pinctrl_get_af(gpio_dev, gpio_pin); + snprintf(pin_mux, MAX_PIN_MUX_LEN, "%s %d", + pinmux_mode[mode], af_num); + break; + case GPIOF_OUTPUT: + case GPIOF_INPUT: + snprintf(pin_mux, MAX_PIN_MUX_LEN, "%s %s", + pinmux_mode[mode], label ? label : ""); + break; + } + + return pin_mux; +} + int stm32_pinctrl_probe(struct udevice *dev) { struct stm32_pinctrl_priv *priv = dev_get_priv(dev); @@ -308,6 +384,7 @@ static struct pinctrl_ops stm32_pinctrl_ops = { #ifndef CONFIG_SPL_BUILD .get_pin_name = stm32_pinctrl_get_pin_name, .get_pins_count = stm32_pinctrl_get_pins_count, + .get_pin_muxing = stm32_pinctrl_get_pin_muxing, #endif };
Hi Patrice,
"gpio input",
"gpio output",
"analog",
"unknown",
"alt function",
u32 af;
return af;
return pin_name;
Again I think this should be passed a buffer to write into.
Hi Simon
On 10/19/18 5:25 AM, Simon Glass wrote:
Hi Patrice,
"gpio input",
"gpio output",
"analog",
"unknown",
"alt function",
u32 af;
return af;
return pin_name;
Ok
Thanks
Patrice
This patch adds gpio get_function ops support. This function reports the state of a gpio.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/gpio/stm32f7_gpio.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/gpio/stm32f7_gpio.c b/drivers/gpio/stm32f7_gpio.c index 4c0786fff88d..82c8b8d23ae6 100644 --- a/drivers/gpio/stm32f7_gpio.c +++ b/drivers/gpio/stm32f7_gpio.c @@ -65,11 +65,31 @@ static int stm32_gpio_set_value(struct udevice *dev, unsigned offset, int value) return 0; }
+static int stm32_gpio_get_function(struct udevice *dev, unsigned int offset) +{ + struct stm32_gpio_priv *priv = dev_get_priv(dev); + struct stm32_gpio_regs *regs = priv->regs; + int bits_index = MODE_BITS(offset); + int mask = MODE_BITS_MASK << bits_index; + u32 mode; + + mode = (readl(®s->moder) & mask) >> bits_index; + if (mode == STM32_GPIO_MODE_OUT) + return GPIOF_OUTPUT; + if (mode == STM32_GPIO_MODE_IN) + return GPIOF_INPUT; + if (mode == STM32_GPIO_MODE_AN) + return GPIOF_UNUSED; + + return GPIOF_FUNC; +} + static const struct dm_gpio_ops gpio_stm32_ops = { .direction_input = stm32_gpio_direction_input, .direction_output = stm32_gpio_direction_output, .get_value = stm32_gpio_get_value, .set_value = stm32_gpio_set_value, + .get_function = stm32_gpio_get_function, };
static int gpio_stm32_probe(struct udevice *dev)
Add get_pin_mux ops support to display the pin muxing description of the sandbox_pins[]
Changes in v3: - Fix typo
Changes in v2: None
drivers/pinctrl/pinctrl-sandbox.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/pinctrl/pinctrl-sandbox.c b/drivers/pinctrl/pinctrl-sandbox.c index 755ac08bdf72..c09e0f2d0e37 100644 --- a/drivers/pinctrl/pinctrl-sandbox.c +++ b/drivers/pinctrl/pinctrl-sandbox.c @@ -17,6 +17,14 @@ static const char * const sandbox_pins[] = { "W1" };
+static const char * const sandbox_pins_muxing[] = { + "I2C SCL", + "I2C SDA", + "Uart TX", + "Uart RX", + "1-wire gpio", +}; + static const char * const sandbox_groups[] = { "i2c", "serial_a", @@ -56,6 +64,12 @@ static const char *sandbox_get_pin_name(struct udevice *dev, unsigned selector) return sandbox_pins[selector]; }
+static const char *sandbox_get_pin_muxing(struct udevice *dev, + unsigned int selector) +{ + return sandbox_pins_muxing[selector]; +} + static int sandbox_get_groups_count(struct udevice *dev) { return ARRAY_SIZE(sandbox_groups); @@ -123,6 +137,7 @@ static int sandbox_pinconf_group_set(struct udevice *dev, const struct pinctrl_ops sandbox_pinctrl_ops = { .get_pins_count = sandbox_get_pins_count, .get_pin_name = sandbox_get_pin_name, + .get_pin_muxing = sandbox_get_pin_muxing, .get_groups_count = sandbox_get_groups_count, .get_group_name = sandbox_get_group_name, .get_functions_count = sandbox_get_functions_count,
Changes in v3:
- Fix typo
Changes in v2: None
"I2C SCL",
"I2C SDA",
"Uart TX",
"Uart RX",
"1-wire gpio",
-- 1.9.1
I suggest adding a test that executes this command on sandbox.
Hi Simon
Changes in v3:
- Fix typo
Changes in v2: None
"I2C SCL",
"I2C SDA",
"Uart TX",
"Uart RX",
"1-wire gpio",
-- 1.9.1
Ok i will add a test for that.
Thanks
Patrice
Bin Meng
Patrice CHOTARD
Patrice Chotard
